je voudrai lancer l’interface graphique sur un pc dont la carte graphique est USB - VGA de ce type i-tec-europe.eu/?t=3&v=145
Mon problème, après avoir installé les drivers et la couche graphique c’est au niveau du lancement de la commande “startx” :
[code]Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
Please also check the log file at “/var/log/Xorg.0.log” for additional information.
giving up.
xinit: No such file or directory (errno 2): unable to connect to X server
xinit: No such process (errno 3): Server error.[/code]
Pourtant le composant est bien reconnu suite à la commande dmesg ou lsusb :
root@ion:/etc/X11# lsusb
Bus 004 Device 002: ID 1ef5:0200
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
[b]Bus 001 Device 002: ID 17e9:02ee Newnham Research[/b]
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@ion:/etc/X11#
[code]root@ion:/etc/X11# cat /var/log/Xorg.0.log
X.Org X Server 1.7.7
Release Date: 2010-05-04
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.32-5-amd64 i686 Debian
Current Operating System: Linux ion 3.0.0+ #1 Thu Oct 27 17:27:43 CEST 2011 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.0.0+ root=UUID=d598c795-8055-4662-aed9-04e1db80fb28 ro console=ttyS0,115200 loglevel=6 reboot=bios quiet
Build Date: 30 October 2011 08:56:49PM
xorg-server 2:1.7.7-14 (Julien Cristau jcristau@debian.org)
Current version of pixman: 0.16.4
Before reporting problems, check http://wiki.x.org
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Thu Jun 14 14:36:14 2012
(==) Using config file: “/etc/X11/xorg.conf”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
(==) ServerLayout “X.org Configured”
() |–>Screen “Screen0” (0)
() | |–>Monitor “Monitor0”
() | |–>Device “Card0”
() |–>Input Device “Mouse0”
() |–>Input Device “Keyboard0”
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
(WW) `fonts.dir’ not found (or not valid) in “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType”.
(Run ‘mkfontdir’ on “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType”).
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
(**) ModulePath set to “/usr/lib/xorg/modules,/usr/local/lib/xorg/modules,/usr/local/lib/xorg/modules/drivers”
(WW) AllowEmptyInput is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
(WW) Disabling Mouse0
(WW) Disabling Keyboard0
(II) Loader magic: 0x81ecce0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(–) using VT number 7
(–) PCI:*(0:0:2:0) 8086:8108:8086:8119 Intel Corporation System Controller Hub (SCH Poulsbo) Graphics Controller rev 7, Mem @ 0xdff80000/524288, 0xc0000000/268435456, 0xdff40000/262144, I/O @ 0x0000e880/8
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
(II) “extmod” will be loaded. This was enabled by default and also specified in the config file.
(II) “dbe” will be loaded. This was enabled by default and also specified in the config file.
(II) “glx” will be loaded. This was enabled by default and also specified in the config file.
(II) “record” will be loaded. This was enabled by default and also specified in the config file.
(II) “dri” will be loaded. This was enabled by default and also specified in the config file.
(II) “dri2” will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “dri2”
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SELinux
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “sisusb”
(II) Loading /usr/lib/xorg/modules/drivers/sisusb_drv.so
(II) Module sisusb: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 0.9.3
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 6.0
(II) SISUSB: driver for SiSUSB chipsets: SIS315E/PRO USB
(WW) Falling back to old probe method for sisusb
(EE) No devices detected.
Fatal server error:
no screens found
for help.
Please also check the log file at “/var/log/Xorg.0.log” for additional information.[/code]
Si vous avez une idée au passage, je vous en remercie d’avance
