Salut!
Voilà j’ai un léger probleme avec ma carte ati radeon HD 5450, je n’arrive pas a la gérer correctement.
J ai essayé avec xrandr pas moyen, j’ai donc essayé d’installer fglrx-glx mais je me heurte a une erreur dans la configuration de fglrx-dkms, je ne sais pas quelles commande taper pour vous donner des infos mais voici:
lspci
00:00.0 Host bridge: Intel Corporation 5520/5500/X58 I/O Hub to ESI Port (rev 13)
00:01.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 1 (rev 13)
00:02.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 2 (rev 13)
00:03.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 3 (rev 13)
00:10.0 PIC: Intel Corporation 5520/5500/X58 Physical and Link Layer Registers Port 0 (rev 13)
00:10.1 PIC: Intel Corporation 5520/5500/X58 Routing and Protocol Layer Registers Port 0 (rev 13)
00:11.0 PIC: Intel Corporation 5520/5500 Physical and Link Layer Registers Port 1 (rev 13)
00:11.1 PIC: Intel Corporation 5520/5500 Routing & Protocol Layer Register Port 1 (rev 13)
00:13.0 PIC: Intel Corporation 5520/5500/X58 I/O Hub I/OxAPIC Interrupt Controller (rev 13)
00:14.0 PIC: Intel Corporation 5520/5500/X58 I/O Hub System Management Registers (rev 13)
00:14.1 PIC: Intel Corporation 5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers (rev 13)
00:14.2 PIC: Intel Corporation 5520/5500/X58 I/O Hub Control Status and RAS Registers (rev 13)
00:15.0 PIC: Intel Corporation 5520/5500/X58 Trusted Execution Technology Registers (rev 13)
00:1a.0 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4
00:1a.1 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5
00:1a.2 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6
00:1a.7 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2
00:1b.0 Audio device: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1
00:1c.1 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Port 2
00:1c.3 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 4
00:1c.4 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 5
00:1d.0 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1
00:1d.1 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2
00:1d.2 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3
00:1d.7 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90)
00:1f.0 ISA bridge: Intel Corporation 82801JIR (ICH10R) LPC Interface Controller
00:1f.2 IDE interface: Intel Corporation 82801JI (ICH10 Family) 4 port SATA IDE Controller #1
00:1f.3 SMBus: Intel Corporation 82801JI (ICH10 Family) SMBus Controller
00:1f.5 IDE interface: Intel Corporation 82801JI (ICH10 Family) 2 port SATA IDE Controller #2
01:00.0 IDE interface: Marvell Technology Group Ltd. Device 91a3 (rev 11)
02:00.0 USB Controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 03)
03:00.0 VGA compatible controller: ATI Technologies Inc Cedar PRO [Radeon HD 5450]
03:00.1 Audio device: ATI Technologies Inc Manhattan HDMI Audio [Mobility Radeon HD 5000 Series]
05:00.0 SATA controller: JMicron Technology Corp. JMB362/JMB363 Serial ATA Controller (rev 02)
05:00.1 IDE interface: JMicron Technology Corp. JMB362/JMB363 Serial ATA Controller (rev 02)
06:00.0 SATA controller: JMicron Technology Corp. JMB362/JMB363 Serial ATA Controller (rev 03)
06:00.1 IDE interface: JMicron Technology Corp. JMB362/JMB363 Serial ATA Controller (rev 03)
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
08:06.0 FireWire (IEEE 1394): Texas Instruments TSB43AB23 IEEE-1394a-2000 Controller (PHY/Link)
xrandr -q
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 640 x 400, current 1152 x 864, maximum 1152 x 864
default connected 1152x864+0+0 0mm x 0mm
1152x864 0.0*
1024x768 0.0
800x600 0.0
640x480 0.0
720x400 0.0
lsmod
Module Size Used by
ipv6 248835 32
loop 12871 0
firewire_sbp2 12573 0
snd_hda_codec_atihdmi 2475 1
joydev 8976 0
snd_hda_intel 20104 1
hid_sunplus 1473 0
snd_hda_codec 45368 2 snd_hda_codec_atihdmi,snd_hda_intel
snd_pcm_oss 34829 0
snd_mixer_oss 14051 1 snd_pcm_oss
snd_pcm 58894 3 snd_hda_intel,snd_hda_codec,snd_pcm_oss
snd_seq_dummy 1327 0
snd_seq_oss 26936 0
snd_seq_midi 4656 0
snd_rawmidi 16960 1 snd_seq_midi
snd_seq_midi_event 5236 2 snd_seq_oss,snd_seq_midi
snd_seq 46567 6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
snd_timer 17390 2 snd_pcm,snd_seq
snd_seq_device 4973 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_rawmidi,snd_seq
snd 46870 12 snd_hda_intel,snd_hda_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_seq_oss,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
button 4666 0
processor 18413 0
soundcore 5743 1 snd
i2c_i801 7588 0
snd_page_alloc 6665 2 snd_hda_intel,snd_pcm
usbhid 17537 0
firewire_ohci 23209 0
uhci_hcd 21540 0
ehci_hcd 34343 0
thermal 11839 0
r8169 34613 0
firewire_core 42321 2 firewire_sbp2,firewire_ohci
usbcore 133040 4 usbhid,uhci_hcd,ehci_hcd
thermal_sys 12197 2 processor,thermal
mii 3850 1 r8169
nls_base 6817 1 usbcore
crc_itu_t 1291 1 firewire_core
le contenu de /var/lib/dkms/fglrx/10-7/build/make.log
DKMS make.log for fglrx-10-7 for kernel 2.6.33.7-rt29-studio (x86_64)
jeudi 14 octobre 2010, 21:52:14 (UTC+0200)
make: entrant dans le répertoire « /home/gilles/Téléchargements/linux-2.6.33.7 »
LD /var/lib/dkms/fglrx/10-7/build/built-in.o
CC [M] /var/lib/dkms/fglrx/10-7/build/firegl_public.o
In file included from /var/lib/dkms/fglrx/10-7/build/firegl_public.c:453:
/var/lib/dkms/fglrx/10-7/build/drm_proc.h: In function ‘FGLDRM__vma_info’:
/var/lib/dkms/fglrx/10-7/build/drm_proc.h:497: warning: format ‘%08lx’ expects type ‘long unsigned int’, but argument 5 has type ‘phys_addr_t’
/var/lib/dkms/fglrx/10-7/build/firegl_public.c: In function ‘fglrx_pci_suspend’:
/var/lib/dkms/fglrx/10-7/build/firegl_public.c:843: error: implicit declaration of function ‘acquire_console_sem’
/var/lib/dkms/fglrx/10-7/build/firegl_public.c:865: error: implicit declaration of function ‘release_console_sem’
/var/lib/dkms/fglrx/10-7/build/firegl_public.c: In function ‘firegl_init_module’:
/var/lib/dkms/fglrx/10-7/build/firegl_public.c:1038: error: expected expression before ‘{’ token
/var/lib/dkms/fglrx/10-7/build/firegl_public.c: In function ‘KCL_MapPageToPfn’:
/var/lib/dkms/fglrx/10-7/build/firegl_public.c:1638: warning: unused variable ‘bus_addr’
/var/lib/dkms/fglrx/10-7/build/firegl_public.c: In function ‘KAS_Mutex_Initialize’:
/var/lib/dkms/fglrx/10-7/build/firegl_public.c:5083: error: implicit declaration of function ‘init_MUTEX’
make[1]: *** [/var/lib/dkms/fglrx/10-7/build/firegl_public.o] Erreur 1
make: *** [_module_/var/lib/dkms/fglrx/10-7/build] Erreur 2
make: quittant le répertoire « /home/gilles/Téléchargements/linux-2.6.33.7 »
J’ai aussi ce message dans synaptic a chaque fois que je veux installer ou desinstaller un paquet qui n as rien a voir:
E: fglrx-modules-dkms: le sous-processus script post-installation installé a retourné une erreur de sortie d'état 10
Voila si quelqu’un peut m’aider a avoir unoutils de configuration simple pour profiter de mes deux écrans parce que la je seche.
Merci.
) chez moi sur une Mobility Radeon HD 5800 Series.
