Suite à l’installation chaotique de l’eepc1015pem, je n’ai pas de son (entre autres choses).
# aplay -l
aplay: device_list:235: no soundcards found...
# lspci
00:00.0 Host bridge: Intel Corporation N10 Family DMI Bridge (rev 02)
00:02.0 VGA compatible controller: Intel Corporation N10 Family Integrated Graphics Controller (rev 02)
00:02.1 Display controller: Intel Corporation N10 Family Integrated Graphics Controller (rev 02)
00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 2 (rev 02)
00:1c.2 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 3 (rev 02)
00:1c.3 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 4 (rev 02)
00:1d.0 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
00:1f.0 ISA bridge: Intel Corporation NM10 Family LPC Controller (rev 02)
00:1f.2 SATA controller: Intel Corporation N10/ICH7 Family SATA AHCI Controller (rev 02)
01:00.0 Ethernet controller: Atheros Communications AR8131 Gigabit Ethernet (rev c0)
02:00.0 USB Controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 03)
03:00.0 Network controller: Broadcom Corporation BCM4313 802.11b/g/n Wireless LAN Controller (rev 01)
J’ai rajouté ça dans /etc/modprobe.d/alsa-base.conf :
options snd-hda-intel model=auto
Mais je pense que le pilote n’est tout simplement pas chargé.
# lsmod
Module Size Used by
i915 315266 2
drm_kms_helper 26893 1 i915
drm 165567 3 i915,drm_kms_helper
i2c_algo_bit 12834 1 i915
button 12994 1 i915
i2c_core 23725 4 i915,drm_kms_helper,drm,i2c_algo_bit
video 17553 1 i915
evdev 17475 9
uinput 17392 1
fuse 61520 1
loop 22515 0
ext4 285166 2
mbcache 12930 1 ext4
jbd2 65157 1 ext4
crc16 12343 1 ext4
sd_mod 35501 4
crc_t10dif 12348 1 sd_mod
uhci_hcd 26290 0
ahci 25089 3
libahci 22568 1 ahci
libata 147240 2 ahci,libahci
ehci_hcd 39529 0
scsi_mod 161457 2 sd_mod,libata
usbcore 122908 3 uhci_hcd,ehci_hcd
atl1c 31796 0
nls_base 12753 1 usbcore
thermal 17330 0
thermal_sys 17939 2 video,thermal
quelqu’un pour m’aider?
Merci,
pl.
Sid, c’est unstable (c’est pas mieux…). Je l’utilise sans soucis sur un autre pc.
