Voila mon probleme
Description du materiel
Portable medion md95921
Tout marche sur ce portable sauf le son
J’ai tout essayé, sur tous les forums, j’ai meme installe des fedora, gentoo, ubuntu mais rien ne fait.
Je precise que les enceintes et le son sont bien fonctionnelles, car j’ai meme ete jusqu’a teste un win pour etre sur que c’etait pas materielle
j’ai compile les derniers drivers, utils, libs et firmwares alsa
uname -a
Linux lap 2.6.18-4-686 #1 SMP Wed Feb 21 16:06:54 UTC 2007 i686 GNU/Linux
#lspci -v 00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 02)
Subsystem: Rioworks Unknown device 2054
Flags: bus master, fast devsel, latency 0, IRQ 74
Memory at d5300000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Capabilities: [60] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
Capabilities: [70] Express Unknown type IRQ 0
Capabilities: [100] Virtual Channel
Capabilities: [130] Unknown (5)
lspci | grep Audio
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: ALC883 Analog [ALC883 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 6: Si3054 Modem [Si3054 Modem]
Subdevices: 1/1
amixer
Simple mixer control ‘Headphone’,0
Capabilities: pswitch
Playback channels: Front Left - Front Right
Mono:
Front Left: Playback [on]
Front Right: Playback [on]
Simple mixer control ‘Front’,0
Capabilities: pvolume pswitch
Limits: Playback 0 - 31
Mono:
Front Left: Playback 25 [81%] [-9.00dB] [on]
Front Right: Playback 25 [81%] [-9.00dB] [on]
Simple mixer control ‘Front Mic’,0
Mono:
Front Left: Playback 31 [100%] [12.00dB] [off]
Front Right: Playback 31 [100%] [12.00dB] [off]
Simple mixer control ‘Front Mic Boost’,0
Capabilities: volume
Capture channels: Front Left - Front Right
Limits: 0 - 3
Front Left: 3 [100%]
Front Right: 3 [100%]
Simple mixer control ‘Surround’,0
Playback channels: Front Left - Front Right# amixer
Mono:
Mono:
Mono:
Limits: 0 - 3
Mono:
Simple mixer control ‘Center’,0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Mono: Playback 25 [81%] [-9.00dB] [on]
Simple mixer control ‘LFE’,0
Simple mixer control ‘Line’,0
Mono:
Front Left: Playback 25 [81%] [3.00dB] [off]
Front Right: Playback 25 [81%] [3.00dB] [off]
Simple mixer control ‘CD’,0
Mono:
Front Left: Playback 25 [81%] [3.00dB] [on]
Front Right: Playback 25 [81%] [3.00dB] [on]
Simple mixer control ‘Mic’,0
Mono:
Simple mixer control ‘Mic Boost’,0
Limits: 0 - 3
Simple mixer control ‘PC Speaker’,0
Mono:
Simple mixer control ‘Capture’,0
Capabilities: cvolume cswitch
Limits: Capture 0 - 31
Front Left: Capture 31 [100%] [34.50dB] [on]
Front Right: Capture 31 [100%] [34.50dB] [on]
Simple mixer control ‘Caller ID’,0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control ‘Channel Mode’,0
Capabilities: enum
Items: ‘6ch’ '8ch’
Item0: '6ch’
Simple mixer control ‘Input Source’,0
Capabilities: enum
Items: ‘Mic’ ‘Front Mic’ ‘Line’ 'CD’
Item0: 'Front Mic’
Simple mixer control ‘Off-hook’,0
Mono:
Mono:
Mono:
Mono:
Limits: 0 - 3
Mono:
Capabilities: enum
Items: ‘6ch’ '8ch’
Item0: '6ch’
Capabilities: enum
Item0: 'Front Mic’
merci d’avance a vous tous et debian powaaaa
