[quote=“agentsteel”]bon ça aide pas trop
tu as quelle version de Debian? Squeeze, Wheezy?
fais voir le message d’erreur exact avec le test telnet
fais voir aussi ton fichier de conf Postfix (main.cf)[/quote]
Je possède la version Wheezy de Debian.
Test Telnet :
[quote]220 traduction-allemand-francais.eu ESMTP Postfix (Debian/GNU)
AUTH LOGIN ZXNzYWlAZXNzYWkub3Jn
502 5.5.2 Error: command not recognized
EHLO facteur.zehome.org
250-traduction-allemand-francais.eu
250-PIPELINING
250-SIZE 10240000
250-VRFY
250-ETRN
250-STARTTLS
250-ENHANCEDSTATUSCODES
250-8BITMIME
250 DSN
503 5.5.1 Error: authentication not enabled[/quote]
Le .conf de Postfix
[quote]# See /usr/share/postfix/main.cf.dist for a commented, more complete version
Debian specific: Specifying a file name will cause the first
line of that file to be used as the name. The Debian default
is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
appending .domain is the MUA’s job.
append_dot_mydomain = no
Uncomment the next line to generate “delayed mail” warnings
delay_warning_time = 1h
readme_directory = no
TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
smtpd_tls_auth_only = yes
See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
information on enabling SSL in the smtp client.
myhostname = traduction-allemand-francais.eu
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
mydestination = traduction-allemand-francais.eu, localhost, localhost.localdomain, localhost
relayhost = smtp.traduction-allemand-francais.eu
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
virtual_uid_maps = static:3000
virtual_gid_maps = static:3000
virtual_mailbox_base = /home/mail2
virtual_transport = dovecot
virtual_mailbox_domains = mysql:/etc/postfix/mysql_virtual_mailbox_domains.cf
virtual_mailbox_maps = mysql:/etc/postfix/mysql_virtual_mailbox_maps.cf
virtual_alias_maps = mysql:/etc/postfix/mysql_virtual_alias_maps.cf
relay_domains = mysql:/etc/postfix/mysql_relay_domains.cf
smtpd_recipient_restrictions =
permit_mynetworks,
permit_sasl_authenticated,
reject_non_fqdn_hostname,
reject_non_fqdn_sender,
reject_non_fqdn_recipient,
reject_unauth_destination,
reject_unauth_pipelining,
reject_invalid_hostname
check_policy_service inet:127.0.0.1:10023,
smtpd_sasl_auth_enable = yes
smtpd_sasl_security_options = noanonymous
content_filter = amavis:[127.0.0.1]:10024
receive_override_options = no_address_mappings[/quote]
