Comment savoir si je boot bien en 5.2 ?
Quand j’effectue la commande : lsmod | grep radeon , je n’obtiens rien…
Que dit ceci:
lspci -k | grep -A2 VGA
uname -a
root@Utilisateur-Debian:/home/utilisateur# lspci -k | grep -A2 VGA
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV280 [Radeon 9200 PRO] (rev 01)
Subsystem: Tul Corporation / PowerColor RV280 [Radeon 9200 PRO]
Kernel modules: radeonfb, radeon
root@Utilisateur-Debian:/home/utilisateur# uname -a
Linux Utilisateur-Debian 4.19.0-6-amd64 #1 SMP Debian 4.19.67-2+deb10u1 (2019-09-20) x86_64 GNU/Linux
Que dit ceci
dpkg -l | grep firmware-amd
ii libpangocairo-1.0-0:amd64 1.42.4-7~deb10u1 amd64 Layout and rendering of internationalized text
ii libpangoft2-1.0-0:amd64 1.42.4-7~deb10u1 amd64 Layout and rendering of internationalized text
ii libpangomm-1.4-1v5:amd64 2.42.0-2 amd64 C++ Wrapper for pango (shared libraries)
ii libpangoxft-1.0-0:amd64 1.42.4-7~deb10u1 amd64 Layout and rendering of internationalized text
ii libpaper-utils 1.1.28 amd64 library for handling paper characteristics (utilities)
ii libpaper1:amd64 1.1.28 amd64 library for handling paper characteristics
ii libparted-fs-resize0:amd64 3.2-25 amd64 disk partition manipulator - shared FS resizing library
ii libparted2:amd64 3.2-25 amd64 disk partition manipulator - shared library
ii libpcap0.8:amd64 1.8.1-6 amd64 system interface for user-level packet capture
ii libpcaudio0:amd64 1.1-3 amd64 C API to different audio devices - shared library
ii libpci3:amd64 1:3.5.2-1 amd64 Linux PCI Utilities (shared library)
ii libpciaccess0:amd64 0.14-1 amd64 Generic PCI access library for X
ii libpcre2-8-0:amd64 10.32-5 amd64 New Perl Compatible Regular Expression Library- 8 bit runtime files
ii libpcre3:amd64 2:8.39-12 amd64 Old Perl 5 Compatible Regular Expression Library - runtime files
ii libpcsclite1:amd64 1.8.24-1 amd64 Middleware to access a smart card using PC/SC (library)
ii libperl5.28:amd64 5.28.1-6 amd64 shared Perl library
ii libpgm-5.2-0:amd64 5.2.122~dfsg-3 amd64 OpenPGM shared library
ii libpipeline1:amd64 1.5.1-2 amd64 pipeline manipulation library
ii libpixman-1-0:amd64 0.36.0-1 amd64 pixel-manipulation library for X and cairo
ii libplist3:amd64 2.0.1~git20190104.3f96731-1 amd64 Library for handling Apple binary and XML property lists
ii libplymouth4:amd64 0.9.4-1.1 amd64 graphical boot animation and logger - shared libraries
ii libpng16-16:amd64 1.6.36-6 amd64 PNG library - runtime (version 1.6)
ii libpolkit-agent-1-0:amd64 0.105-25 amd64 PolicyKit Authentication Agent API
ii libpolkit-backend-1-0:amd64 0.105-25 amd64 PolicyKit backend API
ii libpolkit-gobject-1-0:amd64 0.105-25 amd64 PolicyKit Authorization API
ii libpoppler-glib8:amd64 0.71.0-5 amd64 PDF rendering library (GLib-based shared library)
ii libpoppler82:amd64 0.71.0-5 amd64 PDF rendering library
ii libpopt0:amd64 1.16-12 amd64 lib for parsing cmdline parameters
ii libpostproc55:amd64 7:4.1.4-1~deb10u1 amd64 FFmpeg library for post processing - runtime files
ii libpq5:amd64 11.5-1+deb10u1 amd64 PostgreSQL C client library
ii libprocps7:amd64 2:3.3.15-2 amd64 library for accessing process information from /proc
ii libprotobuf-c1:amd64 1.3.1-1+b1 amd64 Protocol Buffers C shared library (protobuf-c)
ii libproxy1v5:amd64 0.4.15-5 amd64 automatic proxy configuration management library (shared)
ii libpsl5:amd64 0.20.2-2 amd64 Library for Public Suffix List (shared libraries)
ii libpulse-mainloop-glib0:amd64 12.2-4+deb10u1 amd64 PulseAudio client libraries (glib support)
ii libpulse0:amd64 12.2-4+deb10u1 amd64 PulseAudio client libraries
ii libpulsedsp:amd64 12.2-4+deb10u1 amd64 PulseAudio OSS pre-load library
ii libpython-stdlib:amd64 2.7.16-1 amd64 interactive high-level object-oriented language (Python2)
ii libpython2-stdlib:amd64 2.7.16-1 amd64 interactive high-level object-oriented language (Python2)
ii libpython2.7:amd64 2.7.16-2 amd64 Shared Python runtime library (version 2.7)
ii libpython2.7-minimal:amd64 2.7.16-2 amd64 Minimal subset of the Python language (version 2.7)
ii libpython2.7-stdlib:amd64 2.7.16-2 amd64 Interactive high-level object-oriented language (standard library, version 2.7)
ii libpython3-stdlib:amd64 3.7.3-1 amd64 interactive high-level object-oriented language (default python3 version)
ii libpython3.7:amd64 3.7.3-2 amd64 Shared Python runtime library (version 3.7)
ii libpython3.7-minimal:amd64 3.7.3-2 amd64 Minimal subset of the Python language (version 3.7)
ii libpython3.7-stdlib:amd64 3.7.3-2 amd64 Interactive high-level object-oriented language (standard library, version 3.7)
ii libqmi-glib5:amd64 1.22.0-1.2 amd64 Support library to use the Qualcomm MSM Interface (QMI) protocol
ii libqmi-proxy 1.22.0-1.2 amd64 Proxy to communicate with QMI ports
ii libqpdf21:amd64 8.4.0-2 amd64 runtime library for PDF transformation/inspection software
ii libqrencode4:amd64 4.0.2-1 amd64 QR Code encoding library
ii libquadmath0:amd64 8.3.0-6 amd64 GCC Quad-Precision Math Library
ii libqxp-0.0-0 0.0.2-1 amd64 library for reading and converting QuarkXPress files
ii libraptor2-0:amd64 2.0.14-1+b1 amd64 Raptor 2 RDF syntax library
ii librasqal3:amd64 0.9.32-1+b1 amd64 Rasqal RDF query library
ii libraw1394-11:amd64 2.1.2-1+b1 amd64 library for direct access to IEEE 1394 bus (aka FireWire)
ii libraw19:amd64 0.19.2-2 amd64 raw image decoder library
ii librdf0:amd64 1.0.17-1.1+b1 amd64 Redland Resource Description Framework (RDF) library
ii libreadline7:amd64 7.0-5 amd64 GNU readline and history libraries, run-time libraries
ii libreoffice 1:6.1.5-3+deb10u4 amd64 office productivity suite (metapackage)
ii libreoffice-avmedia-backend-gstreamer 1:6.1.5-3+deb10u4 amd64 GStreamer backend for LibreOffice
ii libreoffice-base 1:6.1.5-3+deb10u4 amd64 office productivity suite -- database
ii libreoffice-base-core 1:6.1.5-3+deb10u4 amd64 office productivity suite -- shared library
ii libreoffice-base-drivers 1:6.1.5-3+deb10u4 amd64 Database connectivity drivers for LibreOffice
ii libreoffice-calc 1:6.1.5-3+deb10u4 amd64 office productivity suite -- spreadsheet
ii libreoffice-core 1:6.1.5-3+deb10u4 amd64 office productivity suite -- arch-dependent files
ii libreoffice-draw 1:6.1.5-3+deb10u4 amd64 office productivity suite -- drawing
ii libreoffice-gtk2 1:6.1.5-3+deb10u4 amd64 office productivity suite -- GTK+ 2 integration
ii libreoffice-impress 1:6.1.5-3+deb10u4 amd64 office productivity suite -- presentation
ii libreoffice-math 1:6.1.5-3+deb10u4 amd64 office productivity suite -- equation editor
ii libreoffice-report-builder-bin 1:6.1.5-3+deb10u4 amd64 LibreOffice component for building database reports -- libraries
ii libreoffice-sdbc-firebird 1:6.1.5-3+deb10u4 amd64 Firebird SDBC driver for LibreOffice
ii libreoffice-sdbc-hsqldb 1:6.1.5-3+deb10u4 amd64 HSQLDB SDBC driver for LibreOffice
ii libreoffice-sdbc-postgresql 1:6.1.5-3+deb10u4 amd64 PostgreSQL SDBC driver for LibreOffice
ii libreoffice-writer 1:6.1.5-3+deb10u4 amd64 office productivity suite -- word processor
ii librest-0.7-0:amd64 0.8.1-1 amd64 REST service access library
ii librevenge-0.0-0:amd64 0.0.4-6 amd64 Base Library for writing document interface filters
ii librsvg2-2:amd64 2.44.10-2.1 amd64 SAX-based renderer library for SVG files (runtime)
ii librsvg2-common:amd64 2.44.10-2.1 amd64 SAX-based renderer library for SVG files (extra runtime)
ii librtmp1:amd64 2.4+20151223.gitfa8646d.1-2 amd64 toolkit for RTMP streams (shared library)
ii librubberband2:amd64 1.8.1-7 amd64 audio time-stretching and pitch-shifting library
ii libsamplerate0:amd64 0.1.9-2 amd64 Audio sample rate conversion library
ii libsane:amd64 1.0.27-3.2 amd64 API library for scanners
ii libsane-hpaio:amd64 3.18.12+dfsg0-2 amd64 HP SANE backend for multi-function peripherals
ii libsasl2-2:amd64 2.1.27+dfsg-1 amd64 Cyrus SASL - authentication abstraction library
ii libsasl2-modules:amd64 2.1.27+dfsg-1 amd64 Cyrus SASL - pluggable authentication modules
ii libsasl2-modules-db:amd64 2.1.27+dfsg-1 amd64 Cyrus SASL - pluggable authentication modules (DB)
ii libsbc1:amd64 1.4-1 amd64 Sub Band CODEC library - runtime
ii libsdl1.2debian:amd64 1.2.15+dfsg2-4 amd64 Simple DirectMedia Layer
ii libseccomp2:amd64 2.3.3-4 amd64 high level interface to Linux seccomp filter
ii libsecret-1-0:amd64 0.18.7-1 amd64 Secret store
ii libselinux1:amd64 2.8-1+b1 amd64 SELinux runtime shared libraries
ii libsemanage1:amd64 2.8-2 amd64 SELinux policy management library
ii libsensors5:amd64 1:3.5.0-3 amd64 library to read temperature/voltage/fan sensors
ii libsepol1:amd64 2.8-1 amd64 SELinux library for manipulating binary security policies
ii libserd-0-0:amd64 0.28.0~dfsg0-1 amd64 lightweight RDF syntax library
ii libshine3:amd64 3.1.1-2 amd64 Fixed-point MP3 encoding library - runtime files
ii libshout3:amd64 2.4.1-2 amd64 MP3/Ogg Vorbis broadcast streaming library
ii libsidplay1v5:amd64 1.36.59-11 amd64 SID (MOS 6581) emulation library
ii libsigc++-2.0-0v5:amd64 2.10.1-2 amd64 type-safe Signal Framework for C++ - runtime
ii libslang2:amd64 2.3.2-2 amd64 S-Lang programming library - runtime version
ii libsm6:amd64 2:1.2.3-1 amd64 X11 Session Management library
ii libsmartcols1:amd64 2.33.1-0.1 amd64 smart column output alignment library
ii libsmbclient:amd64 2:4.9.5+dfsg-5+deb10u1 amd64 shared library for communication with SMB/CIFS servers
ii libsnappy-jni 1.1.7.2-1 amd64 Snappy for Java, a fast compressor/decompresser (JNI library)
ii libsnappy1v5:amd64 1.1.7-1 amd64 fast compression/decompression library
ii libsndfile1:amd64 1.0.28-6 amd64 Library for reading/writing audio files
ii libsndio7.0:amd64 1.5.0-3 amd64 Small audio and MIDI framework from OpenBSD, runtime libraries
ii libsnmp30:amd64 5.7.3+dfsg-5 amd64 SNMP (Simple Network Management Protocol) library
ii libsodium23:amd64 1.0.17-1 amd64 Network communication, cryptography and signaturing library
ii libsonic0:amd64 0.2.0-7 amd64 Simple library to speed up or slow down speech
ii libsord-0-0:amd64 0.16.0~dfsg0-1+b1 amd64 library for storing RDF data in memory
ii libsoundtouch1:amd64 2.1.2+ds1-1 amd64 Sound stretching library
ii libsoup-gnome2.4-1:amd64 2.64.2-2 amd64 HTTP library implementation in C -- GNOME support library
ii libsoup2.4-1:amd64 2.64.2-2 amd64 HTTP library implementation in C -- Shared library
ii libsoxr0:amd64 0.1.2-3 amd64 High quality 1D sample-rate conversion library
ii libspandsp2:amd64 0.0.6+dfsg-2 amd64 Telephony signal processing library
ii libspectre1:amd64 0.2.8-1 amd64 Library for rendering PostScript documents
ii libspeechd2:amd64 0.9.0-5 amd64 Speech Dispatcher: Shared libraries
ii libspeex1:amd64 1.2~rc1.2-1+b2 amd64 The Speex codec runtime library
ii libspeexdsp1:amd64 1.2~rc1.2-1+b2 amd64 The Speex extended runtime library
ii libsqlite3-0:amd64 3.27.2-3 amd64 SQLite 3 shared library
ii libsqlite3-tcl 3.27.2-3 amd64 SQLite 3 Tcl bindings
ii libsratom-0-0:amd64 0.6.0~dfsg0-1 amd64 library for serialising LV2 atoms to/from Turtle
ii libsrtp2-1:amd64 2.2.0-1 amd64 Secure RTP (SRTP) and UST Reference Implementations - shared library
ii libss2:amd64 1.44.5-1+deb10u2 amd64 command-line interface parsing library
ii libssh-gcrypt-4:amd64 0.8.7-1 amd64 tiny C SSH library (gcrypt flavor)
ii libssh2-1:amd64 1.8.0-2.1 amd64 SSH2 client-side library
ii libssl1.1:amd64 1.1.1d-0+deb10u2 amd64 Secure Sockets Layer toolkit - shared libraries
ii libstaroffice-0.0-0:amd64 0.0.6-1 amd64 Import filter library to import all StarOffice documents
ii libstartup-notification0:amd64 0.12-6 amd64 library for program launch feedback (shared library)
ii libstdc++6:amd64 8.3.0-6 amd64 GNU Standard C++ Library v3
ii libstemmer0d:amd64 0+svn585-1+b2 amd64 Snowball stemming algorithms for use in Information Retrieval
ii libsuitesparseconfig5:amd64 1:5.4.0+dfsg-1 amd64 configuration routines for all SuiteSparse modules
ii libswresample3:amd64 7:4.1.4-1~deb10u1 amd64 FFmpeg library for audio resampling, rematrixing etc. - runtime files
ii libswscale5:amd64 7:4.1.4-1~deb10u1 amd64 FFmpeg library for image scaling and various conversions - runtime files
ii libsystemd0:amd64 241-7~deb10u1 amd64 systemd utility library
ii libtag1v5:amd64 1.11.1+dfsg.1-0.3 amd64 audio meta-data library
ii libtag1v5-vanilla:amd64 1.11.1+dfsg.1-0.3 amd64 audio meta-data library - vanilla flavour
ii libtagc0:amd64 1.11.1+dfsg.1-0.3 amd64 audio meta-data library - C bindings
ii libtalloc2:amd64 2.1.14-2 amd64 hierarchical pool based memory allocator
ii libtasn1-6:amd64 4.13-3 amd64 Manage ASN.1 structures (runtime)
ii libtcl8.6:amd64 8.6.9+dfsg-2 amd64 Tcl (the Tool Command Language) v8.6 - run-time library files
ii libtdb1:amd64 1.3.16-2+b1 amd64 Trivial Database - shared library
ii libteamdctl0:amd64 1.28-1 amd64 library for communication with `teamd` process
ii libtevent0:amd64 0.9.37-1 amd64 talloc-based event loop library - shared library
ii libtext-charwidth-perl 0.04-7.1+b1 amd64 get display widths of characters on the terminal
ii libtext-iconv-perl 1.7-5+b7 amd64 converts between character sets in Perl
ii libthai0:amd64 0.1.28-2 amd64 Thai language support library
ii libtheora0:amd64 1.1.1+dfsg.1-15 amd64 Theora Video Compression Codec
ii libthunarx-3-0:amd64 1.8.4-1 amd64 extension library for thunar
ii libtiff5:amd64 4.0.10-4 amd64 Tag Image File Format (TIFF) library
ii libtinfo6:amd64 6.1+20181013-2+deb10u1 amd64 shared low-level terminfo library for terminal handling
ii libtk-img:amd64 1:1.4.8+dfsg-1+deb10u1 amd64 Extended image format support for Tcl/Tk (runtime)
ii libtk8.6:amd64 8.6.9-2 amd64 Tk toolkit for Tcl and X11 v8.6 - run-time files
ii libtommath1:amd64 1.1.0-3 amd64 multiple-precision integer library [runtime]
ii libtumbler-1-0 0.2.3-1 amd64 library for tumbler, a D-Bus thumbnailing service
ii libtwolame0:amd64 0.3.13-4 amd64 MPEG Audio Layer 2 encoding library
ii libuchardet0:amd64 0.0.6-3 amd64 universal charset detection library - shared library
ii libudev1:amd64 241-7~deb10u1 amd64 libudev shared library
ii libudisks2-0:amd64 2.8.1-4 amd64 GObject based library to access udisks2
ii libumfpack5:amd64 1:5.4.0+dfsg-1 amd64 sparse LU factorization library
ii libunique-1.0-0 1.1.6-6 amd64 Library for writing single instance applications - shared libraries
ii libunistring2:amd64 0.9.10-1 amd64 Unicode string library for C
ii libunwind8:amd64 1.2.1-9 amd64 library to determine the call-chain of a program - runtime
ii libupower-glib3:amd64 0.99.10-1 amd64 abstraction for power management - shared library
ii libusb-0.1-4:amd64 2:0.1.12-32 amd64 userspace USB programming library
ii libusb-1.0-0:amd64 2:1.0.22-2 amd64 userspace USB programming library
ii libusbmuxd4:amd64 1.1.0~git20181007.07a493a-1 amd64 USB multiplexor daemon for iPhone and iPod Touch devices - library
ii libutempter0:amd64 1.1.6-3 amd64 privileged helper for utmp/wtmp updates (runtime)
ii libuuid1:amd64 2.33.1-0.1 amd64 Universally Unique ID library
ii libv4l-0:amd64 1.16.3-3 amd64 Collection of video4linux support libraries
ii libv4lconvert0:amd64 1.16.3-3 amd64 Video4linux frame format conversion library
ii libva-drm2:amd64 2.4.0-1 amd64 Video Acceleration (VA) API for Linux -- DRM runtime
ii libva-x11-2:amd64 2.4.0-1 amd64 Video Acceleration (VA) API for Linux -- X11 runtime
ii libva2:amd64 2.4.0-1 amd64 Video Acceleration (VA) API for Linux -- runtime
ii libvdpau-va-gl1:amd64 0.4.2-1+b1 amd64 VDPAU driver with OpenGL/VAAPI backend
ii libvdpau1:amd64 1.1.1-10 amd64 Video Decode and Presentation API for Unix (libraries)
ii libvidstab1.1:amd64 1.1.0-2 amd64 video stabilization library (shared library)
ii libvisio-0.1-1:amd64 0.1.6-1+b2 amd64 library for parsing the visio file structure
ii libvisual-0.4-0:amd64 0.4.0-15 amd64 audio visualization framework
ii libvo-aacenc0:amd64 0.1.3-1+b1 amd64 VisualOn AAC encoder library
ii libvo-amrwbenc0:amd64 0.1.3-1+b1 amd64 VisualOn AMR-WB encoder library
ii libvolume-key1 0.3.12-2+b1 amd64 Library for manipulating storage encryption keys and passphrases
ii libvorbis0a:amd64 1.3.6-2 amd64 decoder library for Vorbis General Audio Compression Codec
ii libvorbisenc2:amd64 1.3.6-2 amd64 encoder library for Vorbis General Audio Compression Codec
ii libvorbisfile3:amd64 1.3.6-2 amd64 high-level API for Vorbis General Audio Compression Codec
ii libvpx5:amd64 1.7.0-3 amd64 VP8 and VP9 video codec (shared library)
ii libvte-2.91-0:amd64 0.54.2-2 amd64 Terminal emulator widget for GTK+ 3.0 - runtime files
ii libvulkan1:amd64 1.1.97-2 amd64 Vulkan loader library
ii libwacom-bin 0.32-1 amd64 Wacom model feature query library -- binaries
ii libwacom2:amd64 0.32-1 amd64 Wacom model feature query library
ii libwavpack1:amd64 5.1.0-6 amd64 audio codec (lossy and lossless) - library
ii libwayland-client0:amd64 1.16.0-1 amd64 wayland compositor infrastructure - client library
ii libwayland-cursor0:amd64 1.16.0-1 amd64 wayland compositor infrastructure - cursor library
ii libwayland-egl1:amd64 1.16.0-1 amd64 wayland compositor infrastructure - EGL library
ii libwayland-server0:amd64 1.16.0-1 amd64 wayland compositor infrastructure - server library
ii libwbclient0:amd64 2:4.9.5+dfsg-5+deb10u1 amd64 Samba winbind client library
ii libwebkit2gtk-4.0-37:amd64 2.24.4-1~deb10u1 amd64 Web content engine library for GTK
ii libwebp6:amd64 0.6.1-2 amd64 Lossy compression of digital photographic images.
ii libwebpdemux2:amd64 0.6.1-2 amd64 Lossy compression of digital photographic images.
ii libwebpmux3:amd64 0.6.1-2 amd64 Lossy compression of digital photographic images.
ii libwebrtc-audio-processing1:amd64 0.3-1 amd64 AudioProcessing module from the WebRTC project.
ii libwildmidi2:amd64 0.4.3-1 amd64 software MIDI player library
ii libwnck-3-0:amd64 3.30.0-2 amd64 Window Navigator Construction Kit - runtime files
ii libwnck22:amd64 2.30.7-6 amd64 Window Navigator Construction Kit - runtime files
ii libwoff1:amd64 1.0.2-1 amd64 library for converting fonts to WOFF 2.0
ii libwpd-0.10-10:amd64 0.10.3-1 amd64 Library for handling WordPerfect documents (shared library)
ii libwpg-0.3-3:amd64 0.3.3-1 amd64 WordPerfect graphics import/convert library (shared library)
ii libwps-0.4-4:amd64 0.4.10-1 amd64 Works text file format import filter library (shared library)
ii libwrap0:amd64 7.6.q-28 amd64 Wietse Venema's TCP wrappers library
ii libx11-6:amd64 2:1.6.7-1 amd64 X11 client-side library
ii libx11-xcb1:amd64 2:1.6.7-1 amd64 Xlib/XCB interface library
ii libx264-155:amd64 2:0.155.2917+git0a84d98-2 amd64 x264 video coding library
ii libx265-165:amd64 2.9-4 amd64 H.265/HEVC video stream encoder (shared library)
ii libxapian30:amd64 1.4.11-1 amd64 Search engine library
ii libxatracker2:amd64 18.3.6-2 amd64 X acceleration library -- runtime
ii libxau6:amd64 1:1.0.8-1+b2 amd64 X11 authorisation library
ii libxaw7:amd64 2:1.0.13-1+b2 amd64 X11 Athena Widget library
ii libxcb-dri2-0:amd64 1.13.1-2 amd64 X C Binding, dri2 extension
ii libxcb-dri3-0:amd64 1.13.1-2 amd64 X C Binding, dri3 extension
ii libxcb-glx0:amd64 1.13.1-2 amd64 X C Binding, glx extension
ii libxcb-present0:amd64 1.13.1-2 amd64 X C Binding, present extension
ii libxcb-render0:amd64 1.13.1-2 amd64 X C Binding, render extension
ii libxcb-shape0:amd64 1.13.1-2 amd64 X C Binding, shape extension
ii libxcb-shm0:amd64 1.13.1-2 amd64 X C Binding, shm extension
ii libxcb-sync1:amd64 1.13.1-2 amd64 X C Binding, sync extension
ii libxcb-util0:amd64 0.3.8-3+b2 amd64 utility libraries for X C Binding -- atom, aux and event
ii libxcb-xfixes0:amd64 1.13.1-2 amd64 X C Binding, xfixes extension
ii libxcb1:amd64 1.13.1-2 amd64 X C Binding
ii libxcomposite1:amd64 1:0.4.4-2 amd64 X11 Composite extension library
ii libxcursor1:amd64 1:1.1.15-2 amd64 X cursor management library
ii libxdamage1:amd64 1:1.1.4-3+b3 amd64 X11 damaged region extension library
ii libxdmcp6:amd64 1:1.1.2-3 amd64 X11 Display Manager Control Protocol library
ii libxext6:amd64 2:1.3.3-1+b2 amd64 X11 miscellaneous extension library
ii libxfce4panel-2.0-4 4.12.2-1 amd64 Xfce4 panel libraries (GTK3 variant)
ii libxfce4ui-1-0:amd64 4.12.1-3 amd64 widget library for Xfce - Gtk+2 variant
ii libxfce4ui-2-0:amd64 4.12.1-3 amd64 widget library for Xfce - Gtk+3 variant
ii libxfce4ui-utils 4.12.1-3 amd64 Utility files for libxfce4ui
ii libxfce4util-bin 4.12.1-3 amd64 tools for libxfce4util
ii libxfce4util7:amd64 4.12.1-3 amd64 Utility functions library for Xfce4
ii libxfconf-0-2 4.12.1-1 amd64 Client library for Xfce4 configure interface
ii libxfixes3:amd64 1:5.0.3-1 amd64 X11 miscellaneous 'fixes' extension library
ii libxfont2:amd64 1:2.0.3-1 amd64 X11 font rasterisation library
ii libxft2:amd64 2.3.2-2 amd64 FreeType-based font drawing library for X
ii libxi6:amd64 2:1.7.9-1 amd64 X11 Input extension library
ii libxinerama1:amd64 2:1.1.4-2 amd64 X11 Xinerama extension library
ii libxkbcommon0:amd64 0.8.2-1 amd64 library interface to the XKB compiler - shared library
ii libxkbfile1:amd64 1:1.0.9-2+b11 amd64 X11 keyboard file manipulation library
ii libxklavier16:amd64 5.4-4 amd64 X Keyboard Extension high-level API
ii libxml-parser-perl 2.44-4 amd64 Perl module for parsing XML files
ii libxml2:amd64 2.9.4+dfsg1-7+b3 amd64 GNOME XML library
ii libxmlsec1:amd64 1.2.27-2 amd64 XML security library
ii libxmlsec1-nss:amd64 1.2.27-2 amd64 Nss engine for the XML security library
ii libxmu6:amd64 2:1.1.2-2+b3 amd64 X11 miscellaneous utility library
ii libxmuu1:amd64 2:1.1.2-2+b3 amd64 X11 miscellaneous micro-utility library
ii libxnvctrl0:amd64 418.74-1 amd64 NV-CONTROL X extension (runtime library)
ii libxpm4:amd64 1:3.5.12-1 amd64 X11 pixmap library
ii libxrandr2:amd64 2:1.5.1-1 amd64 X11 RandR extension library
ii libxrender1:amd64 1:0.9.10-1 amd64 X Rendering Extension client library
ii libxres1:amd64 2:1.2.0-2 amd64 X11 Resource extension library
ii libxshmfence1:amd64 1.3-1 amd64 X shared memory fences - shared library
ii libxslt1.1:amd64 1.1.32-2.1~deb10u1 amd64 XSLT 1.0 processing library - runtime library
ii libxss1:amd64 1:1.2.3-1 amd64 X11 Screen Saver extension library
ii libxt6:amd64 1:1.1.5-1+b3 amd64 X11 toolkit intrinsics library
ii libxtables12:amd64 1.8.2-4 amd64 netfilter xtables library
ii libxtst6:amd64 2:1.2.3-1 amd64 X11 Testing -- Record extension library
ii libxv1:amd64 2:1.0.11-1 amd64 X11 Video extension library
ii libxvidcore4:amd64 2:1.3.5-1 amd64 Open source MPEG-4 video codec (library)
ii libxvmc1:amd64 2:1.0.10-1 amd64 X11 Video extension library
ii libxxf86dga1:amd64 2:1.1.4-1+b3 amd64 X11 Direct Graphics Access extension library
ii libxxf86vm1:amd64 1:1.1.4-1+b2 amd64 X11 XFree86 video mode extension library
ii libyajl2:amd64 2.1.0-3 amd64 Yet Another JSON Library
ii libyaml-0-2:amd64 0.2.1-1 amd64 Fast YAML 1.1 parser and emitter library
ii libzbar0:amd64 0.22-1 amd64 bar code scanner and decoder (library)
ii libzmf-0.0-0:amd64 0.0.2-1+b2 amd64 Zoner Draw/Zebra file reading/converting library
ii libzmq5:amd64 4.3.1-4+deb10u1 amd64 lightweight messaging kernel (shared library)
ii libzstd1:amd64 1.3.8+dfsg-3 amd64 fast lossless compression algorithm
ii libzvbi0:amd64 0.2.35-16 amd64 Vertical Blanking Interval decoder (VBI) - runtime files
ii light-locker 1.8.0-3 amd64 simple screen locker for lightDM display manager
ii lightdm 1.26.0-4 amd64 simple display manager
ii lightdm-gtk-greeter 2.0.6-1 amd64 simple display manager (GTK+ greeter)
ii linux-image-4.19.0-6-amd64 4.19.67-2+deb10u1 amd64 Linux 4.19 for 64-bit PCs (signed)
ii linux-image-amd64 4.19+105+deb10u1 amd64 Linux for 64-bit PCs (meta-package)
ii lm-sensors 1:3.5.0-3 amd64 utilities to read temperature/voltage/fan sensors
ii login 1:4.5-1.1 amd64 system login tools
ii logrotate 3.14.0-4 amd64 Log rotation utility
ii lp-solve 5.5.0.15-4+b1 amd64 Solve (mixed integer) linear programming problems
ii lsof 4.91+dfsg-1 amd64 utility to list open files
ii man-db 2.8.5-2 amd64 on-line manual pager
ii mawk 1.3.3-17+b3 amd64 a pattern scanning and text processing language
ii mesa-va-drivers:amd64 18.3.6-2 amd64 Mesa VA-API video acceleration drivers
ii mesa-vdpau-drivers:amd64 18.3.6-2 amd64 Mesa VDPAU video acceleration drivers
ii modemmanager 1.10.0-1 amd64 D-Bus service for managing modems
ii mount 2.33.1-0.1 amd64 tools for mounting and manipulating filesystems
ii mousepad 0.4.1-2 amd64 simple Xfce oriented text editor
ii mscompress 0.4-3+b1 amd64 Microsoft "compress.exe/expand.exe" compatible (de)compressor
ii nano 3.2-3 amd64 small, friendly text editor inspired by Pico
ii ncurses-bin 6.1+20181013-2+deb10u1 amd64 terminal-related programs and man pages
ii netcat-traditional 1.10-41.1 amd64 TCP/IP swiss army knife
ii network-manager 1.14.6-2 amd64 network management framework (daemon and userspace tools)
ii network-manager-gnome 1.8.20-1.1 amd64 network management framework (GNOME frontend)
ii notification-daemon 3.20.0-4 amd64 daemon for displaying passive pop-up notifications
ii ntfs-3g 1:2017.3.23AR.3-3 amd64 read/write NTFS driver for FUSE
ii openjdk-11-jre:amd64 11.0.5+10-1~deb10u1 amd64 OpenJDK Java runtime, using Hotspot JIT
ii openjdk-11-jre-headless:amd64 11.0.5+10-1~deb10u1 amd64 OpenJDK Java runtime, using Hotspot JIT (headless)
ii openssh-client 1:7.9p1-10+deb10u1 amd64 secure shell (SSH) client, for secure access to remote machines
ii openssl 1.1.1d-0+deb10u2 amd64 Secure Sockets Layer toolkit - cryptographic utility
ii os-prober 1.77 amd64 utility to detect other OSes on a set of drives
ii p11-kit 0.23.15-2 amd64 p11-glue utilities
ii p11-kit-modules:amd64 0.23.15-2 amd64 p11-glue proxy and trust modules
ii p7zip 16.02+dfsg-6 amd64 7zr file archiver with high compression ratio
ii p7zip-full 16.02+dfsg-6 amd64 7z and 7za file archivers with high compression ratio
ii packagekit 1.1.12-5 amd64 Provides a package management service
ii packagekit-tools 1.1.12-5 amd64 Provides PackageKit command-line tools
ii parole 1.0.1-1 amd64 media player based on GStreamer framework
ii parted 3.2-25 amd64 disk partition manipulator
ii passwd 1:4.5-1.1 amd64 change and administer password and group data
ii pavucontrol 3.0-4 amd64 PulseAudio Volume Control
ii pciutils 1:3.5.2-1 amd64 Linux PCI Utilities
ii perl 5.28.1-6 amd64 Larry Wall's Practical Extraction and Report Language
ii perl-base 5.28.1-6 amd64 minimal Perl system
ii perl-openssl-defaults:amd64 3 amd64 version compatibility baseline for Perl OpenSSL packages
ii pinentry-curses 1.1.0-2 amd64 curses-based PIN or pass-phrase entry dialog for GnuPG
ii pinentry-gnome3 1.1.0-2 amd64 GNOME 3 PIN or pass-phrase entry dialog for GnuPG
ii plymouth 0.9.4-1.1 amd64 boot animation, logger and I/O multiplexer
ii plymouth-label 0.9.4-1.1 amd64 boot animation, logger and I/O multiplexer - label control
ii policykit-1 0.105-25 amd64 framework for managing administrative policies and privileges
ii policykit-1-gnome 0.105-7 amd64 authentication agent for PolicyKit
ii poppler-utils 0.71.0-5 amd64 PDF utilities (based on Poppler)
ii ppp 2.4.7-2+4.1 amd64 Point-to-Point Protocol (PPP) - daemon
ii printer-driver-brlaser 4-1 amd64 printer driver for (some) Brother laser printers
ii printer-driver-c2050 0.3b-8 amd64 printer driver for Lexmark 2050 Color Jetprinter
ii printer-driver-c2esp 27-4 amd64 printer driver for Kodak ESP AiO color inkjet Series
ii printer-driver-cjet 0.8.9-7 amd64 printer driver for Canon LBP laser printers
ii printer-driver-dymo 1.4.0-8 amd64 printer driver for DYMO label printers
ii printer-driver-escpr 1.6.33-1 amd64 printer driver for Epson Inkjet that use ESC/P-R
ii printer-driver-foo2zjs 20171202dfsg0-2 amd64 printer driver for ZjStream-based printers
ii printer-driver-fujixerox 1.1.0+ds-3 amd64 printer driver for Fuji Xerox printers
ii printer-driver-gutenprint 5.3.1-7 amd64 printer drivers for CUPS
ii printer-driver-hpcups 3.18.12+dfsg0-2 amd64 HP Linux Printing and Imaging - CUPS Raster driver (hpcups)
ii printer-driver-hpijs 3.18.12+dfsg0-2 amd64 HP Linux Printing and Imaging - printer driver (hpijs)
ii printer-driver-m2300w 0.51-13 amd64 printer driver for Minolta magicolor 2300W/2400W color laser printers
ii printer-driver-min12xxw 0.0.9-11 amd64 printer driver for KonicaMinolta PagePro 1[234]xxW
ii printer-driver-pnm2ppa 1.13-9 amd64 printer driver for HP-GDI printers
ii printer-driver-postscript-hp 3.18.12+dfsg0-2 amd64 HP Printers PostScript Descriptions
ii printer-driver-ptouch 1.4.2-3 amd64 printer driver Brother P-touch label printers
ii printer-driver-pxljr 1.4+repack0-5 amd64 printer driver for HP Color LaserJet 35xx/36xx
ii printer-driver-splix 2.0.0+svn315-7 amd64 Driver for Samsung and Xerox SPL2 and SPLc laser printers
ii procps 2:3.3.15-2 amd64 /proc file system utilities
ii pulseaudio 12.2-4+deb10u1 amd64 PulseAudio sound server
ii pulseaudio-utils 12.2-4+deb10u1 amd64 Command line tools for the PulseAudio sound server
ii python 2.7.16-1 amd64 interactive high-level object-oriented language (Python2 version)
ii python-minimal 2.7.16-1 amd64 minimal subset of the Python2 language
ii python-talloc:amd64 2.1.14-2 amd64 hierarchical pool based memory allocator - Python bindings
ii python2 2.7.16-1 amd64 interactive high-level object-oriented language (Python2 version)
ii python2-minimal 2.7.16-1 amd64 minimal subset of the Python2 language
ii python2.7 2.7.16-2 amd64 Interactive high-level object-oriented language (version 2.7)
ii python2.7-minimal 2.7.16-2 amd64 Minimal subset of the Python language (version 2.7)
ii python3 3.7.3-1 amd64 interactive high-level object-oriented language (default python3 version)
ii python3-apt 1.8.4 amd64 Python 3 interface to libapt-pkg
ii python3-brlapi:amd64 5.6-10 amd64 Braille display access via BRLTTY - Python3 bindings
ii python3-cairo:amd64 1.16.2-1+b1 amd64 Python3 bindings for the Cairo vector graphics library
ii python3-cups 1.9.73-2+b1 amd64 Python3 bindings for CUPS
ii python3-dbus 1.2.8-3 amd64 simple interprocess messaging system (Python 3 interface)
ii python3-gi 3.30.4-1 amd64 Python 3 bindings for gobject-introspection libraries
ii python3-gi-cairo 3.30.4-1 amd64 Python 3 Cairo bindings for the GObject library
ii python3-gst-1.0 1.14.4-1+b1 amd64 GStreamer GObject Introspection overrides for Python (Python 3)
ii python3-minimal 3.7.3-1 amd64 minimal subset of the Python language (default python3 version)
ii python3-pil:amd64 5.4.1-2 amd64 Python Imaging Library (Python3)
ii python3-pycurl 7.43.0.2-0.1 amd64 Python bindings to libcurl (Python 3)
ii python3-renderpm:amd64 3.5.13-1 amd64 python low level render interface
ii python3-reportlab-accel:amd64 3.5.13-1 amd64 C coded extension accelerator for the ReportLab Toolkit
ii python3-smbc 1.0.15.6-1+b2 amd64 Python 3 bindings for the Samba client library
ii python3-uno 1:6.1.5-3+deb10u4 amd64 Python-UNO bridge
ii python3.7 3.7.3-2 amd64 Interactive high-level object-oriented language (version 3.7)
ii python3.7-minimal 3.7.3-2 amd64 Minimal subset of the Python language (version 3.7)
ii ristretto 0.8.3-1 amd64 lightweight picture-viewer for the Xfce desktop environment
ii rsyslog 8.1901.0-1 amd64 reliable system and kernel logging daemon
ii rtkit 0.11-6 amd64 Realtime Policy and Watchdog Daemon
ii samba-libs:amd64 2:4.9.5+dfsg-5+deb10u1 amd64 Samba core libraries
ii sane-utils 1.0.27-3.2 amd64 API library for scanners -- utilities
ii sed 4.7-1 amd64 GNU stream editor for filtering/transforming text
ii shared-mime-info 1.10-1 amd64 FreeDesktop.org shared MIME database and spec
ii speech-dispatcher 0.9.0-5 amd64 Common interface to speech synthesizers
ii speech-dispatcher-audio-plugins:amd64 0.9.0-5 amd64 Speech Dispatcher: Audio output plugins
ii speech-dispatcher-espeak-ng 0.9.0-5 amd64 Speech Dispatcher: Espeak-ng output module
ii sudo 1.8.27-1+deb10u1 amd64 Provide limited super user privileges to specific users
ii synaptic 0.84.6 amd64 Graphical package manager
ii system-config-printer-udev 1.5.11-4 amd64 Utilities to detect and configure printers automatically
ii systemd 241-7~deb10u1 amd64 system and service manager
ii systemd-sysv 241-7~deb10u1 amd64 system and service manager - SysV links
ii sysvinit-utils 2.93-8 amd64 System-V-like utilities
ii tar 1.30+dfsg-6 amd64 GNU version of the tar archiving utility
ii tcl 8.6.9+1 amd64 Tool Command Language (default version) - shell
ii tcl-tls:amd64 1.7.16-1 amd64 TLS OpenSSL extension to Tcl
ii tcl8.6 8.6.9+dfsg-2 amd64 Tcl (the Tool Command Language) v8.6 - shell
ii telnet 0.17-41.2 amd64 basic telnet client
ii thunar 1.8.4-1 amd64 File Manager for Xfce
ii thunar-archive-plugin 0.4.0-2 amd64 Archive plugin for Thunar file manager
ii thunar-media-tags-plugin 0.3.0-2 amd64 Media tags plugin for Thunar file manager
ii thunar-volman 0.9.1-1 amd64 Thunar extension for volumes management
ii tix 8.4.3-10 amd64 library for Tk -- runtime package
ii tk 8.6.9+1 amd64 Toolkit for Tcl and X11 (default version) - windowing shell
ii tk-html3 3.0~fossil20110109-7 amd64 Render HTML and CSS content with Tk
ii tk8.6 8.6.9-2 amd64 Tk toolkit for Tcl and X11 v8.6 - windowing shell
ii traceroute 1:2.1.0-2 amd64 Traces the route taken by packets over an IPv4/IPv6 network
ii tumbler 0.2.3-1 amd64 D-Bus thumbnailing service
ii udev 241-7~deb10u1 amd64 /dev/ and hotplug management daemon
ii udisks2 2.8.1-4 amd64 D-Bus service to access and manipulate storage devices
ii uno-libs3 6.1.5-3+deb10u4 amd64 LibreOffice UNO runtime environment -- public shared libraries
ii unzip 6.0-23+deb10u1 amd64 De-archiver for .zip files
ii upower 0.99.10-1 amd64 abstraction for power management
ii ure 6.1.5-3+deb10u4 amd64 LibreOffice UNO runtime environment
ii usb-modeswitch 2.5.2+repack0-2 amd64 mode switching tool for controlling "flip flop" USB devices
ii usbmuxd 1.1.1~git20181007.f838cf6-1 amd64 USB multiplexor daemon for iPhone and iPod Touch devices
ii usbutils 1:010-3 amd64 Linux USB utilities
ii util-linux 2.33.1-0.1 amd64 miscellaneous system utilities
ii va-driver-all:amd64 2.4.0-1 amd64 Video Acceleration (VA) API -- driver metapackage
ii vdpau-driver-all:amd64 1.1.1-10 amd64 Video Decode and Presentation API for Unix (driver metapackage)
ii vim-tiny 2:8.1.0875-5 amd64 Vi IMproved - enhanced vi editor - compact version
ii wget 1.20.1-1.1 amd64 retrieves files from the web
ii whiptail 0.52.20-8 amd64 Displays user-friendly dialog boxes from shell scripts
ii wpasupplicant 2:2.7+git20190128+0c1e29f-6+deb10u1 amd64 client support for WPA and WPA2 (IEEE 802.11i)
ii x11-apps 7.7+7 amd64 X applications
ii x11-session-utils 7.7+3 amd64 X session utilities
ii x11-utils 7.7+4 amd64 X11 utilities
ii x11-xkb-utils 7.7+4 amd64 X11 XKB utilities
ii x11-xserver-utils 7.7+8 amd64 X server utilities
ii xarchiver 1:0.5.4.14-1 amd64 GTK+ frontend for most used compression formats
ii xauth 1:1.0.10-1 amd64 X authentication utility
ii xbrlapi 5.6-10 amd64 Access software for a blind person using a braille display - xbrlapi
ii xdg-user-dirs 0.17-2 amd64 tool to manage well known user directories
ii xfburn 0.5.5-2 amd64 CD-burner application for Xfce Desktop Environment
ii xfce4-appfinder 4.12.0-2 amd64 Application finder for the Xfce4 Desktop Environment
ii xfce4-battery-plugin 1.1.2-1 amd64 battery monitor plugin for the Xfce4 panel
ii xfce4-clipman 2:1.4.3-1 amd64 clipboard history utility
ii xfce4-clipman-plugin 2:1.4.3-1 amd64 clipboard history plugin for Xfce panel
ii xfce4-cpufreq-plugin 1.2.1-1 amd64 cpufreq information plugin for the Xfce4 panel
ii xfce4-cpugraph-plugin 1.0.5-2 amd64 CPU load graph plugin for the Xfce4 panel
ii xfce4-datetime-plugin 0.7.0-2 amd64 date and time plugin for the Xfce4 panel
ii xfce4-dict 0.8.2-1 amd64 Dictionary plugin for Xfce4 panel
ii xfce4-diskperf-plugin 2.6.1-2 amd64 disk performance display plugin for the Xfce4 panel
ii xfce4-fsguard-plugin 1.1.0-2 amd64 filesystem monitor plugin for the Xfce4 panel
ii xfce4-genmon-plugin 4.0.1-2 amd64 Generic Monitor for the Xfce4 panel
ii xfce4-goodies 4.12.6 amd64 enhancements for the Xfce4 Desktop Environment
ii xfce4-mailwatch-plugin 1.2.0-3 amd64 mail watcher plugin for the Xfce4 panel
ii xfce4-netload-plugin 1.3.1-2 amd64 network load monitor plugin for the Xfce4 panel
ii xfce4-notes 1.8.1-2 amd64 Notes application for the Xfce4 desktop
ii xfce4-notes-plugin 1.8.1-2 amd64 Notes plugin for the Xfce4 desktop
ii xfce4-notifyd 0.4.3-1 amd64 simple, visually-appealing notification daemon for Xfce
ii xfce4-panel 4.12.2-1 amd64 panel for Xfce4 desktop environment
ii xfce4-places-plugin 1.7.0-4 amd64 quick access to folders, documents and removable media
ii xfce4-power-manager 1.6.1-1 amd64 power manager for Xfce desktop
ii xfce4-power-manager-plugins 1.6.1-1 amd64 power manager plugins for Xfce panel
ii xfce4-pulseaudio-plugin:amd64 0.4.1-1 amd64 Xfce4 panel plugin to control pulseaudio
ii xfce4-screenshooter 1.9.3-1 amd64 screenshots utility for Xfce
ii xfce4-sensors-plugin 1.3.0-2+b1 amd64 hardware sensors plugin for the Xfce4 panel
ii xfce4-session 4.12.1-6 amd64 Xfce4 Session Manager
ii xfce4-settings 4.12.4-1 amd64 graphical application for managing Xfce settings
ii xfce4-smartbookmark-plugin 0.5.0-1 amd64 search the web via the Xfce4 panel
ii xfce4-systemload-plugin 1.2.2-1 amd64 system load monitor plugin for the Xfce4 panel
ii xfce4-taskmanager 1.2.2-1 amd64 process manager for the Xfce4 Desktop Environment
ii xfce4-terminal 0.8.7.4-2 amd64 Xfce terminal emulator
ii xfce4-timer-plugin 1.7.0-1 amd64 timer plugin for Xfce panel
ii xfce4-verve-plugin 2.0.0-1 amd64 Verve (command line) plugin for Xfce panel
ii xfce4-wavelan-plugin 0.6.0-2 amd64 wavelan status plugin for the Xfce4 panel
ii xfce4-weather-plugin 0.8.10-1 amd64 weather information plugin for the Xfce4 panel
ii xfce4-whiskermenu-plugin 2.3.1-1 amd64 Alternate menu plugin for the Xfce desktop environment
ii xfce4-xkb-plugin 1:0.8.1-2 amd64 xkb layout switch plugin for the Xfce4 panel
ii xfconf 4.12.1-1 amd64 utilities for managing settings in Xfce
ii xfdesktop4 4.12.4-2 amd64 xfce desktop background, icons and root menu manager
ii xfonts-utils 1:7.7+6 amd64 X Window System font utility programs
ii xfwm4 4.12.5-1 amd64 window manager of the Xfce project
ii xinit 1.4.0-1 amd64 X server initialisation tool
ii xorg 1:7.7+19 amd64 X.Org X Window System
ii xsane 0.999-6+b1 amd64 featureful graphical frontend for SANE (Scanner Access Now Easy)
ii xserver-xorg 1:7.7+19 amd64 X.Org X server
ii xserver-xorg-core 2:1.20.4-1 amd64 Xorg X server - core server
ii xserver-xorg-input-all 1:7.7+19 amd64 X.Org X server -- input driver metapackage
ii xserver-xorg-input-libinput 0.28.2-2 amd64 X.Org X server -- libinput input driver
ii xserver-xorg-input-wacom 0.34.99.1-1 amd64 X.Org X server -- Wacom input driver
ii xserver-xorg-legacy 2:1.20.4-1 amd64 setuid root Xorg server wrapper
ii xserver-xorg-video-all 1:7.7+19 amd64 X.Org X server -- output driver metapackage
ii xserver-xorg-video-amdgpu 18.1.99+git20190207-1 amd64 X.Org X server -- AMDGPU display driver
ii xserver-xorg-video-ati 1:19.0.1-1 amd64 X.Org X server -- AMD/ATI display driver wrapper
ii xserver-xorg-video-fbdev 1:0.5.0-1 amd64 X.Org X server -- fbdev display driver
ii xserver-xorg-video-intel 2:2.99.917+git20180925-2 amd64 X.Org X server -- Intel i8xx, i9xx display driver
ii xserver-xorg-video-nouveau 1:1.0.16-1 amd64 X.Org X server -- Nouveau display driver
ii xserver-xorg-video-qxl 0.1.5-2+b1 amd64 X.Org X server -- QXL display driver
ii xserver-xorg-video-radeon 1:19.0.1-1 amd64 X.Org X server -- AMD/ATI Radeon display driver
ii xserver-xorg-video-vesa 1:2.4.0-1 amd64 X.Org X server -- VESA display driver
ii xserver-xorg-video-vmware 1:13.3.0-2 amd64 X.Org X server -- VMware display driver
ii xterm 344-1 amd64 X terminal emulator
ii xxd 2:8.1.0875-5 amd64 tool to make (or reverse) a hex dump
ii xz-utils 5.2.4-1 amd64 XZ-format compression utilities
ii zenity 3.30.0-2 amd64 Display graphical dialog boxes from shell scripts
ii zlib1g:amd64 1:1.2.11.dfsg-1 amd64 compression library - runtime
Dis autrement, vérifie si le paquet firmware-amd-graphics est installé ou pas? Je ne suis pas sûr de bien voir.
Sinon, installe le.
root@Utilisateur-Debian:/home/utilisateur# apt install firmware-amd-graphics
0 mis à jour, 1 nouvellement installés, 0 à enlever et 9 non mis à jour.
Il est nécessaire de prendre 3.593 ko dans les archives.
Après cette opération, 32,8 Mo d'espace disque supplémentaires seront utilisés.
Réception de :1 http://deb.debian.org/debian buster-backports/non-free amd64 firmware-amd-graphics all 20190717-2~bpo10+1 [3.593 kB]
3.593 ko réceptionnés en 1s (6.727 ko/s)
Sélection du paquet firmware-amd-graphics précédemment désélectionné.
(Lecture de la base de données... 105164 fichiers et répertoires déjà installés.)
Préparation du dépaquetage de .../firmware-amd-graphics_20190717-2~bpo10+1_all.deb ...
Dépaquetage de firmware-amd-graphics (20190717-2~bpo10+1) ...
Paramétrage de firmware-amd-graphics (20190717-2~bpo10+1) ...
Traitement des actions différées (« triggers ») pour initramfs-tools (0.133+deb10u1) ...
update-initramfs: Generating /boot/initrd.img-4.19.0-6-amd64
voila qui est installé. Que faire mnt ?
Si tu rebootes ton PC, il se passe quoi exactement ?
Je redémarre mnt ?
En fait, quand je démarre le pc, j’arrive sur le grub et quand je laisse sur le premier choix, l’écran devient noir et plus rien. Par contre quand je fais nomodeset, ça fonctionne et j’arrive sur la page pour le login
Je ne te demande pas ce que ça faisait “avant”, mais après avoir rebooté maintenant.
ha ok, ben je vais essayer lol
Ecran noir, même chose qu’avant.
root@Utilisateur-Debian:/home/utilisateur# dpkg -l | grep firmware-amd
ii firmware-amd-graphics 20190717-2~bpo10+1 all Binary firmware for AMD/ATI graphics chips
Mais ton écran “est noir”, juste au niveau du Grub ? Ou après ?
Comment fais-tu pour avoir accès à ton écran et taper les commandes ?
Et ça dit quoi ?
find /etc/apt -name '*.list' -print -exec grep "^d" {} \;
Non, j’arrive sur le grub et quand je choisi le premier linux debian, l’écran devient et reste noir donc je dois vite faire e puis entrer nomodeset et la, j’arrive sur le login.
/etc/apt/sources.list.d/buster-backports.list
deb http://deb.debian.org/debian buster-backports main contrib non-free
deb-src http:deb.debian.org/debian buster-backports main contrib non-free
deb http://deb.debian.org/debian/ buster main
deb-src http://deb.debian.org/debian/ buster main
deb http://security.debian.org/debian-security buster/updates main
deb-src http://security.debian.org/debian-security buster/updates main
deb http://deb.debian.org/debian/ buster-updates main
deb-src http://deb.debian.org/debian/ buster-updates main
root@Utilisateur-Debian:/home/utilisateur# ```
Pas normal, d’autant que le lspci te dit que c’est géré par le module radeon.
Fais sous root un modprobe radeon et relance le serveur X
