J’ai un problème avec un disque dur en XFS.
Le disque dur fait 1TO, il devait être utilisé à 95%
Je suis sous Debian Wheezy 32bits Linux mustang 3.2.0-4-686-pae #1 SMP Debian 3.2.46-1+deb7u1 i686 GNU/Linux
le disque est en /dev/sdb1
Depuis hier je ne peux plus le lire :
fsck.xfs /dev/sdb1
If you wish to check the consistency of an XFS filesystem or
repair a damaged filesystem, see xfs_check(8) and xfs_repair(8).
[code][root@mustang log]# xfs_repair /dev/sdb1
Phase 1 - find and verify superblock…
superblock read failed, offset 0, size 524288, ag 0, rval -1
fatal error – Input/output error
De temps en temps quand je le reboot ça fonctionne, puis plus .
le log :
[53282.111858] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.111862] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 10 00 00 00 08 00
[53282.111873] end_request: I/O error, dev sdb, sector 4096
[53282.112228] sd 1:0:0:0: [sdb] Unhandled error code
[53282.112235] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.112245] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.112285] end_request: I/O error, dev sdb, sector 0
[53282.112632] sd 1:0:0:0: [sdb] Unhandled error code
[53282.112635] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.112640] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.112650] end_request: I/O error, dev sdb, sector 0
[53282.112994] sd 1:0:0:0: [sdb] Unhandled error code
[53282.112998] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.113003] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.113014] end_request: I/O error, dev sdb, sector 0
[53282.113356] sd 1:0:0:0: [sdb] Unhandled error code
[53282.113360] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.113364] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.113375] end_request: I/O error, dev sdb, sector 0
[53282.113717] sd 1:0:0:0: [sdb] Unhandled error code
[53282.113721] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.113725] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.113736] end_request: I/O error, dev sdb, sector 0
[53282.114078] sd 1:0:0:0: [sdb] Unhandled error code
[53282.114081] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.114086] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.114096] end_request: I/O error, dev sdb, sector 0
[53282.114442] sd 1:0:0:0: [sdb] Unhandled error code
[53282.114445] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.114449] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.114460] end_request: I/O error, dev sdb, sector 0
[53282.114801] sd 1:0:0:0: [sdb] Unhandled error code
[53282.114805] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.114809] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.114819] end_request: I/O error, dev sdb, sector 0
[53282.115162] sd 1:0:0:0: [sdb] Unhandled error code
[53282.115165] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.115169] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.115180] end_request: I/O error, dev sdb, sector 0
[53282.115523] sd 1:0:0:0: [sdb] Unhandled error code
[53282.115526] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.115531] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.115541] end_request: I/O error, dev sdb, sector 0
[53282.115891] sd 1:0:0:0: [sdb] Unhandled error code
[53282.115894] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.115898] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.115909] end_request: I/O error, dev sdb, sector 0
[53282.116255] sd 1:0:0:0: [sdb] Unhandled error code
[53282.116258] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.116263] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.116273] end_request: I/O error, dev sdb, sector 0
[53282.116607] sd 1:0:0:0: [sdb] Unhandled error code
[53282.116610] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.116614] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 18 00 00 08 00
[53282.116625] end_request: I/O error, dev sdb, sector 24
[53282.116967] sd 1:0:0:0: [sdb] Unhandled error code
[53282.116971] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.116976] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.116986] end_request: I/O error, dev sdb, sector 0
[53282.117328] sd 1:0:0:0: [sdb] Unhandled error code
[53282.117332] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.117336] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.117347] end_request: I/O error, dev sdb, sector 0
[53282.117688] sd 1:0:0:0: [sdb] Unhandled error code
[53282.117691] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.117696] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.117706] end_request: I/O error, dev sdb, sector 0
[53282.118047] sd 1:0:0:0: [sdb] Unhandled error code
[53282.118050] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.118054] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[53282.118065] end_request: I/O error, dev sdb, sector 56
[53282.118407] sd 1:0:0:0: [sdb] Unhandled error code
[53282.118411] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.118415] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.118426] end_request: I/O error, dev sdb, sector 0
[53282.118767] sd 1:0:0:0: [sdb] Unhandled error code
[53282.118770] sd 1:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[53282.118774] sd 1:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
[53282.118785] end_request: I/O error, dev sdb, sector 0
Quelqu’un a-t-il une idée ? ou déjà eu le cas ?
Merci.
