bonjour à tous
donc j’ai essayé les drivers cité plus haut et cela ne fonctionne toujours pas
j’ai donc regarder le fichier /var/log/xorg.0.log que voici [quote][ 19.775]
X.Org X Server 1.12.4
Release Date: 2012-08-27
[ 19.775] X Protocol Version 11, Revision 0
[ 19.775] Build Operating System: Linux 3.2.0-4-amd64 x86_64 Debian
[ 19.775] Current Operating System: Linux kali 3.9.3-pf #18 SMP PREEMPT Tue May 21 09:04:19 UTC 2013 x86_64
[ 19.775] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.9.3-pf root=UUID=dadfdd1f-41a7-42e5-8e79-94ab57e92d2e ro initrd=/install/gtk/initrd.gz quiet splash i8042.nomux i8042.reset=1 i8042.nopnp
[ 19.775] Build Date: 17 April 2013 10:22:47AM
[ 19.775] xorg-server 2:1.12.4-6 (Julien Cristau jcristau@debian.org)
[ 19.775] Current version of pixman: 0.26.0
[ 19.775] Before reporting problems, check wiki.x.org
[ 19.775] Markers: (–) probed, () from config file, (==) default setting,
[ 19.775] (==) Log file: “/var/log/Xorg.0.log”, Time: Tue Sep 3 09:07:19 2013
[ 19.837] (==) Using config file: “/etc/X11/xorg.conf”
[ 19.837] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 19.901] (==) ServerLayout “X.org Configured”
[ 19.901] () |–>Screen “Screen0” (0)
[ 19.901] () | |–>Monitor “Monitor0”
[ 19.901] () | |–>Device “Card0”
[ 19.901] () |–>Screen “Screen1” (1)
[ 19.901] () | |–>Monitor “Monitor1”
[ 19.901] () | |–>Device “Card1”
[ 19.901] () |–>Screen “Screen2” (2)
[ 19.901] () | |–>Monitor “Monitor2”
[ 19.901] () | |–>Device “Card2”
[ 19.901] () |–>Input Device “Mouse0”
[ 19.901] () |–>Input Device “Keyboard0”
[ 19.901] (==) Automatically adding devices
[ 19.901] (==) Automatically enabling devices
[ 19.937] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 19.937] Entry deleted from font path.
[ 19.979] (WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
[ 19.980] Entry deleted from font path.
[ 19.980] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 19.980] (WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
[ 19.980] () FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins,
built-ins
[ 19.980] () ModulePath set to “/usr/lib/xorg/modules”
[ 19.980] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 19.980] (WW) Disabling Mouse0
[ 19.980] (WW) Disabling Keyboard0
[ 19.980] (II) Loader magic: 0x7fc521012ae0
[ 19.980] (II) Module ABI versions:
[ 19.980] X.Org ANSI C Emulation: 0.4
[ 19.980] X.Org Video Driver: 12.1
[ 19.980] X.Org XInput driver : 16.0
[ 19.980] X.Org Server Extension : 6.0
[ 19.981] (–) PCI:*(0:0:2:0) 8086:0166:1b50:571c rev 9, Mem @ 0xf7800000/4194304, 0xe0000000/268435456, I/O @ 0x0000f000/64
[ 19.981] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 19.981] (II) “extmod” will be loaded. This was enabled by default and also specified in the config file.
[ 19.981] (II) “dbe” will be loaded. This was enabled by default and also specified in the config file.
[ 19.981] (II) “glx” will be loaded. This was enabled by default and also specified in the config file.
[ 19.981] (II) “record” will be loaded. This was enabled by default and also specified in the config file.
[ 19.981] (II) “dri” will be loaded. This was enabled by default and also specified in the config file.
[ 19.981] (II) “dri2” will be loaded. This was enabled by default and also specified in the config file.
[ 19.981] (II) LoadModule: “extmod”
[ 20.003] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 20.021] (II) Module extmod: vendor=“X.Org Foundation”
[ 20.021] compiled for 1.12.4, module version = 1.0.0
[ 20.021] Module class: X.Org Server Extension
[ 20.021] ABI class: X.Org Server Extension, version 6.0
[ 20.021] (II) Loading extension SELinux
[ 20.021] (II) Loading extension MIT-SCREEN-SAVER
[ 20.021] (II) Loading extension XFree86-VidModeExtension
[ 20.021] (II) Loading extension XFree86-DGA
[ 20.021] (II) Loading extension DPMS
[ 20.021] (II) Loading extension XVideo
[ 20.021] (II) Loading extension XVideo-MotionCompensation
[ 20.021] (II) Loading extension X-Resource
[ 20.021] (II) LoadModule: “glx”
[ 20.021] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 20.027] (II) Module glx: vendor=“X.Org Foundation”
[ 20.027] compiled for 1.12.4, module version = 1.0.0
[ 20.027] ABI class: X.Org Server Extension, version 6.0
[ 20.027] (==) AIGLX enabled
[ 20.027] (II) Loading extension GLX
[ 20.027] (II) LoadModule: “dbe”
[ 20.027] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 20.028] (II) Module dbe: vendor=“X.Org Foundation”
[ 20.028] compiled for 1.12.4, module version = 1.0.0
[ 20.028] Module class: X.Org Server Extension
[ 20.028] ABI class: X.Org Server Extension, version 6.0
[ 20.028] (II) Loading extension DOUBLE-BUFFER
[ 20.028] (II) LoadModule: “dri”
[ 20.028] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 20.038] (II) Module dri: vendor=“X.Org Foundation”
[ 20.038] compiled for 1.12.4, module version = 1.0.0
[ 20.038] ABI class: X.Org Server Extension, version 6.0
[ 20.038] (II) Loading extension XFree86-DRI
[ 20.038] (II) LoadModule: “record”
[ 20.038] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 20.039] (II) Module record: vendor=“X.Org Foundation”
[ 20.039] compiled for 1.12.4, module version = 1.13.0
[ 20.039] Module class: X.Org Server Extension
[ 20.039] ABI class: X.Org Server Extension, version 6.0
[ 20.039] (II) Loading extension RECORD
[ 20.039] (II) LoadModule: “dri2”
[ 20.039] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 20.039] (II) Module dri2: vendor=“X.Org Foundation”
[ 20.039] compiled for 1.12.4, module version = 1.2.0
[ 20.039] (II) Loading extension DRI2
[ 20.039] (II) LoadModule: “intel”
[ 20.039] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 20.073] (II) Module intel: vendor=“X.Org Foundation”
[ 20.073] compiled for 1.12.3.902, module version = 2.19.0
[ 20.073] Module class: X.Org Video Driver
[ 20.073] ABI class: X.Org Video Driver, version 12.1
[ 20.073] (II) LoadModule: “fbdev”
[ 20.073] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 20.073] (II) Module fbdev: vendor=“X.Org Foundation”
[ 20.073] compiled for 1.12.1, module version = 0.4.2
[ 20.073] ABI class: X.Org Video Driver, version 12.0
[ 20.073] (II) LoadModule: “vesa”
[ 20.073] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 20.073] (II) Module vesa: vendor=“X.Org Foundation”
[ 20.073] compiled for 1.12.1, module version = 2.3.1
[ 20.073] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge Desktop (GT1), Sandybridge Desktop (GT2),
Sandybridge Desktop (GT2+), Sandybridge Mobile (GT1),
Sandybridge Mobile (GT2), Sandybridge Mobile (GT2+),
Sandybridge Server, Ivybridge Mobile (GT1), Ivybridge Mobile (GT2),
Ivybridge Desktop (GT1), Ivybridge Desktop (GT2), Ivybridge Server,
Ivybridge Server (GT2)
[ 20.074] (II) FBDEV: driver for framebuffer: fbdev
[ 20.074] (II) VESA: driver for VESA chipsets: vesa
[ 20.074] (++) using VT number 7
[ 20.079] (WW) Falling back to old probe method for fbdev
[ 20.079] (II) Loading sub module “fbdevhw”
[ 20.079] (II) LoadModule: “fbdevhw”
[ 20.079] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 20.090] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 20.090] compiled for 1.12.4, module version = 0.0.2
[ 20.090] ABI class: X.Org Video Driver, version 12.1
[ 20.090] (WW) Falling back to old probe method for vesa
[ 20.090] drmOpenDevice: node name is /dev/dri/card0
[ 20.090] drmOpenDevice: open result is 8, (OK)
[ 20.090] drmOpenByBusid: Searching for BusID pci:0000:00:02.0
[ 20.090] drmOpenByBusid: drmOpenMinor returns 8
[ 20.090] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[ 20.091] (==) intel(0): Depth 24, (–) framebuffer bpp 32
[ 20.091] (==) intel(0): RGB weight 888
[ 20.091] (==) intel(0): Default visual is TrueColor
[ 20.091] (II) intel(0): Integrated Graphics Chipset: Intel® Ivybridge Mobile (GT2)
[ 20.091] (–) intel(0): Chipset: “Ivybridge Mobile (GT2)”
[ 20.091] () intel(0): Relaxed fencing enabled
[ 20.091] () intel(0): Wait on SwapBuffers? enabled
[ 20.091] () intel(0): Triple buffering? enabled
[ 20.091] () intel(0): Framebuffer tiled
[ 20.091] () intel(0): Pixmaps tiled
[ 20.091] () intel(0): 3D buffers tiled
[ 20.091] () intel(0): SwapBuffers wait enabled
[ 20.091] (==) intel(0): video overlay key set to 0x101fe
[ 20.091] (II) intel(0): Output LVDS1 using monitor section Monitor0
[ 20.091] (II) intel(0): found backlight control interface /sys/class/backlight/acpi_video0
[ 20.092] (II) intel(0): Output VGA1 has no monitor section
[ 20.093] (II) intel(0): Output HDMI1 has no monitor section
[ 20.093] (II) intel(0): Output DP1 has no monitor section
[ 20.093] (II) intel(0): EDID for output LVDS1
[ 20.093] (II) intel(0): Not using default mode “320x240” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “400x300” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “512x384” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “640x480” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “640x512” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “800x600” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “896x672” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “928x696” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “960x720” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “576x432” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “680x384” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “700x525” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “720x450” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “800x512” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “840x525” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “960x540” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “960x600” (doublescan mode not supported)
[ 20.093] (II) intel(0): Not using default mode “1024x768” (doublescan mode not supported)
[ 20.093] (II) intel(0): Printing probed modes for output LVDS1
[ 20.093] (II) intel(0): Modeline "1366x768"x59.9 72.00 1366 1380 1436 1502 768 769 772 800 -hsync -vsync (47.9 kHz P)
[ 20.093] (II) intel(0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
[ 20.093] (II) intel(0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
[ 20.093] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 20.093] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 20.093] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 20.093] (II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 20.094] (II) intel(0): EDID for output VGA1
[ 20.094] (II) intel(0): EDID for output HDMI1
[ 20.094] (II) intel(0): EDID for output DP1
[ 20.094] (II) intel(0): Output LVDS1 connected
[ 20.094] (II) intel(0): Output VGA1 disconnected
[ 20.094] (II) intel(0): Output HDMI1 disconnected
[ 20.095] (II) intel(0): Output DP1 disconnected
[ 20.095] (II) intel(0): Using exact sizes for initial modes
[ 20.095] (II) intel(0): Output LVDS1 using initial mode 1366x768
[ 20.095] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 20.095] (II) intel(0): Kernel page flipping support detected, enabling
[ 20.095] (==) intel(0): DPI set to (96, 96)
[ 20.095] (II) Loading sub module “fb”
[ 20.095] (II) LoadModule: “fb”
[ 20.095] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 20.114] (II) Module fb: vendor=“X.Org Foundation”
[ 20.114] compiled for 1.12.4, module version = 1.0.0
[ 20.114] ABI class: X.Org ANSI C Emulation, version 0.4
[ 20.114] (II) Loading sub module “dri2”
[ 20.114] (II) LoadModule: “dri2”
[ 20.114] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 20.114] (II) Module dri2: vendor=“X.Org Foundation”
[ 20.114] compiled for 1.12.4, module version = 1.2.0
[ 20.114] ABI class: X.Org Server Extension, version 6.0
[ 20.114] (II) UnloadModule: “fbdev”
[ 20.114] (II) Unloading fbdev
[ 20.114] (II) UnloadSubModule: “fbdevhw”
[ 20.114] (II) Unloading fbdevhw
[ 20.114] (II) UnloadModule: “vesa”
[ 20.114] (II) Unloading vesa
[ 20.114] (==) Depth 24 pixmap format is 32 bpp
[ 20.114] (II) intel(0): [DRI2] Setup complete
[ 20.114] (II) intel(0): [DRI2] DRI driver: i965
[ 20.114] (II) intel(0): Allocated new frame buffer 1408x768 stride 5632, tiled
[ 20.120] (II) UXA(0): Driver registered support for the following operations:
[ 20.120] (II) solid
[ 20.120] (II) copy
[ 20.120] (II) composite (RENDER acceleration)
[ 20.120] (II) put_image
[ 20.120] (II) get_image
[ 20.120] (==) intel(0): Backing store disabled
[ 20.120] (==) intel(0): Silken mouse enabled
[ 20.120] (II) intel(0): Initializing HW Cursor
[ 20.120] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 20.128] (==) intel(0): DPMS enabled
[ 20.128] (==) intel(0): Intel XvMC decoder enabled
[ 20.128] (II) intel(0): Set up textured video
[ 20.128] (II) intel(0): [XvMC] xvmc_vld driver initialized.
[ 20.128] (II) intel(0): direct rendering: DRI2 Enabled
[ 20.128] (==) intel(0): hotplug detection: “enabled”
[ 20.156] (–) RandR disabled
[ 20.156] (II) Initializing built-in extension Generic Event Extension
[ 20.156] (II) Initializing built-in extension SHAPE
[ 20.156] (II) Initializing built-in extension MIT-SHM
[ 20.156] (II) Initializing built-in extension XInputExtension
[ 20.156] (II) Initializing built-in extension XTEST
[ 20.156] (II) Initializing built-in extension BIG-REQUESTS
[ 20.156] (II) Initializing built-in extension SYNC
[ 20.156] (II) Initializing built-in extension XKEYBOARD
[ 20.156] (II) Initializing built-in extension XC-MISC
[ 20.156] (II) Initializing built-in extension SECURITY
[ 20.156] (II) Initializing built-in extension XINERAMA
[ 20.156] (II) Initializing built-in extension XFIXES
[ 20.156] (II) Initializing built-in extension RENDER
[ 20.156] (II) Initializing built-in extension RANDR
[ 20.156] (II) Initializing built-in extension COMPOSITE
[ 20.156] (II) Initializing built-in extension DAMAGE
[ 20.156] (II) SELinux: Disabled on system
[ 20.279] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 20.279] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 20.279] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 20.279] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 20.279] (II) AIGLX: Loaded and initialized i965
[ 20.279] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 20.279] (II) intel(0): Setting screen physical size to 361 x 203
[ 21.330] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[ 21.330] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 21.330] (II) LoadModule: “evdev”
[ 21.348] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 21.361] (II) Module evdev: vendor=“X.Org Foundation”
[ 21.361] compiled for 1.12.1, module version = 2.7.0
[ 21.361] Module class: X.Org XInput Driver
[ 21.361] ABI class: X.Org XInput driver, version 16.0
[ 21.361] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 21.361] () Power Button: always reports core events
[ 21.361] () evdev: Power Button: Device: “/dev/input/event4”
[ 21.361] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 21.361] (–) evdev: Power Button: Found keys
[ 21.361] (II) evdev: Power Button: Configuring as keyboard
[ 21.361] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event4”
[ 21.361] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 21.361] () Option “xkb_rules” “evdev”
[ 21.361] () Option “xkb_model” “pc105”
[ 21.361] () Option “xkb_layout” “fr”
[ 21.361] () Option “xkb_variant” “latin9”
[ 21.524] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[ 21.524] () Video Bus: Applying InputClass “evdev keyboard catchall”
[ 21.524] (II) Using input driver ‘evdev’ for ‘Video Bus’
[ 21.524] () Video Bus: always reports core events
[ 21.524] () evdev: Video Bus: Device: “/dev/input/event8”
[ 21.524] (–) evdev: Video Bus: Vendor 0 Product 0x6
[ 21.524] (–) evdev: Video Bus: Found keys
[ 21.524] (II) evdev: Video Bus: Configuring as keyboard
[ 21.524] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8/event8”
[ 21.524] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 7)
[ 21.524] () Option “xkb_rules” “evdev”
[ 21.524] () Option “xkb_model” “pc105”
[ 21.524] () Option “xkb_layout” “fr”
[ 21.524] () Option “xkb_variant” “latin9”
[ 21.524] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 21.524] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 21.524] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 21.524] () Power Button: always reports core events
[ 21.524] () evdev: Power Button: Device: “/dev/input/event2”
[ 21.524] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 21.524] (–) evdev: Power Button: Found keys
[ 21.524] (II) evdev: Power Button: Configuring as keyboard
[ 21.525] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2”
[ 21.525] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id
[ 21.525] () Option “xkb_rules” “evdev”
[ 21.525] () Option “xkb_model” “pc105”
[ 21.525] () Option “xkb_layout” “fr”
[ 21.525] () Option “xkb_variant” “latin9”
[ 21.525] (II) config/udev: Adding input device Lid Switch (/dev/input/event3)
[ 21.525] (II) No input driver specified, ignoring this device.
[ 21.525] (II) This device may have been added with another device file.
[ 21.525] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 21.525] () Sleep Button: Applying InputClass “evdev keyboard catchall”
[ 21.525] (II) Using input driver ‘evdev’ for ‘Sleep Button’
[ 21.525] () Sleep Button: always reports core events
[ 21.525] () evdev: Sleep Button: Device: “/dev/input/event1”
[ 21.525] (–) evdev: Sleep Button: Vendor 0 Product 0x3
[ 21.525] (–) evdev: Sleep Button: Found keys
[ 21.525] (II) evdev: Sleep Button: Configuring as keyboard
[ 21.525] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1”
[ 21.525] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 9)
[ 21.526] (II) config/udev: Adding input device USB Video Device (/dev/input/event7)
[ 21.526] () USB Video Device: Applying InputClass “evdev keyboard catchall”
[ 21.526] (II) Using input driver ‘evdev’ for ‘USB Video Device’
[ 21.526] () USB Video Device: always reports core events
[ 21.526] () evdev: USB Video Device: Device: “/dev/input/event7”
[ 21.526] (–) evdev: USB Video Device: Vendor 0x90c Product 0x37c0
[ 21.526] (–) evdev: USB Video Device: Found keys
[ 21.526] (II) evdev: USB Video Device: Configuring as keyboard
[ 21.526] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/input/input7/event7”
[ 21.526] (II) XINPUT: Adding extended input device “USB Video Device” (type: KEYBOARD, id 10)
[ 21.526] () Option “xkb_rules” “evdev”
[ 21.526] () Option “xkb_model” “pc105”
[ 21.526] () Option “xkb_layout” “fr”
[ 21.526] () Option “xkb_variant” “latin9”
[ 21.526] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event5)
[ 21.526] () Logitech USB Receiver: Applying InputClass “evdev pointer catchall”
[ 21.526] () Logitech USB Receiver: Applying InputClass “fsp”
[ 21.526] (II) Using input driver ‘evdev’ for ‘Logitech USB Receiver’
[ 21.526] () Logitech USB Receiver: always reports core events
[ 21.526] () evdev: Logitech USB Receiver: Device: “/dev/input/event5”
[ 21.526] (–) evdev: Logitech USB Receiver: Vendor 0x46d Product 0xc52f
[ 21.526] (–) evdev: Logitech USB Receiver: Found 20 mouse buttons
[ 21.526] (–) evdev: Logitech USB Receiver: Found scroll wheel(s)
[ 21.526] (–) evdev: Logitech USB Receiver: Found relative axes
[ 21.526] (–) evdev: Logitech USB Receiver: Found x and y relative axes
[ 21.526] (II) evdev: Logitech USB Receiver: Configuring as mouse
[ 21.526] (II) evdev: Logitech USB Receiver: Adding scrollwheel support
[ 21.526] () evdev: Logitech USB Receiver: YAxisMapping: buttons 4 and 5
[ 21.527] () evdev: Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 21.527] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.3/3-1.3:1.0/input/input5/event5”
[ 21.527] (II) XINPUT: Adding extended input device “Logitech USB Receiver” (type: MOUSE, id 11)
[ 21.527] (II) evdev: Logitech USB Receiver: initialized for relative axes.
[ 21.527] () Logitech USB Receiver: (accel) keeping acceleration scheme 1
[ 21.527] () Logitech USB Receiver: (accel) acceleration profile 0
[ 21.527] () Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 21.527] () Logitech USB Receiver: (accel) acceleration threshold: 4
[ 21.527] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
[ 21.527] (II) No input driver specified, ignoring this device.
[ 21.527] (II) This device may have been added with another device file.
[ 21.527] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event6)
[ 21.527] () Logitech USB Receiver: Applying InputClass “evdev keyboard catchall”
[ 21.527] (II) Using input driver ‘evdev’ for ‘Logitech USB Receiver’
[ 21.527] () Logitech USB Receiver: always reports core events
[ 21.527] () evdev: Logitech USB Receiver: Device: “/dev/input/event6”
[ 21.527] (–) evdev: Logitech USB Receiver: Vendor 0x46d Product 0xc52f
[ 21.527] (–) evdev: Logitech USB Receiver: Found 1 mouse buttons
[ 21.527] (–) evdev: Logitech USB Receiver: Found scroll wheel(s)
[ 21.527] (–) evdev: Logitech USB Receiver: Found relative axes
[ 21.527] (II) evdev: Logitech USB Receiver: Forcing relative x/y axes to exist.
[ 21.527] (–) evdev: Logitech USB Receiver: Found absolute axes
[ 21.527] (II) evdev: Logitech USB Receiver: Forcing absolute x/y axes to exist.
[ 21.527] (–) evdev: Logitech USB Receiver: Found keys
[ 21.527] (II) evdev: Logitech USB Receiver: Configuring as mouse
[ 21.527] (II) evdev: Logitech USB Receiver: Configuring as keyboard
[ 21.527] (II) evdev: Logitech USB Receiver: Adding scrollwheel support
[ 21.527] () evdev: Logitech USB Receiver: YAxisMapping: buttons 4 and 5
[ 21.527] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.3/3-1.3:1.1/input/input6/event6”
[ 21.527] (II) XINPUT: Adding extended input device “Logitech USB Receiver” (type: KEYBOARD, id 12)
[ 21.527] () Option “xkb_rules” “evdev”
[ 21.527] () Option “xkb_model” “pc105”
[ 21.527] () Option “xkb_layout” “fr”
[ 21.527] () Option “xkb_variant” “latin9”
[ 21.528] (II) evdev: Logitech USB Receiver: initialized for relative axes.
[ 21.528] (WW) evdev: Logitech USB Receiver: ignoring absolute axes.
[ 21.528] () Logitech USB Receiver: (accel) keeping acceleration scheme 1
[ 21.528] () Logitech USB Receiver: (accel) acceleration profile 0
[ 21.528] () Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 21.528] () Logitech USB Receiver: (accel) acceleration threshold: 4
[ 21.528] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event10)
[ 21.528] (II) No input driver specified, ignoring this device.
[ 21.528] (II) This device may have been added with another device file.
[ 21.528] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event11)
[ 21.528] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event9)
[ 21.529] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 21.529] () AT Translated Set 2 keyboard: Applying InputClass “evdev keyboard catchall”
[ 21.529] (II) Using input driver ‘evdev’ for ‘AT Translated Set 2 keyboard’
[ 21.529] () AT Translated Set 2 keyboard: always reports core events
[ 21.529] () evdev: AT Translated Set 2 keyboard: Device: “/dev/input/event0”
[ 21.529] (–) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 21.529] (–) evdev: AT Translated Set 2 keyboard: Found keys
[ 21.529] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 21.529] () Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input0/event0”
[ 21.529] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 13)
[ 21.529] () Option “xkb_rules” “evdev”
[ 21.529] () Option “xkb_model” “pc105”
[ 21.529] () Option “xkb_layout” “fr”
[ 21.529] () Option “xkb_variant” “latin9”
et je m’aperçois qu’il y a ce passage :
[quote][ 19.980] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 19.980] (WW) Disabling Keyboard0[/quote]
cela ne pourrait-il pas venir de là ?
