J’ai un petit souci à l’étape 17 :
Lorsque je tape cette commande :
make-kpkg --append-to-version “-seal_neness” --initrd kernel_image modules_image kernel_headers
/usr/src/linux#
J’ai ce message :
Warning: You are using the initrd option, that may not
work, depending on your kernel version and architecture,
unless you have applied the initrd cramfs patch to
the kernel, or modified mkinitrd not to use cramfs by
default. The cramfs initrd patch, is included in the
Debian supplied kernel sources. New kernels on most
architectures do work fine.
By default, I assume you know what you are doing, and I
apologize for being so annoying. Should I abort[Ny]?
Je fais entrer et j'ai sa :
/usr/src/kernel-source-2.6.8/scripts/gcc-version.sh: line 1: i486-linux-gnu-gcc: command not found
/usr/share/kernel-package/rules:1637: *** Error. I do not know where the kernel image goes to [kimagedest undefined] The usual case for this is that I could not determine which arch or subarch tihs machine belongs to. Please specify a subarch, and try again.. Arrêt.
Donc j’ai arreter et je vous demande si d’aprés vous c’est normal et que faire ?
un load .config me donne aussi sa :
neness:/usr/src/linux# load .config
bash: load: command not found
Qu’est ce qui se passe, car moi je n’y comprends rien !
merci
