le code error dans la navigator :
[code]An Error Was Encountered
220 mx.google.com ESMTP v1sm98698524qas.15 - gsmtp
hello: 250-mx.google.com at your service, [80.241.216.212]
250-SIZE 35882577
250-8BITMIME
250-AUTH LOGIN PLAIN XOAUTH XOAUTH2 PLAIN-CLIENTTOKEN
250-ENHANCEDSTATUSCODES
250 CHUNKING
data: 503 5.5.1 RCPT first. v1sm98698524qas.15 - gsmtp
The following SMTP error was encountered: 503 5.5.1 RCPT first. v1sm98698524qas.15 - gsmtp
502 5.5.1 Unrecognized command. v1sm98698524qas.15 - gsmtp
The following SMTP error was encountered: 502 5.5.1 Unrecognized command. v1sm98698524qas.15 - gsmtp
Unable to send email using PHP SMTP. Your server might not be configured to send mail using this method.
220 mx.google.com ESMTP ks9sm5206009qeb.11 - gsmtp
250-SIZE 35882577
250-8BITMIME
250 CHUNKING
data: 503 5.5.1 RCPT first. ks9sm5206009qeb.11 - gsmtp
The following SMTP error was encountered: 503 5.5.1 RCPT first. ks9sm5206009qeb.11 - gsmtp
502 5.5.1 Unrecognized command. ks9sm5206009qeb.11 - gsmtp
The following SMTP error was encountered: 502 5.5.1 Unrecognized command. ks9sm5206009qeb.11 - gsmtp
User-Agent: CodeIgniter
Date: Wed, 8 Jan 2014 02:10:24 +0100
Reply-To: “” <>
X-Mailer: CodeIgniter
X-Priority: 3 (Normal)
Message-ID: <52cca5823ec01>
Mime-Version: 1.0
Content-Type: multipart/alternative; boundary=“B_ALT_52cca5823ec72”
This is a multi-part message in MIME format.
Your email application may not support this format.
–B_ALT_52cca5823ec72
Content-Type: text/plain; charset=utf-8
Content-Transfer-Encoding: 8bit
Content-Type: text/html; charset=utf-8
Content-Transfer-Encoding: quoted-printable
–B_ALT_52cca5823ec72–[/code]
plus d’info je bosse avec Codeigniter !
