Je tourne en rond et malgré le suivi des tuto et du wiki Debian, je n’y arrive pas, que ce soit sous KDE (3.5) ou sous gnome.
Je précise que sur la même machine, Compiz fonctionne parfaitement avec Ubuntu 10.04
Quand je " $ compiz --replace ", j’ai cette réponse :
ricardo@Ricardo-Dell:~$ compiz --replace
Checking for Xgl: not present.
Detected PCI ID for VGA: 01:00.0 0300: 1002:9591 (prog-if 00 [VGA controller])
Checking for texture_from_pixmap: present.
Checking for non power of two support: present.
Checking for Composite extension: present.
Comparing resolution (1440x900) to maximum 3D texture size (2048): Passed.
Checking for nVidia: not present.
Checking for FBConfig: present.
Starting kde-window-decorator
/usr/bin/compiz.real (core) - Fatal: No GLXFBConfig for default depth, this isn't going to work.
/usr/bin/compiz.real (core) - Error: Failed to manage screen: 0
/usr/bin/compiz.real (core) - Fatal: No manageable screens found on display :0
mon xorg.conf :
[code]Section “Extensions”
Option “Composite” “enable”
EndSection
Section “InputDevice”
Identifier “Generic Keyboard”
Driver “kbd”
Option “XkbRules” “xorg”
Option “XkbModel” “pc105”
Option “XkbLayout” “fr”
Option “XkbVariant” “latin9”
EndSection
Identifier “Configured Mouse”
Driver “mouse”
EndSection
Section “Device”
Identifier “Configured Video Device”
Option “XAANoOffscreenPixmaps” “true”
EndSection
Section “Monitor”
Identifier “Configured Monitor”
EndSection
Section “Screen”
Identifier “Default Screen”
Monitor “Configured Monitor”
EndSection
