Je n’arrive qu’a copier la fin du message… le voici
[code]For further configuration of the driver, please run aticonfig from a terminal window or AMD CCC:LE from the Desktop Manager Menu.
System must be rebooted to avoid system instability and potential data loss.
See /usr/share/ati/fglrx-install.log for installation details.
Running post installer steps…
Updating your /etc/X11/xorg.conf file now…
Finalizing install…
Adding module fglrx… Added
Removing module drm… FAILED
Error removing drm module for pre-install cleanup operation.
Please investigate this further since it may make your fglrx driver install fail.
Congratulations! It looks like your new 12-8 fglrx driver installed successfully!
Your driver install is now finished. You have the following options:
start-desktop - All finished, (re-)start desktop now.
quit - Quit now, to do something else before starting your desktop.
- start-desktop
- quit
#? 2
Ok, exiting now, thanks for using this script.
==== Ok, you are done with the system upgrade. Hope it works. ====
Finalizing install…
- start-desktop
- quit
#? 2
