Déjà donné un certain nombre de fois:
[quote]Disk Power Management
From openSUSE
Disk Power Management Configuration
Create a configuration file to management disk power management:
/etc/pm/config.d/disk
[code]# Configure disk power management settings to ensure both
# long disk life and good power management.
# Space delimited list of disk devices this affects.
DEVICES_DISK_PM_NAMES="/dev/sda"
# Power management modes
# Powersave mode off
# Disable APM and spin-down
DEVICES_DISK_PM_POWERSAVE_OFF="hdparm -q -B 255 -q -S 0"
# Powersave mode on
# Enable APM to conservative 200 and set spin-down for 21 minutes
DEVICES_DISK_PM_POWERSAVE_ON="hdparm -q -B 200 -q -S 252"[/code]
Note: Your laptop drive can get hot with no power management if you leave your laptop plugged in all the time. You may want to set DEVICES_DISK_PM_POWERSAVE_OFF to a large value, but not disabled completely. If you were going to do this, you might use something like: hdparm -q -B 254 -q -S 242
This means set the least power management, but not off, and spin down the disk after an hour.
Disk Power Management Script
Then create the power management script:
/etc/pm/power.d/disk
[code]#!/bin/bash
. /usr/lib/pm-utils/functions
. /etc/pm/config.d/disk
if test -z "${DEVICES_DISK_PM_NAMES}"; then
exit 1
fi
case "$1" in
true)
echo "**enabled pm for harddisk"
for DISK_NAME in `echo ${DEVICES_DISK_PM_NAMES}`; do
${DEVICES_DISK_PM_POWERSAVE_ON} ${DISK_NAME}
done ;;
false)
echo "**disabled pm for harddisk"
${DEVICES_DISK_PM_POWERSAVE_OFF} ${DISK_NAME}
done ;;
esac[/code]
Make the script executable.
chmod +x /etc/pm/power.d/disk
Test the script
You can then test the set up by using the following commands:
pm-powersave true
hdparm -I /dev/sda | grep ‘Advanced Power’
An asterisk next to ‘Advanced Power Management feature set’ means its enabled. Now try this:
pm-powersave false
No asterisk means it’s disabled.
These settings are immediately accessible to kpowersave or gnome-power-manager and are used by default when plugging in your power adapter or removing it on a laptop.
Et pour que ça ne recommence pas après une mise-en-veille:
Suspend/Resume handling Script adopted based on Redhat Bugzilla Link:
disksr --> the script is created with a slight modification to adapt the one like suse script for handling suspend/resume and named disksr (sr stands for suspend resume), to be copied into /etc/pm/sleep.d/
create a file called disksr with the following contents
[code]#!/bin/bash
if test -z ${DEVICES_DISK_PM_NAMES}; then
exit 1
fi
case "$1" in
hibernate|suspend)
done ;;
thaw|resume)
done ;;
esac[/code]
give the file executable permission, chmod +x disksr from the folder where the script is saved. Copy the script to /etc/pm/sleep.d/ using the following command
sudo cp disksr /etc/pm/sleep.d/
sudo chmod +x /etc/pm/sleep.d/disksr
