[quote=“sebB”]Peux-tu poster cat /proc/cpuinfo
et
cat /boot/config-2.6.32-5-amd64 egrep |
‘CONFIG_X86_PCC_CPUFREQ|CONFIG_X86_ACPI_CPUFREQ|CONFIG_X86_POWERNOW_K8|CONFIG_X86_SPEEDSTEP_CENTRINO|CONFIG_X86_P4_CLOCKMOD’[/quote]
[code]laptop-ph:~$ cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 28
model name : Intel® Atom™ CPU 330 @ 1.60GHz
stepping : 2
cpu MHz : 1599.929
cache size : 512 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts rep_good aperfmperf pni dtes64 monitor ds_cpl tm2 ssse3 cx16 xtpr pdcm movbe lahf_lm
bogomips : 3199.85
clflush size : 64
cache_alignment : 64
address sizes : 32 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 28
stepping : 2
cpu MHz : 1599.929
cache size : 512 KB
physical id : 0
siblings : 4
core id : 1
cpu cores : 2
apicid : 2
initial apicid : 2
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
bogomips : 3199.96
clflush size : 64
power management:
processor : 2
cpu family : 6
model : 28
stepping : 2
cpu MHz : 1599.929
cache size : 512 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 2
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
bogomips : 3199.95
clflush size : 64
power management:
processor : 3
cpu family : 6
model : 28
stepping : 2
cpu MHz : 1599.929
cache size : 512 KB
physical id : 0
siblings : 4
core id : 1
cpu cores : 2
apicid : 3
initial apicid : 3
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
bogomips : 3199.97
clflush size : 64
power management:
[code]laptop-ph:~$ cat /boot/config-2.6.32-5-amd64 | grep "CONFIG_X86_PCC_CPUFREQ|CONFIG_X86_ACPI_CPUFREQ|CONFIG_X86_POWERNOW_K8|CONFIG_X86_SPEEDSTEP_CENTRINO|CONFIG_X86_P4_CLOCKMOD"
CONFIG_X86_ACPI_CPUFREQ=m
CONFIG_X86_POWERNOW_K8=m
CONFIG_X86_SPEEDSTEP_CENTRINO=m
CONFIG_X86_P4_CLOCKMOD is not set
[quote=“i M@N”]L’histoire de laptop-mode-tools c’était en plus, oublie ça … enlève laptop-mode-tools pour le moment puis remets les paquets radeontool, rfkill, acpi-support, eeepc-acpi-scripts et pm-utils.
C’est fait !
[quote=“i M@N”]il reste la solution acpi-cpufreq qui est compilé en module dans le kernel normalement (mais ça n’a pas l’air de fonctionner super avec tous les processeurs) … essaye voir :
iman@debian:~$ cat /boot/config-2.6.32-5-686 | grep ACPI_CPUFREQ
laptop-ph:~$ cat /boot/config-2.6.32-5-amd64 | grep ACPI_CPUFREQ
[quote=“i M@N”]sudo modprobe acpi-cpufreq
et donne ce que te renvoient :
cpufreq-info
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors
Si tu as “conservative” dans la liste tu peux faire :
Si ça fonctionne remplace p4-clockmod par acpi-cpufreq dans /etc/modules
root@laptop-ph:~# modprobe acpi-cpufreq
FATAL: Error inserting acpi_cpufreq (/lib/modules/2.6.32-5-amd64/kernel/arch/x86/kernel/cpu/cpufreq/acpi-cpufreq.ko): No such device
Et donc, pas de surprise :
root@laptop-ph:~# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors
cat: /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors: Aucun fichier ou dossier de ce type
