[quote=“neness”]Je suis passer à la 2.6.8 mais je n’ai plus de son c’est normal ?
merci d’avance ![/quote]
ah oui le son ils l’ont enlevés en 2.6, ca servait a rien
Non sérieux comment faire ?
J’ai désinstaller tous les alsa et réinstaller les alsa suivants :
aconnectgui - graphical ALSA sequencer connection manager
alsa-base - ALSA driver configuration files
alsa-headers - transitional dummy package that can be safely removed
alsa-oss - ALSA wrapper for OSS applications
alsa-source - ALSA driver sources
alsa-utils - ALSA utilities
alsamixergui - graphical soundcard mixer for ALSA soundcard driver
alsaplayer - PCM player designed for ALSA
alsaplayer-alsa - PCM player designed for ALSA (ALSA output module)
alsaplayer-common - PCM player designed for ALSA (common files)
alsaplayer-daemon - PCM player designed for ALSA (non-interactive version)
alsaplayer-esd - PCM player designed for ALSA (ESD output module)
alsaplayer-gtk - PCM player designed for ALSA (GTK version)
alsaplayer-jack - PCM player designed for ALSA (jack output module)
alsaplayer-nas - PCM player designed for ALSA (NAS output module)
alsaplayer-oss - PCM player designed for ALSA (OSS output module)
alsaplayer-text - PCM player designed for ALSA (text version)
alsaplayer-xosd - PCM player designed for ALSA (osd version)
J’ai pas installe cela :
alsa-modules-2.4.27-2-386 - ALSA driver modules
alsa-modules-2.4.27-2-586tsc - ALSA driver modules
alsa-modules-2.4.27-2-686 - ALSA driver modules
alsa-modules-2.4.27-2-686-smp - ALSA driver modules
alsa-modules-2.4.27-2-k6 - ALSA driver modules
alsa-modules-2.4.27-2-k7 - ALSA driver modules
alsa-modules-2.4.27-2-k7-smp - ALSA driver modules
alsa-modules-2.4-386 - ALSA modules for kernel 2.4 on 386
alsa-modules-2.4-586tsc - ALSA modules for kernel 2.4 on Pentium Classic
alsa-modules-2.4-686 - ALSA modules for kernel 2.4 on PPro/Celeron/PII/PIII/P4
alsa-modules-2.4-686-smp - ALSA modules for kernel 2.4 on PPro/Celeron/PII/PIII/P4
alsa-modules-2.4-k6 - ALSA modules for kernel 2.4 on AMD K6/K6-II/K6-III
alsa-modules-2.4-k7 - ALSA modules for kernel 2.4 on AMD K7
alsa-modules-2.4-k7-smp - ALSA modules for kernel 2.4 on AMD K7 SMP
alsa-modules-2.4.27-3-386 - ALSA modules for kernel 2.4.27-3-386
alsa-modules-2.4.27-3-586tsc - ALSA modules for kernel 2.4.27-3-586tsc
alsa-modules-2.4.27-3-686 - ALSA modules for kernel 2.4.27-3-686
alsa-modules-2.4.27-3-686-smp - ALSA modules for kernel 2.4.27-3-686-smp
alsa-modules-2.4.27-3-k6 - ALSA modules for kernel 2.4.27-3-k6
alsa-modules-2.4.27-3-k7 - ALSA modules for kernel 2.4.27-3-k7
alsa-modules-2.4.27-3-k7-smp - ALSA modules for kernel 2.4.27-3-k7-smp
Ensuite j’ai redémarrez et toujours pas de son !
merci de votre aide
[code]# apt-get remove --purge alsa-base alsa-utils
$ alsamixer[/code]
merci ghost je tente sa
gros merci sa marche et c’est ce que je voulais !
Sa sert à quoi de compiler ou recompiler au faite ?
Et si je veux passer comme certain à la 2.6.17 que faire ??
grand merci à ghost
Chaque pilote grossit un peu ton noyau, et plus il est gros, moins il démarre vite (mais ce sont des microsecondes).
recompiler peut servir à activer des pilotes/fonctionnalités qui sont trop rares pour etre inclus par defaut.
Par ailleurs, il est parfois necessaire de ne pas utiliser un noyau standard pour certains softs, donc il faut le “patcher” (ca fait les modifs sur les sources d’origine) opuis de compiler ce qu’on obtient.
Pour ce qui est d’accèder au derniers noyaux quand on est en sarge, il y a un trucs et astuces pour ça.
cool !
a passer le temps et à desorienter les nouveaux
passer en Etch / Sid ou suivre la méthode de Ash
you’re welcome.
ok merci je regarde sa !!
merci de votre aide
Je nomme ce topic résolut !
C’est normal qu’à chaque démarrage j’ai plus de son et que je dois retaper tout sa pour l’avoir ??
$ alsamixer
Dsl si je suis un peu brusque mais j’ai un litige avec mon auto-ecole qui m’arnaque !
déjà, AMA, tu peux ne faire que l’alsaconf ou peut être lancer l’alsamixer gui, mais non, sinon, c’est pas normal.
Essayes un truc:
quand le son fonctionne, tu fais un sudo cp /etc/modules /etc/modules.bak
sudo lsmod | grep snd | awk '{ print $1 }' >/etc/modules
Merci matt avec tes comandes le son remarche à merveille !
merci à vous tous
sauf que tu devais etre root quand tu as fait le deuxiême sudo, parceque tel quel ça n’aurait pas du marcher
Mais tu n’es pas partie en vacances, toi ?
après avoir fait
fais un
pour enregistrer tes réglages …
