J’aimerais installer electricsheep sur ma xfce.
J’ai suivi ce post:
webupd8.org/2011/11/how-to-g … -with.html
je vois bien electricsheep dans mes screensavers.
Mais lorsque je le lance, j’obtiens ceci:
[NULL @ 0x1de2820] Value 4707126720094797824.000000 for parameter 'probesize' out of range
[NULL @ 0x1de2820] Value 4707126720094797824.000000 for parameter 'analyzeduration' out of range
[NULL @ 0x1de2820] Value 4697254411347427328.000000 for parameter 'indexmem' out of range
[NULL @ 0x1de2820] Value 4703785510416416768.000000 for parameter 'rtbufsize' out of range
[NULL @ 0x1de2820] Value -4616189618054758400.000000 for parameter 'fpsprobesize' out of range
[NULL @ 0x1de2820] Value 4607182418800017408.000000 for parameter 'f_err_detect' out of range
[NULL @ 0x1de2820] Value 4607182418800017408.000000 for parameter 'err_detect' out of range
[AVI demuxer @ 0x1de2dc0] Value 4607182418800017408.000000 for parameter 'use_odml' out of range
[NULL @ 0x1de34a0] Value 4686111960511545344.000000 for parameter 'b' out of range
[NULL @ 0x1de34a0] Value 4683532506232782848.000000 for parameter 'ab' out of range
[NULL @ 0x1de34a0] Value 4705844345939427328.000000 for parameter 'bt' out of range
[NULL @ 0x1de34a0] Value 4617315517961601024.000000 for parameter 'me_method' out of range
[NULL @ 0x1de34a0] Value 4622945017495814144.000000 for parameter 'g' out of range
[NULL @ 0x1de34a0] Value 4611686018427387904.000000 for parameter 'qmin' out of range
[NULL @ 0x1de34a0] Value 4629418941960159232.000000 for parameter 'qmax' out of range
[NULL @ 0x1de34a0] Value 4613937818241073152.000000 for parameter 'qdiff' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'wpredp' out of range
[NULL @ 0x1de34a0] Value 4607182418800017408.000000 for parameter 'bug' out of range
[NULL @ 0x1de34a0] Value 4607182418800017408.000000 for parameter 'er' out of range
[NULL @ 0x1de34a0] Value 4607182418800017408.000000 for parameter 'err_detect' out of range
[NULL @ 0x1de34a0] Value 4613937818241073152.000000 for parameter 'ec' out of range
[NULL @ 0x1de34a0] Value 4620693217682128896.000000 for parameter 'ildctcmp' out of range
[NULL @ 0x1de34a0] Value 4620693217682128896.000000 for parameter 'subq' out of range
[NULL @ 0x1de34a0] Value 4696837138094751744.000000 for parameter 'ibias' out of range
[NULL @ 0x1de34a0] Value 4696837138094751744.000000 for parameter 'pbias' out of range
[NULL @ 0x1de34a0] Value 4642507528377204736.000000 for parameter 'lmin' out of range
[NULL @ 0x1de34a0] Value 4660262442142531584.000000 for parameter 'lmax' out of range
[NULL @ 0x1de34a0] Value 4696130710463840256.000000 for parameter 'flags2' out of range
[NULL @ 0x1de34a0] Value 4607182418800017408.000000 for parameter 'threads' out of range
[NULL @ 0x1de34a0] Value 4620693217682128896.000000 for parameter 'nssew' out of range
[NULL @ 0x1de34a0] Value -4586705114244317184.000000 for parameter 'profile' out of range
[NULL @ 0x1de34a0] Value -4586705114244317184.000000 for parameter 'level' out of range
[NULL @ 0x1de34a0] Value 4623507967449235456.000000 for parameter 'skipcmp' out of range
[NULL @ 0x1de34a0] Value 4642507528377204736.000000 for parameter 'mblmin' out of range
[NULL @ 0x1de34a0] Value 4660262442142531584.000000 for parameter 'mblmax' out of range
[NULL @ 0x1de34a0] Value 4643211215818981376.000000 for parameter 'mepc' out of range
[NULL @ 0x1de34a0] Value 4607182418800017408.000000 for parameter 'bidir_refine' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'cqp' out of range
[NULL @ 0x1de34a0] Value 4627730092099895296.000000 for parameter 'keyint_min' out of range
[NULL @ 0x1de34a0] Value 4607182418800017408.000000 for parameter 'refs' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'directpred' out of range
[NULL @ 0x1de34a0] Value 4618441417868443648.000000 for parameter 'sc_factor' out of range
[NULL @ 0x1de34a0] Value 4643211215818981376.000000 for parameter 'mv0_threshold' out of range
[NULL @ 0x1de34a0] Value 4630826316843712512.000000 for parameter 'b_sensitivity' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'compression_level' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'min_prediction_order' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'max_prediction_order' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'prediction_order_method' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'min_partition_order' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'max_partition_order' out of range
[NULL @ 0x1de34a0] Value 4607182418800017408.000000 for parameter 'ticks_per_frame' out of range
[NULL @ 0x1de34a0] Value 4611686018427387904.000000 for parameter 'color_primaries' out of range
[NULL @ 0x1de34a0] Value 4611686018427387904.000000 for parameter 'color_trc' out of range
[NULL @ 0x1de34a0] Value 4611686018427387904.000000 for parameter 'colorspace' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'aq_mode' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'rc_lookahead' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'lpc_type' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'lpc_passes' out of range
[NULL @ 0x1de34a0] Value 4613937818241073152.000000 for parameter 'thread_type' out of range
[NULL @ 0x1de34a0] Value -4616189618054758400.000000 for parameter 'request_sample_fmt' out of range
[avi @ 0x1de2820] decoding for stream 0 failed
[avi @ 0x1de2820] Could not find codec parameters (Video: h264 (h264 / 0x34363268), 800x592)
Une idée svp?
