Voila, jvous expose mon problême car j’ai réussi avec succes a installer les fichier proprio de ATI… Fin bref, et puis je me suis dis pourquoi pas beryl avec etch
Donc j’utilise les driver libre et la… c’est le drame ( j’ai essayé mil et un tuto, AUCUN ne marche ):
Voici le message d’erreur renvoyé :
[quote]xauth: creating new authority file /home/rice/.serverauth.10042
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux jovamine-port 2.6.18-5-686 #1 SMP Wed Sep 26 17:54:59 UTC 2007 i686
Build Date: 04 September 2007
Before reporting problems, check wiki.x.org
Module Loader present
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Sat Sep 29 01:21:22 2007
(==) Using config file: “/etc/X11/xorg.conf”
(EE) No devices detected.
Fatal server error:
no screens found
XIO: fatal IO error 104 (Connection reset by peer) on X server “:0.0”
after 0 requests (0 known processed) with 0 events remaining.
ET en utilisant fglrx dans xorg.conf
Mon xorg actuel( driver charger > fglrx ):
[quote]Section "ServerLayout"
Identifier "Default Layout"
Screen 0 “aticonfig-Screen[0]” 0 0
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section “Files”
# path to defoma fonts
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Monitor"
Identifier "Écran générique"
HorizSync 28.0 - 64.0
VertRefresh 43.0 - 60.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]"
Option “VendorName” "ATI Proprietary Driver"
Option “ModelName” "Generic Autodetecting Monitor"
Option “DPMS” "true"
EndSection
Section "Device"
Identifier "Carte vidéo générique"
Driver "vesa"
BusID "PCI:1:0:0"
Option “MonitorLayout” "LVDS, TMDS"
Option “EnablePageFlip” "on"
Option “XAANoOffscreenPixmaps” "true"
Option “AddARGBGLXVisuals” "True"
Option “AllowGLXWithComposite” "True"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]"
Driver "fglrx"
Option “AllowGLXWithComposite” “True”
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Carte vidéo générique"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x800"
EndSubSection
Depth 4
Modes "1280x800"
EndSubSection
Depth 8
Modes "1280x800"
EndSubSection
Depth 15
Modes "1280x800"
EndSubSection
Depth 16
Modes "1280x800"
EndSubSection
Depth 24
Modes "1280x800"
EndSubSection
EndSection
Section "Extensions"
Option “Composite” "enable"
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]"
Device "aticonfig-Device[0]"
Monitor "aticonfig-Monitor[0]"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
