oki
root@debian:/home/angel# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 006: ID 174c:55aa ASMedia Technology Inc.
root@debian:/home/angel# lsusb -D /dev/bus/usb/$(lsusb | grep “174c” | awk ‘{ print $2"/"substr($4,0,3)}’)
Cannot open /dev/bus/usb/001/00
par contre dmesg tout court j’ai pas l’impression que tout passe
ça commence là
[ 6554.912071] 7 80 1562976
[ 6554.912073] 0 90 1562976
[ 6554.912075] 8 81 1562976
[ 6554.912077] e6 80 1562976
[ 6554.912080] 0 90 1562976
[ 6554.912082] 0 90 1562976
[ 6554.912084] 0 90 1562976
[ 6554.912086] 1 90 1562976
[ 6554.912089] 2 90 1562976
[ 6554.912091] 12 90 1562976
[ 6554.912093] 1b 90 1562976
[ 6554.912095] ff 90 1562976
[ 6554.912098] last result at 1562976
[ 6554.912100] last redo_fd_request at 1562976
[ 6554.912104] 20 00 .
[ 6554.912112] status=50
[ 6554.912114] fdc_busy=1
[ 6554.912120] do_floppy=main_command_interrupt
[ 6554.912125] fd_timer.function=fd_watchdog
[ 6554.912128] cont=f8434080
[ 6554.912130] current_req=f2774ee0
[ 6554.912132] command_status=-1
[ 6554.912134]
[ 6554.912138] floppy0: floppy timeout called
[ 6554.912144] end_request: I/O error, dev fd0, sector 0
[ 6554.912151] Buffer I/O error on device fd0, logical block 0
[ 6555.612020] ..
[ 6557.920007]
[ 6557.920013] floppy driver state
[ 6557.920015] -------------------
[ 6557.920044] now=1564480 last interrupt=1563728 diff=752 last called handler=recal_interrupt
[ 6557.920047] timeout_message=floppy start
[ 6557.920050] last output bytes:
[ 6557.920052] 0 90 1563728
[ 6557.920055] 13 90 1563728
[ 6557.920057] 0 90 1563728
[ 6557.920059] 1a 90 1563728
[ 6557.920061] 0 90 1563728
[ 6557.920063] 3 90 1563728
[ 6557.920066] c1 90 1563728
[ 6557.920068] 10 90 1563728
[ 6557.920070] 7 80 1563728
[ 6557.920072] 0 90 1563728
[ 6557.920074] 8 81 1563728
[ 6557.920077] e6 80 1563728
[ 6557.920079] 0 90 1563728
[ 6557.920081] 0 90 1563728
[ 6557.920083] 0 90 1563728
[ 6557.920085] 1 90 1563728
[ 6557.920087] 2 90 1563728
[ 6557.920090] 12 90 1563728
[ 6557.920092] 1b 90 1563728
[ 6557.920094] ff 90 1563728
[ 6557.920096] last result at 1563728
[ 6557.920098] last redo_fd_request at 1563728
[ 6557.920102] 20 00 .
[ 6557.920111] status=50
[ 6557.920113] fdc_busy=1
[ 6557.920118] do_floppy=main_command_interrupt
[ 6557.920123] fd_timer.function=fd_watchdog
[ 6557.920126] cont=f8434080
[ 6557.920128] current_req=f2774ee0
[ 6557.920130] command_status=-1
[ 6557.920132]
[ 6557.920135] floppy0: floppy timeout called
[ 6557.920142] end_request: I/O error, dev fd0, sector 0
[ 6557.920149] Buffer I/O error on device fd0, logical block 0
[ 6558.080025] ......not responding...
[ 6585.455842] sd 5:0:0:0: [sdc] READ CAPACITY failed
[ 6585.455848] sd 5:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 6585.455854] sd 5:0:0:0: [sdc] Sense Key : Not Ready [current]
[ 6585.455859] sd 5:0:0:0: [sdc] Add. Sense: Logical unit is in process of becoming ready
[ 6592.447430] sd 5:0:0:0: [sdc] Test WP failed, assume Write Enabled
[ 6599.438899] sd 5:0:0:0: [sdc] Asking for cache data failed
[ 6599.438906] sd 5:0:0:0: [sdc] Assuming drive cache: write through
[ 6599.445752] sd 5:0:0:0: [sdc] Spinning up disk.......
[ 6611.488790] usb 1-6: USB disconnect, device number 3
[ 6612.368012] .ready
[ 6612.368085] sd 5:0:0:0: [sdc] READ CAPACITY failed
[ 6612.368089] sd 5:0:0:0: [sdc] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[ 6612.368095] sd 5:0:0:0: [sdc] Sense not available.
[ 6612.368128] sd 5:0:0:0: [sdc] Asking for cache data failed
[ 6612.368133] sd 5:0:0:0: [sdc] Assuming drive cache: write through
[ 6612.368138] sd 5:0:0:0: [sdc] Attached SCSI disk
[ 6615.412019] usb 1-6: new high-speed USB device number 4 using ehci_hcd
[ 6615.929901] usb 1-6: New USB device found, idVendor=174c, idProduct=55aa
[ 6615.929907] usb 1-6: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 6615.929911] usb 1-6: Product: MS
[ 6615.929914] usb 1-6: Manufacturer:
[ 6615.929916] usb 1-6: SerialNumber: 12345678942B
[ 6615.930893] scsi6 : usb-storage 1-6:1.0
[ 6617.143945] scsi 6:0:0:0: Direct-Access MS 0 PQ: 0 ANSI: 6
[ 6617.146730] sd 6:0:0:0: Attached scsi generic sg3 type 0
[ 6617.150987] sd 6:0:0:0: [sdc] Spinning up disk.....................................................................................not responding...
[ 6739.301708] sd 6:0:0:0: [sdc] READ CAPACITY failed
[ 6739.301715] sd 6:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 6739.301720] sd 6:0:0:0: [sdc] Sense Key : Not Ready [current]
[ 6739.301725] sd 6:0:0:0: [sdc] Add. Sense: Logical unit is in process of becoming ready
[ 6746.290180] sd 6:0:0:0: [sdc] Test WP failed, assume Write Enabled
[ 6753.282899] sd 6:0:0:0: [sdc] Asking for cache data failed
[ 6753.282907] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[ 6753.289259] sd 6:0:0:0: [sdc] Spinning up disk.............
[ 6774.360010]
[ 6774.360015] floppy driver state
[ 6774.360017] -------------------
[ 6774.360047] now=1618590 last interrupt=1617748 diff=842 last called handler=recal_interrupt
[ 6774.360051] timeout_message=floppy start
[ 6774.360053] last output bytes:
[ 6774.360055] 0 90 1617748
[ 6774.360058] 13 90 1617748
[ 6774.360060] 0 90 1617748
[ 6774.360063] 1a 90 1617748
[ 6774.360065] 0 90 1617748
[ 6774.360067] 3 90 1617748
[ 6774.360069] c1 90 1617748
[ 6774.360072] 10 90 1617748
[ 6774.360074] 7 80 1617748
[ 6774.360076] 0 90 1617748
[ 6774.360078] 8 81 1617748
[ 6774.360081] e6 80 1617843
[ 6774.360083] 0 90 1617843
[ 6774.360085] 0 90 1617843
[ 6774.360087] 0 90 1617843
[ 6774.360090] 1 90 1617843
[ 6774.360092] 2 90 1617843
[ 6774.360094] 12 90 1617843
[ 6774.360097] 1b 90 1617843
[ 6774.360099] ff 90 1617843
[ 6774.360101] last result at 1617748
[ 6774.360103] last redo_fd_request at 1617748
[ 6774.360107] 20 00 .
[ 6774.360116] status=50
[ 6774.360118] fdc_busy=1
[ 6774.360123] do_floppy=main_command_interrupt
[ 6774.360129] fd_timer.function=fd_watchdog
[ 6774.360132] cont=f8434080
[ 6774.360134] current_req=f4db86b8
[ 6774.360136] command_status=-1
[ 6774.360138]
[ 6774.360142] floppy0: floppy timeout called
[ 6774.360148] end_request: I/O error, dev fd0, sector 0
[ 6777.376007]
[ 6777.376012] floppy driver state
[ 6777.376014] -------------------
[ 6777.376044] now=1619344 last interrupt=1618593 diff=751 last called handler=recal_interrupt
[ 6777.376047] timeout_message=floppy start
[ 6777.376049] last output bytes:
[ 6777.376052] 0 90 1618593
[ 6777.376055] 13 90 1618593
[ 6777.376057] 0 90 1618593
[ 6777.376059] 1a 90 1618593
[ 6777.376061] 0 90 1618593
[ 6777.376064] 3 90 1618593
[ 6777.376066] c1 90 1618593
[ 6777.376068] 10 90 1618593
[ 6777.376070] 7 80 1618593
[ 6777.376073] 0 90 1618593
[ 6777.376075] 8 81 1618593
[ 6777.376077] e6 80 1618593
[ 6777.376079] 0 90 1618593
[ 6777.376081] 0 90 1618593
[ 6777.376084] 0 90 1618593
[ 6777.376086] 1 90 1618593
[ 6777.376088] 2 90 1618593
[ 6777.376090] 12 90 1618593
[ 6777.376092] 1b 90 1618593
[ 6777.376095] ff 90 1618593
[ 6777.376097] last result at 1618593
[ 6777.376099] last redo_fd_request at 1618593
[ 6777.376103] 20 00 .
[ 6777.376111] status=50
[ 6777.376113] fdc_busy=1
[ 6777.376119] do_floppy=main_command_interrupt
[ 6777.376124] fd_timer.function=fd_watchdog
[ 6777.376127] cont=f8434080
[ 6777.376129] current_req=f4db8230
[ 6777.376131] command_status=-1
[ 6777.376133]
[ 6777.376136] floppy0: floppy timeout called
[ 6777.376143] end_request: I/O error, dev fd0, sector 0
[ 6778.976019] ..
[ 6780.384009]
[ 6780.384015] floppy driver state
[ 6780.384017] -------------------
[ 6780.384046] now=1620096 last interrupt=1619344 diff=752 last called handler=recal_interrupt
[ 6780.384072] timeout_message=floppy start
[ 6780.384074] last output bytes:
[ 6780.384077] 0 90 1619344
[ 6780.384080] 13 90 1619344
[ 6780.384082] 0 90 1619344
[ 6780.384085] 1a 90 1619344
[ 6780.384087] 0 90 1619344
[ 6780.384089] 3 90 1619344
[ 6780.384092] c1 90 1619344
[ 6780.384094] 10 90 1619344
[ 6780.384096] 7 80 1619344
[ 6780.384099] 0 90 1619344
[ 6780.384101] 8 81 1619344
[ 6780.384103] e6 80 1619344
[ 6780.384106] 0 90 1619344
[ 6780.384108] 0 90 1619344
[ 6780.384110] 0 90 1619344
[ 6780.384113] 1 90 1619344
[ 6780.384115] 2 90 1619344
[ 6780.384117] 12 90 1619344
[ 6780.384120] 1b 90 1619344
[ 6780.384122] ff 90 1619344
[ 6780.384124] last result at 1619344
[ 6780.384126] last redo_fd_request at 1619344
[ 6780.384131] 20 00 .
[ 6780.384139] status=50
[ 6780.384141] fdc_busy=1
[ 6780.384147] do_floppy=main_command_interrupt
[ 6780.384153] fd_timer.function=fd_watchdog
[ 6780.384156] cont=f8434080
[ 6780.384158] current_req=f4db8230
[ 6780.384160] command_status=-1
[ 6780.384162]
[ 6780.384166] floppy0: floppy timeout called
[ 6780.384172] end_request: I/O error, dev fd0, sector 0
[ 6780.384180] Buffer I/O error on device fd0, logical block 0
[ 6781.436014] ..
[ 6783.392007]
[ 6783.392012] floppy driver state
[ 6783.392014] -------------------
[ 6783.392043] now=1620848 last interrupt=1620096 diff=752 last called handler=recal_interrupt
[ 6783.392047] timeout_message=floppy start
[ 6783.392049] last output bytes:
[ 6783.392052] 0 90 1620096
[ 6783.392054] 13 90 1620096
[ 6783.392057] 0 90 1620096
[ 6783.392059] 1a 90 1620096
[ 6783.392061] 0 90 1620096
[ 6783.392063] 3 90 1620096
[ 6783.392065] c1 90 1620096
[ 6783.392068] 10 90 1620096
[ 6783.392070] 7 80 1620096
[ 6783.392072] 0 90 1620096
[ 6783.392074] 8 81 1620096
[ 6783.392077] e6 80 1620096
[ 6783.392079] 0 90 1620096
[ 6783.392081] 0 90 1620096
[ 6783.392083] 0 90 1620096
[ 6783.392086] 1 90 1620096
[ 6783.392088] 2 90 1620096
[ 6783.392090] 12 90 1620096
[ 6783.392092] 1b 90 1620096
[ 6783.392095] ff 90 1620096
[ 6783.392097] last result at 1620096
[ 6783.392099] last redo_fd_request at 1620096
[ 6783.392103] 20 00 .
[ 6783.392111] status=50
[ 6783.392113] fdc_busy=1
[ 6783.392119] do_floppy=main_command_interrupt
[ 6783.392125] fd_timer.function=fd_watchdog
[ 6783.392127] cont=f8434080
[ 6783.392129] current_req=f4db8230
[ 6783.392131] command_status=-1
[ 6783.392133]
[ 6783.392137] floppy0: floppy timeout called
[ 6783.392143] end_request: I/O error, dev fd0, sector 0
[ 6783.392151] Buffer I/O error on device fd0, logical block 0
[ 6783.904012] ...
[ 6786.400005]
[ 6786.400009] floppy driver state
[ 6786.400011] -------------------
[ 6786.400042] now=1621600 last interrupt=1620848 diff=752 last called handler=recal_interrupt
[ 6786.400045] timeout_message=floppy start
[ 6786.400047] last output bytes:
[ 6786.400050] 0 90 1620848
[ 6786.400053] 13 90 1620848
[ 6786.400055] 0 90 1620848
[ 6786.400058] 1a 90 1620848
[ 6786.400060] 0 90 1620848
[ 6786.400063] 3 90 1620848
[ 6786.400065] c1 90 1620848
[ 6786.400068] 10 90 1620848
[ 6786.400070] 7 80 1620848
[ 6786.400072] 0 90 1620848
[ 6786.400075] 8 81 1620848
[ 6786.400077] e6 80 1620848
[ 6786.400080] 0 90 1620848
[ 6786.400082] 0 90 1620848
[ 6786.400084] 0 90 1620848
[ 6786.400087] 1 90 1620848
[ 6786.400089] 2 90 1620848
[ 6786.400092] 12 90 1620848
[ 6786.400094] 1b 90 1620848
[ 6786.400096] ff 90 1620848
[ 6786.400099] last result at 1620848
[ 6786.400101] last redo_fd_request at 1620848
[ 6786.400105] 20 00 .
[ 6786.400114] status=50
[ 6786.400116] fdc_busy=1
[ 6786.400121] do_floppy=main_command_interrupt
[ 6786.400127] fd_timer.function=fd_watchdog
[ 6786.400130] cont=f8434080
[ 6786.400132] current_req=f4db8230
[ 6786.400134] command_status=-1
[ 6786.400136]
[ 6786.400140] floppy0: floppy timeout called
[ 6786.400146] end_request: I/O error, dev fd0, sector 0
[ 6786.400154] Buffer I/O error on device fd0, logical block 0
[ 6787.604014] ..
[ 6789.408007]
[ 6789.408013] floppy driver state
[ 6789.408015] -------------------
[ 6789.408044] now=1622352 last interrupt=1621600 diff=752 last called handler=recal_interrupt
[ 6789.408047] timeout_message=floppy start
[ 6789.408050] last output bytes:
[ 6789.408053] 0 90 1621600
[ 6789.408055] 13 90 1621600
[ 6789.408057] 0 90 1621600
[ 6789.408060] 1a 90 1621600
[ 6789.408062] 0 90 1621600
[ 6789.408064] 3 90 1621600
[ 6789.408066] c1 90 1621600
[ 6789.408069] 10 90 1621600
[ 6789.408071] 7 80 1621600
[ 6789.408073] 0 90 1621600
[ 6789.408075] 8 81 1621600
[ 6789.408078] e6 80 1621600
[ 6789.408080] 0 90 1621600
[ 6789.408082] 0 90 1621600
[ 6789.408084] 0 90 1621600
[ 6789.408087] 1 90 1621600
[ 6789.408089] 2 90 1621600
[ 6789.408091] 12 90 1621600
[ 6789.408093] 1b 90 1621600
[ 6789.408096] ff 90 1621600
[ 6789.408098] last result at 1621600
[ 6789.408100] last redo_fd_request at 1621600
[ 6789.408104] 20 00 .
[ 6789.408113] status=50
[ 6789.408115] fdc_busy=1
[ 6789.408120] do_floppy=main_command_interrupt
[ 6789.408126] fd_timer.function=fd_watchdog
[ 6789.408128] cont=f8434080
[ 6789.408130] current_req=f4db8230
[ 6789.408133] command_status=-1
[ 6789.408134]
[ 6789.408138] floppy0: floppy timeout called
[ 6789.408145] end_request: I/O error, dev fd0, sector 0
[ 6789.408153] Buffer I/O error on device fd0, logical block 0
[ 6789.410480] floppy0: unexpected interrupt
[ 6789.410547] floppy0: sensei repl[0]=80
[ 6790.072014] ..
[ 6792.416007]
[ 6792.416012] floppy driver state
[ 6792.416014] -------------------
[ 6792.416044] now=1623104 last interrupt=1622353 diff=751 last called handler=recal_interrupt
[ 6792.416047] timeout_message=floppy start
[ 6792.416050] last output bytes:
[ 6792.416053] 0 90 1622353
[ 6792.416055] 13 90 1622353
[ 6792.416057] 0 90 1622353
[ 6792.416059] 1a 90 1622353
[ 6792.416062] 0 90 1622353
[ 6792.416064] 3 90 1622353
[ 6792.416066] c1 90 1622353
[ 6792.416068] 10 90 1622353
[ 6792.416070] 7 80 1622353
[ 6792.416073] 0 90 1622353
[ 6792.416075] 8 81 1622353
[ 6792.416077] e6 80 1622353
[ 6792.416079] 0 90 1622353
[ 6792.416082] 0 90 1622353
[ 6792.416084] 0 90 1622353
[ 6792.416086] 1 90 1622353
[ 6792.416088] 2 90 1622353
[ 6792.416090] 12 90 1622353
[ 6792.416093] 1b 90 1622353
[ 6792.416095] ff 90 1622353
[ 6792.416097] last result at 1622353
[ 6792.416099] last redo_fd_request at 1622353
[ 6792.416103] 20 00 .
[ 6792.416112] status=50
[ 6792.416114] fdc_busy=1
[ 6792.416119] do_floppy=main_command_interrupt
[ 6792.416125] fd_timer.function=fd_watchdog
[ 6792.416127] cont=f8434080
[ 6792.416129] current_req=f4db8230
[ 6792.416131] command_status=-1
[ 6792.416133]
[ 6792.416137] floppy0: floppy timeout called
[ 6792.416143] end_request: I/O error, dev fd0, sector 0
[ 6792.416151] Buffer I/O error on device fd0, logical block 0
[ 6792.418478] floppy0: unexpected interrupt
[ 6792.418545] floppy0: sensei repl[0]=80
[ 6792.544010] ...
[ 6795.424008]
[ 6795.424013] floppy driver state
[ 6795.424016] -------------------
[ 6795.424045] now=1623856 last interrupt=1623105 diff=751 last called handler=recal_interrupt
[ 6795.424049] timeout_message=floppy start
[ 6795.424051] last output bytes:
[ 6795.424054] 0 90 1623105
[ 6795.424056] 13 90 1623105
[ 6795.424059] 0 90 1623105
[ 6795.424061] 1a 90 1623105
[ 6795.424063] 0 90 1623105
[ 6795.424066] 3 90 1623105
[ 6795.424068] c1 90 1623105
[ 6795.424070] 10 90 1623105
[ 6795.424072] 7 80 1623105
[ 6795.424075] 0 90 1623105
[ 6795.424077] 8 81 1623105
[ 6795.424079] e6 80 1623105
[ 6795.424082] 0 90 1623105
[ 6795.424084] 0 90 1623105
[ 6795.424086] 0 90 1623105
[ 6795.424088] 1 90 1623105
[ 6795.424091] 2 90 1623105
[ 6795.424093] 12 90 1623105
[ 6795.424095] 1b 90 1623105
[ 6795.424097] ff 90 1623105
[ 6795.424100] last result at 1623105
[ 6795.424102] last redo_fd_request at 1623105
[ 6795.424106] 20 00 .
[ 6795.424114] status=50
[ 6795.424116] fdc_busy=1
[ 6795.424122] do_floppy=main_command_interrupt
[ 6795.424128] fd_timer.function=fd_watchdog
[ 6795.424130] cont=f8434080
[ 6795.424133] current_req=f4db8230
[ 6795.424135] command_status=-1
[ 6795.424137]
[ 6795.424140] floppy0: floppy timeout called
[ 6795.424147] end_request: I/O error, dev fd0, sector 0
[ 6795.424155] Buffer I/O error on device fd0, logical block 0
[ 6796.244021] ..
[ 6798.432013]
[ 6798.432017] floppy driver state
[ 6798.432019] -------------------
[ 6798.432051] now=1624608 last interrupt=1623856 diff=752 last called handler=recal_interrupt
[ 6798.432055] timeout_message=floppy start
[ 6798.432057] last output bytes:
[ 6798.432060] 0 90 1623856
[ 6798.432062] 13 90 1623856
[ 6798.432065] 0 90 1623856
[ 6798.432067] 1a 90 1623856
[ 6798.432069] 0 90 1623856
[ 6798.432071] 3 90 1623856
[ 6798.432074] c1 90 1623856
[ 6798.432076] 10 90 1623856
[ 6798.432078] 7 80 1623856
[ 6798.432080] 0 90 1623856
[ 6798.432083] 8 81 1623856
[ 6798.432085] e6 80 1623856
[ 6798.432087] 0 90 1623856
[ 6798.432089] 0 90 1623856
[ 6798.432091] 0 90 1623856
[ 6798.432094] 1 90 1623856
[ 6798.432096] 2 90 1623856
[ 6798.432098] 12 90 1623856
[ 6798.432100] 1b 90 1623856
[ 6798.432103] ff 90 1623856
[ 6798.432105] last result at 1623856
[ 6798.432107] last redo_fd_request at 1623856
[ 6798.432111] 20 00 .
[ 6798.432119] status=50
[ 6798.432121] fdc_busy=1
[ 6798.432127] do_floppy=main_command_interrupt
[ 6798.432133] fd_timer.function=fd_watchdog
[ 6798.432135] cont=f8434080
[ 6798.432137] current_req=f4db8230
[ 6798.432139] command_status=-1
[ 6798.432141]
[ 6798.432145] floppy0: floppy timeout called
[ 6798.432152] end_request: I/O error, dev fd0, sector 0
[ 6798.432160] Buffer I/O error on device fd0, logical block 0
[ 6798.712026] ...
[ 6801.440007]
[ 6801.440013] floppy driver state
[ 6801.440015] -------------------
[ 6801.440046] now=1625360 last interrupt=1624608 diff=752 last called handler=recal_interrupt
[ 6801.440049] timeout_message=floppy start
[ 6801.440052] last output bytes:
[ 6801.440054] 0 90 1624608
[ 6801.440057] 13 90 1624608
[ 6801.440059] 0 90 1624608
[ 6801.440061] 1a 90 1624608
[ 6801.440064] 0 90 1624608
[ 6801.440066] 3 90 1624608
[ 6801.440068] c1 90 1624608
[ 6801.440070] 10 90 1624608
[ 6801.440073] 7 80 1624608
[ 6801.440075] 0 90 1624608
[ 6801.440077] 8 81 1624608
[ 6801.440079] e6 80 1624608
[ 6801.440082] 0 90 1624608
[ 6801.440084] 0 90 1624608
[ 6801.440086] 0 90 1624608
[ 6801.440088] 1 90 1624608
[ 6801.440091] 2 90 1624608
[ 6801.440093] 12 90 1624608
[ 6801.440095] 1b 90 1624608
[ 6801.440098] ff 90 1624608
[ 6801.440100] last result at 1624608
[ 6801.440102] last redo_fd_request at 1624608
[ 6801.440106] 20 00 .
[ 6801.440114] status=50
[ 6801.440116] fdc_busy=1
[ 6801.440122] do_floppy=main_command_interrupt
[ 6801.440128] fd_timer.function=fd_watchdog
[ 6801.440130] cont=f8434080
[ 6801.440132] current_req=f4db8230
[ 6801.440135] command_status=-1
[ 6801.440136]
[ 6801.440140] floppy0: floppy timeout called
[ 6801.440146] end_request: I/O error, dev fd0, sector 0
[ 6801.440154] Buffer I/O error on device fd0, logical block 0
[ 6802.416016] ..
[ 6804.448007]
[ 6804.448013] floppy driver state
[ 6804.448015] -------------------
[ 6804.448044] now=1626112 last interrupt=1625360 diff=752 last called handler=recal_interrupt
[ 6804.448047] timeout_message=floppy start
[ 6804.448050] last output bytes:
[ 6804.448053] 0 90 1625360
[ 6804.448055] 13 90 1625360
[ 6804.448057] 0 90 1625360
[ 6804.448060] 1a 90 1625360
[ 6804.448062] 0 90 1625360
[ 6804.448064] 3 90 1625360
[ 6804.448066] c1 90 1625360
[ 6804.448069] 10 90 1625360
[ 6804.448071] 7 80 1625360
[ 6804.448073] 0 90 1625360
[ 6804.448075] 8 81 1625360
[ 6804.448078] e6 80 1625360
[ 6804.448080] 0 90 1625360
[ 6804.448082] 0 90 1625360
[ 6804.448084] 0 90 1625360
[ 6804.448087] 1 90 1625360
[ 6804.448089] 2 90 1625360
[ 6804.448091] 12 90 1625360
[ 6804.448093] 1b 90 1625360
[ 6804.448096] ff 90 1625360
[ 6804.448098] last result at 1625360
[ 6804.448100] last redo_fd_request at 1625360
[ 6804.448104] 20 00 .
[ 6804.448113] status=50
[ 6804.448115] fdc_busy=1
[ 6804.448120] do_floppy=main_command_interrupt
[ 6804.448126] fd_timer.function=fd_watchdog
[ 6804.448129] cont=f8434080
[ 6804.448131] current_req=f4db8230
[ 6804.448133] command_status=-1
[ 6804.448135]
[ 6804.448138] floppy0: floppy timeout called
[ 6804.448145] end_request: I/O error, dev fd0, sector 0
[ 6804.448153] Buffer I/O error on device fd0, logical block 0
[ 6804.884053] ...
[ 6807.456007]
[ 6807.456012] floppy driver state
[ 6807.456014] -------------------
[ 6807.456043] now=1626864 last interrupt=1626112 diff=752 last called handler=recal_interrupt
[ 6807.456047] timeout_message=floppy start
[ 6807.456049] last output bytes:
[ 6807.456052] 0 90 1626112
[ 6807.456054] 13 90 1626112
[ 6807.456057] 0 90 1626112
[ 6807.456059] 1a 90 1626112
[ 6807.456061] 0 90 1626112
[ 6807.456063] 3 90 1626112
[ 6807.456066] c1 90 1626112
[ 6807.456068] 10 90 1626112
[ 6807.456070] 7 80 1626112
[ 6807.456072] 0 90 1626112
[ 6807.456075] 8 81 1626112
[ 6807.456077] e6 80 1626112
[ 6807.456079] 0 90 1626112
[ 6807.456081] 0 90 1626112
[ 6807.456084] 0 90 1626112
[ 6807.456086] 1 90 1626112
[ 6807.456088] 2 90 1626112
[ 6807.456090] 12 90 1626112
[ 6807.456093] 1b 90 1626112
[ 6807.456095] ff 90 1626112
[ 6807.456097] last result at 1626112
[ 6807.456099] last redo_fd_request at 1626112
[ 6807.456103] 20 00 .
[ 6807.456112] status=50
[ 6807.456114] fdc_busy=1
[ 6807.456119] do_floppy=main_command_interrupt
[ 6807.456125] fd_timer.function=fd_watchdog
[ 6807.456128] cont=f8434080
[ 6807.456130] current_req=f4db8230
[ 6807.456132] command_status=-1
[ 6807.456134]
[ 6807.456137] floppy0: floppy timeout called
[ 6807.456144] end_request: I/O error, dev fd0, sector 0
[ 6807.456152] Buffer I/O error on device fd0, logical block 0
[ 6808.584014] ..
[ 6810.464007]
[ 6810.464013] floppy driver state
[ 6810.464015] -------------------
[ 6810.464045] now=1627616 last interrupt=1626864 diff=752 last called handler=recal_interrupt
[ 6810.464048] timeout_message=floppy start
[ 6810.464050] last output bytes:
[ 6810.464053] 0 90 1626864
[ 6810.464055] 13 90 1626864
[ 6810.464058] 0 90 1626864
[ 6810.464060] 1a 90 1626864
[ 6810.464062] 0 90 1626864
[ 6810.464064] 3 90 1626864
[ 6810.464066] c1 90 1626864
[ 6810.464069] 10 90 1626864
[ 6810.464071] 7 80 1626864
[ 6810.464073] 0 90 1626864
[ 6810.464075] 8 81 1626864
[ 6810.464077] e6 80 1626864
[ 6810.464080] 0 90 1626864
[ 6810.464082] 0 90 1626864
[ 6810.464084] 0 90 1626864
[ 6810.464086] 1 90 1626864
[ 6810.464088] 2 90 1626864
[ 6810.464091] 12 90 1626864
[ 6810.464093] 1b 90 1626864
[ 6810.464095] ff 90 1626864
[ 6810.464097] last result at 1626864
[ 6810.464099] last redo_fd_request at 1626864
[ 6810.464103] 20 00 .
[ 6810.464111] status=50
[ 6810.464113] fdc_busy=1
[ 6810.464119] do_floppy=main_command_interrupt
[ 6810.464124] fd_timer.function=fd_watchdog
[ 6810.464127] cont=f8434080
[ 6810.464129] current_req=f4db8230
[ 6810.464131] command_status=-1
[ 6810.464133]
[ 6810.464136] floppy0: floppy timeout called
[ 6810.464142] end_request: I/O error, dev fd0, sector 0
[ 6810.464150] Buffer I/O error on device fd0, logical block 0
[ 6811.052018] ..
[ 6813.472007]
[ 6813.472012] floppy driver state
[ 6813.472015] -------------------
[ 6813.472044] now=1628368 last interrupt=1627616 diff=752 last called handler=recal_interrupt
[ 6813.472047] timeout_message=floppy start
[ 6813.472049] last output bytes:
[ 6813.472052] 0 90 1627616
[ 6813.472054] 13 90 1627616
[ 6813.472057] 0 90 1627616
[ 6813.472059] 1a 90 1627616
[ 6813.472061] 0 90 1627616
[ 6813.472064] 3 90 1627616
[ 6813.472066] c1 90 1627616
[ 6813.472068] 10 90 1627616
[ 6813.472070] 7 80 1627616
[ 6813.472073] 0 90 1627616
[ 6813.472075] 8 81 1627616
[ 6813.472077] e6 80 1627616
[ 6813.472079] 0 90 1627616
[ 6813.472082] 0 90 1627616
[ 6813.472084] 0 90 1627616
[ 6813.472086] 1 90 1627616
[ 6813.472088] 2 90 1627616
[ 6813.472091] 12 90 1627616
[ 6813.472093] 1b 90 1627616
[ 6813.472095] ff 90 1627616
[ 6813.472097] last result at 1627616
[ 6813.472099] last redo_fd_request at 1627616
[ 6813.472104] 20 00 .
[ 6813.472112] status=50
[ 6813.472114] fdc_busy=1
[ 6813.472119] do_floppy=main_command_interrupt
[ 6813.472125] fd_timer.function=fd_watchdog
[ 6813.472128] cont=f8434080
[ 6813.472130] current_req=f4db8230
[ 6813.472132] command_status=-1
[ 6813.472134]
[ 6813.472137] floppy0: floppy timeout called
[ 6813.472144] end_request: I/O error, dev fd0, sector 0
[ 6813.472152] Buffer I/O error on device fd0, logical block 0
[ 6813.520030] ...
[ 6816.480007]
[ 6816.480012] floppy driver state
[ 6816.480015] -------------------
[ 6816.480043] now=1629120 last interrupt=1628368 diff=752 last called handler=recal_interrupt
[ 6816.480047] timeout_message=floppy start
[ 6816.480049] last output bytes:
[ 6816.480052] 0 90 1628368
[ 6816.480055] 13 90 1628368
[ 6816.480057] 0 90 1628368
[ 6816.480059] 1a 90 1628368
[ 6816.480061] 0 90 1628368
[ 6816.480064] 3 90 1628368
[ 6816.480066] c1 90 1628368
[ 6816.480068] 10 90 1628368
[ 6816.480070] 7 80 1628368
[ 6816.480073] 0 90 1628368
[ 6816.480075] 8 81 1628368
[ 6816.480077] e6 80 1628368
[ 6816.480080] 0 90 1628368
[ 6816.480082] 0 90 1628368
[ 6816.480084] 0 90 1628368
[ 6816.480086] 1 90 1628368
[ 6816.480089] 2 90 1628368
[ 6816.480091] 12 90 1628368
[ 6816.480093] 1b 90 1628368
[ 6816.480095] ff 90 1628368
[ 6816.480097] last result at 1628368
[ 6816.480100] last redo_fd_request at 1628368
[ 6816.480104] 20 00 .
[ 6816.480112] status=50
[ 6816.480114] fdc_busy=1
[ 6816.480120] do_floppy=main_command_interrupt
[ 6816.480126] fd_timer.function=fd_watchdog
[ 6816.480128] cont=f8434080
[ 6816.480130] current_req=f4db8230
[ 6816.480132] command_status=-1
[ 6816.480134]
[ 6816.480138] floppy0: floppy timeout called
[ 6816.480145] end_request: I/O error, dev fd0, sector 0
[ 6816.480152] Buffer I/O error on device fd0, logical block 0
[ 6817.220016] ..
[ 6819.488007]
[ 6819.488012] floppy driver state
[ 6819.488014] -------------------
[ 6819.488043] now=1629872 last interrupt=1629120 diff=752 last called handler=recal_interrupt
[ 6819.488047] timeout_message=floppy start
[ 6819.488049] last output bytes:
[ 6819.488052] 0 90 1629120
[ 6819.488054] 13 90 1629120
[ 6819.488056] 0 90 1629120
[ 6819.488059] 1a 90 1629120
[ 6819.488061] 0 90 1629120
[ 6819.488063] 3 90 1629120
[ 6819.488065] c1 90 1629120
[ 6819.488068] 10 90 1629120
[ 6819.488070] 7 80 1629120
[ 6819.488072] 0 90 1629120
[ 6819.488074] 8 81 1629120
[ 6819.488077] e6 80 1629120
[ 6819.488079] 0 90 1629120
[ 6819.488081] 0 90 1629120
[ 6819.488083] 0 90 1629120
[ 6819.488086] 1 90 1629120
[ 6819.488088] 2 90 1629120
[ 6819.488090] 12 90 1629120
[ 6819.488093] 1b 90 1629120
[ 6819.488095] ff 90 1629120
[ 6819.488097] last result at 1629120
[ 6819.488099] last redo_fd_request at 1629120
[ 6819.488103] 20 00 .
[ 6819.488112] status=50
[ 6819.488114] fdc_busy=1
[ 6819.488119] do_floppy=main_command_interrupt
[ 6819.488125] fd_timer.function=fd_watchdog
[ 6819.488128] cont=f8434080
[ 6819.488130] current_req=f4db8230
[ 6819.488132] command_status=-1
[ 6819.488134]
[ 6819.488137] floppy0: floppy timeout called
[ 6819.488144] end_request: I/O error, dev fd0, sector 0
[ 6819.488152] Buffer I/O error on device fd0, logical block 0
[ 6819.688022] ...
[ 6822.496007]
[ 6822.496012] floppy driver state
[ 6822.496014] -------------------
[ 6822.496043] now=1630624 last interrupt=1629872 diff=752 last called handler=recal_interrupt
[ 6822.496046] timeout_message=floppy start
[ 6822.496049] last output bytes:
[ 6822.496051] 0 90 1629872
[ 6822.496054] 13 90 1629872
[ 6822.496056] 0 90 1629872
[ 6822.496058] 1a 90 1629872
[ 6822.496060] 0 90 1629872
[ 6822.496063] 3 90 1629872
[ 6822.496065] c1 90 1629872
[ 6822.496067] 10 90 1629872
[ 6822.496069] 7 80 1629872
[ 6822.496071] 0 90 1629872
[ 6822.496074] 8 81 1629872
[ 6822.496076] e6 80 1629872
[ 6822.496078] 0 90 1629872
[ 6822.496080] 0 90 1629872
[ 6822.496083] 0 90 1629872
[ 6822.496085] 1 90 1629872
[ 6822.496087] 2 90 1629872
[ 6822.496089] 12 90 1629872
[ 6822.496091] 1b 90 1629872
[ 6822.496094] ff 90 1629872
[ 6822.496096] last result at 1629872
[ 6822.496098] last redo_fd_request at 1629872
[ 6822.496102] 20 00 .
[ 6822.496110] status=50
[ 6822.496112] fdc_busy=1
[ 6822.496118] do_floppy=main_command_interrupt
[ 6822.496123] fd_timer.function=fd_watchdog
[ 6822.496126] cont=f8434080
[ 6822.496128] current_req=f4db8230
[ 6822.496130] command_status=-1
[ 6822.496132]
[ 6822.496135] floppy0: floppy timeout called
[ 6822.496142] end_request: I/O error, dev fd0, sector 0
[ 6822.496149] Buffer I/O error on device fd0, logical block 0
[ 6823.392013] ..
[ 6825.504007]
[ 6825.504012] floppy driver state
[ 6825.504014] -------------------
[ 6825.504044] now=1631376 last interrupt=1630624 diff=752 last called handler=recal_interrupt
[ 6825.504047] timeout_message=floppy start
[ 6825.504049] last output bytes:
[ 6825.504052] 0 90 1630624
[ 6825.504054] 13 90 1630624
[ 6825.504057] 0 90 1630624
[ 6825.504059] 1a 90 1630624
[ 6825.504061] 0 90 1630624
[ 6825.504063] 3 90 1630624
[ 6825.504066] c1 90 1630624
[ 6825.504068] 10 90 1630624
[ 6825.504070] 7 80 1630624
[ 6825.504072] 0 90 1630624
[ 6825.504074] 8 81 1630624
[ 6825.504077] e6 80 1630624
[ 6825.504079] 0 90 1630624
[ 6825.504081] 0 90 1630624
[ 6825.504083] 0 90 1630624
[ 6825.504085] 1 90 1630624
[ 6825.504088] 2 90 1630624
[ 6825.504090] 12 90 1630624
[ 6825.504092] 1b 90 1630624
[ 6825.504094] ff 90 1630624
[ 6825.504096] last result at 1630624
[ 6825.504099] last redo_fd_request at 1630624
[ 6825.504103] 20 00 .
[ 6825.504111] status=50
[ 6825.504113] fdc_busy=1
[ 6825.504118] do_floppy=main_command_interrupt
[ 6825.504124] fd_timer.function=fd_watchdog
[ 6825.504127] cont=f8434080
[ 6825.504129] current_req=f4db8230
[ 6825.504131] command_status=-1
[ 6825.504133]
[ 6825.504136] floppy0: floppy timeout called
[ 6825.504143] end_request: I/O error, dev fd0, sector 0
[ 6825.504150] Buffer I/O error on device fd0, logical block 0
[ 6825.856012] ...
[ 6828.512007]
[ 6828.512012] floppy driver state
[ 6828.512014] -------------------
[ 6828.512043] now=1632128 last interrupt=1631376 diff=752 last called handler=recal_interrupt
[ 6828.512046] timeout_message=floppy start
[ 6828.512048] last output bytes:
[ 6828.512051] 0 90 1631376
[ 6828.512054] 13 90 1631376
[ 6828.512056] 0 90 1631376
[ 6828.512058] 1a 90 1631376
[ 6828.512060] 0 90 1631376
[ 6828.512062] 3 90 1631376
[ 6828.512065] c1 90 1631376
[ 6828.512067] 10 90 1631376
[ 6828.512069] 7 80 1631376
[ 6828.512071] 0 90 1631376
[ 6828.512073] 8 81 1631376
[ 6828.512076] e6 80 1631376
[ 6828.512078] 0 90 1631376
[ 6828.512080] 0 90 1631376
[ 6828.512082] 0 90 1631376
[ 6828.512084] 1 90 1631376
[ 6828.512087] 2 90 1631376
[ 6828.512089] 12 90 1631376
[ 6828.512091] 1b 90 1631376
[ 6828.512093] ff 90 1631376
[ 6828.512095] last result at 1631376
[ 6828.512097] last redo_fd_request at 1631376
[ 6828.512101] 20 00 .
[ 6828.512110] status=50
[ 6828.512112] fdc_busy=1
[ 6828.512117] do_floppy=main_command_interrupt
[ 6828.512123] fd_timer.function=fd_watchdog
[ 6828.512125] cont=f8434080
[ 6828.512127] current_req=f4db8230
[ 6828.512129] command_status=-1
[ 6828.512131]
[ 6828.512135] floppy0: floppy timeout called
[ 6828.512141] end_request: I/O error, dev fd0, sector 0
[ 6828.512149] Buffer I/O error on device fd0, logical block 0
[ 6829.560012] ..
[ 6831.520007]
[ 6831.520013] floppy driver state
[ 6831.520015] -------------------
[ 6831.520044] now=1632880 last interrupt=1632128 diff=752 last called handler=recal_interrupt
[ 6831.520048] timeout_message=floppy start
[ 6831.520050] last output bytes:
[ 6831.520052] 0 90 1632128
[ 6831.520055] 13 90 1632128
[ 6831.520057] 0 90 1632128
[ 6831.520060] 1a 90 1632128
[ 6831.520062] 0 90 1632128
[ 6831.520064] 3 90 1632128
[ 6831.520066] c1 90 1632128
[ 6831.520069] 10 90 1632128
[ 6831.520071] 7 80 1632128
[ 6831.520073] 0 90 1632128
[ 6831.520075] 8 81 1632128
[ 6831.520078] e6 80 1632128
[ 6831.520080] 0 90 1632128
[ 6831.520082] 0 90 1632128
[ 6831.520084] 0 90 1632128
[ 6831.520087] 1 90 1632128
[ 6831.520089] 2 90 1632128
[ 6831.520091] 12 90 1632128
[ 6831.520093] 1b 90 1632128
[ 6831.520096] ff 90 1632128
[ 6831.520098] last result at 1632128
[ 6831.520100] last redo_fd_request at 1632128
[ 6831.520104] 20 00 .
[ 6831.520113] status=50
[ 6831.520115] fdc_busy=1
[ 6831.520120] do_floppy=main_command_interrupt
[ 6831.520126] fd_timer.function=fd_watchdog
[ 6831.520129] cont=f8434080
[ 6831.520131] current_req=f4db8230
[ 6831.520133] command_status=-1
[ 6831.520135]
[ 6831.520139] floppy0: floppy timeout called
[ 6831.520145] end_request: I/O error, dev fd0, sector 0
[ 6831.520153] Buffer I/O error on device fd0, logical block 0
[ 6832.028013] ...................not responding...
[ 6875.444539] sd 6:0:0:0: [sdc] READ CAPACITY failed
[ 6875.444546] sd 6:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 6875.444551] sd 6:0:0:0: [sdc] Sense Key : Not Ready [current]
[ 6875.444556] sd 6:0:0:0: [sdc] Add. Sense: Logical unit is in process of becoming ready
[ 6882.437639] sd 6:0:0:0: [sdc] Test WP failed, assume Write Enabled
[ 6889.430227] sd 6:0:0:0: [sdc] Asking for cache data failed
[ 6889.430234] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[ 6889.430240] sd 6:0:0:0: [sdc] Attached SCSI disk
[ 7079.655119] usb 1-6: USB disconnect, device number 4
[10244.200072] usb 1-6: new high-speed USB device number 5 using ehci_hcd
[10244.334855] usb 1-6: New USB device found, idVendor=0930, idProduct=6544
[10244.334860] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[10244.334864] usb 1-6: Product: DataTraveler G2
[10244.334867] usb 1-6: Manufacturer: Kingston
[10244.334870] usb 1-6: SerialNumber: 001D92DC4AE3C99113710B89
[10244.342940] scsi7 : usb-storage 1-6:1.0
[10245.340673] scsi 7:0:0:0: Direct-Access Kingston DataTraveler G2 1.00 PQ: 0 ANSI: 2
[10245.348729] sd 7:0:0:0: Attached scsi generic sg3 type 0
[10245.349777] sd 7:0:0:0: [sdc] 15654848 512-byte logical blocks: (8.01 GB/7.46 GiB)
[10245.350264] sd 7:0:0:0: [sdc] Write Protect is off
[10245.350270] sd 7:0:0:0: [sdc] Mode Sense: 65 44 09 30
[10245.350765] sd 7:0:0:0: [sdc] No Caching mode page found
[10245.350771] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[10245.354267] sd 7:0:0:0: [sdc] No Caching mode page found
[10245.354275] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[10245.355057] sdc: sdc1
[10245.359640] sd 7:0:0:0: [sdc] No Caching mode page found
[10245.359647] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[10245.359652] sd 7:0:0:0: [sdc] Attached SCSI removable disk
[10264.965337] FAT-fs (sdc1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[10368.125598] sdc: detected capacity change from 8015282176 to 0
[10370.647644] usb 1-6: USB disconnect, device number 5
[10470.016028] ------------[ cut here ]------------
[10470.016041] WARNING: at /build/linux-V87crB/linux-3.2.68/net/sched/sch_generic.c:256 dev_watchdog+0xb6/0x109()
[10470.016045] Hardware name: A7N8X-E
[10470.016048] NETDEV WATCHDOG: eth0 (skge): transmit queue 0 timed out
[10470.016051] Modules linked in: nls_utf8 nls_cp437 vfat fat usb_storage ppdev lp bnep rfcomm bluetooth rfkill nfsd nfs nfs_acl auth_rpcgss fscache lockd sunrpc loop snd_emu10k1_synth snd_emux_synth snd_seq_midi_emul snd_seq_virmidi snd_wavefront snd_emu10k1 snd_cs4236 nouveau snd_opl3_lib snd_wss_lib mxm_wmi snd_ac97_codec wmi snd_mpu401 snd_mpu401_uart video ttm drm_kms_helper snd_util_mem snd_seq_midi snd_hwdep snd_seq_midi_event drm snd_pcm snd_rawmidi snd_page_alloc ac97_bus snd_seq snd_seq_device snd_timer snd emu10k1_gp power_supply i2c_algo_bit psmouse ns558 evdev shpchp gameport soundcore i2c_nforce2 i2c_core pcspkr serio_raw processor parport_pc parport thermal_sys button ext4 crc16 jbd2 mbcache sg sr_mod sd_mod crc_t10dif cdrom ata_generic sata_sil pata_amd libata ohci_hcd scsi_mod ehci_hcd floppy firewire_ohci usbcore 8139too 8139cp mii skge firewire_core crc_itu_t usb_common [last unloaded: scsi_wait_scan]
[10470.016140] Pid: 3375, comm: htop Not tainted 3.2.0-4-686-pae #1 Debian 3.2.68-1+deb7u2
[10470.016143] Call Trace:
[10470.016154] [<c10387c4>] ? warn_slowpath_common+0x68/0x79
[10470.016159] [<c12352a7>] ? dev_watchdog+0xb6/0x109
[10470.016164] [<c103883d>] ? warn_slowpath_fmt+0x29/0x2d
[10470.016169] [<c12352a7>] ? dev_watchdog+0xb6/0x109
[10470.016181] [<c103d26f>] ? local_bh_enable+0x2/0x2
[10470.016186] [<c1042500>] ? run_timer_softirq+0x150/0x1f3
[10470.016191] [<c12351f1>] ? netif_tx_unlock+0x38/0x38
[10470.016196] [<c103d26f>] ? local_bh_enable+0x2/0x2
[10470.016200] [<c103d303>] ? __do_softirq+0x94/0x12f
[10470.016204] [<c103d26f>] ? local_bh_enable+0x2/0x2
[10470.016207] <IRQ> [<c103d4f4>] ? irq_exit+0x32/0x80
[10470.016217] [<c101e6b9>] ? smp_apic_timer_interrupt+0x5b/0x65
[10470.016226] [<c12c63ad>] ? apic_timer_interrupt+0x31/0x38
[10470.016229] ---[ end trace f4d9320bc612afef ]---
[13735.624100] usb 1-6: new high-speed USB device number 6 using ehci_hcd
[13736.121906] usb 1-6: New USB device found, idVendor=174c, idProduct=55aa
[13736.121912] usb 1-6: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[13736.121916] usb 1-6: Product: MS
[13736.121919] usb 1-6: Manufacturer:
[13736.121922] usb 1-6: SerialNumber: 12345678942B
[13736.123493] scsi8 : usb-storage 1-6:1.0
[13737.337583] scsi 8:0:0:0: Direct-Access MS 0 PQ: 0 ANSI: 6
[13737.340384] sd 8:0:0:0: Attached scsi generic sg3 type 0
[13737.344482] sd 8:0:0:0: [sdc] Spinning up disk.....................................................................................not responding...
[13859.612328] sd 8:0:0:0: [sdc] READ CAPACITY failed
[13859.612335] sd 8:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[13859.612340] sd 8:0:0:0: [sdc] Sense Key : Not Ready [current]
[13859.612345] sd 8:0:0:0: [sdc] Add. Sense: Logical unit is in process of becoming ready
[13866.609668] sd 8:0:0:0: [sdc] Test WP failed, assume Write Enabled
[13873.609065] sd 8:0:0:0: [sdc] Asking for cache data failed
[13873.609072] sd 8:0:0:0: [sdc] Assuming drive cache: write through
[13873.618251] sd 8:0:0:0: [sdc] Spinning up disk................................................................................not responding...
et kern.log > angelik.altervista.org/angelique/kern
je pense avoir vu un truc :
Jun 23 12:43:28 debian kernel: [13735.624100] usb 1-6: new high-speed USB device number 6 using ehci_hcd
Jun 23 12:43:28 debian kernel: [13736.121906] usb 1-6: New USB device found, idVendor=174c, idProduct=55aa
Jun 23 12:43:28 debian kernel: [13736.121912] usb 1-6: New USB device strings: Mfr=2, Product=3, SerialNumber=1
Jun 23 12:43:28 debian kernel: [13736.121916] usb 1-6: Product: MS
Jun 23 12:43:28 debian kernel: [13736.121919] usb 1-6: Manufacturer:
Jun 23 12:43:28 debian kernel: [13736.121922] usb 1-6: SerialNumber: 12345678942B
Jun 23 12:43:28 debian kernel: [13736.123493] scsi8 : usb-storage 1-6:1.0
Jun 23 12:43:29 debian kernel: [13737.337583] scsi 8:0:0:0: Direct-Access MS 0 PQ: 0 ANSI: 6
Jun 23 12:43:29 debian kernel: [13737.340384] sd 8:0:0:0: Attached scsi generic sg3 type 0
Jun 23 12:45:11 debian kernel: [13737.344482] sd 8:0:0:0: [sdc] Spinning up disk…not responding…
Jun 23 12:45:32 debian kernel: [13859.612328] sd 8:0:0:0: [sdc] READ CAPACITY failed
Jun 23 12:45:32 debian kernel: [13859.612335] sd 8:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Jun 23 12:45:32 debian kernel: [13859.612340] sd 8:0:0:0: [sdc] Sense Key : Not Ready [current]
Jun 23 12:45:32 debian kernel: [13859.612345] sd 8:0:0:0: [sdc] Add. Sense: Logical unit is in process of becoming ready
Jun 23 12:45:39 debian kernel: [13866.609668] sd 8:0:0:0: [sdc] Test WP failed, assume Write Enabled
Jun 23 12:45:46 debian kernel: [13873.609065] sd 8:0:0:0: [sdc] Asking for cache data failed
Jun 23 12:45:46 debian kernel: [13873.609072] sd 8:0:0:0: [sdc] Assuming drive cache: write through
Jun 23 12:47:26 debian kernel: [13873.618251] sd 8:0:0:0: [sdc] Spinning up disk…not responding…
Jun 23 12:47:48 debian kernel: [13995.462306] sd 8:0:0:0: [sdc] READ CAPACITY failed
Mon matos ancien ne lit pas les disks de trop grande capacité ??? READ CAPACITY failed
