Bonsoir,
Je possède un netbook Vaio doté d’une carte Intel 945 GME et d’un écran avec une résolution de 1366*768.7
Impossible de démarrer Gnome dessus.
J’ai essayé en testing en SID pareil :
[code]X.Org X Server 1.7.4
Release Date: 2010-01-08
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.32-trunk-686 i686 Debian
Current Operating System: Linux vaio 2.6.32-trunk-686 #1 SMP Sun Jan 10 06:32:16 UTC 2010 i686
Kernel command line: BOOT_IMAGE=/vmlinuz-2.6.32-trunk-686 root=UUID=497cb2b1-9d2d-4b49-82c2-1fe0484b2b5c ro quiet single
Build Date: 20 January 2010 10:52:55PM
xorg-server 2:1.7.4-2 (bgoglin@debian.org)
Current version of pixman: 0.16.4
Before reporting problems, check http://wiki.x.org
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Mon Feb 8 18:15:54 2010
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “X.org Configured”
() |–>Screen “Screen0” (0)
() | |–>Monitor “Monitor0”
() | |–>Device “Card0”
() |–>Input Device “Mouse0”
() |–>Input Device “Keyboard0”
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
(WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
() FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins,
built-ins
() ModulePath set to “/usr/lib/xorg/modules”
(WW) AllowEmptyInput is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
(WW) Disabling Mouse0
(WW) Disabling Keyboard0
(II) Loader magic: 0x81e7680
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(–) using VT number 2
(–) PCI:*(0:0:2:0) 8086:27ae:104d:9064 Intel Corporation Mobile 945GME Express Integrated Graphics Controller rev 3, Mem @ 0xf0000000/524288, 0xd0000000/268435456, 0xf0400000/262144, I/O @ 0x00001800/8
(–) PCI: (0:0:2:1) 8086:27a6:104d:9064 Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller rev 3, Mem @ 0xf0080000/524288
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
(II) “extmod” will be loaded. This was enabled by default and also specified in the config file.
(II) “dbe” will be loaded. This was enabled by default and also specified in the config file.
(II) “glx” will be loaded. This was enabled by default and also specified in the config file.
(II) “record” will be loaded. This was enabled by default and also specified in the config file.
(II) “dri” will be loaded. This was enabled by default and also specified in the config file.
(II) “dri2” will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.7.4, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “dri2”
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.4, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.7.4, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “intel”
(II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
compiled for 1.7.3.902, module version = 2.9.1
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 6.0
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, Clarkdale, Arrandale
(II) Primary Device is: PCI 00@00:02:0
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 8, (OK)
drmOpenByBusid: Searching for BusID pci:0000:00:02.0
drmOpenByBusid: drmOpenMinor returns 8
drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
(==) intel(0): Depth 24, (–) framebuffer bpp 32
(==) intel(0): RGB weight 888
(==) intel(0): Default visual is TrueColor
(II) intel(0): Integrated Graphics Chipset: Intel® 945GME
(–) intel(0): Chipset: “945GME”
(II) intel(0): Output VGA1 using monitor section Monitor0
(II) intel(0): Output LVDS1 has no monitor section
(II) intel(0): found backlight control interface /sys/class/backlight/acpi_video0
(II) intel(0): EDID for output VGA1
(II) intel(0): EDID for output LVDS1
(II) intel(0): Output VGA1 disconnected
(II) intel(0): Output LVDS1 disconnected
(WW) intel(0): No outputs definitely connected, trying again…
(WW) intel(0): Unable to find initial modes
(==) intel(0): video overlay key set to 0x101fe
(EE) intel(0): No modes.
(II) UnloadModule: “intel”
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Xorg.conf:
[code]Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 “Screen0” 0 0
InputDevice “Mouse0” "CorePointer"
InputDevice “Keyboard0” "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
FontPath "built-ins"
EndSection
Section "Module"
Load "extmod"
Load "dbe"
Load "dri2"
Load "glx"
Load "dri"
Load "record"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option “Protocol” "auto"
Option “Device” "/dev/input/mice"
Option “ZAxisMapping” "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section “Device”
### Available Driver options are:-
### Values: : integer, : float, : “True”/“False”,
### : “String”, : " Hz/kHz/MHz"
### [arg]: arg optional
#Option “NoAccel” # []
#Option “SWcursor” # []
#Option “ColorKey” #
#Option “CacheLines” #
#Option “Dac6Bit” # []
#Option “DRI” # []
#Option “NoDDC” # []
#Option “ShowCache” # []
#Option “XvMCSurfaces” #
#Option “PageFlip” # []
Identifier "Card0"
Driver "intel"
VendorName "Intel Corporation"
BoardName "Mobile 945GME Express Integrated Graphics Controller"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 24
Modes "1366x768"
EndSubSection
EndSection
Le truc drole c’est que si je branche un écran externe ca marche !! Il semble ne pas detecter mon écran
Si quelqu’un pouvait m’aider car sinon je vais être obligé de remettre ubuntu et ça me saoule !! (mais ca marche au moins)
