Xorg Lenny RV350
J’ai une carte ATI Technologies Inc RV350 AS [Radeon 9550].
Après une mise à jour de Etch à Lenny qui s’est mal passé. J’ai décidé de tout réinstallé à cause de soucis avec apt-get aptitude, mais le mode graphique fonctionnait. Maintenant j’ai un écran noir.
# lspci -v ... 01:00.1 Display controller: ATI Technologies Inc RV350 AS [Radeon 9550] (Secondary) Subsystem: Micro-Star International Co., Ltd. Device 932d Flags: bus master, 66MHz, medium devsel, latency 64 Memory at d8000000 (32-bit, prefetchable) [size=128M] Memory at ff3e0000 (32-bit, non-prefetchable) [size=64K] Capabilities: <access denied> ...
Bien sûr j’ai remarqué que maintenant que dpkg-reconfigure xserver-xorg ne dépasse pas le stade de la gestion du clavier.
Dans cette doc formation-debian.via.ecp.fr/xfree.html il n’y pas grand chose.
[code]# dmesg
[ 21.248608] ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 17
[ 21.248620] ACPI: PCI Interrupt 0000:01:00.0[A] -> Link [LNKE] -> GSI 17 (level, low) -> IRQ 17
[ 21.248832] [drm] Initialized radeon 1.29.0 20080528 on minor 0
[ 21.937433] agpgart: Found an AGP 3.0 compliant device at 0000:00:00.0.
[ 21.937455] agpgart: Putting AGP V3 device at 0000:00:00.0 into 8x mode
[ 21.937494] agpgart: Putting AGP V3 device at 0000:01:00.0 into 8x mode
[ 22.210594] [drm] Setting GART location based on new memory map
[ 22.210612] [drm] Loading R300 Microcode
[ 22.211198] [drm] Num pipes: 1
[ 22.211218] [drm] writeback test succeeded in 2 usecs
[code]# dmidecode
Handle 0x0001, DMI type 1, 25 bytes
System Information
Manufacturer: ASUSTek Computer Inc.
Product Name: K8N-E-Deluxe
Version: To Be Filled By O.E.M.
Serial Number: To Be Filled By O.E.M.
UUID: E0E8B9C3-8DFE-D511-BB4B-00112FD451CD
Wake-up Type: Power Switch
Handle 0x0002, DMI type 2, 8 bytes
Base Board Information
Manufacturer: ASUSTeK Computer INC.
Product Name: 'K8N-E-Deluxe’
Version: Rev 1.xx
Serial Number: MB-1234567890
Handle 0x0004, DMI type 4, 35 bytes
Processor Information
Socket Designation: Socket 754
Type: Central Processor
Family: Athlon 64
Manufacturer: AMD
ID: C0 0F 00 00 FF FB 8B 07
Signature: Family 15, Model 12, Stepping 0
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
MMX (MMX technology supported)
FXSR (Fast floating-point save and restore)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
Version: AMD Athlon™ 64 Processor 3400+
Voltage: 1.6 V
External Clock: 200 MHz
Max Speed: 2400 MHz
Current Speed: 2400 MHz
Status: Populated, Enabled
Upgrade: Socket 754
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: 0x0007
Asset Tag: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Je démarre aux choix sur un noyau 2.6.26-686 ou 2.6.26-486. Le cd netinstall m’avait installe le noyau x686.
[code]# cat /var/log/Xorg.0.log
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 9, (OK)
drmOpenByBusid: Searching for BusID pci:0000:01:00.0
drmOpenByBusid: drmOpenMinor returns 9
drmOpenByBusid: drmGetBusid reports pci:0000:01:00.0
(EE) AIGLX error: dlopen of /usr/lib/dri/r300_dri.so failed (/usr/lib/dri/r300_dri.so: cannot open shared object file: No such file or directory)
(EE) AIGLX: reverting to software rendering
(II) Loading sub module “GLcore”
(II) LoadModule: “GLcore”
(II) Loading /usr/lib/xorg/modules/extensions//libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.0.0
ABI class: X.Org Server Extension, version 0.3
(II) GLX: Initialized MESA-PROXY GL provider for screen 0
(II) RADEON(0): Setting screen physical size to 360 x 270
(WW) Configured Mouse: No Device specified, looking for one…
(II) Configured Mouse: Setting Device option to “/dev/input/mice”
(–) Configured Mouse: Device: “/dev/input/mice”
(==) Configured Mouse: Protocol: “Auto”
() Option “CorePointer”
) Configured Mouse: always reports core events
(==) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
() Configured Mouse: ZAxisMapping: buttons 4 and 5
) Configured Mouse: Buttons: 9
() Configured Mouse: Sensitivity: 1
) Option “CoreKeyboard”
() Generic Keyboard: always reports core events
) Option “Protocol” “standard”
() Generic Keyboard: Protocol: standard
) Option “AutoRepeat” “500 30”
() Option “XkbRules” “xorg”
) Generic Keyboard: XkbRules: “xorg”
() Option “XkbModel” “pc105”
) Generic Keyboard: XkbModel: “pc105”
() Option “XkbLayout” “fr”
) Generic Keyboard: XkbLayout: “fr”
() Option “XkbVariant” “latin9”
) Generic Keyboard: XkbVariant: “latin9”
() Option “CustomKeycodes” “off”
) Generic Keyboard: CustomKeycodes disabled
(II) evaluating device (Configured Mouse)
(II) XINPUT: Adding extended input device “Configured Mouse” (type: MOUSE)
(II) evaluating device (Generic Keyboard)
(II) XINPUT: Adding extended input device “Generic Keyboard” (type: KEYBOARD)
(–) Configured Mouse: PnP-detected protocol: “ExplorerPS/2”
(II) Configured Mouse: ps2EnableDataReporting: succeeded
cat /var/log/Xorg.0.log | grep RV350
(–) PCI:*(1:0:0) ATI Technologies Inc RV350 AS [Radeon 9550] rev 0, Mem @ 0xe0000000/27, 0xff3f0000/16, I/O @ 0x9800/8, BIOS @ 0xff3c0000/17
(–) PCI: (1:0:1) ATI Technologies Inc RV350 AS [Radeon 9550] (Secondary) rev 0, Mem @ 0xd8000000/27, 0xff3e0000/1[/code]
À l’aide de module-assistant j’ai installé le driver fglrx et j’ai récupérer un ancien /etc/X11/xorg.conf que j’avais sauvegardé et ça fonctionne. C’est bateau sans la sauvegarde de ce fichier je ne pense pas que j’aurais pu le faire fonctionner.
[code]$ cat /etc/X11/xorg.conf
/etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 “aticonfig-Screen[0]” 0 0
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section “Files”
    # path to defoma fonts
    FontPath     "/usr/share/fonts/X11/misc"
    FontPath     "/usr/X11R6/lib/X11/fonts/misc"
    FontPath     "/usr/share/fonts/X11/cyrillic"
    FontPath     "/usr/X11R6/lib/X11/fonts/cyrillic"
    FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
    FontPath     "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
    FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
    FontPath     "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
    FontPath     "/usr/share/fonts/X11/Type1"
    FontPath     "/usr/X11R6/lib/X11/fonts/Type1"
    FontPath     "/usr/share/fonts/X11/100dpi"
    FontPath     "/usr/X11R6/lib/X11/fonts/100dpi"
    FontPath     "/usr/share/fonts/X11/75dpi"
    FontPath     "/usr/X11R6/lib/X11/fonts/75dpi"
    FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/psaux"
Option “Protocol” "PS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Monitor"
Identifier "�cran g�n�rique"
HorizSync 28.0 - 89.0
VertRefresh 43.0 - 60.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]"
Option “VendorName” "ATI Proprietary Driver"
Option “ModelName” "Generic Autodetecting Monitor"
Option “DPMS” "true"
EndSection
Section "Device"
Identifier "MSI Radeon RX9550se-TD128"
Driver "fglrx"
VideoRam 128000
EndSection
Section "Device"
Identifier "aticonfig-Device[0]"
Driver "fglrx"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "MSI Radeon RX9550se-TD128"
Monitor "�cran g�n�rique"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1792x1344” “1280x1024” “1280x960” “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]"
Device "aticonfig-Device[0]"
Monitor "aticonfig-Monitor[0]"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option “Composite” "disable"
Option “RENDER” "Enable"
EndSection
Section "DRI"
Mode 0666
EndSection
