Probleme lors du boot
Je viens tout juste de réussir a installer debian wheezy avec la wifi qui fonctionne (ce fut dur ^^)
maintenant j’ai un problème lors du démarrage, après grub 5 ligne s’affiche et la dernière c’est /dev… fully populated.
J’ai regarder sur d’autre forum, j’ai fais la commande dmesg et j’obtient (en join le fichier complet) :
10.302833] lp: driver loaded but no devices found [ 10.306504] ppdev: user-space parallel port driver [ 10.418014] iwlwifi 0000:02:00.0: L1 Disabled; Enabling L0S [ 10.424716] iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0 [ 10.718155] iwlwifi 0000:02:00.0: L1 Disabled; Enabling L0S [ 10.724878] iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0 [ 10.835035] ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 11.027342] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input11 [ 11.322480] EXT4-fs (sda3): re-mounted. Opts: errors=remount-ro,user_xattr,barrier=1,data=ordered,commit=600 [ 11.334124] EXT4-fs (sda4): re-mounted. Opts: user_xattr,barrier=1,data=ordered,commit=600 [ 17.486205] wlan0: authenticate with f4:ca:e5:97:0c:d8 (try 1) [ 17.488840] wlan0: authenticated [ 17.495121] wlan0: associate with f4:ca:e5:97:0c:d8 (try 1) [ 17.500017] wlan0: RX AssocResp from f4:ca:e5:97:0c:d8 (capab=0x411 status=0 aid=3) [ 17.500021] wlan0: associated [ 17.525512] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 55.595378] wlan0: deauthenticating from f4:ca:e5:97:0c:d8 by local choice (reason=3) [ 55.715713] cfg80211: Calling CRDA to update world regulatory domain [ 55.727323] cfg80211: World regulatory domain updated: [ 55.727333] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 55.727344] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 55.727354] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) [ 55.727362] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) [ 55.727370] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 55.727377] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 56.725153] PM: Syncing filesystems ... done. [ 56.725437] PM: Preparing system for mem sleep [ 56.936996] Freezing user space processes ... (elapsed 0.01 seconds) done. [ 56.952830] Freezing remaining freezable tasks ... (elapsed 0.01 seconds) done. [ 56.968815] PM: Entering mem sleep [ 56.969173] Suspending console(s) (use no_console_suspend to debug) [ 56.984826] xhci_hcd 0000:00:14.0: setting latency timer to 64 [ 57.000811] ehci_hcd 0000:00:1d.0: setting latency timer to 64 [ 57.001034] sd 1:0:0:0: [sdb] Synchronizing SCSI cache [ 57.001094] sd 0:0:0:0: [sda] Synchronizing SCSI cache [ 57.001126] sd 1:0:0:0: [sdb] Stopping disk [ 57.001260] sd 0:0:0:0: [sda] Stopping disk [ 57.108651] PM: suspend of devices complete after 107.879 msecs [ 57.124732] ehci_hcd 0000:00:1d.0: wake-up capability enabled by ACPI [ 57.140626] ehci_hcd 0000:00:1a.0: wake-up capability enabled by ACPI [ 57.156623] xhci_hcd 0000:00:14.0: wake-up capability enabled by ACPI [ 57.172572] PM: late suspend of devices complete after 63.990 msecs [ 57.172779] ACPI: Preparing to enter system sleep state S3 [ 57.344626] PM: Saving platform NVS memory [ 57.402410] Disabling non-boot CPUs ... [ 57.504128] CPU 1 is now offline [ 57.608010] CPU 2 is now offline [ 57.711885] CPU 3 is now offline [ 57.712238] Extended CMOS year: 2000 [ 57.712542] ACPI: Low-level resume complete [ 57.712603] PM: Restoring platform NVS memory [ 57.714749] Extended CMOS year: 2000 [ 57.714797] Enabling non-boot CPUs ... [ 57.715007] Booting Node 0 Processor 1 APIC 0x2 [ 57.715009] smpboot cpu 1: start_ip = 98000 [ 57.725936] Calibrating delay loop (skipped) already calibrated this CPU [ 57.747272] CPU1 is up [ 57.747472] Booting Node 0 Processor 2 APIC 0x1 [ 57.747475] smpboot cpu 2: start_ip = 98000 [ 57.758396] Calibrating delay loop (skipped) already calibrated this CPU [ 57.779869] CPU2 is up [ 57.780149] Booting Node 0 Processor 3 APIC 0x3 [ 57.780151] smpboot cpu 3: start_ip = 98000 [ 57.791153] Calibrating delay loop (skipped) already calibrated this CPU [ 57.812637] CPU3 is up [ 57.820047] ACPI: Waking up from system sleep state S3 [ 57.930615] xhci_hcd 0000:00:14.0: wake-up capability disabled by ACPI [ 57.930705] ehci_hcd 0000:00:1a.0: wake-up capability disabled by ACPI [ 57.930953] ehci_hcd 0000:00:1d.0: wake-up capability disabled by ACPI [ 57.931379] PM: early resume of devices complete after 0.894 msecs [ 57.931466] i915 0000:00:02.0: setting latency timer to 64 [ 57.931482] xhci_hcd 0000:00:14.0: setting latency timer to 64 [ 57.931541] ehci_hcd 0000:00:1a.0: setting latency timer to 64 [ 57.931593] snd_hda_intel 0000:00:1b.0: setting latency timer to 64 [ 57.931620] ehci_hcd 0000:00:1d.0: setting latency timer to 64 [ 57.931671] snd_hda_intel 0000:00:1b.0: irq 46 for MSI/MSI-X [ 57.931689] ahci 0000:00:1f.2: setting latency timer to 64 [ 57.931954] sd 0:0:0:0: [sda] Starting disk [ 57.932000] sd 1:0:0:0: [sdb] Starting disk [ 58.044189] Extended CMOS year: 2000 [ 58.181968] usb 4-1.5: reset high-speed USB device number 3 using ehci_hcd [ 58.249763] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
En fait apres le fully populated, l’écran devient noir mais toujours rétro éclairé. J’appuie sur le bouton marche/arret, il se met en veille, 5sec après j’appuie sur entré, il démarre sur la page de login.
Lorsque je met mon mot de passe, l’écran s’éteint et je doit refaire pareil, je retombe ensuite sur l’écran de débrouillage du pc ou j’ai que le mot de passe a mettre et hop je suis logué ouf.
C’est peut être un problème de carte graphique mais j’en ai pas, c’est un i5 ivy bridge avec une 4000HD.
boot.txt (75.9 KB)
Peux-tu aussi donner le retour de la commande lspci
Il se peut que le problème vienne de la carte graphique…
voila
00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09) 00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09) 00:04.0 Signal processing controller: Intel Corporation Device 0153 (rev 09) 00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04) 00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04) 00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04) 00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04) 00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4) 00:1c.1 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2 (rev c4) 00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04) 00:1f.0 ISA bridge: Intel Corporation HM76 Express Chipset LPC Controller (rev 04) 00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04) 00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04) 00:1f.6 Signal processing controller: Intel Corporation 7 Series/C210 Series Chipset Family Thermal Management Controller (rev 04) 02:00.0 Network controller: Intel Corporation Centrino Advanced-N 6235 (rev 24)
J’ai du nouveau, lorsque je branche le pc en hdmi, tout s’affiche sur la tv mais rien sur le pc, Et lorsque j’enlève le clonage sur les 2 écrans, que je les met en affichage étendu, la tv fonctionne toujours mais le pc n’affiche rien.
J’ai encore du nouveau, j’ai réinstaller debian squeeze et ca marche niquel pour l’affichage mais pas pour la wifi. J’ai fait la mise a jour du kernel vers un 3.2 et hop l’affichage bug comme sur wheezy.
Désolé, je ne peux pas t’en dire plus, c’est intel et je n’ai jamais eu de problème de la sorte. Quelqu’un d’autre peut-être? (pas besoin de MP giann, les personnes répondent si elles le peuvent)
D’accord, excuser moi alors je ne le referais plus :smiley:
J’espere que je vais pourvoir regler ce probleme, c’est bisar que c’est lorsque j’ai mis le kernel 3.2 que ca a bugué.
Je peux compiler un kernel 3.2 en mettant les modules gpu du 2.6 ou un truc comme ca ? Pour benificier du clavier, bluetooth, wifi mais aussi d’un écran que s’allume ?
tu ne dis pas: tu laisses du temps au PC avant d’appuyer sur la touche de marche/arrêt … ?
Plate-forme Ivy bridge, sur un autre sujet, quelqu’un disait qu’il fallait un noyau >= 3.4.x pour que ça fonctionne correctement (de mémoire).
Sur mon core i5 c’est effectivement le cas, le noyau 3.2 de Wheezy/Sid gèle de manière aléatoire assez rapidement, y compris pendant le boot.
Idem pour le processeur graphique uniquement supporté dans les noyaux >= 3.4, mais là je ne suis plus sûr, il faudrait vérifier sur le site d’Intel.
Personnellement j’utilise donc le noyau 3.6 d’expérimental, mais le 3.7 d’aptosid fonctionne également.
Usti
[quote=“An0nym”]Salut,
tu ne dis pas: tu laisses du temps au PC avant d’appuyer sur la touche de marche/arrêt … ?[/quote]
Salut, en gros le pc demarre normalement sauf que l’écran est eteint, j’imagine qu’en 20sec c’est assez pour qu’il soit a la page de login, a ce moment la j’appuis sur on/off pour qu’il ce mette en veille et quand je le sort de veille je vois l’ecran de login. Et j’ai essailler d’attendre 10min lorsqu’il devient noir mais rien ne ce passe.
Ustilago, je vais essayer le kernel que tu me dit, le 3.7 est assez stable ou non ? Ou faut preferer le 3.6 ?
Poste-nous le résultat de la commande “lspci -n”
le -n est important… je te l’avais déjà demandé sur l’autre fil… :unamused: :whistle: :unamused:
:006
J’ai compilé et installé le 3.6, y a du mieux mais je suis toujours obliger de mettre en veille apres le fully populated et l’ecran de login, mais le login fonctionne du premier coup et la sortie de veille aussi.
Dsl je pensais que tu voulais le normal
00:00.0 0600: 8086:0154 (rev 09) 00:02.0 0300: 8086:0166 (rev 09) 00:04.0 1180: 8086:0153 (rev 09) 00:14.0 0c03: 8086:1e31 (rev 04) 00:16.0 0780: 8086:1e3a (rev 04) 00:1a.0 0c03: 8086:1e2d (rev 04) 00:1b.0 0403: 8086:1e20 (rev 04) 00:1c.0 0604: 8086:1e10 (rev c4) 00:1c.1 0604: 8086:1e12 (rev c4) 00:1d.0 0c03: 8086:1e26 (rev 04) 00:1f.0 0601: 8086:1e59 (rev 04) 00:1f.2 0106: 8086:1e03 (rev 04) 00:1f.3 0c05: 8086:1e22 (rev 04) 00:1f.6 1180: 8086:1e24 (rev 04) 02:00.0 0280: 8086:088e (rev 24)
Voila, j’avais installer i915, je doit le refaire ?
Au vu des résultats, il te “suffirait” d’un noyau 3.0 et du module i915 pour que ta carte fonctionne (si j’en crois le site kmuto.jp/debian/hcl/) du coup, cherches peut-être si il y a pas des “bug” connus pour ta carte… sinon, là tout de suite… pas d’autre idée… désolé…
:006
Probablement le firmware qui n’est pas installé…
[quote=“Num’s”]Au vu des résultats, il te “suffirait” d’un noyau 3.0 et du module i915 pour que ta carte fonctionne (si j’en crois le site kmuto.jp/debian/hcl/) du coup, cherches peut-être si il y a pas des “bug” connus pour ta carte… sinon, là tout de suite… pas d’autre idée… désolé…
:006[/quote]
Justement en 3.2 ca buguai mais moins en 3.6 donc ca va.
Probablement le firmware qui n’est pas installé…[/quote]
Lequel ? apt-cache search i915 me retourn xserver-xorg-video-intel que j’ai installer donc je sais pas
Ca c’est un pilote, ça n’a rien à voir.
Je ne sais pas, cherche dans ton gestionnaire de paquets avec le terme “firmware”.
D’accord je savais pas, j’ai donc fais ça
[code]apt-cache search firmware
alsa-firmware-loaders - ALSA software loaders for specific hardware
b43-fwcutter - Utility for extracting Broadcom 43xx firmware
firmware-b43-installer - Installer package for firmware for the b43 driver
firmware-b43-lpphy-installer - Installer package for firmware for the b43 driver (LP-PHY version)
firmware-b43legacy-installer - Installer package for firmware for the b43legacy driver
gobi-loader - Firmware loader for Qualcomm Gobi USB chipsets.
isdnactivecards - ISDN utilities - active ISDN card support
isight-firmware-tools - tools for dealing with Apple iSight firmware
linux-wlan-ng-firmware - firmware files used by the linux-wlan-ng driver
prism2-usb-firmware-installer - firmware files for the prism2_usb kernel driver
iasl - Intel ASL compiler/decompiler
brickos - alternative OS for LEGO® Mindstorms RCX. Supports devel. in C/C++
cc1111 - C Compiler for TI/Chipcon 8051-based RF SOCs
colorhug-client - Tools for the Hughski Colorimeter
gir1.2-colorhug-1.0 - GObject introspection data for the Hughski Colorimeter
libcolorhug-dev - Devel files for the Hughski Colorimeter
libcolorhug1 - Library for the Hughski Colorimeter
cycfx2prog - Cypress EZ-USB FX2 (LP) programmer
dfu-programmer - device firmware update (DFU) based USB programmer for Atmel chips
dfu-util - Device firmware update (DFU 1.0) USB programmer
dns323-firmware-tools - build and manipulate firmware images for the DNS-323
fcode-utils - OpenBIOS FCode utilities
flashrom - Identify, read, write, erase, and verify BIOS/ROM/flash chips
fxload - Firmware download to EZ-USB devices
gnu-efi - Library for developing EFI applications
grub-coreboot - GRand Unified Bootloader, version 2 (Coreboot version)
grub-coreboot-bin - GRand Unified Bootloader, version 2 (Coreboot binaries)
grub-firmware-qemu - GRUB firmware image for QEMU
grub-ieee1275 - GRand Unified Bootloader, version 2 (Open Firmware version)
grub-ieee1275-bin - GRand Unified Bootloader, version 2 (Open Firmware binaries)
ifpgui - QT based manager for iRiver iFP audio players
ipxe - PXE boot firmware
ipxe-qemu - PXE boot firmware - ROM images for qemu
ffado-tools - FFADO debugging and firmware tools
hdhomerun-config - Configuration utility for Silicon Dust HD HomeRun
ifp-line-libifp - command line tool to access iRiver iFP audio players
libifp-dev - communicate with iRiver iFP audio devices (development files)
libifp4 - communicate with iRiver iFP audio devices
librtas-dev - userspace RTAS library development files
librtas1 - userspace RTAS library
lshw-gtk - graphical information about hardware configuration
lzma - Compression and decompression in the LZMA format - command line utility
lzma-alone - Compression and decompression in the LZMA format - legacy utility
lzma-dev - Compression and decompression in the LZMA format - development files
mstflint - Mellanox firmware burning application
libofapi-dev - OpenFirmware device-tree parsing library [development files]
libofapi0 - OpenFirmware device-tree parsing library
openbios-ppc - PowerPC Open Firmware
openbios-sparc - SPARC Open Firmware
photopc - Interface to digital still cameras
qthid-fcd-controller - Funcube Dongle controller
qtscrob - audioscrobbler submitter for rockbox-format .scrobbler.log files
scrobble-cli - audioscrobbler submitter for rockbox-format .scrobbler.log files
read-edid - hardware information-gathering tool for VESA PnP monitors
ree - Extract ROM extensions
gptsync - GPT and MBR partition tables synchronisation tool
refit - graphical boot menu for ia32 and x64 EFI systems
s51dude - In-System Programmer for 8051 MCUs using usbtiny
slugimage - NSLU2 firmware image manipulation utility
syslinux - collection of boot loaders
syslinux-common - collection of boot loaders (common files)
syslinux-themes-debian - collection of boot loaders (theme metapackage)
syslinux-themes-debian-squeeze - collection of boot loaders (debian-squeeze theme)
syslinux-themes-debian-wheezy - collection of boot loaders (debian-wheezy theme)
tp-smapi-dkms - ThinkPad hardware/firmware access modules source - dkms version
tp-smapi-source - ThinkPad hardware/firmware access modules source
tvflash - Mellanox firmware update utility
libusbprog-dev - Development files for libusbprog
libusbprog0 - Library for programming the USBprog hardware
usbprog - Firmware programming tool for the USBprog hardware
usbprog-gui - GUI firmware programming tool for the USBprog hardware
wmaloader - firmware downloader for Linksys WMA11B media adapter
xserver-xorg-input-mutouch - X.Org X server – muTouch input driver
altos - utilitaires et firmware Altus Metrum
efibootmgr - interaction avec le gestionnaire d’amorçage EFI
expeyes-firmware-dev - infrastructure logicielle et matérielle pour développer des expériences scientifiques
firmware-linux-free - micrologiciels binaires pour des pilotes du noyau Linux
hannah-foo2zjs - téléchargeur graphique de micrologiciel pour le paquet foo2zjs
linux-wlan-ng - utilitaires pour les cartes sans-fil prism2
openhackware - Émulateur d’OpenFirmware pour PowerPC
amd64-microcode - Processor microcode firmware for AMD CPUs
atmel-firmware - Firmware for Atmel at76c50x wireless networking chips.
bluez-firmware - Firmware for Bluetooth devices
dahdi-firmware-nonfree - DAHDI non-free firmware
firmware-atheros - Binary firmware for Atheros wireless cards
firmware-bnx2 - Binary firmware for Broadcom NetXtremeII
firmware-bnx2x - Binary firmware for Broadcom NetXtreme II 10Gb
firmware-brcm80211 - Binary firmware for Broadcom 802.11 wireless cards
firmware-intelwimax - Binary firmware for Intel WiMAX Connection
firmware-ipw2x00 - Binary firmware for Intel Pro Wireless 2100, 2200 and 2915
firmware-ivtv - Binary firmware for iTVC15-family MPEG codecs (ivtv and pvrusb2 drivers)
firmware-iwlwifi - Binary firmware for Intel Wireless 3945, 4965 and 5000-series cards
firmware-libertas - Binary firmware for Marvell Libertas 8xxx wireless cards
firmware-linux - Binary firmware for various drivers in the Linux kernel (meta-package)
firmware-linux-nonfree - Binary firmware for various drivers in the Linux kernel
firmware-myricom - Binary firmware for Myri-10G Ethernet adapters
firmware-netxen - Binary firmware for QLogic Intelligent Ethernet (3000 and 3100 Series)
firmware-qlogic - Binary firmware for QLogic IBA7220, QLA1xxx, ISP2xxx and SP2x2
firmware-ralink - Binary firmware for Ralink wireless cards
firmware-realtek - Binary firmware for Realtek wired and wireless network adapters
intel-microcode - Processor microcode firmware for Intel CPUs
libertas-firmware - Firmware for Marvell’s libertas wireless chip series (dummy package)
madfuload - Firmware loader for M-Audio DFU audio devices
midisport-firmware - Firmware loader for M-Audio’s MidiSport devices
zd1211-firmware - Firmware images for the zd1211rw wireless driver
grub-ieee1275-dbg - GRand Unified Bootloader, version 2 (Open Firmware debug files)
Serait ce ça ?
C’est le paquet qui contient (entre autre) le module i915:$ apt-cache search i915 (...) xserver-xorg-video-intel - X.Org X server -- Intel i8xx, i9xx display driver
Cherches peut-être ce que tu as comme “warning” (W) ou “error” (E) dans ton /var/log/Xorg.0.loggrep -i -e warning -e error /var/log/Xorg.0.log
édit: est-ce que ton module i915 est bien chargé?$ lsmod | grep i915
re-édit: mal réveillé… :confused: :whistle: :blush:
re-re-édit: intel-microcode semble être un paquet contenant le microcode nécessaire pour les processeur intel…)
:006
J’ai déjà installer xserver-xorg-video-intel.
Pour les commandes j’ai :
giann@debian:~$ grep -i -e warning -e error /var/log/Xorg.0.log
giann@debian:~$ lsmod | grep i915 i915 417600 3 video 17631 2 i915,asus_wmi button 12937 1 i915 drm_kms_helper 27235 1 i915 drm 197759 4 i915,drm_kms_helper i2c_algo_bit 12841 1 i915 i2c_core 24041 5 drm,i915,i2c_i801,drm_kms_helper,i2c_algo_bit
Pour intel-microcode je dois l’installer ?
http://stackoverflow.com/questions/4366837/what-is-intel-microcode
Ici, y en a qui dise que c’est dangereux, que ca provoque des bug …
Après je suis plutôt nul en anglais (ainsi qu’en orthographe d’ailleurs ^^ ) donc j’ai peux être mal compris
Pour le microcode… je ne sais point…
Piste peut-être: chercher dans g**gle “i915 (WW) warning, (EE) error, (NI) not implemented, (??) unknown.”
:006
