Salut à tous !
Au fait, donner le contenu de « /var/log/Xorg.0.log », ça fait partie des choses qui se font :
X.Org X Server 1.7.7
Release Date: 2010-05-04
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.0.0-1-amd64 x86_64 Debian
Current Operating System: Linux galmax 3.2.0-0.bpo.2-rt-amd64 #1 SMP PREEMPT RT Mon Apr 23 09:31:04 UTC 2012 x86_64
Kernel command line: BOOT_IMAGE=/vmlinuz-3.2.0-0.bpo.2-rt-amd64 root=/dev/mapper/base-root ro quiet
Build Date: 29 October 2011 06:58:14PM
xorg-server 2:1.7.7-14 (Julien Cristau <jcristau@debian.org>)
Current version of pixman: 0.16.4
Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Mon May 28 15:35:04 2012
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(==) ServerLayout "aticonfig Layout"
(**) |-->Screen "aticonfig-Screen[0]-0" (0)
(**) | |-->Monitor "aticonfig-Monitor[0]-0"
(**) | |-->Device "aticonfig-Device[0]-0"
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
(II) Loader magic: 0x7c8a40
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(++) using VT number 8
(--) PCI:*(0:4:0:0) 1002:68e1:0000:0000 ATI Technologies Inc Manhattan [Mobility Radeon HD 5430 Series] rev 0, Mem @ 0xe0000000/268435456, 0xfbec0000/131072, I/O @ 0x0000ee00/256, BIOS @ 0x????????/131072
(II) Open ACPI successful (/var/run/acpid.socket)
(II) "extmod" will be loaded by default.
(II) "dbe" will be loaded by default.
(II) "glx" will be loaded by default.
(II) "record" will be loaded by default.
(II) "dri" will be loaded by default.
(II) "dri2" will be loaded by default.
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/linux/libglx.so
(II) Module glx: vendor="Advanced Micro Devices, Inc."
compiled for 6.9.0, module version = 1.0.0
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "fglrx"
(II) Loading /usr/lib/xorg/modules/drivers/fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 1.4.99.906, module version = 8.95.3
Module class: X.Org Video Driver
(II) Loading sub module "fglrxdrm"
(II) LoadModule: "fglrxdrm"
(II) Loading /usr/lib/xorg/modules/linux/libfglrxdrm.so
(II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
(II) ATI Proprietary Linux Driver Version Identifier:8.95.3
(II) ATI Proprietary Linux Driver Release Identifier: 8.951
(II) ATI Proprietary Linux Driver Build Date: Mar 8 2012 23:06:45
(II) Primary Device is: PCI 04@00:00:0
(WW) Falling back to old probe method for fglrx
(II) Loading PCS database from /etc/ati/amdpcsdb
(--) Chipset Supported AMD Graphics Processor (0x68E1) found
(WW) fglrx: No matching Device section for instance (BusID PCI:0@4:0:1) found
(II) AMD Video driver is running on the exact device targeted for this release
(II) AMD Video driver is signed
(II) fglrx(0): pEnt->device->identifier=0xadad10
(II) fglrx(0): === [xdl_x750_atiddxPreInit] === begin
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules/libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 0.1.0
ABI class: X.Org Video Driver, version 6.0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "DPMS" "true"
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB
(==) fglrx(0): Buffer Tiling is ON
(II) Reloading /usr/lib/xorg/modules/linux/libfglrxdrm.so
ukiDynamicMajor: failed to open /proc/ati/major
(**) fglrx(0): NoAccel = NO
(**) fglrx(0): ATI 2D Acceleration Architecture enabled
(--) fglrx(0): Chipset: "ATI Mobility Radeon HD 5400 Series" (Chipset = 0x68e1)
(--) fglrx(0): (PciSubVendor = 0x0000, PciSubDevice = 0x0000)
(==) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
(--) fglrx(0): Linear framebuffer (phys) at 0xe0000000
(--) fglrx(0): MMIO registers at 0xfbec0000
(--) fglrx(0): I/O port at 0x0000ee00
(==) fglrx(0): ROM-BIOS at 0x000c0000
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(II) Loading sub module "vbe"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
(II) fglrx(0): VESA BIOS detected
(II) fglrx(0): VESA VBE Version 3.0
(II) fglrx(0): VESA VBE Total Mem: 16384 kB
(II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS
(II) fglrx(0): VESA VBE OEM Software Rev: 12.20
(II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2005, ATI Technologies Inc.
(II) fglrx(0): VESA VBE OEM Product: XX
(II) fglrx(0): VESA VBE OEM Product Rev: 01.00
(II) fglrx(0): ATI Video BIOS revision 9 or later detected
(--) fglrx(0): Video RAM: 524288 kByte, Type: DDR3
(II) fglrx(0): PCIE card detected
(--) fglrx(0): Using per-process page tables (PPPT) as GART.
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(WW) fglrx(0): Hasn't establisted DRM connection
(II) fglrx(0): [FB] MC range(MCFBBase = 0xf00000000, MCFBSize = 0x20000000)
(WW) fglrx(0): No DRM connection for driver fglrx.
(II) fglrx(0): RandR 1.2 support is enabled!
(II) fglrx(0): RandR 1.2 rotation support is enabled!
(==) fglrx(0): Center Mode is disabled
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Module "ddc" already built-in
(II) fglrx(0): Output DFP1 using monitor section aticonfig-Monitor[0]-0
(II) fglrx(0): Output DFP2 has no monitor section
(II) fglrx(0): Output CRT1 has no monitor section
(II) fglrx(0): Output CRT2 has no monitor section
(II) fglrx(0): Connected Display0: DFP2
(II) fglrx(0): Display0 EDID data ---------------------------
(II) fglrx(0): Manufacturer: SAM Model: 570 Serial#: 1314271795
(II) fglrx(0): Year: 2010 Week: 18
(II) fglrx(0): EDID Version: 1.3
(II) fglrx(0): Digital Display Input
(II) fglrx(0): Max Image Size [cm]: horiz.: 51 vert.: 29
(II) fglrx(0): Gamma: 2.20
(II) fglrx(0): DPMS capabilities: Off
(II) fglrx(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
(II) fglrx(0): First detailed timing is preferred mode
(II) fglrx(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
(II) fglrx(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329
(II) fglrx(0): Supported established timings:
(II) fglrx(0): 720x400@70Hz
(II) fglrx(0): 640x480@60Hz
(II) fglrx(0): 640x480@67Hz
(II) fglrx(0): 640x480@72Hz
(II) fglrx(0): 640x480@75Hz
(II) fglrx(0): 800x600@56Hz
(II) fglrx(0): 800x600@60Hz
(II) fglrx(0): 800x600@72Hz
(II) fglrx(0): 800x600@75Hz
(II) fglrx(0): 832x624@75Hz
(II) fglrx(0): 1024x768@60Hz
(II) fglrx(0): 1024x768@70Hz
(II) fglrx(0): 1024x768@75Hz
(II) fglrx(0): 1280x1024@75Hz
(II) fglrx(0): 1152x864@75Hz
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported standard timings:
(II) fglrx(0): #0: hsize: 1280 vsize 800 refresh: 60 vid: 129
(II) fglrx(0): #1: hsize: 1280 vsize 960 refresh: 60 vid: 16513
(II) fglrx(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) fglrx(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
(II) fglrx(0): #4: hsize: 1680 vsize 1050 refresh: 60 vid: 179
(II) fglrx(0): #5: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
(II) fglrx(0): #6: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) fglrx(0): Supported detailed timing:
(II) fglrx(0): clock: 148.5 MHz Image Size: 510 x 287 mm
(II) fglrx(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
(II) fglrx(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
(II) fglrx(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 81 kHz, PixClock max 175 MHz
(II) fglrx(0): Monitor name: SyncMaster
(II) fglrx(0): Serial No: HVMZ500544
(II) fglrx(0): Number of EDID sections to follow: 1
(II) fglrx(0): EDID (in hex):
(II) fglrx(0): 00ffffffffffff004c2d70053332564e
(II) fglrx(0): 1214010380331d782aee91a3544c9926
(II) fglrx(0): 0f5054bfef808100814081809500b300
(II) fglrx(0): a940714f0101023a801871382d40582c
(II) fglrx(0): 4500fe1f1100001e000000fd00384b1e
(II) fglrx(0): 5111000a202020202020000000fc0053
(II) fglrx(0): 796e634d61737465720a2020000000ff
(II) fglrx(0): 0048564d5a3530303534340a20200102
(II) fglrx(0): End of Display0 EDID data --------------------
(II) fglrx(0): EDID for output DFP1
(II) fglrx(0): EDID for output DFP2
(II) fglrx(0): Printing probed modes for output DFP2
(II) fglrx(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz)
(II) fglrx(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz)
(II) fglrx(0): Modeline "1776x1000"x50.0 148.50 1776 2304 2348 2640 1000 1004 1009 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "1680x1050"x50.0 148.50 1680 2448 2492 2640 1050 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz)
(II) fglrx(0): Modeline "1400x1050"x60.0 162.00 1400 1664 1856 2160 1050 1201 1204 1250 +hsync +vsync (75.0 kHz)
(II) fglrx(0): Modeline "1400x1050"x50.0 148.50 1400 2448 2492 2640 1050 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "1600x900"x60.0 162.00 1600 1664 1856 2160 900 1201 1204 1250 +hsync +vsync (75.0 kHz)
(II) fglrx(0): Modeline "1600x900"x50.0 148.50 1600 2448 2492 2640 900 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "1280x1024"x50.0 148.50 1280 2448 2492 2640 1024 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
(II) fglrx(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(II) fglrx(0): Modeline "1440x900"x50.0 148.50 1440 2448 2492 2640 900 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "1440x900"x60.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz)
(II) fglrx(0): Modeline "1280x960"x50.0 148.50 1280 2448 2492 2640 960 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz)
(II) fglrx(0): Modeline "1280x800"x50.0 148.50 1280 2448 2492 2640 800 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "1280x800"x60.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz)
(II) fglrx(0): Modeline "1152x864"x60.0 148.50 1152 2008 2052 2200 864 1084 1089 1125 +hsync +vsync (67.5 kHz)
(II) fglrx(0): Modeline "1152x864"x50.0 148.50 1152 2448 2492 2640 864 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
(II) fglrx(0): Modeline "1280x768"x50.0 148.50 1280 2448 2492 2640 768 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "1280x768"x60.0 83.50 1280 1352 1480 1680 768 803 809 831 -hsync +vsync (49.7 kHz)
(II) fglrx(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz)
(II) fglrx(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz)
(II) fglrx(0): Modeline "1024x768"x50.0 148.50 1024 2448 2492 2640 768 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(II) fglrx(0): Modeline "1024x768"x70.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(II) fglrx(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) fglrx(0): Modeline "1152x648"x50.0 74.25 1152 1592 1632 1980 648 653 658 750 +hsync +vsync (37.5 kHz)
(II) fglrx(0): Modeline "1024x600"x50.0 148.50 1024 2448 2492 2640 600 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "1024x600"x75.0 78.75 1024 1040 1136 1312 600 769 772 800 +hsync +vsync (60.0 kHz)
(II) fglrx(0): Modeline "1024x600"x70.0 75.00 1024 1048 1184 1328 600 771 777 806 -hsync -vsync (56.5 kHz)
(II) fglrx(0): Modeline "1024x600"x60.0 65.00 1024 1048 1184 1344 600 771 777 806 -hsync -vsync (48.4 kHz)
(II) fglrx(0): Modeline "800x600"x50.0 148.50 800 2448 2492 2640 600 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "800x600"x72.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(II) fglrx(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) fglrx(0): Modeline "800x600"x60.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) fglrx(0): Modeline "800x600"x56.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) fglrx(0): Modeline "720x576"x60.0 148.50 720 2008 2052 2200 576 1084 1089 1125 +hsync +vsync (67.5 kHz)
(II) fglrx(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz)
(II) fglrx(0): Modeline "800x480"x50.0 148.50 800 2448 2492 2640 480 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "800x480"x72.0 50.00 800 856 976 1040 480 637 643 666 +hsync +vsync (48.1 kHz)
(II) fglrx(0): Modeline "800x480"x75.0 49.50 800 816 896 1056 480 601 604 625 +hsync +vsync (46.9 kHz)
(II) fglrx(0): Modeline "800x480"x60.0 40.00 800 840 968 1056 480 601 605 628 +hsync +vsync (37.9 kHz)
(II) fglrx(0): Modeline "800x480"x56.0 36.00 800 824 896 1024 480 601 603 625 +hsync +vsync (35.2 kHz)
(II) fglrx(0): Modeline "720x480"x50.0 148.50 720 2448 2492 2640 480 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz)
(II) fglrx(0): Modeline "640x480"x50.0 148.50 640 2448 2492 2640 480 1084 1089 1125 +hsync +vsync (56.2 kHz)
(II) fglrx(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) fglrx(0): Modeline "640x480"x72.0 31.50 640 656 696 832 480 481 484 520 -hsync -vsync (37.9 kHz)
(II) fglrx(0): Modeline "640x480"x67.0 27.28 640 664 728 816 480 481 484 499 -hsync +vsync (33.4 kHz)
(II) fglrx(0): Modeline "640x480"x60.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) fglrx(0): EDID for output CRT1
(II) fglrx(0): EDID for output CRT2
(II) fglrx(0): Output DFP1 disconnected
(II) fglrx(0): Output DFP2 connected
(II) fglrx(0): Output CRT1 disconnected
(II) fglrx(0): Output CRT2 disconnected
(II) fglrx(0): Using exact sizes for initial modes
(II) fglrx(0): Output DFP2 using initial mode 1920x1080
(II) fglrx(0): DPI set to (96, 96)
(II) fglrx(0): Eyefinity capable adapter detected.
(II) fglrx(0): Adapter ATI Mobility Radeon HD 5400 Series has 4 configurable heads and 1 displays connected.
(==) fglrx(0): PseudoColor visuals disabled
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Module "ramdac" already built-in
(==) fglrx(0): NoDRI = NO
(==) fglrx(0): Capabilities: 0x00000000
(==) fglrx(0): CapabilitiesEx: 0x00000000
(==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
(==) fglrx(0): UseFastTLS=0
(==) fglrx(0): BlockSignalsOnLock=1
(--) Depth 24 pixmap format is 32 bpp
(EE) fglrx(0): atiddxDriScreenInit failed, GPS not been initialized.
(WW) fglrx(0): ***********************************************************
(WW) fglrx(0): * DRI initialization failed *
(WW) fglrx(0): * kernel module (fglrx.ko) may be missing or incompatible *
(WW) fglrx(0): * 2D and 3D acceleration disabled *
(II) fglrx(0): FBADPhys: 0xf00000000 FBMappedSize: 0x10000000
(II) fglrx(0): FBMM initialized for area (0,0)-(1920,8191)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(1920,1920) (front color buffer - assumption)
(II) fglrx(0): Largest offscreen area available: 1920 x 6271
(==) fglrx(0): Backing store disabled
(II) Loading extension FGLRXEXTENSION
(**) fglrx(0): DPMS enabled
(II) fglrx(0): Initialized in-driver Xinerama extension
(WW) fglrx(0): Textured Video not supported without DRI enabled.
(II) LoadModule: "glesx"
(II) Loading /usr/lib/xorg/modules/glesx.so
(II) Module glesx: vendor="X.Org Foundation"
compiled for 1.4.99.906, module version = 1.0.0
(II) Loading extension GLESX
(II) fglrx(0): GLESX enableFlags = 576
(II) LoadModule: "amdxmm"
(II) Loading /usr/lib/xorg/modules/amdxmm.so
(II) Module amdxmm: vendor="X.Org Foundation"
compiled for 1.4.99.906, module version = 2.0.0
(EE) fglrx(0): XMM failed to open CMMQS connection.(EE) fglrx(0):
(EE) fglrx(0): XMM failed to initialize
(WW) fglrx(0): No XV video playback available
(II) fglrx(0): Enable composite support successfully
(WW) fglrx(0): Option "VendorName" is not used
(WW) fglrx(0): Option "ModelName" is not used
(==) fglrx(0): Silken mouse enabled
(==) fglrx(0): Using HW cursor of display infrastructure!
(II) fglrx(0): Disabling in-server RandR and enabling in-driver RandR 1.2.
(--) RandR disabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
SELinux: Disabled on system, not enabling in X server
(II) AIGLX: Screen 0 is not DRI capable
[glesx] __glESXExtensionInit: No GL ES2.0 capable screen found!
(II) fglrx(0): Setting screen physical size to 508 x 285
(II) config/udev: Adding input device Power Button (/dev/input/event5)
(**) Power Button: Applying InputClass "evdev keyboard catchall"
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 2.3.2
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 7.0
(**) Power Button: always reports core events
(**) Power Button: Device: "/dev/input/event5"
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "pc105"
(**) Option "xkb_layout" "fr"
(**) Option "xkb_variant" "latin9"
(II) config/udev: Adding input device Power Button (/dev/input/event4)
(**) Power Button: Device: "/dev/input/event4"
(II) config/udev: Adding input device Logitech USB Laser Mouse (/dev/input/event0)
(**) Logitech USB Laser Mouse: Applying InputClass "evdev pointer catchall"
(**) Logitech USB Laser Mouse: always reports core events
(**) Logitech USB Laser Mouse: Device: "/dev/input/event0"
(II) Logitech USB Laser Mouse: Found 12 mouse buttons
(II) Logitech USB Laser Mouse: Found scroll wheel(s)
(II) Logitech USB Laser Mouse: Found relative axes
(II) Logitech USB Laser Mouse: Found x and y relative axes
(II) Logitech USB Laser Mouse: Configuring as mouse
(**) Logitech USB Laser Mouse: YAxisMapping: buttons 4 and 5
(**) Logitech USB Laser Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "Logitech USB Laser Mouse" (type: MOUSE)
(II) Logitech USB Laser Mouse: initialized for relative axes.
(II) config/udev: Adding input device Logitech USB Laser Mouse (/dev/input/mouse0)
(II) No input driver/identifier specified (ignoring)
(II) config/udev: Adding input device Logitech HID compliant keyboard (/dev/input/event1)
(**) Logitech HID compliant keyboard: Applying InputClass "evdev keyboard catchall"
(**) Logitech HID compliant keyboard: always reports core events
(**) Logitech HID compliant keyboard: Device: "/dev/input/event1"
(II) Logitech HID compliant keyboard: Found keys
(II) Logitech HID compliant keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device "Logitech HID compliant keyboard" (type: KEYBOARD)
(II) config/udev: Adding input device Logitech HID compliant keyboard (/dev/input/event2)
(**) Logitech HID compliant keyboard: Device: "/dev/input/event2"
(II) Logitech HID compliant keyboard: Found 20 mouse buttons
(II) Logitech HID compliant keyboard: Configuring as mouse
(**) Logitech HID compliant keyboard: YAxisMapping: buttons 4 and 5
(**) Logitech HID compliant keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) config/udev: Adding input device UVC Camera (046d:081d) (/dev/input/event6)
(**) UVC Camera (046d:081d): Applying InputClass "evdev keyboard catchall"
(**) UVC Camera (046d:081d): always reports core events
(**) UVC Camera (046d:081d): Device: "/dev/input/event6"
(II) UVC Camera (046d:081d): Found keys
(II) UVC Camera (046d:081d): Configuring as keyboard
(II) XINPUT: Adding extended input device "UVC Camera (046d:081d)" (type: KEYBOARD)
(II) config/udev: Adding input device HDA Intel Headphone (/dev/input/event7)
(II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event8)
(II) config/udev: Adding input device PC Speaker (/dev/input/event3)
(II) fglrx(0): Restoring Recent Mode via PCS is not supported in RANDR 1.2 capable environments
(II) fglrx(0): EDID vendor "SAM", prod id 1392
(II) fglrx(0): Using EDID range info for horizontal sync
(II) fglrx(0): Using EDID range info for vertical refresh
(II) fglrx(0): Printing DDC gathered Modelines:
(II) fglrx(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz)
(II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) fglrx(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) fglrx(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
(II) fglrx(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
(II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
(II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
(II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(II) fglrx(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) fglrx(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) fglrx(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
(II) fglrx(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz)
(II) fglrx(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz)
(II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(II) fglrx(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz)
(II) fglrx(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz)
(II) fglrx(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz)
(II) fglrx(0): Using hsync ranges from config file
(II) fglrx(0): Using vrefresh ranges from config file
Personnellement, je n’en tire pas plus d’information, mais je trouve tout de même ce passage intéressant :
À bientôt.
Le Farfadet Spatial
