Xorg: teinte verte lors de changement de session [RESOLU]
Je possède un pc sous debian Lenny.
Quand je démarrage le PC gdm me demande mon mot de passe. Ma session démarrage; Aucun probléme.
Ma session ouverte, mon amie clique sur fermer session -> changer d’utilisateur pour ce loguer sur sa session.
Gdm apparaît alors teinté en vert. Ma session et sa session seront aussi teinté de vert. Si je relance Xorg (Ctrl + Alt + BackSpace) tout redevient normal.
Voila ci quelqu’un à une idée merci?
Quelque infos.
Distribution: Debian Lenny
PC: AMD sempron 2600
Carte graphique: GeForce FX 5200
lsmod | grep nvidia: nvidia 7086148 34 i2c_core 19828 2 nvidia,i2c_nforce2 nvidia_agp 6108 1 agpgart 28776 2 nvidia,nvidia_agp
/ets/X11/xorg.conf:[code]# nvidia-settings: X configuration file generated by nvidia-settings
nvidia-settings: version 1.0 (buildd@ninsei) Tue Jun 24 18:11:48 UTC 2008
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 1.0 (buildd@ninsei) Fri Sep 5 22:23:08 UTC 2008
Section "ServerLayout"
Identifier "Layout0"
Screen 0 “Screen0” LeftOf "Screen1"
Screen 1 “Screen1” 1440 0
InputDevice “Keyboard0” "CoreKeyboard"
InputDevice “Mouse0” "CorePointer"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section “ServerFlags”
Removed Option “Xinerama” “1”
Option         "Xinerama" "0"
EndSection
Section “InputDevice”
# generated from default
Identifier     "Mouse0"
Driver         "mouse"
Option         "Protocol" "auto"
Option         "Device" "/dev/psaux"
Option         "Emulate3Buttons" "no"
Option         "ZAxisMapping" "4 5"
EndSection
Identifier     "Keyboard0"
Driver         "kbd"
Option         "XkbModel" "pc105"
Option         "XkbLayout" "fr"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Samsung SyncMaster"
HorizSync 30.0 - 81.0
VertRefresh 56.0 - 75.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "TV-0"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Device"
Identifier "Videocard0"
Driver "nvidia"
BoardName "GeForce FX 5200"
BusID "PCI:1:0:0"
Screen 0
EndSection
Section "Device"
Identifier "Videocard1"
Driver "nvidia"
BusID "PCI:1:0:0"
Screen 1
EndSection
Section "Screen"
Identifier "Screen0"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
Option “TwinView” "0"
Option “TwinViewXineramaInfoOrder” "CRT-0"
Option “metamodes” "CRT: nvidia-auto-select +0+0"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Videocard1"
Monitor "Monitor1"
DefaultDepth 24
Option “metamodes” "TV: nvidia-auto-select +0+0"
EndSection
glxgears: 5869 frames in 5.0 seconds = 1173.629 FPS
Vérifies que ton amie n’est pas une alien ? Le vert, c’est carctéristique :mrgreen:
Afin de comparer d’éventuelles erreurs de Xorg, que donne les commandes
quand la session est teintée de vert puis après avoir relancé xorg ?
debian:/home/damien# cat /var/log/Xorg.0.log | grep EE (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (II) Loading extension MIT-SCREEN-SAVER (EE) Failed to load module "type1" (module does not exist, 0)
Le même message dans les deux cas
j’ai commenter Load "type1"
dans mon xorg.conf
maintenant:
Et toujours la teinte verte
personne n’a une idèe?..
[quote=“damdam”]personne n’a une idèe?..[/quote] Fais un test avec un live-CD pour voir si tu as le même PB.
Je viens d’essayer les cd-live d’une knoppix et d’une ubuntu et aucune de ses deux distributions n’a posées de problèmes.
Ok,
As tu le paquet x11-xserver-utils
[quote]BLACKSTAR:/home/rodmov# apt-cache policy x11-xserver-utils
x11-xserver-utils:
Installé : 7.3+5
ou tu y trouveras les utilitaires suivantes [quote]An X client is a program that interfaces with an X server (almost always via
the X libraries), and thus with some input and output hardware like a
graphics card, monitor, keyboard, and pointing device (such as a mouse).
This package provides a miscellaneous assortment of X Server utilities
that ship with the X Window System, including:
  • iceauth, a tool for manipulating ICE protocol authorization records;
  • rgb;
  • sessreg, a simple program for managing utmp/wtmp entries;
  • xcmsdb, a device color characteristic utility for the X Color Management
    System;
  • xgamma, a tool for querying and setting a monitor’s gamma correction;
  • xhost, a very dangerous program that you should never use;
  • xmodmap, a utility for modifying keymaps and pointer button mappings in X;
  • xrandr, a command-line interface to the RandR extension;
  • xrdb, a tool to manage the X server resource database;
  • xrefresh, a tool that forces a redraw of the X screen;
  • xset, a tool for setting miscellaneous X server parameters;
  • xsetmode and xsetpointer, tools for handling X Input devices;
  • xsetroot, a tool for tailoring the appearance of the root window;
  • xstdcmap, a utility to selectively define standard colormap properties;
  • xtrapchar, xtrapin, xtrapinfo, xtrapout, xtrapproto, xtrapreset, and
    xtrapstats, a group of sample clients that use the XTrap extension;
  • xvidtune, a tool for customizing X server modelines for your monitor.[/quote]
    par exemple quand je lance xgamma , il me donne [quote]BLACKSTAR:/home/rodmov# xgamma
    -> Red 1.000, Green 1.000, Blue 1.000
xgamma me repond “Red 1.000, Green 1.000, Blue 1.000” avant et après la teinte verte.
Par contre je viens de remarquer que la sortie TV n’est pas affecté par ce phénomène.
là je ne vois pas trop, mise à part un problème avec ton écran.
Généralement une modification des couleurs est un symptôme du vieillissement d’un écran .
L’écran est tout neuf, c’est un 19 pouce wide LCD. Les couleurs sont nickel avant que je change de section.
Je pense que le problème vient de Xorg ou du pilote nvidia. J’ai déjà essayer de réinstaller le pilote nvidia mais ça n’a pas réglé le problème.
Le problème est réglé: il faut activer le framebuffer
Merci à tous de votre aide.
Simple curiosite : ton ecran, un AL1916W de chez Acer ?
J’ai eu regulierement ce probleme avec cet ecran et le pilote non libre nvidia…
N’ayant jamais su comment j’avais reussi a le regler, je vais garder ta solution dans un coin au cas ou ca me reprenne !
Ca serais pas mal de dire comment tu as activé le frambuffer :stuck_out_tongue:
Si je ne me trompe pas ça donne quelquechose comme ça
Section "Device" [...] Option "UseFBDev" "true" EndSection
Je confirme, chez moi ca donne simplement ca : Section "Device" (...) Option "UseFBDev" (...) EndSectionLe “true” est facultatif.
Mon ecran est un SAMSUNG SyncMaster 931BW
Pour activer le framebuffer j’ai fait un ‘dpkg-reconfigure xserver-xorg’ et j’ai répondu oui à la première question.
Oui mais avec cette méthode si tu as une configuration un peu spéciale elle saute :confused:
Et une bonne config a la mano ca n’a pas de prix 8)
