Package: x-window-system-core
Priority: optional
Section: x11
Installed-Size: 240
Maintainer: Debian X Strike Force <debian-x@lists.debian.org>
Architecture: i386
Source: xfree86
Version: 4.3.0.dfsg.1-14
Depends: xserver-xfree86, xlibmesa-dri, xlibmesa-gl, xlibmesa-glu, xfonts-base (>> 4.0), xfonts-100dpi, xfonts-75dpi, xfonts-scalable, xbase-clients, xutils
Filename: pool/main/x/xfree86/x-window-system-core_4.3.0.dfsg.1-14_i386.deb
MD5sum: a0069d439dbd5f280c79d2e0a8f1545c
Description: X Window System core components
This metapackage provides the essential components for a standalone
workstation running the X Window System. It provides the X libraries, an X
server (except on the S/390 architecture), a set of fonts, and a group of
basic X clients and utilities.
Higher level metapackages, such as those for desktop environments, can
depend on this package and simplify their dependencies.
It should be noted that a package providing x-window-manager and a package
providing x-terminal-emulator should also be installed to ensure a
comfortable X experience.
Priority: optional
Section: x11
Installed-Size: 240
Architecture: all
Source: xfree86
Depends: x-window-system-core, lbxproxy, proxymngr, twm, xdm, xfs, xfwp, xnest, xprt-xprintorg, xterm, xvfb
Filename: pool/main/x/xfree86/x-window-system_4.3.0.dfsg.1-14_all.deb
MD5sum: 77d8760d1e61d1f21d6481ba239318c5
This metapackage provides substantially all the components of the X Window
System as developed by the XFree86 Project, as well as a set of historically
popular accessory programs.
Development and debugging versions of the X protocol client libraries and
other libraries provided with XFree86 are not provided by this metapackage.
Note that Xprint.org's implementation of an XPRINT server is depended upon
by this package until XFree86's XPRINT server is operational.
