Debian qui freeze sauf la souris Oo
Bonjour à tous & toutes,
Tout d’abord je vais mettre les infos dont on parle dans le post “Avant de poster” ^^
[quote]Linux Debian 2.6.26-2-amd64 #1 SMP Tue Mar 9 22:29:32 UTC 2010 x86_64 GNU/Linux
Niveau processeur il s’agit d’un intel E8500 si j’ai bonne mémoire ^^
[quote]Debian:~# lspci
00:00.0 Host bridge: Intel Corporation 82G33/G31/P35/P31 Express DRAM Controller (rev 02)
00:01.0 PCI bridge: Intel Corporation 82G33/G31/P35/P31 Express PCI Express Root Port (rev 02)
00:1a.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 02)
00:1a.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 02)
00:1a.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 02)
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 02)
00:1c.4 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 5 (rev 02)
00:1c.5 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 6 (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 92)
00:1f.0 ISA bridge: Intel Corporation 82801IR (ICH9R) LPC Interface Controller (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801IR/IO/IH (ICH9R/DO/DH) 4 port SATA IDE Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 02)
00:1f.5 IDE interface: Intel Corporation 82801I (ICH9 Family) 2 port SATA IDE Controller (rev 02)
01:00.0 VGA compatible controller: ATI Technologies Inc RV770 [Radeon HD 4850]
01:00.1 Audio device: ATI Technologies Inc HD48x0 audio
03:00.0 IDE interface: Marvell Technology Group Ltd. 88SE6121 SATA II Controller (rev b1)
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 01)
05:02.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306 Fire II IEEE 1394 OHCI Link Layer Controller (rev c0)
Bref :slight_smile: Après ces quotes pour le moins assez barbares, je vais en venir à mon problème…
Depuis ma ré-install de ma debian, celle ci se “freeze” a un moment donné (souvent c’est qu’en j’essai de faire un truc sans l’avoir touchée depuis… un certain temps assez variable). Que ca soit lancer un logiciel, ouvrir nautilus ou autre… bzz freezé !
Sauf que ma souris est toujours mobile je peux cliquer mais ça n’a aucun effet.
J’avais lancé un TOP avant que ca freeze la dernière fois et aucun process ne semble utiliser mon proc ou ma ram a 100% (pour tout dire rien ne semblait l’utiliser à plus de 3% à ce moment là.
Petit détail, le “top” continuait de se rafraichir malgré le PC figé.
Si ça peut vous aider, j’ai pas mal galeré à installer ma carte graph qui est une ATI HD4850
Je me suis servis de nombreux tuto sur le net pour y arriver (entre les écrans noirs et les résolutions defaillantes…)
J’vous met mon xorg.conf des fois que ça serai lié :
[code]# xorg.conf (X.Org X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
Identifier "aticonfig Layout"
Screen 0 “aticonfig-Screen[0]-0” 0 0
EndSection
Section "Files"
EndSection
Section "Module"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
Option “XkbOptions” "lv3:ralt_switch"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]-0"
Option “VendorName” "ATI Proprietary Driver"
Option “ModelName” "Generic Autodetecting Monitor"
Option “DPMS” "true"
EndSection
Section "Device"
Identifier "Configured Video Device"
Option “UseFBDev” "true"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-0"
Driver "fglrx"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]-0"
Device "aticonfig-Device[0]-0"
Monitor "aticonfig-Monitor[0]-0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
EndSubSection
EndSection [/code]
J’espère trouver ici une réponse qui pourrai me sortir de ce petit problème… en espérant que le soucis n’est pas matériel.
Merci de m’avoir lu et merci d’avance pour l’aide que vous pourrez m’apporter,
Bonne journée :slight_smile:
Leank
Tu as compiz-fusion qui tourne ?
Ou plus globalement, est ce que ca freeze lorsque tu as des applis openGL qui tournent (genre un économiseur d’écran) ?
T’as une lenny (d’après la version de ton noyau qui commence à dater) ?
:006
Ca me fait penser que j’a un problème similaire (j’avais la flemme de poster).
J’ai un portable avec un ati 3650HD. Quand je le sors de d’une mis en veille, plus rien de répond sauf la souris. J’arrive à cliquer sur les éléments du bureau mais rien ne s’ouvre.
Si je tue X, le bureau disparait sauf l’ecran de fond et ça ne va pas plus loin. J’ai toujours la souris qui bouge mais je ne peux rien faire d’autre que de rebooter sauvage.
J’utilise aussi fglrx.
Leank, c’est un fixe ou portable? Peut qu’il se met en veille qd tu ne le touches pas.
Je ne suis pas devant la machine là donc pour l’ecran de veille a vérifier mais je suis quasi sûr de l’avoir désactivé.
Je n’ai pas installé compiz fusion ou autre interface toute jolie :slight_smile:
Oui j’ai une Lenny téléchargée y’a moins d’une semaine sur le site de Debian :slight_smile:
C’est un PC fixe :slight_smile:
On a parfois ce genre de freeze quand une barrette mémoire est entrain de rendre l’âme.
Tenter un test de la mémoire d’une petite heure ou plus ne coûte rien :wink:
[quote=“Leank”]Je ne suis pas devant la machine là donc pour l’ecran de veille a vérifier mais je suis quasi sûr de l’avoir désactivé.
C’est un PC fixe :)[/quote]
OK, ca n’est donc probablement pas le même problème que moi.
[quote=“ggoodluck47”]Salut,
Tenter un test de la mémoire d’une petite heure ou plus ne coûte rien :wink:[/quote]
Bien je tenterai ça dans la semaine (a mon avis en rentrant ce soir j’aurai pas l’envie ^^)
Je vous tiendrai au courant du résultat (que ca vienne de ça ou non).
Merci pour vos réponses :slight_smile:
Le test de la RAM est en cours, depuis 2h, j’en suis à 3 “pass” avec 0 “errors”
Je le laisse encore tourner, selon vous il faudrait le laisser combien de temps pour que ça soit fiable comme test ?
(2GO ddr2-400, de la corsair, sensé être fiable non ? )
Perso, je pense qu’une mémoire défectueuse freezerait complètement le système
Je pense aussi mais j’préfère tester, ca ne coute rien :slight_smile:
Je crois d’ailleurs que ca frizais pas avant l’install de ma carte graph ( pas vraiment pu bien tester ^^)
A mon avis le problème serai plus lié à ca:)
Mais je laisse tourner le test, ca me coute rien :slight_smile:
pas forcement ca peu freezer comme ca peu ne pas vouloir demarrer le systeme … :mrgreen:
J’aime bien la théorie de la carte graphique ! C’est assez dans leurs cordes et ce quelle que soit la marque :slightly_smiling:
J’aime bien la théorie de la carte graphique ! C’est assez dans leurs cordes et ce quelle que soit la marque :slightly_smiling:[/quote]
chaque fois que je re installe ma debian j’ai des problemes pour installer mon ATI ^^
C’est pour ca que j’ai fournis mon Xorg.conf dans le premier post.
Re,
Mais pour avoir eu en quelques semaines, deux cartes graphique qui m’ont laché, de deux grandes marques, je pensais plutôt à une panne physique :laughing:
Ca tombe bien, j’ai une ATI 4850 (la même donc, même marque en plus) dans le tiroir, j’vais la mettre et je verrai :slight_smile:
Merci pour le conseil :slight_smile:
Testé avec une autre Carte Graph (même modèle donc aucune re install de drivers), même soucis.
probleme electro-magnetique ??
Re,
La nVidia ne se “purgeait” qu’au dixième reboot :slightly_smiling:
Si c’est çà un ptoblème électro-magnétique alors oui :laughing:
Et euh … une autre idée pour moi ? :smiley:
On a éliminé la RAM et la carte graphique (du moins matériellement) pour les causes.
Si ca venait du driver que me conseilleriez vous ?
comment le désinstaller vraiment proprement et totalement, et surtout comment bien l’installer…?
Je crois avoir trouvé.
regardez ce que j’ai decouvert :
[code]Debian:/home/leank# aticonfig --adapter=0 --od-gettemperature
Adapter 0 - ATI Radeon HD 4800 Series
Sensor 0: Temperature - 114.50 C
du coup j’ai fais un petit :
Debian:/home/leank# aticonfig --pplib-cmd "set fanspeed 0 100" PPLIB command execution is Successful!
Mais je remarque que la température baisse très peu (je suis encore dans les 113°…
Et je n’entend pas le ventilo tourner comme un malade ^^
Pourtant j’ai bien :
Debian:/home/leank# aticonfig --pplib-cmd "get fanspeed 0" Fan speed query: Query Index: 0, Speed in percent Result: Fan Speed: 100%
Des idées ? (j’ai pas encore planté mais je viens de redemarrer… je surveille la température.)
Edit : la Température varie entre 113 et 114° :frowning:
