SALUT!!!
sous gnome depuis 1 moi environs je galere pour installer le screensaver
–j’ai installer le package xcreensaver et xscreensaver-gnome
–j’"ai modifier le gdm.conr comme indique siur le site jws.org/screensaver
mais sans succes jil y a toujour le même message
Xlib: connection to “:0.0” refused by server
Xlib: No protocol specified
xscreensaver: Can’t open display: :0.0
xscreensaver: initial effective uid/gid was root/root (0/0)
xscreensaver: running as nobody/nogroup (65534/65534)
xscreensaver: This is probably because you’re logging in as root. You
shouldn’t log in as root: you should log in as a normal user,
and then `su’ as needed. If you insist on logging in as
root, you will have to turn off X’s security features before
xscreensaver will work.
si quelqu’un peut m’aider ou me diriger ver un MAN ou HOWTO en francais
@+ LYRICS
PS: quel est le nom du package pour mettre Gnome en francais,???
