Je n’ai pas de son,
et me révèle incapable de le faire fonctionner.
Je n’ai jamais compris comment ça fonctionnait.
Mon ordi tourne sous debian squeeze.
Quelques infos :# lspci -v | grep udio
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05)
01:00.1 Audio device: ATI Technologies Inc Juniper HDMI Audio [Radeon HD 5700 Series]
07:02.0 Multimedia audio controller: Creative Labs CA0106 SoundblasterEn effet, il y a une sortie son sur la carte mère et une carte son Creative. Quant à la carte graphique, elle a l’air de bien vouloir traiter du son.
Divers modules sont présents :# lsmod | grep snd
snd_ca0106 23755 0
snd_hda_codec_atihdmi 1687 1
snd_seq_midi 3576 0
snd_seq_midi_event 3684 1 snd_seq_midi
snd_hda_codec_via 38583 1
snd_rawmidi 12513 2 snd_ca0106,snd_seq_midi
snd_ac97_codec 79148 1 snd_ca0106
snd_hda_intel 16787 1
ac97_bus 710 1 snd_ac97_codec
snd_hda_codec 46002 3 snd_hda_codec_atihdmi,snd_hda_codec_via,snd_hda_intel
snd_hwdep 4054 1 snd_hda_codec
snd_pcm 47226 5 saa7134_alsa,snd_ca0106,snd_ac97_codec,snd_hda_intel,snd_hda_codec
snd_seq 35463 3 snd_seq_midi,snd_seq_midi_event
snd_timer 12258 2 snd_pcm,snd_seq
snd_seq_device 3673 3 snd_seq_midi,snd_rawmidi,snd_seq
snd 34363 15 saa7134_alsa,snd_ca0106,snd_hda_codec_via,snd_rawmidi,snd_ac97_codec,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_seq,snd_timer,snd_seq_device
soundcore 3450 1 snd
snd_page_alloc 5045 3 snd_ca0106,snd_hda_intel,snd_pcmÀ part ça, alsa est installé :# dpkg -l | grep alsa
ii alsa-base 1.0.23+dfsg-1 ALSA driver configuration files
ii alsa-utils 1.0.23-2 Utilities for configuring and using ALSA
ii alsaplayer-alsa 0.99.80-5+b1 PCM player designed for ALSA (ALSA output module)
ii alsaplayer-common 0.99.80-5+b1 PCM player designed for ALSA (common files)
ii alsaplayer-gtk 0.99.80-5+b1 PCM player designed for ALSA (GTK+ version)
ii gstreamer0.10-alsa 0.10.30-1 GStreamer plugin for ALSA
ii libpt-1.10.10-plugins-alsa 1.10.10-3 Portable Windows Library Audio Plugin for the ALSA Interface
ii libsdl1.2debian-alsa 1.2.14-6.1 Simple DirectMedia Layer (with X11 and ALSA options)
ii libsnack2-alsa 2.2.10-dfsg1-9 Sound extension to Tcl/Tk and Python/Tkinter - Tcl/Tk libraryJ’ai connecté des écouteurs aux diverses sorties : rien.
Un expert pourrait-il m’aider ?
Merci.
(edit: 0 c’est par defaut)
