Salut!
Ca fais 2 semaines que je suis dessus et tjs des pb.
J’ai commencé a installé xdtv avec un CG ATI
tout buggait, donc j’ai ressorti la TNT2 de Nvidia, installé les drivers proprio. (ac le joli logo NVIDIA)
Jusque la ca va.
J’ainstall xdtv depuis le déport debian multimédia.
Si je lance xdtv, ca plante le serveur X.
Donc je fais ceci:
[quote]srvdebian:~# xdtv -noxv
This is xdtv 2.4.0 running on Linux/x86_64 (2.6.18-5-amd64).
scandir: Aucun fichier ou répertoire de ce type
filename = /root/.xdtv/xdtvrc
Xv support disabled.
Warning: Missing charsets in String to FontSet conversion
wmhooks: netwm detected
wmhooks: netwm state above supported
wmhooks: netwm fullscreen supported
wmhooks: nothing found…
DGA: server=2.0, include=2.0
VidMode: server=2.2, include=2.2
available video mode(s): 1024x768 800x600 640x480 800x600 640x384 512x384 400x 300 400x300 320x240
Warning: Cannot convert string “none” to type relief
*** GRABBER DEVICE TYPE = v4l2
MMX, SSE, AMD MMX extensions, SSE2, have been detected.
Method sse
*** AUDIO DEVICE TYPE = alsa
*** MIXER DEVICE TYPE = alsa
ioctl VIDIOC_STREAMON: Périphérique ou ressource occupé
ioctl VIDIOC_S_FMT: Périphérique ou ressource occupé
et écran noir et j’ai essayé pas mal d’option avec xdtv sans succès.
Si qq1 à le début d’une piste.
Mon Xorg:
[code]# /etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "bitmap"
Load "ddc"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "v4l"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Device"
Identifier "nv"
Driver "nvidia"
BusID "PCI:6:1:0"
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
HorizSync 28-50
VertRefresh 43-75
EndSection
Section "Screen"
Identifier "Default Screen"
Device "nv"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Le p’tit lspci:
[quote]06:01.0 VGA compatible controller: nVidia Corporation NV5M64 [RIVA TNT2 Model 64/Model 64 Pro] (rev 15)
06:02.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)06:02.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
09:0d.0 Multimedia audio controller: C-Media Electronics Inc CM8738 (rev 10)
srvdebian:~#
Mon xdtvrc:
[code]#
Global options
norm = SECAM
capture = grab
source = Television
subpage = 888
freqtab = secam-france
You should uncomment this line
and modify it by your own specific channel:
mixer_tvchan = xxxxxx
restoresnd = off
respectnullsnd = off
vop_autograb = on
xawpopup = on
message_timer = 3000
decoration = on
stayontop = off
subtitles = off
theme = (null)
Fullscreen options
fullscreen = 640 x 480
fullscreen_mode = 3
pixsize = 128 x 96
windowsize = 384 x 288
colorkey = 123456
capture_size = 768 x 576
Grab options
grab_filepath = /root
jpeg_compression = 75
XOSD options
xosd = on
xosd_main_color = white
xosd_outline_color = black
xosd_main_font = --ledfixed------------*
xosd_vtx_font = --ledfixed------------*
record options
container = AVI
codec = XviD
width = 384
height = 288
bitrate = 900
quality = 1
stereo_mode = no
audio_codec = LAME MP3
mp3_bitrate = 128
mp3_quality = 5
mp3_vbr_mode = no
mp3_vbr_quality = 8
fps = 25000
max_gap = 80
audio_fragments = 48
audio_sizefragment = 2048
min_quantizer = 2
max_quantizer = 8
audio_buffer_size = 1764
audio_freq = 44100
audio_fmt = s16le
divx_path = /root
display_frame = yes
record_sub = no
record_chg = no
record_delay = 0
streaming_mode = yes
streaming_http_port = 61000
preview_player = mplayer -nofs -quiet -nosound
record advanced options
ffmpeg_v4mv = no
ffmpeg_naq = no
ffmpeg_gray = no
ffmpeg_gmc = no
ffmpeg_qpel = no
ffmpeg_ildct = no
ffmpeg_keyint = 250
ffmpeg_vmax_b_frames = 0
ffmpeg_vlelim = 0
ffmpeg_vcelim = 0
ffmpeg_lumi_mask = 0
ffmpeg_dark_mask = 0
ffmpeg_tcplx_mask = 0
ffmpeg_scplx_mask = 0
ffmpeg_dia = 0
ffmpeg_cmp = 0
ffmpeg_subcmp = 0
ffmpeg_trell = no
ffmpeg_last_pred = 0
ffmpeg_predia = 0
ffmpeg_precmp = 0
ffmpeg_umv = no
ffmpeg_aic = no
ffmpeg_mbd = 0
ffmpeg_cbp = no
ffmpeg_obmc = no
ffmpeg_ss = no
ffmpeg_aiv = no
ffmpeg_loop = no
ffmpeg_ilme = no
xvid_vhq = 0
xvid_bvhq = no
xvid_chromame = no
xvid_chroma_opt = no
xvid_hqacpred = no
xvid_trell = no
xvid_cartoon = no
xvid_gray = no
xvid_interlacing = no
xvid_turbo = yes
xvid_qpel = no
xvid_gmc = no
xvid_keyint = 250
xvid_frame_drop_ratio = 0
xvid_vmax_b_frames = 0
xvid_bquant_ratio = 150
xvid_bquant_offset = 100
xvid_packed = yes
xvid_closed_gop = yes
xvid_bframe_threshold = 0
xvid_reaction_delay_factor = 16
xvid_averaging_period = 100
xvid_buffer = 100
xvid_max_I_quantizer = 12
xvid_min_I_quantizer = 2
xvid_max_P_quantizer = 12
xvid_min_P_quantizer = 2
xvid_max_B_quantizer = 12
xvid_min_B_quantizer = 2
eventmap
alevt options
alevt_defaultpage = 100
alevt_finetune_mode = none
alevt_finetune = 1
alevt_error_reduction = yes
alevt_error_bell = yes
alevt_vbioffset = yes
alevt_charset = latin-1
For each channel define at least following information
[Channel Name]
channel = Channel Number
norm = PAL|NTSC|SECAM|AUTO
key = key to press to switch the channel on (KP_End, KP_Next,…)
capture = off|grabdisplay|overlay
Voila, merci a vous
