Merci pour la réponse, le soucis n’apparaît pas quand mon PC est branché sur secteur, uniquement quand je suis sur batterie.
Après exécution de la commande [mono]modinfo ath9k[/mono], je ne vois rien qui correspond à des options d’énergie. Ci-dessous le résultat de la commande, n’hésites pas à me dire si il y a quelque qui te parles :
filename: /lib/modules/3.11-0.bpo.2-amd64/kernel/drivers/net/wireless/ath/ath9k/ath9k.ko
license: Dual BSD/GPL
description: Support for Atheros 802.11n wireless LAN cards.
author: Atheros Communications
alias: pci:v0000168Cd00000036sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000037sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000034sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000034sv000010CFsd00001783bc*sc*i*
alias: pci:v0000168Cd00000034sv000014CDsd00000064bc*sc*i*
alias: pci:v0000168Cd00000034sv000014CDsd00000063bc*sc*i*
alias: pci:v0000168Cd00000034sv0000103Csd00001864bc*sc*i*
alias: pci:v0000168Cd00000034sv000011ADsd00006641bc*sc*i*
alias: pci:v0000168Cd00000034sv000011ADsd00006631bc*sc*i*
alias: pci:v0000168Cd00000034sv00001043sd0000850Ebc*sc*i*
alias: pci:v0000168Cd00000034sv00001A3Bsd00002110bc*sc*i*
alias: pci:v0000168Cd00000034sv00001969sd00000091bc*sc*i*
alias: pci:v0000168Cd00000034sv000017AAsd00003214bc*sc*i*
alias: pci:v0000168Cd00000034sv0000168Csd00003117bc*sc*i*
alias: pci:v0000168Cd00000034sv000011ADsd00006661bc*sc*i*
alias: pci:v0000168Cd00000034sv00001A3Bsd00002116bc*sc*i*
alias: pci:v0000168Cd00000033sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000032sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000032sv0000105Bsd0000E075bc*sc*i*
alias: pci:v0000168Cd00000032sv00001A3Bsd00002152bc*sc*i*
alias: pci:v0000168Cd00000032sv00001A3Bsd00002126bc*sc*i*
alias: pci:v0000168Cd00000032sv00001A3Bsd00001237bc*sc*i*
alias: pci:v0000168Cd00000032sv00001A3Bsd00002086bc*sc*i*
alias: pci:v0000168Cd00000030sv*sd*bc*sc*i*
alias: pci:v0000168Cd0000002Esv*sd*bc*sc*i*
alias: pci:v0000168Cd0000002Dsv*sd*bc*sc*i*
alias: pci:v0000168Cd0000002Csv*sd*bc*sc*i*
alias: pci:v0000168Cd0000002Bsv*sd*bc*sc*i*
alias: pci:v0000168Cd0000002Asv*sd*bc*sc*i*
alias: pci:v0000168Cd00000029sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000027sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000024sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000023sv*sd*bc*sc*i*
depends: ath9k_hw,ath9k_common,mac80211,ath,cfg80211
intree: Y
vermagic: 3.11-0.bpo.2-amd64 SMP mod_unload modversions
parm: debug:Debugging mask (uint)
parm: nohwcrypt:Disable hardware encryption (int)
parm: blink:Enable LED blink on activity (int)
parm: btcoex_enable:Enable wifi-BT coexistence (int)
parm: enable_diversity:Enable Antenna diversity for AR9565 (int)
