Voici ce que wine affiche pour Freelancer:
fixme:thread:SetThreadIdealProcessor (0xfffffffe): stub
err:ddraw:DllMain Unknown default surface type. Supported are:
gdi, opengl
err:module:load_builtin_dll failed to load .so lib for builtin L"winemp3.acm": libmpg123.so.0: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
err:d3d_caps:WineD3D_CreateFakeGLContext Can't find a suitable iPixelFormat.
err:d3d:InitAdapters Failed to get a gl context for default adapter
err:d3d:WineDirect3DCreate Direct3D8 is not available without opengl
fixme:msg:pack_message msg 14 (WM_ERASEBKGND) not supported yet
fixme:dsound:DllCanUnloadNow (void): stub
Pour guild wars
err:d3d:WineDirect3DCreate Direct3D9 is not available without opengl
fixme:win:EnumDisplayDevicesW ((null),0,0x32e67c,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),1,0x32e67c,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),0,0x32e48c,0x00000000), stub!
wine: Call from 0x7ef823d2 to unimplemented function GDI32.dll.GdiEntry1, aborting
fixme:win:EnumDisplayDevicesW ((null),0,0x32e6bc,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),1,0x32e6bc,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),0,0x15ddd10,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),1,0x15ddd10,0x00000000), stub!
Morrowind
Pour les 3 on a les même erreurs.
Merci pour ton aide.
