Déplacer Grub sur une autre partition
voila:
SERVER:/home/florent# od -Ax -tx1z -N446 /dev/sda | grep -i rub
000180 52 55 42 20 00 47 65 6f 6d 00 48 61 72 64 20 44  >RUB .Geom.Hard D<
SERVER:/home/florent# od -Ax -tx1z -N446 /dev/sdb | grep -i ru
od: /dev/sdb: Aucun medium trouvé
Après ca je doit faire quoi ?
merci
guigui69
voici:
SERVER:/home/florent# parted /dev/sda unit chs print
Model: ATA WDC WD740GD-00FL (scsi)
Disk /dev/sda: 9039,197,52
Sector size (logical/physical): 512B/512B
BIOS cylinder,head,sector geometry: 9039,255,63.  Each cylinder is 8225kB.
Partition Table: msdos
Number  Start     End          Type      File system  Flags
 1      0,1,0     2479,254,62  primary   ext3
 2      2480,0,0  2734,254,62  primary   linux-swap
 3      2735,0,0  9038,254,62  extended
 5      2735,1,0  9038,254,62  logical   ext3
grub> find /boot/grub/stage1
 (hd1,0)
Heu non, j’ai juste 2 disque dur un IDE 150g et un autre en SATA de 74g
SERVER:/home/florent# cat /boot/grub/menu.lst
# menu.lst - See: grub(8), info grub, update-grub(8)
#            grub-install(8), grub-floppy(8),
#            grub-md5-crypt, /usr/share/doc/grub
#            and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not change this entry to 'saved' or your
# array will desync and will not let you boot your system.
default		0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout		5
# Pretty colours
color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line)  and entries protected by the
# command 'lock'
# e.g. password topsecret
## password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title		Windows 95/98/NT/2000
# root		(hd0,0)
# makeactive
# chainloader	+1
# title		Linux
# root		(hd0,1)
# kernel	/vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
##      kopt_2_6_8=root=/dev/hdc1 ro
##      kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=/dev/sdb1 ro
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd1,0)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
##      alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
##      lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=vga=792 quiet splash
## should update-grub lock old automagic boot options
## e.g. lockold=false
##      lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
##      altoptions=(single-user) single
# altoptions=(single-user mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
##      howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
##      memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## should update-grub add savedefault to the default options
# savedefault=false
## ## End Default Options ##
splashimage=(hd1,0)/boot/grub/splashimages/gentleblue.xpm.gz
title		Debian GNU/Linux, kernel 2.6.26-1-686
root		(hd1,0)
kernel		/boot/vmlinuz-2.6.26-1-686 root=/dev/sdb1 ro vga=792 quiet splash
initrd		/boot/initrd.img-2.6.26-1-686
title		Debian GNU/Linux, kernel 2.6.26-1-686 (single-user mode)
root		(hd1,0)
kernel		/boot/vmlinuz-2.6.26-1-686 root=/dev/sdb1 ro single
title		Debian GNU/Linux, kernel 2.6.24-etchnhalf.1-686
root		(hd1,0)
kernel		/boot/vmlinuz-2.6.24-etchnhalf.1-686 root=/dev/sdb1 ro vga=792 quiet splash
initrd		/boot/initrd.img-2.6.24-etchnhalf.1-686
title		Debian GNU/Linux, kernel 2.6.24-etchnhalf.1-686 (single-user mode)
root		(hd1,0)
kernel		/boot/vmlinuz-2.6.24-etchnhalf.1-686 root=/dev/sdb1 ro single
title		Debian GNU/Linux, kernel 2.6.18-6-686
root		(hd1,0)
kernel		/boot/vmlinuz-2.6.18-6-686 root=/dev/sdb1 ro vga=792 quiet splash
initrd		/boot/initrd.img-2.6.18-6-686
title		Debian GNU/Linux, kernel 2.6.18-6-686 (single-user mode)
root		(hd1,0)
kernel		/boot/vmlinuz-2.6.18-6-686 root=/dev/sdb1 ro single
title		Debian GNU/Linux, kernel 2.6.18-6-486
root		(hd1,0)
kernel		/boot/vmlinuz-2.6.18-6-486 root=/dev/sdb1 ro vga=792 quiet splash
initrd		/boot/initrd.img-2.6.18-6-486
title		Debian GNU/Linux, kernel 2.6.18-6-486 (single-user mode)
root		(hd1,0)
kernel		/boot/vmlinuz-2.6.18-6-486 root=/dev/sdb1 ro single
### END DEBIAN AUTOMAGIC KERNELS LIST
# This is a divider, added to separate the menu items below from the Debian
# ones.
title		Other operating systems:
root
SERVER:/home/florent# grep -i "ata" /boot/config-2.6.26-1-686
CONFIG_X86_MCE_NONFATAL=m
# CONFIG_RELOCATABLE is not set
CONFIG_ATALK=m
CONFIG_MTD_DATAFLASH=m
CONFIG_ATA_OVER_ETH=m
# CONFIG_BLK_DEV_IDE_SATA is not set
CONFIG_SCSI_SAS_ATA=y
CONFIG_SCSI_EATA=m
CONFIG_SCSI_EATA_TAGGED_QUEUE=y
CONFIG_SCSI_EATA_LINKED_COMMANDS=y
CONFIG_SCSI_EATA_MAX_TAGS=16
CONFIG_ATA=m
# CONFIG_ATA_NONSTANDARD is not set
CONFIG_ATA_ACPI=y
CONFIG_SATA_PMP=y
CONFIG_SATA_AHCI=m
CONFIG_SATA_SIL24=m
CONFIG_ATA_SFF=y
CONFIG_SATA_SVW=m
CONFIG_ATA_PIIX=m
CONFIG_SATA_MV=m
CONFIG_SATA_NV=m
CONFIG_SATA_QSTOR=m
CONFIG_SATA_PROMISE=m
CONFIG_SATA_SX4=m
CONFIG_SATA_SIL=m
CONFIG_SATA_SIS=m
CONFIG_SATA_ULI=m
CONFIG_SATA_VIA=m
CONFIG_SATA_VITESSE=m
CONFIG_SATA_INIC162X=m
# CONFIG_PATA_ACPI is not set
# CONFIG_PATA_ALI is not set
# CONFIG_PATA_AMD is not set
CONFIG_PATA_ARTOP=m
# CONFIG_PATA_ATIIXP is not set
# CONFIG_PATA_CMD640_PCI is not set
# CONFIG_PATA_CMD64X is not set
# CONFIG_PATA_CS5520 is not set
# CONFIG_PATA_CS5530 is not set
# CONFIG_PATA_CS5535 is not set
# CONFIG_PATA_CS5536 is not set
# CONFIG_PATA_CYPRESS is not set
# CONFIG_PATA_EFAR is not set
CONFIG_ATA_GENERIC=m
# CONFIG_PATA_HPT366 is not set
# CONFIG_PATA_HPT37X is not set
# CONFIG_PATA_HPT3X2N is not set
# CONFIG_PATA_HPT3X3 is not set
# CONFIG_PATA_ISAPNP is not set
# CONFIG_PATA_IT821X is not set
# CONFIG_PATA_IT8213 is not set
# CONFIG_PATA_JMICRON is not set
# CONFIG_PATA_LEGACY is not set
# CONFIG_PATA_TRIFLEX is not set
CONFIG_PATA_MARVELL=m
# CONFIG_PATA_MPIIX is not set
# CONFIG_PATA_OLDPIIX is not set
# CONFIG_PATA_NETCELL is not set
# CONFIG_PATA_NINJA32 is not set
# CONFIG_PATA_NS87410 is not set
# CONFIG_PATA_NS87415 is not set
# CONFIG_PATA_OPTI is not set
# CONFIG_PATA_OPTIDMA is not set
# CONFIG_PATA_PCMCIA is not set
# CONFIG_PATA_PDC_OLD is not set
# CONFIG_PATA_QDI is not set
# CONFIG_PATA_RADISYS is not set
# CONFIG_PATA_RZ1000 is not set
# CONFIG_PATA_SC1200 is not set
# CONFIG_PATA_SERVERWORKS is not set
# CONFIG_PATA_PDC2027X is not set
# CONFIG_PATA_SIL680 is not set
CONFIG_PATA_SIS_STUB=m
# CONFIG_PATA_SIS is not set
# CONFIG_PATA_VIA is not set
# CONFIG_PATA_WINBOND is not set
# CONFIG_PATA_WINBOND_VLB is not set
CONFIG_PATA_SCH=m
CONFIG_USB_STORAGE_DATAFAB=y
CONFIG_USB_STORAGE_CYPRESS_ATACB=y
# CONFIG_INFINIBAND_IPOIB_DEBUG_DATA is not set
CONFIG_ATARI_PARTITION=y
# CONFIG_DEBUG_RODATA is not set
# Authenticated Encryption with Associated Data
SERVER:/home/florent# lsmod | grep -i ata
ata_piix               14180  3
ata_generic             4676  0
libata                140384  2 ata_piix,ata_generic
scsi_mod              129356  3 sd_mod,usb_storage,libata
dock                    8304  1 libata
[quote]
Pour ce soir on pourra modifier temporairement le menu.lst
afin que tu puisses démarrer sans problèmes.[/quote]
Comment je fait pour mettre a jour la menu.lst?
merci
guigui69
Ok mais c’est quoi le problème exacte concernant mon grub?
Moi je ne vois pas ce qui ne va pas :mrgreen:
Pour moi, d’après les retours de geometry (hd0) au démarrage et puis en live cd
il suffirait de changer dans le menu.lst, les color=#40FF00[/color] par color=#FF0000[/color].
Tu peux essayer en rajoutant au menu, cette entrée
title Test root (hd0,0) kernel /boot/vmlinuz-2.6.26-1-686 root=/dev/sdb1 ro vga=792 quiet splash initrd /boot/initrd.img-2.6.26-1-686
redémarrer et essayer cette entrée. Si ça fonctionne, tu remplaces, dans le
menu.lst, la ligne
# groot=(hd1,0)
par
# groot=(hd0,0)
puis tu enregistres et dans une console
#update-grub
depuis ma debian
grub find /boot/grub/stage1
(hd1,0)
Et depuis grub (demarrage ordi)
(hd0,0)
bizarre.
je test se que tu dit belga
oui les deux disque durs sont branchés, car la je suis sur ma debian (installé sur le 74g) et j’accède a mes données qui sont sur le 163g sans problème.
Pour l’instant j’ai rien fait de plus j’ai modifier le fichier menulst pour démarrer
SERVER:/home/florent# fdisk -l
Disk /dev/hda: 163.9 GB, 163928604672 bytes
255 heads, 63 sectors/track, 19929 cylinders
Disk identifier: 0x0000f657
   Device Boot      Start         End      Blocks   Id  System
/dev/hda1               1       19929   160079661    5  Extended
/dev/hda5               1       19929   160079629+  83  Linux
Disk /dev/sda: 74.3 GB, 74354687488 bytes
255 heads, 63 sectors/track, 9039 cylinders
Disk identifier: 0x000675fa
/dev/sda1               1        2480    19920568+  83  Linux
/dev/sda2            2481        2735     2048287+  82  Linux swap / Solaris
/dev/sda3            2736        9039    50636880    5  Extended
/dev/sda5            2736        9039    50636848+  83  Linux
SERVER:/home/florent# od -Ax -tx1z -N446 /dev/sdb | grep -i rub
 (hd1,0)
grub> geometry (hd0)
drive 0x80: C/H/S = 0/255/63, The number of sectors = 320173056, /dev/hda
   Partition num: 4,  Filesystem type is ext2fs, partition type 0x83
grub> geometry (hd1)
drive 0x81: C/H/S = 0/255/63, The number of sectors = 145223999, /dev/sda
   Partition num: 0,  Filesystem type is ext2fs, partition type 0x83
   Partition num: 1,  Filesystem type unknown, partition type 0x82
SERVER:/home/florent# lspci
00:00.0 Host bridge: Intel Corporation 82865G/PE/P DRAM Controller/Host-Hub Interface (rev 02)
00:01.0 PCI bridge: Intel Corporation 82865G/PE/P PCI to AGP Controller (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev c2)
00:1f.0 ISA bridge: Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801EB/ER (ICH5/ICH5R) IDE Controller (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801EB (ICH5) SATA Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801EB/ER (ICH5/ICH5R) SMBus Controller (rev 02)
00:1f.5 Multimedia audio controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller (rev 02)
01:00.0 VGA compatible controller: nVidia Corporation NV31 [GeForce FX 5600XT] (rev a1)
02:03.0 Ethernet controller: Accton Technology Corporation EN-1216 Ethernet Adapter (rev 11)
merci
guigui69
Voici l’ensemble de des commandes:
SERVER:/home/florent# od -Ax -tx1z -N446 /dev/hda | grep -i rub
## default num
default		0
## timeout sec
timeout		5
# Pretty colours
# command 'lock'
# examples
# root		(hd0,0)
# makeactive
# chainloader	+1
# title		Linux
# root		(hd0,1)
# kopt=root=/dev/sda1 ro
# groot=(hd0,0)
# alternative=true
## alternatives
##      lockold=true
# lockold=false
# xenhopt=
## e.g. howmany=all
##      howmany=7
# howmany=all
##      memtest86=false
# memtest86=true
# savedefault=false
splashimage=(hd0,0)/boot/grub/splashimages/gentleblue.xpm.gz
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.26-1-686 root=/dev/sda1 ro vga=792 quiet splash
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.26-1-686 root=/dev/sda1 ro single
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.24-etchnhalf.1-686 root=/dev/sda1 ro vga=792 quiet splash
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.24-etchnhalf.1-686 root=/dev/sda1 ro single
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.18-6-686 root=/dev/sda1 ro vga=792 quiet splash
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.18-6-686 root=/dev/sda1 ro single
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.18-6-486 root=/dev/sda1 ro vga=792 quiet splash
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.18-6-486 root=/dev/sda1 ro single
# ones.
root
SERVER:/home/florent# cat /boot/grub/device.map
(hd0) /dev/sda
(hd1) /dev/sdb
Que me conseilles-tu de modifier en premier? Par quel étape je doit faire commencer?
Merci d’avance
guigui69
La j’ai pu redémarrer correctement mais j’ai du enlever les paramètre de splashy sinon ça bloque comme ca:
Splashy ERROR: Timeout (120 sec) occurred while waiting for a
