Ok,
au niveau du menu.lst:
# menu.lst - See: grub(8), info grub, update-grub(8)
# grub-install(8), grub-floppy(8),
# grub-md5-crypt, /usr/share/doc/grub
# and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not change this entry to 'saved' or your
# array will desync and will not let you boot your system.
default 0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout 5
# Pretty colours
color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line) and entries protected by the
# command 'lock'
# e.g. password topsecret
## password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
# title Linux
# root (hd0,1)
# kernel /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
## kopt_2_6_8=root=/dev/hdc1 ro
## kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=/dev/sda1 ro
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd2,0)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
## alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
## lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=vga=792 quiet splash
## should update-grub lock old automagic boot options
## e.g. lockold=false
## lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
## altoptions=(single-user) single
# altoptions=(single-user mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
## howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
## memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## should update-grub add savedefault to the default options
# savedefault=false
## ## End Default Options ##
splashimage=(hd2,0)/boot/grub/splashimages/gentleblue.xpm.gz
title Debian GNU/Linux, kernel 2.6.26-1-686
root (hd2,0)
kernel /boot/vmlinuz-2.6.26-1-686 root=/dev/sda1 ro vga=792 quiet splash
initrd /boot/initrd.img-2.6.26-1-686
title Debian GNU/Linux, kernel 2.6.26-1-686 (single-user mode)
root (hd2,0)
kernel /boot/vmlinuz-2.6.26-1-686 root=/dev/sda1 ro single
title Debian GNU/Linux, kernel 2.6.24-etchnhalf.1-686
root (hd2,0)
kernel /boot/vmlinuz-2.6.24-etchnhalf.1-686 root=/dev/sda1 ro vga=792 quiet splash
initrd /boot/initrd.img-2.6.24-etchnhalf.1-686
title Debian GNU/Linux, kernel 2.6.24-etchnhalf.1-686 (single-user mode)
root (hd2,0)
kernel /boot/vmlinuz-2.6.24-etchnhalf.1-686 root=/dev/sda1 ro single
title Debian GNU/Linux, kernel 2.6.18-6-686
root (hd2,0)
kernel /boot/vmlinuz-2.6.18-6-686 root=/dev/sda1 ro vga=792 quiet splash
initrd /boot/initrd.img-2.6.18-6-686
title Debian GNU/Linux, kernel 2.6.18-6-686 (single-user mode)
root (hd2,0)
kernel /boot/vmlinuz-2.6.18-6-686 root=/dev/sda1 ro single
title Debian GNU/Linux, kernel 2.6.18-6-486
root (hd2,0)
kernel /boot/vmlinuz-2.6.18-6-486 root=/dev/sda1 ro vga=792 quiet splash
initrd /boot/initrd.img-2.6.18-6-486
title Debian GNU/Linux, kernel 2.6.18-6-486 (single-user mode)
root (hd2,0)
kernel /boot/vmlinuz-2.6.18-6-486 root=/dev/sda1 ro single
### END DEBIAN AUTOMAGIC KERNELS LIST
# This is a divider, added to separate the menu items below from the Debian
# ones.
title Other operating systems:
root
Disque /dev/sda: 163.9 Go, 163928604672 octets
255 heads, 63 sectors/track, 19929 cylinders
Units = cylindres of 16065 * 512 = 8225280 bytes
Disk identifier: 0x0000f657
/dev/sda1 1 19929 160079661 5 Extended
/dev/sda5 1 19929 160079629+ 83 Linux
Disque /dev/sdb: 74.3 Go, 74355769344 octets
255 heads, 63 sectors/track, 9039 cylinders
Disk identifier: 0x000675fa
/dev/sdb1 1 2480 19920568+ 83 Linux
/dev/sdb2 2481 2735 2048287+ 82 Linux swap / Solaris
/dev/sdb3 2736 9039 50636880 5 Extended
/dev/sdb5 2736 9039 50636848+ 83 Linux
ubuntu@ubuntu:~$
163g IDE 74g SATA
merci
guigui69
