Bonjour à tous !
Aujourd’hui j’ai récupéré un ordinateur de bureau.
J’ai voulu y installer debian wheezy.
Cela a l’air de bien marcher.
Cependant, je n’ai pas d’interface graphique …
c’est un peu tristounet …
Un petit coup de main serai bienvenu ^^
Voici quelques commandes qui sont apparemment utile à la compréhension du problème:
[code]#uname -r
3.2.0-4-amd64[/code]
[code]#lspci
00:00.0 Host bridge: Advanced Micro Devices [AMD] nee ATI RS690 Host Bridge
00:02.0 PCI bridge: Advanced Micro Devices [AMD] nee ATI RS690 PCI to PCI Bridge (PCI Express Graphics Port 0)
00:07.0 PCI bridge: Advanced Micro Devices [AMD] nee ATI RS690 PCI to PCI Bridge (PCI Express Port 3)
00:12.0 SATA controller: Advanced Micro Devices [AMD] nee ATI SB600 Non-Raid-5 SATA
00:13.0 USB controller: Advanced Micro Devices [AMD] nee ATI SB600 USB (OHCI0)
00:13.1 USB controller: Advanced Micro Devices [AMD] nee ATI SB600 USB (OHCI1)
00:13.2 USB controller: Advanced Micro Devices [AMD] nee ATI SB600 USB (OHCI2)
00:13.3 USB controller: Advanced Micro Devices [AMD] nee ATI SB600 USB (OHCI3)
00:13.4 USB controller: Advanced Micro Devices [AMD] nee ATI SB600 USB (OHCI4)
00:13.5 USB controller: Advanced Micro Devices [AMD] nee ATI SB600 USB Controller (EHCI)
00:14.0 SMBus: Advanced Micro Devices [AMD] nee ATI SBx00 SMBus Controller (rev 14)
00:14.1 IDE interface: Advanced Micro Devices [AMD] nee ATI SB600 IDE
00:14.2 Audio device: Advanced Micro Devices [AMD] nee ATI SBx00 Azalia (Intel HDA)
00:14.3 ISA bridge: Advanced Micro Devices [AMD] nee ATI SB600 PCI to LPC Bridge
00:14.4 PCI bridge: Advanced Micro Devices [AMD] nee ATI SBx00 PCI to PCI Bridge
00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor HyperTransport Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Miscellaneous Control
00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Link Control
01:00.0 VGA compatible controller: NVIDIA Corporation G84 [GeForce 8600 GS] (rev a1)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 01)
03:08.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller (rev c0)[/code]
[code]#lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 07b8:e004 AboCom Systems Inc Mass Storage Device
Bus 002 Device 002: ID 04ca:0050 Lite-On Technology Corp.
Bus 002 Device 009: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 006: ID 0204:1976 Chipsbank Microelectronics Co., Ltd [/code]
[code]#dmidecode
dmidecode 2.11
SMBIOS 2.5 present.
51 structures occupying 2263 bytes.
Table at 0x000F0000.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: Phoenix Technologies, LTD
Version: V5.05
Release Date: 12/31/2007
Address: 0xE0000
Runtime Size: 128 kB
ROM Size: 512 kB
Characteristics:
ISA is supported
PCI is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/360 kB floppy services are supported (int 13h)
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
AGP is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Targeted content distribution is supported
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: FUJITSU SIEMENS
Product Name: AMD690VM-FMH
Version: Unknow
Serial Number: YSHS025664
UUID: 00020003-0004-0005-0006-000700080009
Wake-up Type: Power Switch
SKU Number:
Family:
Handle 0x0002, DMI type 2, 8 bytes
Base Board Information
Version: Unknow
Serial Number:
Handle 0x0003, DMI type 3, 17 bytes
Chassis Information
Manufacturer: AMD
Type: Desktop
Lock: Not Present
Version: RS690
Asset Tag:
Boot-up State: Unknown
Power Supply State: Unknown
Thermal State: Unknown
Security Status: Unknown
OEM Information: 0x00000000
Handle 0x0004, DMI type 4, 40 bytes
Processor Information
Socket Designation: Socket AM2
Type: Central Processor
Family: Pentium Pro
Manufacturer: AMD
ID: 22 0F 10 00 FF FB 8B 17
Signature: Type 0, Family 16, Model 2, Stepping 2
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
HTT (Multi-threading)
Version: AMD Phenom™ 9500 Quad-Core Processor
Voltage: 1.5 V
External Clock: 233 MHz
Max Speed: 3000 MHz
Current Speed: 1050 MHz
Status: Populated, Enabled
Upgrade: Socket 940
L1 Cache Handle: 0x000A
L2 Cache Handle: 0x000B
L3 Cache Handle: Not Provided
Serial Number:
Asset Tag:
Part Number:
Core Count: 2
Core Enabled: 2
Thread Count: 2
Characteristics:
64-bit capable
Handle 0x0005, DMI type 5, 24 bytes
Memory Controller Information
Error Detecting Method: 64-bit ECC
Error Correcting Capabilities:
None
Supported Interleave: One-way Interleave
Current Interleave: One-way Interleave
Maximum Memory Module Size: 4096 MB
Maximum Total Memory Size: 16384 MB
Supported Speeds:
70 ns
60 ns
50 ns
Supported Memory Types:
Standard
DIMM
Memory Module Voltage: 2.9 V
Associated Memory Slots: 4
0x0006
0x0007
0x0008
0x0009
Enabled Error Correcting Capabilities: None
Handle 0x0006, DMI type 6, 12 bytes
Memory Module Information
Socket Designation: A0
Bank Connections: 0
Current Speed: Unknown
Type: Other Unknown EDO
Installed Size: 1024 MB (Single-bank Connection)
Enabled Size: 1024 MB (Single-bank Connection)
Error Status: OK
Handle 0x0007, DMI type 6, 12 bytes
Socket Designation: A1
Bank Connections: 2
Error Status: OK
Handle 0x0008, DMI type 6, 12 bytes
Socket Designation: A2
Bank Connections: 4
Installed Size: 512 MB (Single-bank Connection)
Enabled Size: 512 MB (Single-bank Connection)
Error Status: OK
Handle 0x0009, DMI type 6, 12 bytes
Socket Designation: A3
Bank Connections: 6
Error Status: OK
Handle 0x000A, DMI type 7, 19 bytes
Cache Information
Socket Designation: Internal Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 128 kB
Maximum Size: 128 kB
Supported SRAM Types:
Synchronous
Installed SRAM Type: Synchronous
Speed: Unknown
Error Correction Type: Unknown
System Type: Unknown
Associativity: Unknown
Handle 0x000B, DMI type 7, 19 bytes
Cache Information
Socket Designation: External Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 512 kB
Maximum Size: 512 kB
Synchronous
Speed: Unknown
Handle 0x000C, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: PRIMARY IDE
Internal Connector Type: On Board IDE
External Reference Designator: Not Specified
External Connector Type: None
Port Type: Other
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: SECONDARY IDE
Port Type: Other
Handle 0x000E, DMI type 8, 9 bytes
Internal Reference Designator: FDD
Internal Connector Type: On Board Floppy
Port Type: 8251 FIFO Compatible
Handle 0x000F, DMI type 8, 9 bytes
Internal Reference Designator: COM1
Internal Connector Type: 9 Pin Dual Inline (pin 10 cut)
External Connector Type: DB-9 male
Port Type: Serial Port 16450 Compatible
Handle 0x0010, DMI type 8, 9 bytes
Internal Reference Designator: COM2
Handle 0x0011, DMI type 8, 9 bytes
Internal Reference Designator: LPT1
Internal Connector Type: DB-25 female
External Connector Type: DB-25 female
Port Type: Parallel Port ECP/EPP
Handle 0x0012, DMI type 8, 9 bytes
Internal Reference Designator: Keyboard
Internal Connector Type: PS/2
External Connector Type: PS/2
Port Type: Keyboard Port
Handle 0x0013, DMI type 8, 9 bytes
Internal Reference Designator: PS/2 Mouse
Port Type: Mouse Port
Handle 0x0014, DMI type 8, 9 bytes
Internal Reference Designator: Not Specified
Internal Connector Type: None
External Reference Designator: USB0
External Connector Type: Other
Port Type: USB
Handle 0x0015, DMI type 8, 9 bytes
External Reference Designator: USB1
Port Type: USB
Handle 0x0016, DMI type 8, 9 bytes
External Reference Designator: USB2
Port Type: USB
Handle 0x0017, DMI type 8, 9 bytes
External Reference Designator: USB3
Port Type: USB
Handle 0x0018, DMI type 8, 9 bytes
External Reference Designator: USB4
Port Type: USB
Handle 0x0019, DMI type 8, 9 bytes
External Reference Designator: USB5
Port Type: USB
Handle 0x001A, DMI type 8, 9 bytes
External Reference Designator: USB6
Port Type: USB
Handle 0x001B, DMI type 8, 9 bytes
External Reference Designator: USB7
Port Type: USB
Handle 0x001C, DMI type 8, 9 bytes
External Reference Designator: USB8
Port Type: USB
Handle 0x001D, DMI type 8, 9 bytes
External Reference Designator: USB9
Port Type: USB
Handle 0x001E, DMI type 9, 13 bytes
System Slot Information
Designation: PCI0
Type: 32-bit PCI Express
Current Usage: In Use
Length: Long
Characteristics:
5.0 V is provided
PME signal is supported
Handle 0x001F, DMI type 9, 13 bytes
Designation: PCI1
Type: 32-bit PCI
Current Usage: Available
Length: Long
Characteristics:
5.0 V is provided
Handle 0x0020, DMI type 9, 13 bytes
Designation: PCI2
Type: 32-bit PCI
Length: Long
Characteristics:
5.0 V is provided
Handle 0x0021, DMI type 9, 13 bytes
Designation: AGP
Type: 32-bit AGP
Length: Long
Characteristics:
5.0 V is provided
Handle 0x0022, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Long
Installable Languages: 3
n|US|iso8859-1
n|US|iso8859-1
r|CA|iso8859-1
Currently Installed Language: n|US|iso8859-1
Handle 0x0023, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 2 GB
Error Information Handle: Not Provided
Number Of Devices: 4
Handle 0x0024, DMI type 17, 27 bytes
Memory Device
Array Handle: 0x0023
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: A0
Bank Locator: Bank0/1
Type: DDR2
Type Detail: None
Speed: 1639 MHz
Manufacturer:
Serial Number: Not Specified
Asset Tag: None
Part Number: None
Handle 0x0025, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: A1
Bank Locator: Bank2/3
Type: DDR2
Type Detail: None
Speed: 1639 MHz
Manufacturer:
Asset Tag: None
Part Number: None
Handle 0x0026, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: A2
Bank Locator: Bank4/5
Type: DDR2
Type Detail: None
Speed: 1639 MHz
Manufacturer:
Asset Tag: None
Part Number: None
Handle 0x0027, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: A3
Bank Locator: Bank6/7
Type: DDR2
Type Detail: None
Speed: 1639 MHz
Manufacturer:
Asset Tag: None
Part Number: None
Handle 0x0028, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x000BFFFFFFF
Range Size: 3 GB
Physical Array Handle: 0x0023
Partition Width: 1
Handle 0x0029, DMI type 20, 19 bytes
Memory Device Mapped Address
Ending Address: 0x0003FFFFFFF
Range Size: 1 GB
Physical Device Handle: 0x0024
Memory Array Mapped Address Handle: 0x0028
Partition Row Position: 1
Handle 0x002A, DMI type 20, 19 bytes
Starting Address: 0x00040000000
Ending Address: 0x0007FFFFFFF
Range Size: 1 GB
Physical Device Handle: 0x0025
Handle 0x002B, DMI type 20, 19 bytes
Starting Address: 0x00080000000
Ending Address: 0x0009FFFFFFF
Range Size: 512 MB
Physical Device Handle: 0x0026
Handle 0x002C, DMI type 20, 19 bytes
Starting Address: 0x000A0000000
Range Size: 512 MB
Physical Device Handle: 0x0027
Handle 0x002D, DMI type 32, 11 bytes
System Boot Information
Status: No errors detected
Handle 0x002E, DMI type 188, 212 bytes
OEM-specific Type
Header and Data:
BC D4 2E 00 00 00 00 C0 00 00 00 00 00 00 00 00
00 00 00 00 00 06 16 00 00 00 00 00 08 00 00 00
00 40 40 00 10 08 01 00 0A 00 58 6F 03 00 00 00
00 00 BF 00 00 00 00 00 01 00 00 00 00 00 00 00
02 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00
04 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00
06 00 00 00 00 00 00 00 07 00 00 00 00 00 00 00
01 00 00 00 00 00 00 00 01 00 80 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 3F 78 00 E0 3F 38 00 00 00 00 00 00 00 00 00
05 00 00 10 00 00 00 00 25 00 00 00 00 00 00 00
24 CA 6A 0C 34 03 A2 00 10 08 01 00 00 02 00 00
00 00 00 00 44 00 90 0A 0A 00 58 6F 00 00 00 00
00 00 00 00
Handle 0x002F, DMI type 190, 212 bytes
OEM-specific Type
Header and Data:
BE D4 2F 00 10 05 00 00 00 00 00 00 24 A4 40 04
C0 0F E4 2F 00 00 00 00 00 00 00 00 17 00 00 00
00 00 00 00 00 00 00 00 00 02 F4 02 00 00 00 00
00 00 00 00
Handle 0x0030, DMI type 192, 244 bytes
OEM-specific Type
Header and Data:
C0 F4 30 00 05 08 00 00 22 13 11 10 20 22 30 00
E7 08 71 0E FA 0C 10 00 22 13 11 10 0F 0E 0F 0E
0F 0E 0F 0E 0F 0E 0F 0E 0F 0F 0F 11 0F 0F 0F 11
0F 0F 0F 11 0F 0F 0F 20 22 30 00 0B 0A 0B 0A 0B
0A 0B 0A 0B 0A 0B 0A 0A 0C 0B 0A 0A 0C 0B 0A 0A
0C 0B 0A 0B 0B 0B A9 24 83 0A FA 0C 10 00 44 00
43 00 3F 00 3F 00 44 00 4B 00 4A 00 46 00 44 00
4B 00 04 00 03 00 1F 00 1F 00 00 00 0B 00 0A 00
06 00 04 00 00 00 3E 00 44 00 41 00 43 00 00 00
43 00 48 00 49 00 4B 00 00 00 1E 00 04 00 01 00
03 00 00 00 03 00 08 00 09 00 0B 00 00 00 00 00
00 00 00 00 18 19 18 19 19 17 19 19 18 00 00 00
DF 01 00 00 DC 01 00 00 DC 01 00 00 DC 01 00 00
00 00 00 00
Handle 0x0031, DMI type 194, 244 bytes
OEM-specific Type
Header and Data:
C2 F4 31 00 05 08 00 00 22 13 11 10 20 22 30 00
A9 24 93 0A FA 0C 10 00 22 13 11 10 10 0E 0F 0F
10 0E 0F 0F 10 0E 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F
0F 0F 0F 0F 10 10 10 20 22 30 00 0A 0B 0B 0B 0A
0B 0B 0B 0A 0B 0B 0B 0B 0B 0B 0A 0B 0B 0B 0A 0B
0B 0B 0A 0A 0A 0A AB 30 A3 0A FA 0C 10 00 47 00
4A 00 42 00 42 00 47 00 4B 00 4A 00 47 00 46 00
4B 00 07 00 0A 00 02 00 02 00 00 00 0B 00 0A 00
07 00 06 00 00 00 3D 00 41 00 44 00 49 00 00 00
45 00 47 00 4A 00 4B 00 00 00 1D 00 01 00 04 00
09 00 00 00 05 00 07 00 0A 00 0B 00 00 00 00 00
00 00 00 00 19 19 17 17 18 16 19 19 18 00 00 00
FF 00 00 00 DC 01 00 00 DC 01 00 00 DC 01 00 00
00 00 00 00
Handle 0x0032, DMI type 127, 4 bytes
End Of Table[/code]
