X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux debian 2.6.18-4-486 #1 Wed May 9 22:23:40 UTC 2007 i686
Build Date: 04 April 2007
Before reporting problems, check wiki.x.org
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Aug 3 22:12:26 2007
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
() |–>Screen “Default Screen” (0)
() | |–>Monitor “Écran générique”
() | |–>Device “NVIDIA GeForce 8500GT”
() |–>Input Device “Generic Keyboard”
() |–>Input Device “Configured Mouse”
(WW) The directory “/usr/X11R6/lib/X11/fonts/misc” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/Type1” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi” does not exist.
(WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to “/etc/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
(II) No APM support in BIOS or kernel
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.0
X.Org XInput driver : 0.6
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: “bitmap”
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font Bitmap
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 1.0
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,29c0 card 1458,5000 rev 02 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,29c1 card 0000,0000 rev 02 class 06,04,00 hdr 01
(II) PCI: 00:1a:0: chip 8086,2937 card 1458,5004 rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1a:1: chip 8086,2938 card 1458,5004 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1a:2: chip 8086,2939 card 1458,5004 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1a:7: chip 8086,293c card 1458,5006 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1b:0: chip 8086,293e card 1458,a002 rev 02 class 04,03,00 hdr 00
(II) PCI: 00:1c:0: chip 8086,2940 card 0000,0000 rev 02 class 06,04,00 hdr 81
(II) PCI: 00:1c:3: chip 8086,2946 card 0000,0000 rev 02 class 06,04,00 hdr 81
(II) PCI: 00:1c:4: chip 8086,2948 card 0000,0000 rev 02 class 06,04,00 hdr 81
(II) PCI: 00:1d:0: chip 8086,2934 card 1458,5004 rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,2935 card 1458,5004 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,2936 card 1458,5004 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,293a card 1458,5006 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev 92 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,2916 card 1458,5001 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:1f:2: chip 8086,2920 card 1458,b002 rev 02 class 01,01,8a hdr 00
(II) PCI: 00:1f:3: chip 8086,2930 card 1458,5001 rev 02 class 0c,05,00 hdr 00
(II) PCI: 00:1f:5: chip 8086,2926 card 1458,b002 rev 02 class 01,01,85 hdr 00
(II) PCI: 01:00:0: chip 10de,0421 card 1458,3445 rev a1 class 03,00,00 hdr 00
(II) PCI: 03:00:0: chip 197b,2363 card 1458,b000 rev 02 class 01,06,01 hdr 80
(II) PCI: 03:00:1: chip 197b,2363 card 1458,b000 rev 02 class 01,01,85 hdr 00
(II) PCI: 04:00:0: chip 10ec,8168 card 1458,e000 rev 01 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,5), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x0000b000 - 0x0000bfff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xf4000000 - 0xf7ffffff (0x4000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B]
(II) Bus 2: bridge is at (0:28:0), (0,2,2), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x00009000 - 0x00009fff (0x1000) IX[B]
(II) Bus 3: bridge is at (0:28:3), (0,3,3), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 3 I/O range:
[0] -1 0 0x0000c000 - 0x0000cfff (0x1000) IX[B]
(II) Bus 3 non-prefetchable memory range:
[0] -1 0 0xfa000000 - 0xfa0fffff (0x100000) MX[B]
(II) Bus 4: bridge is at (0:28:4), (0,4,4), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 4 I/O range:
[0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 4 non-prefetchable memory range:
[0] -1 0 0xf8000000 - 0xf9ffffff (0x2000000) MX[B]
(II) Bus 4 prefetchable memory range:
[0] -1 0 0x80000000 - 0x800fffff (0x100000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 5: bridge is at (0:30:0), (0,5,5), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 5 I/O range:
[0] -1 0 0x0000a000 - 0x0000afff (0x1000) IX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI:*(1:0:0) nVidia Corporation unknown chipset (0x0421) rev 161, Mem @ 0xf6000000/24, 0xe0000000/28, 0xf4000000/25, I/O @ 0xb000/7
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xf9000000 - 0xf9000fff (0x1000) MX[B]
[1] -1 0 0xfa000000 - 0xfa001fff (0x2000) MX[B]
[2] -1 0 0xfa106000 - 0xfa1060ff (0x100) MX[B]
[3] -1 0 0xfa105000 - 0xfa1053ff (0x400) MX[B]
[4] -1 0 0xfa100000 - 0xfa103fff (0x4000) MX[B]
[5] -1 0 0xfa104000 - 0xfa1043ff (0x400) MX[B]
[6] -1 0 0xf4000000 - 0xf5ffffff (0x2000000) MXB
[7] -1 0 0xe0000000 - 0xefffffff (0x10000000) MXB
[8] -1 0 0xf6000000 - 0xf6ffffff (0x1000000) MXB
[9] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]
[10] -1 0 0x0000c400 - 0x0000c40f (0x10) IX[B]
[11] -1 0 0x0000c300 - 0x0000c303 (0x4) IX[B]
[12] -1 0 0x0000c200 - 0x0000c207 (0x8) IX[B]
[13] -1 0 0x0000c100 - 0x0000c103 (0x4) IX[B]
[14] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
[15] -1 0 0x0000ec00 - 0x0000ec0f (0x10) IX[B]
[16] -1 0 0x0000eb00 - 0x0000eb0f (0x10) IX[B]
[17] -1 0 0x0000ea00 - 0x0000ea03 (0x4) IX[B]
[18] -1 0 0x0000e900 - 0x0000e907 (0x8) IX[B]
[19] -1 0 0x0000e800 - 0x0000e803 (0x4) IX[B]
[20] -1 0 0x0000e700 - 0x0000e707 (0x8) IX[B]
[21] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[22] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
[23] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[24] -1 0 0x0000e500 - 0x0000e51f (0x20) IX[B]
[25] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
[26] -1 0 0x0000e300 - 0x0000e31f (0x20) IX[B]
[27] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
[28] -1 0 0x0000e200 - 0x0000e21f (0x20) IX[B]
[29] -1 0 0x0000e100 - 0x0000e11f (0x20) IX[B]
[30] -1 0 0x0000b000 - 0x0000b07f (0x80) IXB
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xf9000000 - 0xf9000fff (0x1000) MX[B]
[5] -1 0 0xfa000000 - 0xfa001fff (0x2000) MX[B]
[6] -1 0 0xfa106000 - 0xfa1060ff (0x100) MX[B]
[7] -1 0 0xfa105000 - 0xfa1053ff (0x400) MX[B]
[8] -1 0 0xfa100000 - 0xfa103fff (0x4000) MX[B]
[9] -1 0 0xfa104000 - 0xfa1043ff (0x400) MX[B]
[10] -1 0 0xf4000000 - 0xf5ffffff (0x2000000) MXB
[11] -1 0 0xe0000000 - 0xefffffff (0x10000000) MXB
[12] -1 0 0xf6000000 - 0xf6ffffff (0x1000000) MXB
[13] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[15] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]
[16] -1 0 0x0000c400 - 0x0000c40f (0x10) IX[B]
[17] -1 0 0x0000c300 - 0x0000c303 (0x4) IX[B]
[18] -1 0 0x0000c200 - 0x0000c207 (0x8) IX[B]
[19] -1 0 0x0000c100 - 0x0000c103 (0x4) IX[B]
[20] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
[21] -1 0 0x0000ec00 - 0x0000ec0f (0x10) IX[B]
[22] -1 0 0x0000eb00 - 0x0000eb0f (0x10) IX[B]
[23] -1 0 0x0000ea00 - 0x0000ea03 (0x4) IX[B]
[24] -1 0 0x0000e900 - 0x0000e907 (0x8) IX[B]
[25] -1 0 0x0000e800 - 0x0000e803 (0x4) IX[B]
[26] -1 0 0x0000e700 - 0x0000e707 (0x8) IX[B]
[27] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[28] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
[29] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[30] -1 0 0x0000e500 - 0x0000e51f (0x20) IX[B]
[31] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
[32] -1 0 0x0000e300 - 0x0000e31f (0x20) IX[B]
[33] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
[34] -1 0 0x0000e200 - 0x0000e21f (0x20) IX[B]
[35] -1 0 0x0000e100 - 0x0000e11f (0x20) IX[B]
[36] -1 0 0x0000b000 - 0x0000b07f (0x80) IXB
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “ddc”
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading sub module “drm”
(II) LoadModule: “drm”
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.1.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.8776
ABI class: X.Org Server Extension, version 0.1
(II) Loading extension GLX
(II) LoadModule: “int10”
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “v4l”
(II) Loading /usr/lib/xorg/modules/drivers/v4l_drv.so
(II) Module v4l: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 0.1.1
(II) LoadModule: “vbe”
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.0
(II) LoadModule: “nvidia”
(II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.o
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: X.Org Video Driver
(II) LoadModule: “kbd”
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.1
(II) v4l driver for Video4Linux
(II) NVIDIA X Driver 1.0-8776 Mon Oct 16 21:58:46 PDT 2006
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(–) Chipset NVIDIA GPU found
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module “ramdac”
(II) LoadModule: “ramdac”
(II) Loading /usr/lib/xorg/modules/libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 0.1.0
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[13] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[14] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[15] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[18] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]
[19] -1 0 0x0000c400 - 0x0000c40f (0x10) IX[B]
[20] -1 0 0x0000c300 - 0x0000c303 (0x4) IX[B]
[21] -1 0 0x0000c200 - 0x0000c207 (0x8) IX[B]
[22] -1 0 0x0000c100 - 0x0000c103 (0x4) IX[B]
[23] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
[24] -1 0 0x0000ec00 - 0x0000ec0f (0x10) IX[B]
[25] -1 0 0x0000eb00 - 0x0000eb0f (0x10) IX[B]
[26] -1 0 0x0000ea00 - 0x0000ea03 (0x4) IX[B]
[27] -1 0 0x0000e900 - 0x0000e907 (0x8) IX[B]
[28] -1 0 0x0000e800 - 0x0000e803 (0x4) IX[B]
[29] -1 0 0x0000e700 - 0x0000e707 (0x8) IX[B]
[30] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[31] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
[32] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[33] -1 0 0x0000e500 - 0x0000e51f (0x20) IX[B]
[34] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
[35] -1 0 0x0000e300 - 0x0000e31f (0x20) IX[B]
[36] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
[37] -1 0 0x0000e200 - 0x0000e21f (0x20) IX[B]
[38] -1 0 0x0000e100 - 0x0000e11f (0x20) IX[B]
[39] -1 0 0x0000b000 - 0x0000b07f (0x80) IXB
[40] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[41] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
() NVIDIA(0): Depth 24, (–) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
() NVIDIA(0): Enabling RENDER acceleration
