J’ai un serveur domestique sous Debian. Je voulais partager des fichiers, créer un contrôleur de domaine et partager une imprimante. J’ai installé et configuré Samba mais une fois que j’active le serveur, c’est marqué “inactive server”, le contrôleur de domaine ne fonctionne donc pas. Je ne sais pas pourquoi. Je vous poste mon fichier de configuration:
[global]
netbios name = serveur
server string = serveur
workgroup = maison.local
security = domain
hosts allow = 127. 192.168.1.
interfaces = 127.0.0.1/8 192.168.1.11/20
bind interfaces only = yes
remote announce = 192.168.1.255
remote browse sync = 192.168.1.255
printcap name = cups
load printers = yes
cups options = raw
printing = cups
guest account = smbguest
log file = /var/log/samba/samba.log
max log size = 1000
null passwords = no
username level = 6
password level = 6
encrypt passwords = yes
unix password sync = yes
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
local master = yes
domain master = yes
preferred master = yes
domain logons = yes
os level = 80
logon drive = z:
logon home = \%L\homes%u
logon path = \%L\profiles%u
logon script = %G.bat
time server = yes
name resolve order = wins lmhosts bcast
wins support = yes
wins proxy = yes
dns proxy = no
preserve case = yes
short preserve case = yes
client use spnego = no
client signing = no
client schannel = no
server signing = no
server schannel = no
nt pipe support = yes
nt status support = yes
allow trusted domains = no
obey pam restrictions = yes
enable spoolss = yes
client plaintext auth = no
disable netbios = no
follow symlinks = no
update encrypted = yes
pam password change = no
passwd chat timeout = 120
hostname lookups = no
username map = /etc/samba/smbusers
smb passwd file = /etc/samba/smbpasswd
passwd program = /usr/bin/passwd '%u’
passwd chat = Newpassword* %n\n ReTypenewpassword %n\n passwdchanged*\n
add user script = /usr/sbin/useradd -d /dev/null -c ‘Samba User Account’ -s /dev/null '%u’
add user to group script = /usr/sbin/useradd -d /dev/null -c ‘Samba User Account’ -s /dev/null -g ‘%g’ '%u’
add group script = /usr/sbin/groupadd '%g’
delete user script = /usr/sbin/userdel '%u’
delete user from group script = /usr/sbin/userdel ‘%u’ '%g’
delete group script = /usr/sbin/groupdel '%g’
add machine script = /usr/sbin/useradd -d /dev/null -g sambamachines -c ‘Samba Machine Account’ -s /dev/null -M '%u’
machine password timeout = 120
idmap uid = 16777216-33554431
idmap gid = 16777216-33554431
template shell = /dev/null
winbind use default domain = yes
winbind separator = @
winbind cache time = 360
winbind trusted domains only = yes
winbind nested groups = no
winbind nss info = no
winbind refresh tickets = no
winbind offline logon = no
[homes]
comment = Home Directories
path = /home
read only = no
available = yes
browseable = yes
writable = yes
guest ok = no
public = no
printable = no
share modes = no
locking = no
[netlogon]
comment = Network Logon Service
path = /home/netlogon
read only = no
available = yes
browseable = yes
writable = no
guest ok = no
public = no
printable = no
share modes = no
locking = no
[profiles]
comment = User Profiles
path = /var/samba/profiles
read only = no
available = yes
browseable = no
writable = yes
guest ok = no
public = no
printable = no
locking = no
create mode = 0600
directory mask = 0700
[printers]
comment = All Printers
path = /var/spool/samba
browseable = yes
writable = no
guest ok = no
public = no
printable = yes
share modes = no
locking = no
[pdf-documents]
path = /home/pdf-documents
comment = Converted PDF Documents
available = yes
browseable = yes
writeable = yes
guest ok = yes
[pdf-printer]
path = /tmp
comment = PDF Printer Service
printable = yes
guest ok = yes
use client driver = yes
printing = bsd
print command = /usr/bin/gadmin-samba-pdf %s %u
lpq command =
lprm command =
et mon DNS se trouverai sur ce serveur aussi, comme sous win server…
)[/quote]
