Pluzzdl erreur au téléchargement
Après être passé à Jessie, j’ai réinstallé pluzzdl en suivant les instruction données là.
J’obtiens le résulat suivant:
pluzzdl -v http://pluzz.francetv.fr/videos/meteo_jt_13h_,127097696.html [DEBUG ] main.py pluzzdl 0.9.4 avec Python 2.7.9 (x86_64) [DEBUG ] main.py OS : Linux #1 SMP Debian 3.16.7-ckt11-1+deb8u3 (2015-08-04) [DEBUG ] Navigateur.py GET http://pluzz.francetv.fr/videos/meteo_jt_13h_,127097696.html [DEBUG ] PluzzDL.py ID de l'émission : 127097696 [DEBUG ] Navigateur.py GET http://www.pluzz.fr/appftv/webservices/video/getInfosOeuvre.php?mode=zeri&id-diffusion=127097696 [DEBUG ] Navigateur.py Not Found Traceback (most recent call last): File "/usr/share/pluzzdl/main.py", line 94, in <module> progressFnct = progressFnct ) File "/usr/share/pluzzdl/PluzzDL.py", line 78, in __init__ pageInfos = self.navigateur.getFichier( self.XML_DESCRIPTION.replace( "_ID_EMISSION_", idEmission ) ) File "/usr/share/pluzzdl/Navigateur.py", line 59, in getFichier page = self.urlOpener.open( requete, timeout = self.timeOut ) File "/usr/lib/python2.7/urllib2.py", line 437, in open response = meth(req, response) File "/usr/lib/python2.7/urllib2.py", line 550, in http_response 'http', request, response, code, msg, hdrs) File "/usr/lib/python2.7/urllib2.py", line 469, in error result = self._call_chain(*args) File "/usr/lib/python2.7/urllib2.py", line 409, in _call_chain result = func(*args) File "/usr/lib/python2.7/urllib2.py", line 656, in http_error_302 return self.parent.open(new, timeout=req.timeout) File "/usr/lib/python2.7/urllib2.py", line 437, in open response = meth(req, response) File "/usr/lib/python2.7/urllib2.py", line 550, in http_response 'http', request, response, code, msg, hdrs) File "/usr/lib/python2.7/urllib2.py", line 475, in error return self._call_chain(*args) File "/usr/lib/python2.7/urllib2.py", line 409, in _call_chain result = func(*args) File "/usr/lib/python2.7/urllib2.py", line 558, in http_error_default raise HTTPError(req.get_full_url(), code, msg, hdrs, fp) urllib2.HTTPError: HTTP Error 404: Not Found
Cela dépasse mes piètres compétences…
Merci de votre aide
J’ai entendu dire que France TV avait cassé le webservice pour récupérer les infos des émissions.
J’ai trouvé là un patch qui améliore bien les choses, à condition de patcher le pluzzdl qu’on trouve ici
Pour résumer, je récupère la version 9.4 sur code.google.com/p/tvdownloader et j’applique le patch qui y est proposé.
Les choses s’améliorent. Le téléchargement se fait rapidement et complètement mais pas moyen de créer la vidéo finale:
[INFO ] PluzzDL.py Fin du téléchargement [INFO ] PluzzDL.py Création du fichier MKV (vidéo finale) ; veuillez attendre quelques instants [CRITICAL] PluzzDL.py Erreur inconnue [DEBUG ] Historique.py Historique sauvé
et là, je sèche.
J’ai installé ffmpeg, mais rien n’y fait.
Quid donc
