[quote=“linuxcdracer”]mais je veux supprimer xfce avec la commande apt-get remove --purge xfce .[/quote]Il n’existe pas de paquet ayant ce nom “xfce” en testing.
Par contre, des paquets avec xfce dedans, il y en a pas mal :
$ apt-cache search -n xfce
gtk2-engines-xfce - A GTK+-2.0 theme engine for Xfce
libxfce4mcs-client3 - Client library for Xfce4 configure interface
libxfce4mcs-dev - Development files for libxfce4mcs-client and -manager
libxfce4mcs-manager3 - Manager library for Xfce4 configure interface
libxfce4util-dev - Development files for libxfce4util4
libxfce4util4 - Utility functions library for Xfce4
libxfcegui4-4 - Basic GUI C functions for Xfce4
libxfcegui4-dev - Development files for libxfcegui4-3
xfce4-appfinder - Application finder for the Xfce4 Desktop Environment
xfce4-artwork - additional artwork for the Xfce4 Desktop Environment
xfce4-clipman-plugin - clipboard history plugin for the Xfce4 panel
xfce4-cpufreq-plugin - cpufreq information plugin for the Xfce4 panel
xfce4-cpugraph-plugin - CPU load graph plugin for the Xfce4 panel
xfce4-dev-tools - Script to help building Xfce from svn
xfce4-diskperf-plugin - disk performance display plugin for the Xfce4 panel
xfce4-fsguard-plugin - filesystem monitor plugin for the Xfce4 panel
xfce4-icon-theme - Xfce Standard icon theme
xfce4-mailwatch-plugin - mail watcher plugin for the Xfce4 panel
xfce4-mcs-manager - Settings manager for Xfce4
xfce4-mcs-manager-dev - Development files and static plugins
xfce4-mcs-plugins - Special modules for the xfce4-mcs-manager
xfce4-messenger-plugin - Dbus messages plugin for xfce4-panel
xfce4-minicmd-plugin - Mini-command line plugin for the Xfce4 panel
xfce4-mixer - Xfce4 Mixer frontend
xfce4-mixer-alsa - Xfce4 Mixer ALSA backend
xfce4-mixer-oss - Xfce4 Mixer OSS backend
xfce4-netload-plugin - network load monitor plugin for the Xfce4 panel
xfce4-notes-plugin - Notes plugin for the Xfce4 desktop
xfce4-panel - The Xfce4 desktop environment panel
xfce4-panel-dev - The Xfce4 panel development files
xfce4-screenshooter-plugin - Screenshots plugin for Xfce panel
xfce4-smartbookmark-plugin - search the web via the Xfce4 panel
xfce4-systemload-plugin - system load monitor plugin for the Xfce4 panel
xfce4-taskmanager - process manager for the Xfce4 Desktop Environment
xfce4-utils - Various tools for Xfce
xfce4-verve-plugin - Verve (command line) plugin for Xfce 4.4 panel
xfce4-wavelan-plugin - wavelan status plugin for the Xfce4 panel
xfce4-weather-plugin - weather information plugin for the Xfce4 panel
xfce4-xfapplet-plugin - Gnome applets plugin for Xfce panel
libxfce4mcs-client-1 - Client library for Xfce4 configure interface
libxfce4mcs-manager-1 - Manager library for Xfce4 configure interface
libxfce4util-1 - Utility functions library for Xfce4
libxfcegui4-1 - Basic GUI C functions for Xfce4
xfce4-iconbox - Iconbox for the Xfce4 Desktop Environment
xfce4-showdesktop-plugin - show desktop button for the Xfce4 panel
xfce4-systray - Systray panel plugin for XFce4 panel
xfce4-themes - Theme files for Xfce4
xfce4-toys - Eyes plugin for XFce4 panel and xfce4-tips
xfce4-trigger-launcher - Panel plugin to start/stop programs
xfce4 - Meta-package for the Xfce Lightweight Desktop Environment
xfce4-battery-plugin - battery monitor plugin for the Xfce4 panel
xfce4-datetime-plugin - date and time plugin for the Xfce4 panel
xfce4-dict-plugin - Dictionary plugin for Xfce4 panel
xfce4-genmon-plugin - Generic Monitor for the Xfce4 panel
xfce4-goodies - enhancements for the Xfce4 Desktop Environment
xfce4-mount-plugin - mount plugin for the Xfce4 panel
xfce4-mpc-plugin - Xfce panel plugin which serves as client for MPD music player
xfce4-quicklauncher-plugin - rapid launcher plugin for the Xfce4 panel
xfce4-radio-plugin - v4l radio control plugin for the Xfce4 panel
xfce4-sensors-plugin - hardware sensors plugin for the Xfce4 panel
xfce4-session - Xfce4 Session Manager
xfce4-terminal - Xfce terminal emulator
xfce4-xmms-plugin - xmms control plugin for the Xfce4 panel
Il te faudra virer ceux qui sont installés. Si tu l’as installé avec le méta-paquet xfce4, tu peux connaître les dépendances avec :
[code]$ apt-cache show xfce4
Package: xfce4
Priority: optional
Section: x11
Installed-Size: 24
Maintainer: Debian Xfce Maintainers pkg-xfce-devel@lists.alioth.debian.org
Architecture: all
Version: 4.3.99.2
Replaces: xfce4-themes (<= 4.0.0+cvs.20030301-1), xfce4-dev (<< 4.0.0+cvs.20030421)
Depends: xfwm4 (>= 4.3.99.2), xfwm4-themes (>= 4.3.99.2), xfce4-mcs-plugins (>= 4.3.99.2), xfce4-panel (>= 4.3.99.2), xfce4-icon-theme (>= 4.3.99.2), xfdesktop4 (>= 4.3.99.1), thunar (>= 0.4.0rc1), xfce4-utils (>= 4.3.99.2), gtk2-engines-xfce (>= 2.3.99.2), xfce4-session (>= 4.3.99.1)
Recommends: xfce4-mixer, xfprint4, orage, xfce4-terminal, xfmedia, desktop-base
Suggests: x-window-system-core
Filename: pool/main/x/xfce4/xfce4_4.3.99.2_all.deb
MD5sum: b9fc508f19439292f5c85d50a08310c3
SHA1: 0e5529196c12e78495ab6c4765547fc648bda033
SHA256: 738f33472273489565c3ed8cf06376b0c8443f688c2439b5e02f0bf9286fafa8
Description: Meta-package for the Xfce Lightweight Desktop Environment
Xfce is a lightweight desktop environment for unix-like operating systems.
It aims to be fast and lightweight, while still being visually appealing and
easy to use. Designed for productivity, it loads and executes applications
fast, while conserving system resources.
This package is a meta-package; it depends on the core packages of the
Xfce4 desktop environment and recommends some extra Xfce4 packages. If you
intend to use Xfce4 and want the full experience then installing this
package and the packages it Recommends is a great place to start.
If you just want to pick and choose the core components then feel free to
remove this package.
Homepage: http://www.xfce.org/
Tag: admin::configuring, role::program, scope::utility, suite::xfce, uitoolkit::gtk, use::configuring, x11::application
Task: xfce-desktop
Package: xfce4
Priority: optional
Section: x11
Installed-Size: 48
Architecture: all
Version: 4.3.99.1
Depends: xfwm4 (>= 4.3.99.1-1), xfwm4-themes (>= 4.3.99.1-1), xfce4-mcs-plugins (>= 4.3.99.1-1), xfce4-panel (>= 4.3.99.1-1), xfce4-icon-theme (>= 4.3.99.1-1), xfdesktop4 (>= 4.3.99.1-1), thunar, xfce4-utils (>= 4.3.99.1-1), gtk2-engines-xfce, xfce4-session (>= 4.3.99.1-1)
Filename: pool/main/x/xfce4/xfce4_4.3.99.1_all.deb
MD5sum: 297e5eb4a3e9520b5affb55f4fd28482
SHA1: f4eb81b5237d75f8c601618563918d9a14fc34e0
SHA256: ae76b5d52b840439d3d46c9be4ac7c4a0438ca4ef26cdb8bbeb1bc39187447e3
Description: meta-package for xfce4 dependencies
Task: xfce-desktop
Package: xfce4
Priority: optional
Section: x11
Installed-Size: 17
Maintainer: Martin Loschwitz madkiss@debian.org
Architecture: all
Version: 4.0.5-1
Depends: xfwm4, xfwm4-themes, xfce4-mcs-plugins, xfce4-panel, xfce4-themes, xfdesktop4, xffm4, xffm4-icons, xfce4-utils (>= 4.0.5-2), gtk2-engines-xfce, xfce4-session
Recommends: xfce4-iconbox, xfce4-mixer, xfce4-systray, xfce4-toys, xfce4-trigger-launcher, xfprint4, xfcalendar
Filename: pool/main/x/xfce4/xfce4_4.0.5-1_all.deb
MD5sum: f314006d8b1a1fc19aedbacd030f03e8
SHA1: 721a5b4ff9ded54107c742507c23f3a3f2a5d24b
SHA256: 8f042c4d3950848dcdcf20d1e8e279799d808a1af8aa6c6656b86a410689ce0b
Description: Installs XFce4 core and scripts to set it up
This package is a pseudo meta package: It basically installs the
core modules of the XFce4 desktop environment and some scripts to
get it work (for example a launch script for GDM and a script
that does the necessary things to create a local XFce4 setup in
a user’s $HOME-dir). If you intend to XFce4, installing this
package is a good point to start with and highly recommended.[/code]
