Voici :
[code]C:\Users\cetipabo>ssh -vvv root@xxxxxxxxxx.net
OpenSSH_3.8.1p1, OpenSSL 0.9.7d 17 Mar 2004
debug2: ssh_connect: needpriv 0
debug1: Connecting to xxxxxxxxxx.net [85.17.xxx.xxx] port 22.
debug1: Connection established.
debug1: identity file /cygdrive/c/Users/cetipabo/.ssh/identity type -1
debug1: identity file /cygdrive/c/Users/cetipabo/.ssh/id_rsa type -1
debug1: identity file /cygdrive/c/Users/cetipabo/.ssh/id_dsa type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_5.5p1 Debia
n-6+squeeze1
debug1: match: OpenSSH_5.5p1 Debian-6+squeeze1 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_3.8.1p1
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha1,diffie-hellman-gro
up1-sha1
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,arcfour,
aes192-cbc,aes256-cbc,rijndael-cbc@lysator.liu.se,aes128-ctr,aes192-ctr,aes256-c
tr
tr
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,hmac-ripemd160,hmac-ripemd160@open
ssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha256,diffie-hellman-g
roup-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour12
8,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rij
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160
,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib@openssh.com
debug2: mac_init: found hmac-md5
debug1: kex: server->client aes128-cbc hmac-md5 none
debug1: kex: client->server aes128-cbc hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug2: dh_gen_key: priv key bits set: 141/256
debug2: bits set: 508/1024
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug3: check_host_in_hostfile: filename /cygdrive/c/Users/cetipabo/.ssh/known_hosts
debug3: check_host_in_hostfile: match line 1
debug1: Host ‘xxxxxxxxxx.net’ is known and matches the RSA host key.
debug1: Found key in /cygdrive/c/Users/cetipabo/.ssh/known_hosts:1
debug2: bits set: 501/1024
debug1: ssh_rsa_verify: signature correct
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /cygdrive/c/Users/cetipabo/.ssh/identity (0x0)
debug2: key: /cygdrive/c/Users/cetipabo/.ssh/id_rsa (0x0)
debug2: key: /cygdrive/c/Users/cetipabo/.ssh/id_dsa (0x0)
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /cygdrive/c/Users/cetipabo/.ssh/identity
debug3: no such identity: /cygdrive/c/Users/cetipabo/.ssh/identity
debug1: Trying private key: /cygdrive/c/Users/cetipabo/.ssh/id_rsa
debug3: no such identity: /cygdrive/c/Users/cetipabo/.ssh/id_rsa
debug1: Trying private key: /cygdrive/c/Users/cetipabo/.ssh/id_dsa
debug3: no such identity: /cygdrive/c/Users/cetipabo/.ssh/id_dsa
debug2: we did not send a packet, disable method
debug3: authmethod_lookup password
debug3: remaining preferred: ,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
root@xxxxxxxxxx.net’s password:
debug3: packet_send2: adding 64 (len 56 padlen 8 extra_pad 64)
debug2: we sent a password packet, wait for reply
Connection closed by 85.17.xxx.xxx
il se passe environ 2 minutes avant l’affichage de Connection closed by 85.17.xxx.xxx
