tu me demandais une réponse “vite fait”…
hmm. je prefère mettre tous les détails.
bah merci bien anoyzthen c’est super sympa. La je dois m’absenter mais je me penche sur ton tuto demain
je te tiendrai au courant.
bonne journée
salut, me voila de retour, alors si tu as toujours un peu de temps pour m’aider anoyzthen voila les sorties de ce que tu m’as demande:
[code]root@1[debian]# fdisk -l
Disk /dev/sda: 100.0 GB, 100030242816 bytes
255 heads, 63 sectors/track, 12161 cylinders
/dev/sda1 * 1 10950 87955843+ 7 HPFS/NTFS
/dev/sda2 10952 12030 8667067+ c W95 FAT32 (LBA)
/dev/sda3 12031 12161 1052257+ d7 Unknown
Disk /dev/sdb: 100.0 GB, 100030242816 bytes
/dev/sdb1 1 1275 10241406 c W95 FAT32 (LBA)
/dev/sdb2 1276 8337 56725515 7 HPFS/NTFS
/dev/sdb3 8338 12021 29591730 83 Linux
/dev/sdb4 12022 12161 1124550 82 Linux swap / Solaris
linux est sur /dev/sdb3
root@1[debian]# cat var/log/Xorg.0.log | grep '(EE)'
(EE) No devices detected.
[code]root@1[debian]# cat etc/X11/xorg.conf
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option “SendCoreEvents” "true"
Option “Device” "/dev/psaux"
Option “Protocol” "auto-dev"
Option “HorizScrollDelta” "0"
EndSection
Section "Device"
Identifier "Generic Video Card"
Driver "nv"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
HorizSync 28-57
VertRefresh 43-60
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Generic Video Card"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1152x768” “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Synaptics Touchpad"
EndSection
Section "DRI"
Mode 0666
EndSection
[code]et un extrait du lspci:
0000:05:00.0 VGA compatible controller: nVidia Corporation: Unknown device 0398 (rev a1)
voila, donc apparemment la carte est pas reconnue pourtant elle fonctionne avec la knoppix. par contre pour le lspci je suis pas sur de mon coup car il est fait sous knoppix et la knoppix marche quand meme! peut etre je n’ai pas isole la bonne ligne…
ok je regarde ça dans l’après midi
alors ta carte graphique c’est une nvidia
ici: forum.debian-fr.org/viewtopic.ph … ght=nvidia
c’est le tutorial pour installer les drivers nvidia.
fait déjà ça, dit moi ou ça en est, on verra après pour le dual boot.
merci
premier probleme, je n’arrive pas à mettre à jour. Je suis sous knoppix en chroot, comme sources.list j’ai pris celui de truc et astuces mais juste les lignes pour la version stable. et voila les messages d’erreur:[code]Failed to fetch http://security.debian.org/dists/etch/updates/non-free/source/Sources.gz Could not resolve 'security.debian.org’
Failed to fetch http://security.debian.org/dists/etch/updates/main/binary-i386/Packages.gz Could not resolve 'security.debian.org’W: You may want to run apt-get update to correct these problems
E: Some index files failed to download, they have been ignored, or old ones used instead.
J’ai pas tout mis mais ca fait ca pour tous les depots. peut etre sont -ils pas accessibles en ce moment mais ca m’etonne quand meme
ps: ma connexion internet fonctionne
bah mets le ici ton sources.list, je pense que sur le forum chacun en a un different… y’a pas de version canonique.
le voila
## etch
deb http://ftp.fr.debian.org/debian/ etch main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ etch main contrib non-free
#debian-marillat
deb http://www.debian-multimedia.org etch main
deb-src http://www.debian-multimedia.org etch main
# security
deb http://security.debian.org/ etch/updates main contrib non-free
deb-src http://security.debian.org/ etch/updates main contrib non-free
# volatile
deb http://ftp.ens-cachan.fr/ftp/debian-volatile etch/volatile main contrib non-free
deb-src http://ftp.ens-cachan.fr/ftp/debian-volatile etch/volatile main contrib non-free
est-ce que tu as permis à ton firewall de laisser passer le protocol ftp ?
c’est different de DNS et HTTP.
(moralité pas sur qu’elle soit 100% fonctionnelle ta connection avec un firewall un peu musclé )
le firewall est desactive. Le ftp et http marchent quand je ne suis pas en chroot. mais apt-get update ne fonctionne plus quand je suis en chroot
je vais voir si je peux choper une console avec le cd d’install en rescue mode
[quote=“ours-blanc-”]le firewall est desactive. Le ftp et http marchent quand je ne suis pas en chroot. mais apt-get update ne fonctionne plus quand je suis en chroot
je vais voir si je peux choper une console avec le cd d’install en rescue mode[/quote]
okay j’avais eu ce problème… j’ai fait un petit script pour transmettre la connection internet quand on fait un chroot. je crois qu’il faut juste copier un fichier qui est présent dans /etc/. je me rappelle plus le nom de ce fichier…
arg…
voilà une fois que tu as fait ton chroot, tu copies /etc/resolv.conf provennant du linux sur lequel tu as effectué la connection.
une fois ça effectué le pat-get update doit etre possible (en tout cas j’avais eu ce meme problème)
merci encore, ca marche! je me penche donc maintenant sur l’installation des drivers nvidia
desolé je n’y arrive pas, j’ai un probleme avec les headers et je comprends pas tout.
J’ai installe le noyau 2.6.18 met quand je fais uname -r il me met 2.6.17. Le probleme c’est que paquet linux header 2.6.17 n’existe pas je peux pas les installer.
et j’en ai besoin a l’execution de cette commande:m-a a-i -i -t -f nvidia-kernel
voila le message d’erreur:
[code]Bad luck, the kernel headers for the target kernel version could not be found
and you did not specify other valid kernel headers to use.
If the running kernel has been shipped with the Debian distribution, please
install the package linux-headers-2.6.17. If your kernel source tree (or
headers) is located in some non-usual location, please set the KERNELDIRS
environment variable to the path of this directory, or (alternatively) specify
the source directory we build for with the --kernel-dir option in
module-assistant calls.
donc voila ou j’en suis…
je sais pas comment passe sur le noyau 2.6.18 ou alors comment trouve les headers du 2.6.17
bonne soiree
ah j’avais eu pareil… attends je reflechis avant d’écrire une betise.
je dirais que pour etre sur le noyau 2.6.18:
primo faut booter dessus… uname te retourne la valeur de ce qu’il execute au moment où tu lances la commande.
secundo s’assurer que le /usr/src/linux pointe sur les headers ou les sources du 2.6.18 qui sont dans /usr/src
une fois que c’est fait, l’installation de nvidia comme dans le tuto fonctionne.
( un peu présompteux comme affirmation mais je crois que ça c’était passé comme ça chez moi ).
c’est bon ua fiat, tu peux booter dessus ?
ben je pense pas que je peux parceque je sais pas si on peut choisir le noyau au boot de knoppix.
C’est pas une limite du chroot d’ailleurs ca? parceque je comprends pas ce que me renvoie le uname -r vu que la distrib n’est pas demarree reellement en chroot.
je vais voir si il y a un autre noyau avec knoppix
Dans ton chroot, tu refais ta commande m-a, mais tu lui dis que tu ne veux pas compiler pour le noyau de ta knoppix, mais d’utiliser les headers que tu as installés:
m-a a-i -i -t -f nvidia-kernel -k /usr/src/linux-headers-2.6.18
Mais je ne comprends pas parceque je n’ai pas suivi: pkoi tu travailles en chroot depuis la knoppix ?
Ca serait peut être plus interressant de faire marcher en premier le reseau sur la debian, et de travailler ensuite depuis ta debian, plutot que de t’interresser à l’affichage, non ?
je crois que c’est moi qui lui ait dit de s’occuper des nvidia
je me rappelle plus pourquoi tu peux plus utiliser grub ?
oui, parceque l’objectif, si j’ai bien compris, c’est tout de même de booter la knoppix, non ?
ours blanc: tu as fait la manip decrite par anoythzen pour booter sur le grub depuis la vista ?
