Bonjour à tous!
Je viens d’installer Debian jessie sur mon portable lenovo G50-30
comme d’habitude je galère pour l’installation du wifi !! j’ai pourtant installer le microcode realteak demandé.
voici quelques infos :
uname -a
Linux lenovo 3.16.0-4-686-pae #1 SMP Debian 3.16.7-ckt11-1 (2015-05-24) i686 GNU/Linux
Je suis sous Gnome avec network-manager (enfin je crois !!!)
[code]# iwconfig
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=0 dBm
Retry short limit:7 RTS thr=2347 B Fragment thr:off
Encryption key:off
Power Management:on
lo no wireless extensions.
eth0 no wireless extensions.
[code] cat interfaces
This file describes the network interfaces available on your system
auto lo
iface lo inet loopback
# lspci
00:00.0 Host bridge: Intel Corporation Atom Processor Z36xxx/Z37xxx Series SoC Transaction Register (rev 0c)
00:02.0 VGA compatible controller: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Graphics & Display (rev 0c)
00:13.0 SATA controller: Intel Corporation Device 0f23 (rev 0c)
00:1a.0 Encryption controller: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Trusted Execution Engine (rev 0c)
00:1b.0 Audio device: Intel Corporation Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller (rev 0c)
00:1c.0 PCI bridge: Intel Corporation Device 0f48 (rev 0c)
00:1c.2 PCI bridge: Intel Corporation Device 0f4c (rev 0c)
00:1c.3 PCI bridge: Intel Corporation Device 0f4e (rev 0c)
00:1d.0 USB controller: Intel Corporation Atom Processor Z36xxx/Z37xxx Series USB EHCI (rev 0c)
00:1f.0 ISA bridge: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Power Control Unit (rev 0c)
00:1f.3 SMBus: Intel Corporation Device 0f12 (rev 0c)
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10)
Mon interface reste toujours “désactivée” impossible de l’activer.
je ne sais plus quoi faire ?
merci d’avance
[quote=“Triangle”]Si le firmware est installé tu as deux pistes :
Désactivé dans le bios
Interrupteur physique à mettre en on.
je ne vois pas de bouton physique !!
Le Bios a été contrôlé et tout est “Enable”
[quote=“Triangle”]
Si tu utilises network-manager ou wicd, le contenu de /etx/network/interfaces n’a pas de références aux cartes gérées par ces logiciels.[/quote]
J’ai bien compris et il n’ya pas de référence à ma carte !!
Ok hybridemoineau mais je fais quoi ?
tu penses qu’il faut que je supprime network-manager et que j’installe wicd ?
Je ne suis pas certaine que ça règle mon problème ?
Vu que la carte est vu physiquement par le système, y a juste à l’allumer…
J’ai aussi un thinkpad mais un SL510 et il y a un bouton pour allumer le wifi physiquement.
Je ressors ce sujet car je n’avais pas besoins du bluetooth jusqu’à présent mais là j’aimerai bien qu’il fonctionne.
et j’avoue que je suis perdue
je n’avais pas mis de firmeware (comme pour le wifi) et je ne retrouve pas le nom ni comment faire):
je sais pas quoi vous donner pour commencer :
[code]/etc/init.d# ./bluetooth status
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
Active: active (running) since mer. 2015-12-16 21:47:48 CET; 26min ago
Docs: man:bluetoothd(8)
Main PID: 459 (bluetoothd)
Status: “Running”
CGroup: /system.slice/bluetooth.service
└─459 /usr/lib/bluetooth/bluetoothd
Peu-être que certains paquets ne sont pas installés? Là, je sèche! Je n’ai rien fait de plus et cela fonctionne parfaitement chez moi; alors que je ne m’en sers jamais.
