La réponse au dmesg est un peu longue :
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] dfl dfl lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at e4000000 (gap: e4000000:1ac00000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 14 pages/cpu @c3000000 s34328 r0 d23016 u1048576
[ 0.000000] pcpu-alloc: s34328 r0 d23016 u1048576 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 844929
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-686 root=UUID=da0b1b6a-a8dc-45f1-8310-bc3894639c68 ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Enabling fast FPU save and restore… done.
[ 0.000000] Enabling unmasked SIMD FPU exception support… done.
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x3, cntxt size 0x240
[ 0.000000] Initializing HighMem for node 0 (000373fe:000cfee0)
[ 0.000000] Memory: 3363964k/3406720k available (2506k kernel code, 41200k reserved, 1326k data, 380k init, 2501512k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xffd56000 - 0xfffff000 (2724 kB)
[ 0.000000] pkmap : 0xff400000 - 0xff800000 (4096 kB)
[ 0.000000] vmalloc : 0xf7bfe000 - 0xff3fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf73fe000 ( 883 MB)
[ 0.000000] .init : 0xc13bf000 - 0xc141e000 ( 380 kB)
[ 0.000000] .data : 0xc1272a57 - 0xc13be4c4 (1326 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1272a57 (2506 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode…Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:1280
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2800.297 MHz processor.
[ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency… 5600.59 BogoMIPS (lpj=11201188)
[ 0.004017] Security Framework initialized
[ 0.004021] SELinux: Disabled at boot.
[ 0.004027] Mount-cache hash table entries: 512
[ 0.004124] Initializing cgroup subsys ns
[ 0.004128] Initializing cgroup subsys cpuacct
[ 0.004131] Initializing cgroup subsys devices
[ 0.004133] Initializing cgroup subsys freezer
[ 0.004135] Initializing cgroup subsys net_cls
[ 0.004153] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.004155] CPU: L2 cache: 3072K
[ 0.004157] CPU: Physical Processor ID: 0
[ 0.004159] CPU: Processor Core ID: 0
[ 0.004161] mce: CPU supports 6 MCE banks
[ 0.004168] CPU0: Thermal monitoring enabled (TM2)
[ 0.004171] using mwait in idle threads.
[ 0.004176] Performance Events: Core2 events, Intel PMU driver.
[ 0.004181] … version: 2
[ 0.004182] … bit width: 40
[ 0.004184] … generic registers: 2
[ 0.004185] … value mask: 000000ffffffffff
[ 0.004186] … max period: 000000007fffffff
[ 0.004188] … fixed-purpose events: 3
[ 0.004189] … event mask: 0000000700000003
[ 0.004194] Checking ‘hlt’ instruction… OK.
[ 0.021087] ACPI: Core revision 20090903
[ 0.025662] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.025990] …TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.065684] CPU0: Intel® Core™2 Duo CPU E7400 @ 2.80GHz stepping 0a
[ 0.068001] Booting processor 1 APIC 0x1 ip 0x6000
[ 0.008000] Initializing CPU#1
[ 0.008000] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.008000] CPU: L2 cache: 3072K
[ 0.008000] CPU: Physical Processor ID: 0
[ 0.008000] CPU: Processor Core ID: 1
[ 0.008000] CPU1: Thermal monitoring enabled (TM2)
[ 0.152059] CPU1: Intel® Core™2 Duo CPU E7400 @ 2.80GHz stepping 0a
[ 0.152065] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[ 0.156043] Brought up 2 CPUs
[ 0.156046] Total of 2 processors activated (11200.50 BogoMIPS).
[ 0.157092] CPU0 attaching sched-domain:
[ 0.157096] domain 0: span 0-1 level MC
[ 0.157098] groups: group c3003778 cpus 0 group c3103778 cpus 1
[ 0.157103] CPU1 attaching sched-domain:
[ 0.157105] domain 0: span 0-1 level MC
[ 0.157107] groups: group c3103778 cpus 1 group c3003778 cpus 0
[ 0.157158] devtmpfs: initialized
[ 0.157158] regulator: core version 0.5
[ 0.157158] NET: Registered protocol family 16
[ 0.157158] ACPI: bus type pci registered
[ 0.157158] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 63
[ 0.157158] PCI: MCFG area at e0000000 reserved in E820
[ 0.157158] PCI: Using MMCONFIG for extended config space
[ 0.157158] PCI: Using configuration type 1 for base access
[ 0.157158] bio: create slab at 0
[ 0.157158] ACPI: EC: Look up EC in DSDT
[ 0.162394] ACPI: Interpreter enabled
[ 0.162401] ACPI: (supports S0 S3 S4 S5)
[ 0.162419] ACPI: Using IOAPIC for interrupt routing
[ 0.165844] ACPI: No dock devices found.
[ 0.165919] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.166000] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.166003] pci 0000:00:01.0: PME# disabled
[ 0.166053] pci 0000:00:1b.0: reg 10 64bit mmio: [0xe9100000-0xe9103fff]
[ 0.166088] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.166092] pci 0000:00:1b.0: PME# disabled
[ 0.166143] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.166146] pci 0000:00:1c.0: PME# disabled
[ 0.166200] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.166204] pci 0000:00:1c.3: PME# disabled
[ 0.166243] pci 0000:00:1d.0: reg 20 io port: [0xe000-0xe01f]
[ 0.166284] pci 0000:00:1d.1: reg 20 io port: [0xe100-0xe11f]
[ 0.166325] pci 0000:00:1d.2: reg 20 io port: [0xe200-0xe21f]
[ 0.166365] pci 0000:00:1d.3: reg 20 io port: [0xe300-0xe31f]
[ 0.166404] pci 0000:00:1d.7: reg 10 32bit mmio: [0xe9104000-0xe91043ff]
[ 0.166547] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0800 (mask 000f)
[ 0.166550] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0290 (mask 000f)
[ 0.166590] pci 0000:00:1f.2: reg 10 io port: [0x00-0x07]
[ 0.166595] pci 0000:00:1f.2: reg 14 io port: [0x00-0x03]
[ 0.166600] pci 0000:00:1f.2: reg 18 io port: [0x00-0x07]
[ 0.166605] pci 0000:00:1f.2: reg 1c io port: [0x00-0x03]
[ 0.166610] pci 0000:00:1f.2: reg 20 io port: [0xf000-0xf00f]
[ 0.166630] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.166633] pci 0000:00:1f.2: PME# disabled
[ 0.166672] pci 0000:00:1f.3: reg 20 io port: [0x500-0x51f]
[ 0.166716] pci 0000:01:00.0: reg 10 32bit mmio: [0xe6000000-0xe6ffffff]
[ 0.166724] pci 0000:01:00.0: reg 14 64bit mmio pref: [0xd0000000-0xdfffffff]
[ 0.166732] pci 0000:01:00.0: reg 1c 64bit mmio: [0xe4000000-0xe5ffffff]
[ 0.166737] pci 0000:01:00.0: reg 24 io port: [0xc000-0xc07f]
[ 0.166742] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.166837] pci 0000:00:01.0: bridge io port: [0xc000-0xcfff]
[ 0.166840] pci 0000:00:01.0: bridge 32bit mmio: [0xe4000000-0xe7ffffff]
[ 0.166844] pci 0000:00:01.0: bridge 64bit mmio pref: [0xd0000000-0xdfffffff]
[ 0.166876] pci 0000:00:1c.0: bridge io port: [0xb000-0xbfff]
[ 0.166923] pci 0000:03:00.0: reg 10 io port: [0xd000-0xd0ff]
[ 0.166941] pci 0000:03:00.0: reg 18 64bit mmio pref: [0xe9010000-0xe9010fff]
[ 0.166954] pci 0000:03:00.0: reg 20 64bit mmio pref: [0xe9000000-0xe900ffff]
[ 0.166961] pci 0000:03:00.0: reg 30 32bit mmio pref: [0x000000-0x00ffff]
[ 0.166996] pci 0000:03:00.0: supports D1 D2
[ 0.166998] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.167003] pci 0000:03:00.0: PME# disabled
[ 0.172081] pci 0000:00:1c.3: bridge io port: [0xd000-0xdfff]
[ 0.172086] pci 0000:00:1c.3: bridge 32bit mmio: [0xe8000000-0xe8ffffff]
[ 0.172092] pci 0000:00:1c.3: bridge 64bit mmio pref: [0xe9000000-0xe90fffff]
[ 0.172143] pci 0000:00:1e.0: transparent bridge
[ 0.172147] pci 0000:00:1e.0: bridge io port: [0xa000-0xafff]
[ 0.172170] pci_bus 0000:00: on NUMA node 0
[ 0.172175] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
[ 0.172301] ACPI: PCI Interrupt Routing Table [_SB.PCI0.PEX0.PRT]
[ 0.172351] ACPI: PCI Interrupt Routing Table [_SB.PCI0.PEX3.PRT]
[ 0.172401] ACPI: PCI Interrupt Routing Table [_SB.PCI0.HUB0._PRT]
[ 0.180331] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
[ 0.180406] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.180481] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 9 10 11 12 14 15)
[ 0.180553] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[ 0.180627] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.180700] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.180772] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.180845] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[ 0.180925] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.180927] vgaarb: loaded
[ 0.180940] PCI: Using ACPI for IRQ routing
[ 0.180940] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.180940] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.180940] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.184016] Switching to clocksource tsc
[ 0.185085] pnp: PnP ACPI init
[ 0.185091] ACPI: bus type pnp registered
[ 0.187178] pnp: PnP ACPI: found 16 devices
[ 0.187180] ACPI: ACPI bus type pnp unregistered
[ 0.187184] PnPBIOS: Disabled by ACPI PNP
[ 0.187191] system 00:01: ioport range 0x4d0-0x4d1 has been reserved
[ 0.187193] system 00:01: ioport range 0x290-0x29f has been reserved
[ 0.187196] system 00:01: ioport range 0x800-0x87f has been reserved
[ 0.187198] system 00:01: ioport range 0x290-0x294 has been reserved
[ 0.187200] system 00:01: ioport range 0x880-0x88f has been reserved
[ 0.187207] system 00:0c: ioport range 0x400-0x4bf has been reserved
[ 0.187211] system 00:0d: iomem range 0xe0000000-0xe3ffffff has been reserved
[ 0.187216] system 00:0e: iomem range 0xcd200-0xcffff has been reserved
[ 0.187218] system 00:0e: iomem range 0xf0000-0xf7fff could not be reserved
[ 0.187221] system 00:0e: iomem range 0xf8000-0xfbfff could not be reserved
[ 0.187223] system 00:0e: iomem range 0xfc000-0xfffff could not be reserved
[ 0.187226] system 00:0e: iomem range 0xcfee0000-0xcfefffff could not be reserved
[ 0.187228] system 00:0e: iomem range 0x0-0x9ffff could not be reserved
[ 0.187231] system 00:0e: iomem range 0x100000-0xcfedffff could not be reserved
[ 0.187233] system 00:0e: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.187236] system 00:0e: iomem range 0xfed13000-0xfed1dfff has been reserved
[ 0.187238] system 00:0e: iomem range 0xfed20000-0xfed8ffff has been reserved
[ 0.187241] system 00:0e: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.187243] system 00:0e: iomem range 0xffb00000-0xffb7ffff has been reserved
[ 0.187246] system 00:0e: iomem range 0xfff00000-0xffffffff has been reserved
[ 0.187248] system 00:0e: iomem range 0xe0000-0xeffff has been reserved
[ 0.221904] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.221907] pci 0000:00:01.0: IO window: 0xc000-0xcfff
[ 0.221910] pci 0000:00:01.0: MEM window: 0xe4000000-0xe7ffffff
[ 0.221914] pci 0000:00:01.0: PREFETCH window: 0x000000d0000000-0x000000dfffffff
[ 0.221917] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:02
[ 0.221920] pci 0000:00:1c.0: IO window: 0xb000-0xbfff
[ 0.221924] pci 0000:00:1c.0: MEM window: 0xe9200000-0xe93fffff
[ 0.221928] pci 0000:00:1c.0: PREFETCH window: 0x000000e9400000-0x000000e95fffff
[ 0.221934] pci 0000:00:1c.3: PCI bridge, secondary bus 0000:03
[ 0.221936] pci 0000:00:1c.3: IO window: 0xd000-0xdfff
[ 0.221941] pci 0000:00:1c.3: MEM window: 0xe8000000-0xe8ffffff
[ 0.221944] pci 0000:00:1c.3: PREFETCH window: 0x000000e9000000-0x000000e90fffff
[ 0.221950] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:04
[ 0.221952] pci 0000:00:1e.0: IO window: 0xa000-0xafff
[ 0.221956] pci 0000:00:1e.0: MEM window: disabled
[ 0.221959] pci 0000:00:1e.0: PREFETCH window: disabled
[ 0.221970] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.221973] pci 0000:00:01.0: setting latency timer to 64
[ 0.221980] pci 0000:00:1c.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.221983] pci 0000:00:1c.0: setting latency timer to 64
[ 0.221990] pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[ 0.221994] pci 0000:00:1c.3: setting latency timer to 64
[ 0.221999] pci 0000:00:1e.0: setting latency timer to 64
[ 0.222002] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.222004] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.222006] pci_bus 0000:01: resource 0 io: [0xc000-0xcfff]
[ 0.222009] pci_bus 0000:01: resource 1 mem: [0xe4000000-0xe7ffffff]
[ 0.222011] pci_bus 0000:01: resource 2 pref mem [0xd0000000-0xdfffffff]
[ 0.222013] pci_bus 0000:02: resource 0 io: [0xb000-0xbfff]
[ 0.222015] pci_bus 0000:02: resource 1 mem: [0xe9200000-0xe93fffff]
[ 0.222018] pci_bus 0000:02: resource 2 pref mem [0xe9400000-0xe95fffff]
[ 0.222020] pci_bus 0000:03: resource 0 io: [0xd000-0xdfff]
[ 0.222022] pci_bus 0000:03: resource 1 mem: [0xe8000000-0xe8ffffff]
[ 0.222024] pci_bus 0000:03: resource 2 pref mem [0xe9000000-0xe90fffff]
[ 0.222026] pci_bus 0000:04: resource 0 io: [0xa000-0xafff]
[ 0.222029] pci_bus 0000:04: resource 3 io: [0x00-0xffff]
[ 0.222031] pci_bus 0000:04: resource 4 mem: [0x000000-0xffffffff]
[ 0.222053] NET: Registered protocol family 2
[ 0.222118] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.222326] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.222612] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.222759] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.222761] TCP reno registered
[ 0.222813] NET: Registered protocol family 1
[ 0.222900] pci 0000:01:00.0: Boot video device
[ 0.222932] Unpacking initramfs…
[ 0.423596] Freeing initrd memory: 8507k freed
[ 0.426952] audit: initializing netlink socket (disabled)
[ 0.426964] type=2000 audit(1331189041.423:1): initialized
[ 0.429948] highmem bounce pool size: 64 pages
[ 0.429952] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.431055] VFS: Disk quotas dquot_6.5.2
[ 0.431097] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.431157] msgmni has been set to 1703
[ 0.431306] alg: No test for stdrng (krng)
[ 0.431344] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.431347] io scheduler noop registered
[ 0.431348] io scheduler anticipatory registered
[ 0.431350] io scheduler deadline registered
[ 0.431376] io scheduler cfq registered (default)
[ 0.431465] pcieport 0000:00:01.0: irq 24 for MSI/MSI-X
[ 0.431470] pcieport 0000:00:01.0: setting latency timer to 64
[ 0.431550] pcieport 0000:00:1c.0: irq 25 for MSI/MSI-X
[ 0.431556] pcieport 0000:00:1c.0: setting latency timer to 64
[ 0.431648] pcieport 0000:00:1c.3: irq 26 for MSI/MSI-X
[ 0.431654] pcieport 0000:00:1c.3: setting latency timer to 64
[ 0.431821] isapnp: Scanning for PnP cards…
[ 0.784640] isapnp: No Plug & Play device found
[ 0.785679] Linux agpgart interface v0.103
[ 0.785775] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.785860] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.786128] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.786281] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.786682] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.786688] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.786754] mice: PS/2 mouse device common for all mice
[ 0.786811] rtc_cmos 00:04: RTC can wake from S4
[ 0.786848] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.786871] rtc0: alarms up to one month, 242 bytes nvram, hpet irqs
[ 0.786887] cpuidle: using governor ladder
[ 0.786889] cpuidle: using governor menu
[ 0.786894] No iBFT detected.
[ 0.787186] TCP cubic registered
[ 0.787292] NET: Registered protocol family 10
[ 0.787867] Mobile IPv6
[ 0.787870] NET: Registered protocol family 17
[ 0.787881] Using IPI No-Shortcut mode
[ 0.787929] PM: Resume from disk failed.
[ 0.787937] registered taskstats version 1
[ 0.788166] rtc_cmos 00:04: setting system clock to 2012-03-08 06:44:01 UTC (1331189041)
[ 0.788204] Initalizing network drop monitor service
[ 0.788224] Freeing unused kernel memory: 380k freed
[ 0.788374] Write protecting the kernel text: 2508k
[ 0.788391] Write protecting the kernel read-only data: 920k
[ 0.800598] udev[56]: starting version 164
[ 0.803774] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 0.887351] usbcore: registered new interface driver usbfs
[ 0.887371] usbcore: registered new interface driver hub
[ 0.887667] usbcore: registered new device driver usb
[ 0.899448] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.899467] r8169 0000:03:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 0.899509] r8169 0000:03:00.0: setting latency timer to 64
[ 0.899556] r8169 0000:03:00.0: irq 27 for MSI/MSI-X
[ 0.900066] r8169 0000:03:00.0: eth0: RTL8168c/8111c at 0xf7d06000, 00:24:1d:14:f7:44, XID 1c4000c0 IRQ 27
[ 0.901281] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.901301] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 0.901309] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 0.901312] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 0.901326] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 0.901342] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 0.902080] SCSI subsystem initialized
[ 0.905232] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 0.905347] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xe9104000
[ 0.918126] Floppy drive(s): fd0 is 1.44M
[ 0.920127] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 0.920155] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.920157] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.920159] usb usb1: Product: EHCI Host Controller
[ 0.920161] usb usb1: Manufacturer: Linux 2.6.32-5-686 ehci_hcd
[ 0.920163] usb usb1: SerialNumber: 0000:00:1d.7
[ 0.920254] usb usb1: configuration #1 chosen from 1 choice
[ 0.920305] hub 1-0:1.0: USB hub found
[ 0.920311] hub 1-0:1.0: 8 ports detected
[ 0.920835] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.920866] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 0.920873] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.920875] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.920883] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.920904] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000e000
[ 0.920928] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.920930] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.920932] usb usb2: Product: UHCI Host Controller
[ 0.920934] usb usb2: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
[ 0.920936] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.920984] usb usb2: configuration #1 chosen from 1 choice
[ 0.921005] hub 2-0:1.0: USB hub found
[ 0.921010] hub 2-0:1.0: 2 ports detected
[ 0.921045] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.921050] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.921053] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.921058] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 0.921084] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000e100
[ 0.921108] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.921110] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.921112] usb usb3: Product: UHCI Host Controller
[ 0.921114] usb usb3: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
[ 0.921115] usb usb3: SerialNumber: 0000:00:1d.1
[ 0.921117] libata version 3.00 loaded.
[ 0.921162] usb usb3: configuration #1 chosen from 1 choice
[ 0.921184] hub 3-0:1.0: USB hub found
[ 0.921189] hub 3-0:1.0: 2 ports detected
[ 0.921223] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.921228] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.921231] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.921236] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 0.921261] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000e200
[ 0.921286] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.921288] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.921290] usb usb4: Product: UHCI Host Controller
[ 0.921292] usb usb4: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
[ 0.921293] usb usb4: SerialNumber: 0000:00:1d.2
[ 0.921338] usb usb4: configuration #1 chosen from 1 choice
[ 0.921359] hub 4-0:1.0: USB hub found
[ 0.921364] hub 4-0:1.0: 2 ports detected
[ 0.921398] uhci_hcd 0000:00:1d.3: PCI INT D -> GSI 16 (level, low) -> IRQ 16
[ 0.921402] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 0.921405] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 0.921410] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 0.921435] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000e300
[ 0.921459] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.921461] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.921463] usb usb5: Product: UHCI Host Controller
[ 0.921465] usb usb5: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
[ 0.921466] usb usb5: SerialNumber: 0000:00:1d.3
[ 0.921511] usb usb5: configuration #1 chosen from 1 choice
[ 0.921532] hub 5-0:1.0: USB hub found
[ 0.921536] hub 5-0:1.0: 2 ports detected
[ 0.923226] ata_piix 0000:00:1f.2: version 2.13
[ 0.923237] ata_piix 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.923241] ata_piix 0000:00:1f.2: MAP [ P0 P2 IDE IDE ]
[ 0.923270] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 0.923581] scsi0 : ata_piix
[ 0.923670] scsi1 : ata_piix
[ 0.924261] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf000 irq 14
[ 0.924263] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xf008 irq 15
[ 0.935451] FDC 0 is a post-1991 82077
[ 1.089636] ata1.00: HPA detected: current 240119615, native 240121728
[ 1.089642] ata1.00: ATA-7: Maxtor 6L120M0, BANC1E00, max UDMA/133
[ 1.089646] ata1.00: 240119615 sectors, multi 16: LBA NCQ (not used)
[ 1.105134] ata1.00: configured for UDMA/133
[ 1.105243] scsi 0:0:0:0: Direct-Access ATA Maxtor 6L120M0 BANC PQ: 0 ANSI: 5
[ 1.208294] ata2.00: ATAPI: DVD-ROM DDU1622, VER AS72, max UDMA/66
[ 1.208322] ata2.01: ATAPI: SONY DVD RW DW-Q28A, KYS1, max UDMA/66
[ 1.224206] ata2.00: configured for UDMA/66
[ 1.232512] usb 1-1: new high speed USB device using ehci_hcd and address 2
[ 1.240211] ata2.01: configured for UDMA/66
[ 1.241068] scsi 1:0:0:0: CD-ROM SONY DVD-ROM DDU1622 AS72 PQ: 0 ANSI: 5
[ 1.242019] scsi 1:0:1:0: CD-ROM SONY DVD RW DW-Q28A KYS1 PQ: 0 ANSI: 5
[ 1.250229] sr0: scsi3-mmc drive: 16x/40x cd/rw xa/form2 cdda tray
[ 1.250232] Uniform CD-ROM driver Revision: 3.20
[ 1.250369] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.251966] sd 0:0:0:0: [sda] 240119615 512-byte logical blocks: (122 GB/114 GiB)
[ 1.252018] sd 0:0:0:0: [sda] Write Protect is off
[ 1.252020] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.252038] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 1.252175] sda:sr1: scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray
[ 1.254111] sr 1:0:1:0: Attached scsi CD-ROM sr1
[ 1.274390] sda1 sda2 sda3 sda4 < sda5 sda6 >
[ 1.290390] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.294212] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.294237] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.294260] sr 1:0:1:0: Attached scsi generic sg2 type 5
[ 1.369087] usb 1-1: New USB device found, idVendor=05e3, idProduct=0710
[ 1.369091] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=2
[ 1.369095] usb 1-1: Product: USB Storage
[ 1.369097] usb 1-1: SerialNumber: 000000009144
[ 1.369177] usb 1-1: configuration #1 chosen from 1 choice
[ 1.375197] Initializing USB Mass Storage driver…
[ 1.375341] scsi2 : SCSI emulation for USB Mass Storage devices
[ 1.375398] usbcore: registered new interface driver usb-storage
[ 1.375400] USB Mass Storage support registered.
[ 1.375524] usb-storage: device found at 2
[ 1.375526] usb-storage: waiting for device to settle before scanning
[ 1.480513] usb 1-3: new high speed USB device using ehci_hcd and address 3
[ 1.630806] usb 1-3: New USB device found, idVendor=13b1, idProduct=002f
[ 1.630810] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.630813] usb 1-3: Product: Linksys AE1000
[ 1.630816] usb 1-3: Manufacturer: Linksys
[ 1.630898] usb 1-3: configuration #1 chosen from 1 choice
[ 1.939865] EXT4-fs (sda5): mounted filesystem with ordered data mode
[ 3.946494] udev[442]: starting version 164
[ 5.907988] nvidia: module license ‘NVIDIA’ taints kernel.
[ 5.907991] Disabling lock debugging due to kernel taint
[ 6.372528] usb-storage: device scan complete
[ 6.373763] scsi 2:0:0:0: Direct-Access Generic STORAGE DEVICE 9144 PQ: 0 ANSI: 0
[ 6.375006] scsi 2:0:0:1: Direct-Access Generic STORAGE DEVICE 9144 PQ: 0 ANSI: 0
[ 6.376254] scsi 2:0:0:2: Direct-Access Generic STORAGE DEVICE 9144 PQ: 0 ANSI: 0
[ 6.377507] scsi 2:0:0:3: Direct-Access Generic STORAGE DEVICE 9144 PQ: 0 ANSI: 0
[ 6.377984] sd 2:0:0:0: Attached scsi generic sg3 type 0
[ 6.378195] sd 2:0:0:1: Attached scsi generic sg4 type 0
[ 6.378402] sd 2:0:0:2: Attached scsi generic sg5 type 0
[ 6.378611] sd 2:0:0:3: Attached scsi generic sg6 type 0
[ 6.390122] sd 2:0:0:1: [sdc] Attached SCSI removable disk
[ 6.395944] sd 2:0:0:3: [sde] Attached SCSI removable disk
[ 6.403871] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 6.404870] sd 2:0:0:2: [sdd] Attached SCSI removable disk
[ 6.548394] input: PC Speaker as /devices/platform/pcspkr/input/input1
[ 6.560619] ACPI: SSDT cfee6d80 0022A (v01 PmRef Cpu0Ist 00003000 INTL 20040311)
[ 6.560915] processor LNXCPU:00: registered as cooling_device0
[ 6.561082] ACPI: SSDT cfee7240 00152 (v01 PmRef Cpu1Ist 00003000 INTL 20040311)
[ 6.792570] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 6.792578] nvidia 0000:01:00.0: setting latency timer to 64
[ 6.792582] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 6.792685] processor LNXCPU:01: registered as cooling_device1
[ 6.792821] NVRM: loading NVIDIA UNIX x86 Kernel Module 195.36.31 Tue Jun 1 22:08:27 PDT 2010
[ 6.844054] rt3572sta: disagrees about version of symbol module_layout
[ 6.845062] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 6.845106] ACPI: Power Button [PWRB]
[ 6.845156] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 6.845175] ACPI: Power Button [PWRF]
[ 6.848723] i801_smbus 0000:00:1f.3: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 6.850668] intel_rng: FWH not detected
[ 6.944221] parport_pc 00:09: reported by Plug and Play ACPI
[ 6.944263] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[ 7.403846] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 7.403868] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 7.496602] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input4
[ 7.650936] input: ImExPS/2 Logitech Wheel Mouse as /devices/platform/i8042/serio1/input/input5
[ 8.811110] loop: module loaded
[ 9.241758] EXT4-fs (sda6): mounted filesystem with ordered data mode
[ 10.465215] fuse init (API version 7.13)
[ 14.618023] r8169 0000:03:00.0: eth0: link down
[ 14.618031] r8169 0000:03:00.0: eth0: link down
[ 14.618186] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.221350] r8169 0000:03:00.0: eth0: link up
[ 16.221574] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 17.969187] Bluetooth: Core ver 2.15
[ 17.969702] NET: Registered protocol family 31
[ 17.969705] Bluetooth: HCI device and connection manager initialized
[ 17.969708] Bluetooth: HCI socket layer initialized
[ 18.024266] Bluetooth: L2CAP ver 2.14
[ 18.024269] Bluetooth: L2CAP socket layer initialized
[ 18.268950] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.268954] Bluetooth: BNEP filters: protocol multicast
[ 18.339153] Bridge firewalling registered
[ 18.516730] lp0: using parport0 (interrupt-driven).
[ 18.591083] ppdev: user-space parallel port driver
[ 18.869370] Bluetooth: SCO (Voice Link) ver 0.6
[ 18.869373] Bluetooth: SCO socket layer initialized
[ 26.852006] eth0: no IPv6 routers present
[ 388.960933] CPU0 attaching NULL sched-domain.
[ 388.960938] CPU1 attaching NULL sched-domain.
[ 388.988566] CPU0 attaching sched-domain:
[ 388.988570] domain 0: span 0-1 level MC
[ 388.988573] groups: group c3003778 cpus 0 group c3103778 cpus 1
[ 388.988581] CPU1 attaching sched-domain:
[ 388.988583] domain 0: span 0-1 level MC
[ 388.988586] groups: group c3103778 cpus 1 group c3003778 cpus 0
[22285.305812] rt2870sta: module is from the staging directory, the quality is unknown, you have been warned.
[22285.312082] rtusb init —>
[22285.312132] usbcore: registered new interface driver rt2870
!! Avec tous mes compliments si tu arrives à t’y retrouver .
Voilà à présent la réponse à # modprobe rt2870sta :
WARNING: All config files need .conf: /etc/modprobe.d/blacklist, it will be ignored in a future release.
Là ç’est plus court mais ça ne rigole pas , c’est grave ?
