J’ai reçu mon ordinateur portabla il y a deux semaines et j’y ai installé debian. Mais voila, tous les jours au moins une fois, l’ordinateur se fige en pleine utilisation et plus moyen de rien faire. Plsu aucune touche du clavier ni la souris de fonctionne. Je suis obligé de le redémarrer.
N’etant pas encore un grand as de linux, j’aurai besoin d’aide pour trouver la source du probleme.
Voila ce que j’ai dans le syslog au niveau de la minute ou ca a buggé (19h54) :
Merci pour votre aide
Feb 13 19:53:17 laptop-pierre dhclient: bound to 192.168.0.165 -- renewal in 19484 seconds.
Feb 13 19:53:18 laptop-pierre avahi-daemon[2629]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::caf7:33ff:fe77:bcb7.
Feb 13 19:53:18 laptop-pierre avahi-daemon[2629]: Joining mDNS multicast group on interface wlan0.IPv6 with address 2a01:e34:eeab:dd40:caf7:33ff:fe77:bcb7.
Feb 13 19:53:18 laptop-pierre avahi-daemon[2629]: Registering new address record for 2a01:e34:eeab:dd40:caf7:33ff:fe77:bcb7 on wlan0.*.
Feb 13 19:53:18 laptop-pierre avahi-daemon[2629]: Withdrawing address record for fe80::caf7:33ff:fe77:bcb7 on wlan0.
Feb 13 19:53:24 laptop-pierre acpid: client connected from 3932[0:0]
Feb 13 19:53:24 laptop-pierre acpid: 1 client rule loaded
Feb 13 19:53:27 laptop-pierre dbus[2567]: [system] Activating service name='org.freedesktop.UDisks' (using servicehelper)
Feb 13 19:53:27 laptop-pierre dbus[2567]: [system] Successfully activated service 'org.freedesktop.UDisks'
Feb 13 19:53:34 laptop-pierre acpid: client 3932[0:0] has disconnected
Feb 13 19:53:49 laptop-pierre kernel: [ 59.359728] iwlwifi 0000:02:00.0: Tx aggregation enabled on ra = 00:24:d4:98:56:2c tid = 0
Feb 13 19:54:14 laptop-pierre kernel: [ 84.658168] iwlwifi 0000:02:00.0: Tx aggregation enabled on ra = 00:24:d4:98:56:2c tid = 0
Feb 13 19:54:27 laptop-pierre acpid: client connected from 3932[0:0]
Feb 13 19:54:27 laptop-pierre acpid: 1 client rule loaded
Feb 13 19:54:44 laptop-pierre kernel: [ 114.317717] iwlwifi 0000:02:00.0: Tx aggregation enabled on ra = 00:24:d4:98:56:2c tid = 0
Feb 13 19:55:55 laptop-pierre kernel: imklog 5.8.11, log source = /proc/kmsg started.
Feb 13 19:55:55 laptop-pierre rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="2272" x-info="http://www.rsyslog.com"] start
Feb 13 19:55:55 laptop-pierre kernel: [ 0.000000] Initializing cgroup subsys cpuset
