Probleme installation webcam usb Logitech ClikSmart 310
Afin de continuer mon apprentissage sur Debian(qui me passionne), j’essaye d’installer sans succés une webcam usb Logitech ClickSmart 310.
J’ai suivi: wiki.debian.org/fr/Webcam/spca5xx
installé les paquets camorama, linux-source, linux-headers et (comme je ne trouve pas le paquet spca5xx-source) installé le paquet libgphoto2–dev2 qui contient un module gspca.
Pouvez-vous m’aider?
Ordinateur portable: TARGA Traveller 820 2600+
# dpkg -l |grep linux-image
ii linux-image-3.2.0-4-686-pae 3.2.65-1+deb7u2 i386 Linux 3.2 for modern PCs
ii linux-image-686-pae 3.2+46 i386 Linux for modern PCs (meta-package)
        # lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 046d:0900 Logitech, Inc. ClickSmart 310
        # lsmod
Module Size Used by
gspca_spca500 13014 0
gspca_main 22300 1 gspca_spca500
videodev 61658 1 gspca_main
media 13692 1 videodev
parport_pc 22036 0
ppdev 12651 0
lp 12797 0
parport 31254 3 lp,ppdev,parport_pc
bnep 17288 2
rfcomm 28626 0
bluetooth 103791 10 rfcomm,bnep
rfkill 18516 3 bluetooth
crc16 12327 1 bluetooth
binfmt_misc 12813 1
uinput 12991 1
nfsd 173901 2
nfs 265953 0
nfs_acl 12463 2 nfs,nfsd
auth_rpcgss 32143 2 nfs,nfsd
fscache 31978 1 nfs
lockd 61373 2 nfs,nfsd
sunrpc 148000 6 lockd,auth_rpcgss,nfs_acl,nfs,nfsd
loop 17810 0
ohci_hcd 22059 0
joydev 17010 0
snd_intel8x0m 17503 0
snd_intel8x0 22372 1
snd_ac97_codec 84236 2 snd_intel8x0,snd_intel8x0m
ehci_hcd 39631 0
snd_pcm 53461 3 snd_ac97_codec,snd_intel8x0,snd_intel8x0m
snd_page_alloc 12867 3 snd_pcm,snd_intel8x0,snd_intel8x0m
snd_seq 39512 0
usbcore 104555 5 ehci_hcd,ohci_hcd,gspca_main,gspca_spca500
snd_seq_device 13016 1 snd_seq
snd_timer 22356 2 snd_seq,snd_pcm
snd 42761 9 snd_timer,snd_seq_device,snd_seq,snd_pcm,snd_ac97_codec,snd_intel8x0,snd_intel8x0m
sg 21476 0
sr_mod 17468 0
soundcore 12921 1 snd
cdrom 34813 1 sr_mod
ac97_bus 12462 1 snd_ac97_codec
usb_common 12338 1 usbcore
pcmcia 32047 0
firewire_ohci 26784 0
firewire_core 38753 1 firewire_ohci
i2c_sis96x 12485 0
sis900 21945 0
crc_itu_t 12331 1 firewire_core
psmouse 59609 0
i2c_core 19116 2 i2c_sis96x,videodev
k8temp 12575 0
button 12817 0
shpchp 26717 0
ac 12552 0
powernow_k8 17379 0
mperf 12421 1 powernow_k8
yenta_socket 22402 0
mii 12595 1 sis900
serio_raw 12803 0
evdev 17225 13
battery 12986 0
power_supply 13283 2 battery,ac
processor 27565 2 powernow_k8
pcmcia_rsrc 17380 1 yenta_socket
pcmcia_core 17942 3 pcmcia_rsrc,yenta_socket,pcmcia
pcspkr 12515 0
ext3 134152 1
mbcache 12938 1 ext3
jbd 47281 1 ext3
sd_mod 35425 3
crc_t10dif 12332 1 sd_mod
ata_generic 12439 0
pata_sis 13123 2
libata 125014 2 pata_sis,ata_generic
thermal 13103 0
thermal_sys 17752 2 thermal,processor
scsi_mod 135081 4 libata,sd_mod,sr_mod,sg
Lors de l’ouverture de Camorama j’ai le message suivant:
Error (camorama)
Could not connect to video device (/dev/videoO)
Please check connection.
J’ai désinstallé et réinstallé camorama sans succés.
Je n’ai pas le dossier /dev/videoO
Merci d’avance
bonsoir.
Installez déjà le kernel des backports,il y a neuf chances sur dix pour que votre cam fonctionne à la volée.En principe toutes les logitech fonctionnent nativement dans linux.Avez vous testé la webcam avec vlc?
Merci avram
J’ai ajouté cette ligne à mon /etc/apt/sources.list:
deb ftp.debian.org/debian wheezy-backports main contrib non-free
effectué: # aptitude install -t wheezy-backports
mais je n’ai pas installé les paquets qui m’étaient proposés comme ndiswrapper que je neveux pas utiliser.
Tout cela sans succés ma webcam ne fonctionne pas ni avec VLC
bonjour.
pour ajouter wheezy-backports au sources-list ajoutez la ligne
deb http.debian.net/debian wheezy-backports main contrib non-free
suivi de:
#apt-get update
et enfin installez le kernel des backports:
apt-get install -t wheezy-backports linux-image-3.16.0-0.bpo.4-686-pae
suivi de:
#update-grub
redémarrez la machine et le menu grub vous proposera de le kernel 3.2 ou le kernel 3.16,choisissez le 3.16 et voyez pour la webcam.
Mais avant toute manip modifiant votre système prenez l’habitude de faire une sauvegarde de votre wheezy,en utilisant clonezilla par exemple.
concernant les backports:
backports.debian.org/Instructions/
pour lister les paquets disponibles en backports:
packages.debian.org/wheezy-backports/
pour utiliser clonezilla en bootant directement sur son image iso (donc ne nécessite la gravure d’un cd) en passant par le menu de grub:
clonezilla-sur-grub2-t50908.html
Merci avram pour toutes ces instructions qui vont me permettre de “travailler” Debian, notamment la sauvegarde !!!
A bientôt pour le résultat?
Vérifies que l’installation de [mono]camorama[/mono], à bien engendrer celles de ces dépendances également.
[code][12:36:40]:~$ aptitude show camorama
Paquet : camorama
Nouveau: oui
État: non installé
Version : 0.19-2.2
Priorité : optionnel
Section : gnome
Responsable : Leo Costela costela@debian.org
Architecture : i386
Taille décompressée : 1 536 k
Dépend: libart-2.0-2 (>= 2.3.18), libatk1.0-0 (>= 1.12.4), libbonobo2-0 (>= 2.15.0), libbonoboui2-0 (>= 2.15.1), libc6 (>= 2.3.6-6~), libcairo2 (>= 1.2.4), libfontconfig1 (>=
2.8.0), libfreetype6 (>= 2.2.1), libgconf2-4 (>= 2.31.1), libgdk-pixbuf2.0-0 (>= 2.22.0), libglade2-0 (>= 1:2.6.1), libglib2.0-0 (>= 2.14.0), libgnome2-0 (>= 2.17.3),
libgnomecanvas2-0 (>= 2.11.1), libgnomeui-0 (>= 2.22.0), libgnomevfs2-0 (>= 1:2.17.90), libgtk2.0-0 (>= 2.10.0), libice6 (>= 1:1.0.0), liborbit2 (>= 1:2.14.10),
libpango1.0-0 (>= 1.14.0), libpopt0 (>= 1.16), libsm6, libv4l-0 (>= 0.5.0), libxml2 (>= 2.6.27), gconf2 (>= 2.28.1-2)
Description : gnome utility to view and save images from a webcam
Camorama is a small utility to view and save images from a webcam or any other Video4Linux device. It can apply a number of image filters and make remote captures.
Site : http://camorama.fixedgear.org
Par le biais d’[mono]$ apt-cache policy <la_liste>[/mono]
@BelZéButh: mais en principe les dépendances sont installées automatiquement par le gestionnaire de paquets.
En principe, oui.
Merci BelZébuth :
Paquet : camorama
État: installé
Automatiquement installé: non
Version : 0.19-2.2
Section : gnome
Architecture : i386
1.2.4), libfontconfig1 (>= 2.8.0), libfreetype6 (>= 2.2.1), libgconf2-4
libglib2.0-0 (>= 2.14.0), libgnome2-0 (>= 2.17.3), libgnomecanvas2-0
1:2.14.10), libpango1.0-0 (>= 1.14.0), libpopt0 (>= 1.16), libsm6,
captures.
Site : camorama.fixedgear.org
             ~$ apt-cache policy camorama
camorama:
Installé : 0.19-2.2
Candidat : 0.19-2.2
Table de version :
*** 0.19-2.2 0
500 ftp.fr.debian.org/debian/ wheezy/main i386 Packages
100 /var/lib/dpkg/status
Je ne me sens pas capable d’effectuer la sauvegarde préconisée par avram je n’ai que 11GO alloué a Debian
Une chose, le site du développeur n’est plus maintenu. http://camorama.fixedgear.org/
Pour un novice (?), la tâche sera plus ou moins ardue.
Source : Webcam : GSPCA et SPCA5XX
[quote=“Ubuntu”]3.5 Installer les pilotes
Avant de commencer à installer les pilotes débranchez votre webcam du port USB.
Suivant la webcam ces procédures ne sont plus nécessaires le module est maintenant intégré dans les modules du noyau d’Ubuntu de Dapper allez directement à chargement du module.
Recupérez les pilotes USB pour la carte :
Vous devez pour cela télécharger dans votre répertoire personnel l'archive disponible ici [mxhaard.free.fr/download.html](http://mxhaard.free.fr/download.html) :
    Pour noyau inférieur à 2.6.11 spca5xx-20060402.tar.gz (où 20060402 est la version du 2 avril 2006 ou la version 20051212)
    Pour noyau supérieur à 2.6.11 gspcav1-20071214.tar.gz
  • Puis l’extraire grâce à la commande : [/quote]
    Il semblerait bien que cela soit dû au pilote/module/noyau.
[quote=“papilu65”]Could not connect to video device (/dev/videoO)
Please check connection.[/quote]
Concernant les sauvegardes, tu peux faire cela sur un deuxième disque, qu’il soit interne ou externe. Peut-être, investir dans disque (USB) externe (1 T0), les prix sont abordables.
Tu peux aller fouiner de ce côté
ps: vu le look du monsieur je pense que tu peux lui faire confiance
Je n’arrive pas a installer le fichier gspcav1-20071224.tar
Aprés téléchargement dans mon dossier Bureau je l’ai décompressé.
Je veux appliquer le procédé suivant:
$ cd ~/le_répertoire_ou_sont_tes_sources
$ ./configure
make
make install
Voici les réponses de mon système:
~$ cd ~/Bureau
~/Bureau$ ./configure gspcav1-20071224.tar
bash: ./configure: Aucun fichier ou dossier de ce type
Merci pour vôtre aide
[quote=“papilu65”]Bonjour,
$ ./configure
make
make install
~$ cd ~/Bureau
Merci pour vôtre aide[/quote]
Ce fichier a l’air de de dater de 2007, je sais pas si c’est raisonnable d’installer ça.
Avez vosu suivi les instructions de avram pour installer un kernel plus récent ? probleme-installation-webcam-usb-logitech-cliksmart-310-t51529.html#p511560
[quote=“papilu65”]
J’ai installé le kernel des backports, comme conseillé par avram, et aprés démarrage sur le kernel 3.16 je ne peux toujours pas détecter la webcam en vidéo (elle est toujours détectée en appareil photo),elle ne fonctionne pas avec VLC, camorama indique toujours “Error (camorama),Could not connect to video device (/dev/videoO)”,j’ai essayé avec “studio webcam cheeze” toujours sans résultat, et n’ai toujours pas pu installer le fichier gspca.
j’abandonne cette installation que j’aurai du faire en 2006, mais je ne connaissais pas Debian…
Pouvez-vous m’indiquer comment je dois faire pour supprimer le Kernel 3.16, je resterai sur le 3.2 ?
Merci a vous tous pour vôtre disponibilité.
lancez la commande,en user
groups
pour vérifier votre appartenance au groupe video
~$ groups
lucien cdrom floppy audio dip video plugdev scanner bluetooth netdev
Merci avram
je viens de brancher une vieille webcam genius eye 110(2006) et elle ne fonctionne pas non plus,il semblerai que les cams trop vieilles ne soient plus supportées ou alors je ne sais pas.De Quelle année est votre cam?
Ma cam est de Janvier 2003,mais ce n’est pas un problème puisqu’elle fonctionne trés bien sous XP;
cela m’as permis de travailler en ligne de commande.
merci avram,mais dites moi comment supprimer le Kernel, je n’ai que 11GO consacré a Debian.
votr cam fonctionne sous xp parce que vous aviez installé le pilote pour cette cam,idem pour cam eye 110,elle fonctionne encore sous xp mais plus dans jessie.
Si vous voulez désinstaller le noyau 3.16 faites en root:
apt-get remove linux-image-3.16.0-0.bpo.4-686-pae
suivi bien sûr de
update-grub
et
dans votre sources.list supprimez(ou diésez) la ligne des dépôts wheezy-backports
