[Audio] NVIDIA Corporation GF106 High Definition Audio Controller - pas de son
Equipé depuis peu avec une carte son NVIDIA GF106, je n’arrive pas à obtenir de son sur ma debian 9.4.
# lspci -vv | grep -A 30 Audio
08:00.1 Audio device: NVIDIA Corporation GF106 High Definition Audio Controller (rev a1)
Subsystem: Hewlett-Packard Company GF106 High Definition Audio Controller
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 256 bytes
Interrupt: pin B routed to IRQ 45
Region 0: Memory at fbefc000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [60] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst+ PME-Enable+ DSel=0 DScale=0 PME-
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [78] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <4us, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 75.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <256ns, L1 <4us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM L0s L1 Enabled; RCB 128 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
Si vous avez une idée… merci !
passez par pulseaudio et pavucontrol pour régler les problèmes liés au son
#apt install pulseaudio pavucontrol
ouvrez pavucontrol et faire les réglages.
Déjà essayé… pulseaudio tourne en tâche de fond et pavucontrol m’indique en périphérique de sortie “Sortie factice” (aucune sortie hardware).
si vous avez un fichier audio ou video ouvrez le avec une application idoine; allez dans pavucontrol et voyez ce qui se passe sur l’onglet “lecture”; veillez que le son ne soit pas désactivé en utilisant la commande alsamixer.
Le son n’est pas muté. J’ai bien un signal en entrée sur pavucontrol, en sortie également sur la “sortie factice”.
essayez sur la sortie output devices
“aucun périphérique de sortie disponible”…
et en ouvrant l’onglet « lecture » en choisissant applications ou all streams?
Oui bien sûr… signal d’entrée OK (“all streams” ou “applications”), mais signal de sortie présent uniquement sur la virtual device dans les deux cas, et aucun signal sur “hardware output devices”, comme si pulseaudio ne détectait aucune carte son.
avec la commande alsamixer essayez de changer de carte son; vous en avez deux, la nvidia et celle de la carte mère; faut un peu bidouiller entre les deux cartes et pavucontrol
Déjà testé… :-/
Alsa voit “Nvidia GPU 11 HDMI/DP” et “PulseAudio” (qui correspond à la virtual device).
D’autre part je n’ai qu’une carte…
# aplay -l
carte 0: NVidia [HDA NVidia], périphérique 3: HDMI 0 [HDMI 0]
Sous-périphériques: 1/1
Sous-périphérique #0: subdevice #0
carte 0: NVidia [HDA NVidia], périphérique 7: HDMI 0 [HDMI 0]
carte 0: NVidia [HDA NVidia], périphérique 8: HDMI 0 [HDMI 0]
carte 0: NVidia [HDA NVidia], périphérique 9: HDMI 0 [HDMI 0]
vous êtes bien sur la sortie hdmi?
mais c’est un portable ou un fixe?
Que dit
cat /proc/asound/cards
Exemple
 0 [SB             ]: HDA-Intel - HDA ATI SB
                      HDA ATI SB at 0xf0500000 irq 16
J’ai fait exprès de masquer hdmi
cat /etc/modprobe.d/snd_hda_intel.conf
options snd_hda_intel model=auto
options snd_hda_intel enable=1,0
Les sorties de la carte sont en jack 3.5, si c’est la question…
C’est un fixe.
@grandtoubab
0 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xfbefc000 irq 45
quel pilote pour la carte nvidia, nouveau ou proprio?
pour lister le pilote
lspci -nnk | grep -i audio A2
# lsmod | grep snd_
snd_hda_codec_hdmi 49152 4
snd_hda_intel 36864 1
snd_hda_codec 135168 2 snd_hda_intel,snd_hda_codec_hdmi
snd_hda_core 86016 3 snd_hda_intel,snd_hda_codec,snd_hda_codec_hdmi
snd_hwdep 16384 1 snd_hda_codec
snd_pcm 110592 4 snd_hda_intel,snd_hda_codec,snd_hda_core,snd_hda_codec_hdmi
snd_timer 32768 1 snd_pcm
snd 86016 8 snd_hda_intel,snd_hwdep,snd_hda_codec,snd_timer,snd_hda_codec_hdmi,snd_pcm
# lspci -nnk | grep -i audio
08:00.1 Audio device [0403]: NVIDIA Corporation GF106 High Definition Audio Controller [10de:0be9] (rev a1)
Subsystem: Hewlett-Packard Company GF106 High Definition Audio Controller [103c:084a]
manque le -A2 pour vérifier le pilote choisi
Exemple
lspci -nnk | grep -i audio -A2
00:14.2 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 Azalia (Intel HDA) [1002:4383] (rev 40)
_ Subsystem: Hewlett-Packard Compa_ny SBx00 Azalia (Intel HDA) [103c:1443]
Oups…
# lspci -nnk | grep -i audio -A2
Avec le noyau 4.16 ça donne ça
 modinfo snd_hda_intel
filename:       /lib/modules/4.16.0-2-amd64/kernel/sound/pci/hda/snd-hda-intel.ko
description:    Intel HDA driver
license:        GPL
alias:          pci:v00001022d*sv*sd*bc04sc03i00*
alias:          pci:v00001002d*sv*sd*bc04sc03i00*
alias:          pci:v000015ADd00001977sv*sd*bc*sc*i*
alias:          pci:v000017F3d00003010sv*sd*bc*sc*i*
alias:          pci:v000013F6d00005011sv*sd*bc*sc*i*
alias:          pci:v00001102d00000009sv*sd*bc*sc*i*
alias:          pci:v00001102d00000012sv*sd*bc*sc*i*
alias:          pci:v00001102d00000010sv*sd*bc*sc*i*
alias:          pci:v00006549d00002200sv*sd*bc*sc*i*
alias:          pci:v00006549d00001200sv*sd*bc*sc*i*
alias:          pci:v000010DEd*sv*sd*bc04sc03i00*
alias:          pci:v000010B9d00005461sv*sd*bc*sc*i*
alias:          pci:v00001039d00007502sv*sd*bc*sc*i*
alias:          pci:v00001106d00009140sv*sd*bc*sc*i*
alias:          pci:v00001106d00009170sv*sd*bc*sc*i*
alias:          pci:v00001106d00003288sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AAF0sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AAE0sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AAE8sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AAD8sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AAC8sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AAC0sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AAB0sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AAA8sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AAA0sv*sd*bc*sc*i*
alias:          pci:v00001002d00009902sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA98sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA90sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA88sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA80sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA68sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA60sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA58sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA50sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA48sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA40sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA38sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA30sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA28sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA20sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA18sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA10sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA08sv*sd*bc*sc*i*
alias:          pci:v00001002d0000AA00sv*sd*bc*sc*i*
alias:          pci:v00001002d00009840sv*sd*bc*sc*i*
alias:          pci:v00001002d0000970Fsv*sd*bc*sc*i*
alias:          pci:v00001002d0000960Fsv*sd*bc*sc*i*
alias:          pci:v00001002d00007919sv*sd*bc*sc*i*
alias:          pci:v00001002d0000793Bsv*sd*bc*sc*i*
alias:          pci:v00001002d000015B3sv*sd*bc*sc*i*
alias:          pci:v00001002d0000157Asv*sd*bc*sc*i*
alias:          pci:v00001002d00001308sv*sd*bc*sc*i*
alias:          pci:v00001002d00000002sv*sd*bc*sc*i*
alias:          pci:v00001022d000015E3sv*sd*bc*sc*i*
alias:          pci:v00001022d0000780Dsv*sd*bc*sc*i*
alias:          pci:v00001002d00004383sv*sd*bc*sc*i*
alias:          pci:v00001002d0000437Bsv*sd*bc*sc*i*
alias:          pci:v00008086d*sv*sd*bc04sc03i00*
alias:          pci:v00008086d00003A6Esv*sd*bc*sc*i*
alias:          pci:v00008086d00003A3Esv*sd*bc*sc*i*
alias:          pci:v00008086d0000293Fsv*sd*bc*sc*i*
alias:          pci:v00008086d0000293Esv*sd*bc*sc*i*
alias:          pci:v00008086d0000284Bsv*sd*bc*sc*i*
alias:          pci:v00008086d0000269Asv*sd*bc*sc*i*
alias:          pci:v00008086d000027D8sv*sd*bc*sc*i*
alias:          pci:v00008086d00002668sv*sd*bc*sc*i*
alias:          pci:v00008086d00002284sv*sd*bc*sc*i*
alias:          pci:v00008086d00000F04sv*sd*bc*sc*i*
alias:          pci:v00008086d0000080Asv*sd*bc*sc*i*
alias:          pci:v00008086d0000811Bsv*sd*bc*sc*i*
alias:          pci:v00008086d00003B56sv*sd*bc*sc*i*
alias:          pci:v00008086d0000160Csv*sd*bc*sc*i*
alias:          pci:v00008086d00000D0Csv*sd*bc*sc*i*
alias:          pci:v00008086d00000C0Csv*sd*bc*sc*i*
alias:          pci:v00008086d00000A0Csv*sd*bc*sc*i*
alias:          pci:v00008086d00003198sv*sd*bc*sc*i*
alias:          pci:v00008086d00001A98sv*sd*bc*sc*i*
alias:          pci:v00008086d00005A98sv*sd*bc*sc*i*
alias:          pci:v00008086d00009DC8sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A348sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A2F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00009D71sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A171sv*sd*bc*sc*i*
alias:          pci:v00008086d00009D70sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A170sv*sd*bc*sc*i*
alias:          pci:v00008086d00009CA0sv*sd*bc*sc*i*
alias:          pci:v00008086d00009C21sv*sd*bc*sc*i*
alias:          pci:v00008086d00009C20sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A270sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A1F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00008D21sv*sd*bc*sc*i*
alias:          pci:v00008086d00008D20sv*sd*bc*sc*i*
alias:          pci:v00008086d00008CA0sv*sd*bc*sc*i*
alias:          pci:v00008086d00008C20sv*sd*bc*sc*i*
alias:          pci:v00008086d00001E20sv*sd*bc*sc*i*
alias:          pci:v00008086d00001D20sv*sd*bc*sc*i*
alias:          pci:v00008086d00001C20sv*sd*bc*sc*i*
depends:        snd-hda-core,snd-hda-codec,snd-pcm,snd
retpoline:      Y
intree:         Y
vermagic:       4.16.0-2-amd64 SMP mod_unload modversions
parm:           index:Index value for Intel HD audio interface. (array of int)
parm:           id:ID string for Intel HD audio interface. (array of charp)
parm:           enable:Enable Intel HD audio interface. (array of bool)
parm:           model:Use the given board model. (array of charp)
parm:           position_fix:DMA pointer read method.(-1 = system default, 0 = auto, 1 = LPIB, 2 = POSBUF, 3 = VIACOMBO, 4 = COMBO, 5 = SKL+). (array of int)
parm:           bdl_pos_adj:BDL position adjustment offset. (array of int)
parm:           probe_mask:Bitmask to probe codecs (default = -1). (array of int)
parm:           probe_only:Only probing and no codec initialization. (array of int)
parm:           jackpoll_ms:Ms between polling for jack events (default = 0, using unsol events only) (array of int)
parm:           single_cmd:Use single command to communicate with codecs (for debugging only). (bint)
parm:           enable_msi:Enable Message Signaled Interrupt (MSI) (bint)
parm:           patch:Patch file for Intel HD audio interface. (array of charp)
parm:           beep_mode:Select HDA Beep registration mode (0=off, 1=on) (default=1). (array of bool)
parm:           power_save:Automatic power-saving timeout (in second, 0 = disable). (xint)
parm:           pm_blacklist:Enable power-management blacklist (bool)
parm:           power_save_controller:Reset controller in power save mode. (bool)
parm:           align_buffer_size:Force buffer and period sizes to be multiple of 128 bytes. (bint)
parm:           snoop:Enable/disable snooping (bint)
