Poblème de réseaux
Bonsoir,
J’ai deux PCs reliés par la WIFI à Box Alice (tout est Ok).
Aussi, je voudrais profiter du réseau local :
Du côté Vista pas de problème, je vois les dossiers partagés sur debian
Du côté Debian, je ne vois pas les dossiers partagés sur Vista
Je vous joins le fichier SMB.CONF
[global]
workgroup = mshome
netbios name = cire
dns proxy = no
interfaces = 127.0.0.0/8 eth1
log file = /var/log/samba/log.%m
max log size = 1000
[global]
workgroup = mshome
netbios name = cire
server string = %h server
dns proxy = no
max log size = 1000
syslog = 0
panic action = /usr/share/samba/panic-action %d
security = share
########## Printing ##########
If you want to automatically load your printer list rather
than setting them up individually then you’ll need this
; load printers = yes
lpr(ng) printing. You may wish to override the location of the
printcap file
; printing = bsd
; printcap name = /etc/printcap
CUPS printing. See also the cupsaddsmb(8) manpage in the
cupsys-client package.
; printing = cups
; printcap name = cups
When using [print$], root is implicitly a ‘printer admin’, but you can
also give this right to other users to add drivers and set printer
properties
; printer admin = @ntadmin
############ Misc ############
Using the following line enables you to customise your configuration
on a per machine basis. The %m gets replaced with the netbios name
of the machine that is connecting
; include = /home/samba/etc/smb.conf.%m
Most people will find that this option gives better performance.
See smb.conf(5) and /usr/share/doc/samba-doc/htmldocs/Samba3-HOWTO/speed.html
for details
You may want to add the following on a Linux system:
     SO_RCVBUF=8192 SO_SNDBUF=8192
socket options = TCP_NODELAY
The following parameter is useful only if you have the linpopup package
installed. The samba maintainer and the linpopup maintainer are
working to ease installation and configuration of linpopup and samba.
; message command = /bin/sh -c ‘/usr/bin/linpopup “%f” “%m” %s; rm %s’ &
Domain Master specifies Samba to be the Domain Master Browser. If this
machine will be configured as a BDC (a secondary logon server), you
must set this to ‘no’; otherwise, the default behavior is recommended.
; domain master = auto
Some defaults for winbind (make sure you’re not using the ranges
for something else.)
; idmap uid = 10000-20000
; idmap gid = 10000-20000
; template shell = /bin/bash
; The following was the default behaviour in sarge
; but samba upstream reverted the default because it might induce
; performance issues in large organizations
; See #368251 for some of the consequences of not having
; this setting and smb.conf(5) for all details
; winbind enum groups = yes
; winbind enum users = yes
#======================= Share Definitions =======================
wins support = no
[homes]
comment = Home Directories
browseable = yes
By default, the home directories are exported read-only. Change next
parameter to ‘yes’ if you want to be able to write to them.
writable = yes
File creation mask is set to 0700 for security reasons. If you want to
create files with group=rw permissions, set next parameter to 0775.
create mask = 0775
Directory creation mask is set to 0700 for security reasons. If you want to
create dirs. with group=rw permissions, set next parameter to 0775.
directory mask = 0775
Restrict access to home directories
to the one of the authenticated user
This might need tweaking when using external authentication schemes
valid users = %S
Un-comment the following and create the netlogon directory for Domain Logons
(you need to configure Samba to act as a domain controller too.)
;[netlogon]
; comment = Network Logon Service
; path = /home/samba/netlogon
; guest ok = yes
; writable = no
; share modes = no
Un-comment the following and create the profiles directory to store
users profiles (see the “logon path” option above)
The path below should be writable by all users so that their
profile directory may be created the first time they log on
;[profiles]
; comment = Users profiles
; path = /home/samba/profiles
; guest ok = no
; browseable = no
; create mask = 0600
; directory mask = 0700
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
public = no
writable = no
create mode = 0700
Windows clients look for this share name as a source of downloadable
printer drivers
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
browseable = yes
read only = yes
guest ok = no
Uncomment to allow remote administration of Windows print drivers.
Replace ‘ntadmin’ with the name of the group your admin users are
members of.
; write list = root, @ntadmin
A sample share for sharing your CD-ROM with others.
;[cdrom]
; comment = Samba server’s CD-ROM
; writable = no
; locking = no
; path = /cdrom
; public = yes
The next two parameters show how to auto-mount a CD-ROM when the
cdrom share is accesed. For this to work /etc/fstab must contain
an entry like this:
/dev/scd0 /cdrom iso9660 defaults,noauto,ro,user 0 0
The CD-ROM gets unmounted automatically after the connection to the
If you don’t want to use auto-mounting/unmounting make sure the CD
is mounted on /cdrom
; preexec = /bin/mount /cdrom
; postexec = /bin/umount /cdrom
[Tempo]
path = /home/eric/Tempo
available = yes
browseable = yes
public = yes
writable = yes
guest ok = yes
Merci d’avance
Cela ne dépend pas du smb.conf de ta debian qui concerne la partie serveur qui fonctionne bien puisque ton windows voit les partages debian.
Quel client utilises tu sous debian pour “ne rien voir” ? Comment fais tu ?
Le client, a vrai dire, je ne sais pas ce que tu veux dire…alors si tu pouvais m’éclairer…merci
Comment fais tu pour essayer de voir ton windows sous debian ? Tu utilises quoi ?
J’ai installé Wicd qui est mon interface réseau WiFi en desinstallant le reste (KdeNetwork-manager, Kwifi…) et l’interface graphique est le Partage Samba et je vois le groupe (mshome) et apres il m’affiche une erreur ( pas de reponse du serveur)
[quote=“le_sage”]J’ai installé Wicd qui est mon interface réseau WiFi en desinstallant le reste (KdeNetwork-manager, Kwifi…)[/quote] Ok, mais ça, ça concerne le wifi, pas le partage. [quote=“le_sage”]et l’interface graphique est le Partage Samba et je vois le groupe (mshome) et apres il m’affiche une erreur ( pas de reponse du serveur)[/quote] Bon, je ne sais pas ce que tu appelles le “Partage Samba”, mais comme tu parles de kwifi, je suppose que tu es sous KDE.
Dans konqueror, qu’est ce que ça donne si tu mets comme url smb://<l’adresse ip de ta machine windows>/ ?
Sinon, dans le menu K, Configuration/Internet et Réseau/Navigation dans le réseau local, as tu vérifié un peu les éléments de configuration de lisa (il y a un assistant de config) et rlan ?
Sinon, vérifies que lisa est bien installé.
Ok pour konqueror (smb://127.0.0.1 et pour smb//IP de Vista, Un probleme de NetBios…
Je ne comprend pas ta réponse: c’est [résolu] ? Tu as vérifié la présence et les paramètres de lisa ?
Je n’avais pas Lisa, donc je l’ai installé dans synatic mais rien…
quote="mattotop"
Tu as vérifié la présence et les paramètres de lisa ?[/quote]
Comment fais tu pour detecter le présence de lisa car dans les menus indiquées elle n’y etait pas…
aptitude search lisa: si tu as un i au début de la ligne concernant lisa, c’est que c’est installé. Ou apt-cache policy lisa te dira quelle version est installée, ainsi que aptitude show lisa, etc… pleins d’outils apt peuvent te donner l’info.
Je ne vois pas du tout la je cale
[quote=“le_sage”]Ok pour konqueror (smb://127.0.0.1 et pour smb//IP de Vista, Un probleme de NetBios…
Merci[/quote]
Salut, essaye avec:
n’oublie pas les deux points smb:// et pas smb// car il semblerait que tu ais oublié.
Sinon ton histoire de problème de NetBios, c’est quand tu tapes smb://127.0.0.1 qu’il apparait. Ce n’est pas très clair dans ton post.
L’adresse 127.0.0.1 correspond à ton adresse sur l’interface boucle locale; (lo), normalement tu devrais voir les partages de ta debian lorsque tu tapes smb://127.0.0.1 , est-ce le cas?
Si possible, lorsqu’il y a un message d’erreur donne le en copier coller, ne serait-ce que la partie qui te parait la plus significative de celui-ci.
Sinon ce que te dis de faire Mattotop c’est de vérifier si lisa est installé, pour cela tu peux taper en ligne de commande qu’il t’a donné en gras…
Je vais ce que vous m’avez indiqué mais l’erreur est toujours là :
[quote=“le_sage”]Je vais ce que vous m’avez indiqué mais l’erreur est toujours là :[/quote] :question:
Mais tu as lisa d’installé et configuré ?
le_sage, tu nous dis que l’erreur est là, mais nous on ne voit rien si tu ne nous fait pas un copier coller du message d’erreur (ou d’une partie de…). Là tu es vraiment trop, comment dire, évasif? Bref on manque d’infos… Soit plus verbeux, bavard quoi.
J’ai bien reçu vos messages.
J’ai bien suivi vos conseils mais l’erreur est toujours la même à savoir je vais dans Konqueror, réseau local et j’obtiens locahost et rien d’autres, alors je vais dans partage samba j’obtiens mshome et après je clique sur mshome et j’ai une erreur (erreur konqueror, pas de réponse du serveur, mshome)
Et ce qu’on t’a conseillé de tester, et les questions qu’on t’a posé ça donne quoi ?
(dernier essai d’obtenir un peu d’info pour t’aider :imp: )
Tout à a été testé le réseau fonction bien lorsque je mets l’adresse IP à la place de MSHOME mais certainement que je suis dur de la feuille.
