Bonjour tout le monde,
J’ai un problème :
ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_req=2 ttl=64 time=3502 ms
64 bytes from 192.168.1.1: icmp_req=3 ttl=64 time=2494 ms
64 bytes from 192.168.1.1: icmp_req=4 ttl=64 time=1488 ms
64 bytes from 192.168.1.1: icmp_req=5 ttl=64 time=481 ms
64 bytes from 192.168.1.1: icmp_req=6 ttl=64 time=3411 ms
64 bytes from 192.168.1.1: icmp_req=7 ttl=64 time=2404 ms
64 bytes from 192.168.1.1: icmp_req=8 ttl=64 time=1397 ms
64 bytes from 192.168.1.1: icmp_req=9 ttl=64 time=390 ms
64 bytes from 192.168.1.1: icmp_req=10 ttl=64 time=3402 ms
64 bytes from 192.168.1.1: icmp_req=11 ttl=64 time=2396 ms
64 bytes from 192.168.1.1: icmp_req=12 ttl=64 time=1389 ms
64 bytes from 192.168.1.1: icmp_req=13 ttl=64 time=381 ms
^C
— 192.168.1.1 ping statistics —
14 packets transmitted, 12 received, 14% packet loss, time 13081ms
rtt min/avg/max/mdev = 381.545/1928.428/3502.312/1126.750 ms, pipe 4
En fait, j’ai 2 problèmes :
ping 192.168.1.10
PING 192.168.1.10 (192.168.1.10) 56(84) bytes of data.
64 bytes from 192.168.1.10: icmp_req=20 ttl=128 time=3373 ms
64 bytes from 192.168.1.10: icmp_req=21 ttl=128 time=2370 ms
64 bytes from 192.168.1.10: icmp_req=22 ttl=128 time=1369 ms
64 bytes from 192.168.1.10: icmp_req=23 ttl=128 time=370 ms
64 bytes from 192.168.1.10: icmp_req=28 ttl=128 time=3356 ms
64 bytes from 192.168.1.10: icmp_req=29 ttl=128 time=2357 ms
64 bytes from 192.168.1.10: icmp_req=30 ttl=128 time=1358 ms
64 bytes from 192.168.1.10: icmp_req=31 ttl=128 time=359 ms
64 bytes from 192.168.1.10: icmp_req=40 ttl=128 time=3235 ms
64 bytes from 192.168.1.10: icmp_req=41 ttl=128 time=2237 ms
64 bytes from 192.168.1.10: icmp_req=42 ttl=128 time=1238 ms
64 bytes from 192.168.1.10: icmp_req=43 ttl=128 time=239 ms
^C
— 192.168.1.10 ping statistics —
45 packets transmitted, 12 received, 73% packet loss, time 44171ms
rtt min/avg/max/mdev = 239.770/1822.209/3373.605/1119.238 ms, pipe 4
Inutile de dire que la navigation sur internet est un peu lente.
Yam
