voila les extraits de dmesg je m’absente -manger- peut-etre à plus tard, mais<deja merci de ton aide)
[ 5.048544] hdb: cache flushes supported
[ 5.048593] hdb: hdb1
[ 5.062004] hdc: ATAPI 48X DVD-ROM CD-R/RW drive, 2048kB Cache
[ 5.062004] Uniform CD-ROM driver Revision: 3.20
[ 5.072011] hdd: ATAPI 40X DVD-ROM DVD-R CD-R/RW drive, 2000kB Cache
[ 5.542574] PM: Starting manual resume from disk
[ 5.602291] kjournald starting. Commit interval 5 seconds
[ 5.603686] EXT3-fs: mounted filesystem with ordered data mode.
[ 7.464795] udevd version 125 started
[ 8.546557] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 8.562565] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 8.650556] Linux agpgart interface v0.103
[ 8.706562] agpgart: Detected an Intel 865 Chipset.
[ 8.716037] agpgart: AGP aperture is 256M @ 0xe0000000
[ 8.734365] input: Power Button (FF) as /class/input/input5
[ 8.786517] ACPI: Power Button (FF) [PWRF]
[ 8.786664] input: Power Button (CM) as /class/input/input6
[ 8.822522] ACPI: Power Button (CM) [PWRB]
[ 9.654741] intel_rng: FWH not detected
[ 9.709593] ACPI: PCI Interrupt 0000:00:1f.3[B] -> GSI 17 (level, low) -> IRQ 17
[ 9.858342] Linux video capture interface: v2.00
[ 9.883640] saa7130/34: v4l2 driver version 0.2.14 loaded
[ 9.883640] ACPI: PCI Interrupt 0000:02:09.0[A] -> GSI 21 (level, low) -> IRQ 21
[ 9.883640] saa7133[0]: found at 0000:02:09.0, rev: 208, irq: 21, latency: 64, mmio: 0xff9ff800
[ 9.883640] saa7133[0]: subsystem: 11bd:002f, board: Pinnacle PCTV 310i [card=101,autodetected]
[ 9.883640] saa7133[0]: board init: gpio is 600e000
[ 9.997017] input: Pinnacle PCTV as /class/input/input7
[ 10.046299] ir-kbd-i2c: Pinnacle PCTV detected at i2c-1/1-0047/ir0 [saa7133[0]]
[ 10.095644] saa7133[0]: i2c eeprom 00: bd 11 2f 00 54 20 1c 00 43 43 a9 1c 55 d2 b2 92
[ 10.095663] saa7133[0]: i2c eeprom 10: ff e0 60 06 ff 20 ff ff 00 30 8d 2c 17 b3 ff ff
[ 10.095681] saa7133[0]: i2c eeprom 20: 01 2c 01 02 02 01 04 31 98 ff 00 a6 ff 21 00 c2
[ 10.095697] saa7133[0]: i2c eeprom 30: 96 10 03 32 15 20 ff ff 0c 22 17 77 03 1c 86 43
[ 10.095714] saa7133[0]: i2c eeprom 40: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 10.095731] saa7133[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 10.095747] saa7133[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 10.095764] saa7133[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 10.095781] saa7133[0]: i2c eeprom 80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 10.095797] saa7133[0]: i2c eeprom 90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 10.095814] saa7133[0]: i2c eeprom a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 10.095831] saa7133[0]: i2c eeprom b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 10.095847] saa7133[0]: i2c eeprom c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 10.095864] saa7133[0]: i2c eeprom d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 10.095881] saa7133[0]: i2c eeprom e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 10.095897] saa7133[0]: i2c eeprom f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 10.241000] tuner’ 1-004b: chip found @ 0x96 (saa7133[0])
[ 10.342758] tda829x 1-004b: setting tuner address to 61
[ 10.455631] tda829x 1-004b: type set to tda8290+75a
[ 14.906274] saa7133[0]: registered device video0 [v4l2]
[ 14.906274] saa7133[0]: registered device vbi0
[ 14.906274] saa7133[0]: registered device radio0
[ 14.987734] ACPI: PCI Interrupt 0000:02:0a.0[A] -> GSI 22 (level, low) -> IRQ 22
[ 15.023740] gameport: Trident 4DWave is pci0000:02:0a.0/gameport0, speed 1491kHz
[ 15.151811] DVB: registering new adapter (saa7133[0])
[ 15.151818] DVB: registering frontend 0 (Philips TDA10046H DVB-T)…
[ 15.230299] tda1004x: setting up plls for 48MHz sampling clock
[ 15.527777] tda1004x: found firmware revision 20 – ok
[ 15.833437] Adding 979956k swap on /dev/hda2. Priority:-1 extents:1 across:979956k
[ 30.434237] [drm] Setting GART location based on new memory map
[ 30.434250] [drm] Loading R500 Microcode
[ 30.434295] [drm] Num pipes: 3
[ 30.434308] [drm] writeback test succeeded in 2 usecs
[ 33.857997] eth0: no IPv6 routers present
[ 69.617080] tda1004x: setting up plls for 48MHz sampling clock
[ 69.906458] tda1004x: found firmware revision 20 – ok
[ 135.331561] tda1004x: setting up plls for 48MHz sampling clock
[ 135.661190] tda1004x: found firmware revision 20 – ok
la commande scan fr-TaVille > /home…/channel.conf
tourne
a plus
