La buse…
Excuse moi je fais 50.000 trucs en même temps…
[code]# ./temporoot2 m
/dev/sda1 /boot boot
/dev/sda5 /mnt/sda5 sda5
/dev/sdb1 /mnt/sdb1 sdb1
/dev/sda6 /mnt/sda6 sda6
/dev/sda9 /mnt/sda9 sda9
mount: wrong fs type, bad option, bad superblock on aufs,
missing codepage or helper program, or other error
(for several filesystems (e.g. nfs, cifs) you might
need a /sbin/mount. helper program)
In some cases useful info is found in syslog - try
dmesg | tail or so
/dev/sda8 /home home
Faites chroot /mnt/sda9/tempo/mnt[/code]
# mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,relatime,size=10240k,nr_inodes=1023071,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=819716k,mode=755)
/dev/disk/by-uuid/dab4cb26-1298-47d3-b52e-c8610cc32872 on / type btrfs (rw,relatime,space_cache)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /run/shm type tmpfs (rw,nosuid,nodev,noexec,relatime,size=3278040k)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
/dev/sda1 on /boot type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
/dev/sda5 on /mnt/sda5 type ext4 (rw,relatime,user_xattr,barrier=1,data=ordered)
/dev/sdb1 on /mnt/sdb1 type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
/dev/sda6 on /mnt/sda6 type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
/dev/sda9 on /mnt/sda9 type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
/dev/sda8 on /home type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
/dev/sda3 on /mnt/sda9/tempo/M_ROOT type btrfs (rw,relatime,space_cache)
aufs on /mnt/sda9/tempo/mnt type aufs (rw,relatime,si=58b7b803bc80ca09)
/dev/sda1 on /mnt/sda9/tempo/M_boot type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
aufs on /mnt/sda9/tempo/mnt/boot type aufs (rw,relatime,si=58b7b8030a526209)
/dev/sda5 on /mnt/sda9/tempo/M_sda5 type ext4 (rw,relatime,user_xattr,barrier=1,data=ordered)
aufs on /mnt/sda9/tempo/mnt/mnt/sda5 type aufs (rw,relatime,si=58b7b802d2ae4209)
/dev/sdb1 on /mnt/sda9/tempo/M_sdb1 type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
aufs on /mnt/sda9/tempo/mnt/mnt/sdb1 type aufs (rw,relatime,si=58b7b803dd7f3209)
/dev/sda6 on /mnt/sda9/tempo/M_sda6 type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
aufs on /mnt/sda9/tempo/mnt/mnt/sda6 type aufs (rw,relatime,si=58b7b80381fc4209)
/dev/sda9 on /mnt/sda9/tempo/M_sda9 type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
/dev/sda8 on /mnt/sda9/tempo/M_home type ext4 (rw,relatime,user_xattr,acl,barrier=1,data=ordered)
aufs on /mnt/sda9/tempo/mnt/home type aufs (rw,relatime,si=58b7b802d2ae3609)
Ça m’a l’air parfait (fake commenté…)
