lu PascalHambourg
alors j’ai pris le dernier installateur et refait une install se que je peut te dire dans l’immédiat :
[code]cat /proc/mdstat
Personalities : [raid1]
md1 : active raid1 sda2[0] sdb2[1]
236425080 blocks super 1.2 [2/2] [UU]
[==========>…] resync = 51.1% (120891968/236425080) finish=36.3min speed=52963K/sec
md0 : active raid1 sda1[0] sdb1[1]
6834164 blocks super 1.2 [2/2] [UU]
[code]Disk /dev/sdb: 250.1 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders
Disk identifier: 0x00057c16
/dev/sdb1 * 1 852 6835200 fd Linux raid autodetect
Partition 1 does not end on cylinder boundary.
/dev/sdb2 852 30285 236426240 fd Linux raid autodetect
/dev/sdb3 30285 30402 935936 82 Linux swap / Solaris
Disk /dev/sda: 250.1 GB, 250059350016 bytes
Disk identifier: 0x00045b20
/dev/sda1 * 1 852 6835200 fd Linux raid autodetect
/dev/sda2 852 30285 236426240 fd Linux raid autodetect
[code]Disk /dev/md0: 6998 MB, 6998183936 bytes
2 heads, 4 sectors/track, 1708541 cylinders
Units = cylinders of 8 * 512 = 4096 bytes
Disk identifier: 0x00000000
Disk /dev/md0 doesn’t contain a valid partition table
Disk /dev/md1: 242.1 GB, 242099281920 bytes
2 heads, 4 sectors/track, 59106270 cylinders
Disk /dev/md1 doesn’t contain a valid partition table
[code]mdadm --detail /dev/md0
/dev/md0:
Version : 1.2
Creation Time : Thu Oct 7 19:17:02 2010
Raid Level : raid1
Array Size : 6834164 (6.52 GiB 7.00 GB)
Used Dev Size : 6834164 (6.52 GiB 7.00 GB)
Raid Devices : 2
Total Devices : 2
Persistence : Superblock is persistent
Update Time : Thu Oct 7 18:21:48 2010
State : active
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0
Name : debian:0 (local to host debian)
UUID : 3e262650:92e2d644:2d4fda02:14d3ab7f
Events : 35
Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
1 8 17 1 active sync /dev/sdb1
[code]mdadm --detail /dev/md1
/dev/md1:
Version : 1.2
Creation Time : Thu Oct 7 19:17:13 2010
Raid Level : raid1
Array Size : 236425080 (225.47 GiB 242.10 GB)
Used Dev Size : 236425080 (225.47 GiB 242.10 GB)
Raid Devices : 2
Total Devices : 2
Update Time : Thu Oct 7 18:20:31 2010
State : active, resyncing
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0
Rebuild Status : 54% complete
Name : debian:1 (local to host debian)
UUID : e4b83292:45cca904:d7dd0bff:9d593802
Events : 31
0 8 2 0 active sync /dev/sda2
1 8 18 1 active sync /dev/sdb2
Le plus inquiétant étant çà :
[code]mdadm --examine /dev/md0
mdadm: No md superblock detected on /dev/md0.
mdadm --examine /dev/md1
mdadm: No md superblock detected on /dev/md1.
Pb matériel des dd ?
hum peut etre une piste sur le liens que tu donne plus haut cela renvoie vers cette page :
raid.wiki.kernel.org/index.php/Superblock
si je comprend bien le noyau se base sur la version 0.90 de superblocks.
Alors que mdadm se base sur la version 1.2 d’où mon pb pour démarrer mon raid visiblement non ?
