Salut à tous.
J’ai un serveur sur Debian 5.0 stable, et je dois installer une interface graphique pour tester une appli
J’ai donc lancé l’install du bureau XFCE4
je tape
et il laisse l’écran en “veille”
Je suis persuadé que ça vient de la XKB. Ou alors j’interprète mal les chose
xauth: creating new authority file /root/.serverauth.8825
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux nagios57 2.6.18-6-486 #1 Fri Dec 12 16:18:30 UTC 2008 i686
Build Date: 29 May 2008
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug 7 11:26:04 2009
(==) Using config file: "/etc/X11/xorg.conf"
(EE) AIGLX: Screen 0 is not DRI capable
xkb_keycodes { include "xfree86+aliases(azerty)" };
xkb_types { include "complete" };
xkb_compatibility { include "complete" };
xkb_symbols { include "pc(pc105)+fr" };
xkb_geometry { include "pc(pc102)" };
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols
> Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
J’ai essayé
setxkbmap -rules xorg -model pc102 -layout fr -option ""
Mais il me retourne
Cannot open display "default display"
Voici mon xorg.conf
Section "Files"
18 FontPath "/usr/share/fonts/X11/misc"
19 FontPath "/usr/X11R6/lib/X11/fonts/misc"
20 FontPath "/usr/share/fonts/X11/cyrillic"
21 FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
22 FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
23 FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
24 FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
25 FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
26 FontPath "/usr/share/fonts/X11/Type1"
27 FontPath "/usr/X11R6/lib/X11/fonts/Type1"
28 FontPath "/usr/share/fonts/X11/100dpi"
29 FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
30 FontPath "/usr/share/fonts/X11/75dpi"
31 FontPath "/usr/X11R6/lib/X11/fonts/75dpi"
32 # path to defoma fonts
33 FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
34 EndSection
35
36 Section "Module"
37 Load "bitmap"
38 Load "ddc"
39 # Load "dri"
40 Load "extmod"
41 Load "freetype"
42 Load "glx"
43 Load "int10"
44 Load "vbe"
45 EndSection
46
47 Section "InputDevice"
48 Identifier "Generic Keyboard"
49 Driver "kbd"
50 Option "CoreKeyboard"
51 Option "XkbModel" "pc102"
52 Option "XkbLayout" "fr"
53 EndSection
54
55 Section "InputDevice"
56 Identifier "Configured Mouse"
57 Driver "mouse"
58 Option "CorePointer"
59 Option "Device" "/dev/input/mice"
60 Option "Protocol" "ImPS/2"
61 EndSection
62
63 Section "Device"
64 Identifier "Aucune Idee"
65 Driver "vesa"
66 BusID "PCI:1:0:0"
67 EndSection
68
69 Section "Monitor"
70 Identifier "Ãcran générique"
71 Option "DPMS"
72 HorizSync 28-51
73 VertRefresh 43-60
74 EndSection
75
76 Section "Screen"
77 Identifier "Default Screen"
78 Device "Aucune Idee"
79 Monitor "Ãcran génériqu
80 DefaultDepth 16
81 SubSection "Display"
82 Depth 1
83 Modes "1024x768" "800x600" "640x480"
84 EndSubSection
85 SubSection "Display"
86 Depth 4
87 Modes "1024x768" "800x600" "640x480"
88 EndSubSection
89 SubSection "Display"
90 Depth 8
91 Modes "1024x768" "800x600" "640x480"
92 EndSubSection
93 SubSection "Display"
94 Depth 15
95 Modes "1024x768" "800x600" "640x480"
96 EndSubSection
97 SubSection "Display"
98 Depth 16
99 Modes "1024x768" "800x600" "640x480"
100 EndSubSection
101 SubSection "Display"
102 Depth 24
103 Modes "1024x768" "800x600" "640x480"
104 EndSubSection
105 EndSection
106
107 Section "ServerLayout"
108 Identifier "Default Layout"
109 Screen "Default Screen"
110 InputDevice "Generic Keyboard"
111 InputDevice "Configured Mouse"
112 EndSection
113
114 Section "DRI"
115 Mode 0666
116 EndSection
Merci d’avance ![]()
